    4. [gelöst] Zigbee Neustart bei Firmwareupdates für Devices
      Rushmed Most Active last edited by Rushmed
      beim Versuch auf Firmwareaktualisierungen für meine Zigbee Geräte zu prüfen stürzt mein Zigbee Adapter immer ab und startet dann neu.
      Hier der Log:
      host.Smartazamba
      2021-12-31 20:34:17.494	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.Smartazamba
      2021-12-31 20:34:17.492	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.Smartazamba
      2021-12-31 20:34:17.492	error	Caught by controller[2]: at processTimers (internal/timers.js:500:7)
      host.Smartazamba
      2021-12-31 20:34:17.491	error	Caught by controller[2]: at listOnTimeout (internal/timers.js:557:17)
      host.Smartazamba
      2021-12-31 20:34:17.491	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
      host.Smartazamba
      2021-12-31 20:34:17.490	error	Caught by controller[2]: Error: Timeout - 37570 - 1 - null - 25 - 1 after 30000ms
      host.Smartazamba
      2021-12-31 20:34:17.489	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.Smartazamba
      2021-12-31 20:34:17.489	error	Caught by controller[1]: at processTimers (internal/timers.js:500:7)
      host.Smartazamba
      2021-12-31 20:34:17.488	error	Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
      host.Smartazamba
      2021-12-31 20:34:17.488	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
      host.Smartazamba
      2021-12-31 20:34:17.487	error	Caught by controller[1]: Error: Timeout - 39699 - 1 - null - 25 - 1 after 30000ms
      host.Smartazamba
      2021-12-31 20:34:17.486	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      zigbee.0
      2021-12-31 20:34:16.758	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      2021-12-31 20:34:16.756	info	terminating
      zigbee.0
      2021-12-31 20:34:16.383	error	Timeout - 37570 - 1 - null - 25 - 1 after 30000ms
      zigbee.0
      2021-12-31 20:34:16.382	error	Error: Timeout - 37570 - 1 - null - 25 - 1 after 30000ms at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
      zigbee.0
      2021-12-31 20:34:16.381	error	unhandled promise rejection: Timeout - 37570 - 1 - null - 25 - 1 after 30000ms
      zigbee.0
      2021-12-31 20:34:16.381	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      2021-12-31 20:34:16.259	info	Zigbee: disabling joining new devices.
      zigbee.0
      2021-12-31 20:34:16.255	info	cleaned everything up...
      zigbee.0
      2021-12-31 20:34:16.246	error	Timeout - 39699 - 1 - null - 25 - 1 after 30000ms
      zigbee.0
      2021-12-31 20:34:16.245	error	Error: Timeout - 39699 - 1 - null - 25 - 1 after 30000ms at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
      zigbee.0
      2021-12-31 20:34:16.188	error	unhandled promise rejection: Timeout - 39699 - 1 - null - 25 - 1 after 30000ms
      zigbee.0
      2021-12-31 20:34:16.187	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      2021-12-31 20:34:16.177	info	Failed to check if update available for '0x842e14fffe471ae1' (Device didn't respond to OTA request)
      zigbee.0
      2021-12-31 20:34:16.173	info	Failed to check if update available for '0x680ae2fffe12f5b2' (Device didn't respond to OTA request)
      zigbee.0
      2021-12-31 20:34:16.157	info	Failed to check if update available for '0x90fd9ffffed895cf' (Device didn't respond to OTA request)
      zigbee.0
      2021-12-31 20:34:16.153	info	Failed to check if update available for '0xd0cf5efffe1dc9fc' (Device didn't respond to OTA request)
      zigbee.0
      2021-12-31 20:34:16.127	info	Failed to check if update available for '0xec1bbdfffea04dd2' (Device didn't respond to OTA request)
      zigbee.0
      2021-12-31 20:34:16.112	info	Failed to check if update available for '0xb4e3f9fffe0dcce7' (Device didn't respond to OTA request)
      zigbee.0
      2021-12-31 20:34:16.103	info	Failed to check if update available for '0x680ae2fffe0a50c2' (Device didn't respond to OTA request)
      zigbee.0
      2021-12-31 20:34:16.093	info	Failed to check if update available for '0x842e14fffe7b15e8' (Device didn't respond to OTA request)
      zigbee.0
      2021-12-31 20:34:16.065	info	Failed to check if update available for '0xec1bbdfffe2933b5' (Device didn't respond to OTA request)
      Mein Pi4:
      Plattform
      linux
      Betriebssystem
      linux
      Architektur
      arm
      CPUs
      Geschwindigkeit
      1500 MHz
      Modell
      ARMv7 Processor rev 3 (v7l)
      RAM
      7.71 GB
      System-Betriebszeit
      00:13:27
      Node.js
      v14.18.2
      NPM
      6.14.15
      Datenträgergröße
      58.39 GB
      freier Festplattenspeicher
      38.9 GB
      Adaptereinstellungen V1.6.6:
      Hat jemand ne Ahnung was da los ist?
      David G. Thomas Braun 2 Replies Last reply Reply Quote 0
      • David G.
        David G. @Rushmed last edited by
        @rushmed
        Wie prüfst du denn auf Updates?
        Hab das noch nie gemacht.
        Mal sehen was bei mir passiert.
          Thomas Braun Most Active @Rushmed last edited by
          @rushmed
          Das OTA Firmware Upgrade wird aber auch nicht von allen Herstellern angeboten.
            Rushmed Most Active @David G. last edited by
            @Thomas-Braun OK. Es ist ja ok wenn angezeigt wird dass das Device keine Updates unterstützt. Das gabs ja schon immer. Aber dass mir der Adapter komplett abschmiert ist neu.
            • David G.
              @rushmed
              Danke.
              Bei mir klappt es. Selbe Adapterversion.
              Nur 4 Geräte haben einen Fehler mit
              Update of '0xd0cf5efffeeedcb2' failed (Image is truncated: not long enough to contain a valid tag)
                Adapterupdate auf 1.6.8 hat auch nicht geholfen.
                Habe dann begonnen ungenutzte Geräte (die ich nur testweise gepaired habe) zu etfernen und jetz ist wieder alles tuttipaletti.
                Frohes Neues!
                zigbee firmware geräte
