    • Boronsbruder
      Boronsbruder last edited by
      Gutes Neues!
      @SBorg
      2022-01-01 01:03:00.081 - warn: javascript.0 (23412) You are assigning a string to the state "0_userdata.0.Statistik.Wetter.Data.2021.12" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions.
      2022-01-01 01:03:00.084 - warn: javascript.0 (23412) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1967:33)
      2022-01-01 01:03:00.085 - warn: javascript.0 (23412) at processImmediate (internal/timers.js:466:21)
      2022-01-01 01:03:00.129 - warn: javascript.0 (23412) You are assigning a string to the state "0_userdata.0.Statistik.Wetter.Data.2021.12" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions.
      2022-01-01 01:03:00.132 - warn: javascript.0 (23412) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1439:20)
      2022-01-01 01:03:00.132 - warn: javascript.0 (23412) at Object. (script.js.common.Wetterstation_Statistik:346:169)
      2022-01-01 01:03:00.133 - warn: javascript.0 (23412) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:342:38)
      2022-01-01 01:03:00.133 - warn: javascript.0 (23412) at processImmediate (internal/timers.js:466:21)
      2022-01-01 01:03:00.135 - info: javascript.0 (23412) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2021.12 into object: Unexpected end of JSON input
      2022-01-01 01:03:00.136 - info: javascript.0 (23412) Could not parse value for id 0_userdata.0.Statistik.Wetter.Data.2021.12 into object: Unexpected end of JSON input
      spuckte das log heute aus. (nur zur Info 😉 )
        Andre105 @Boronsbruder last edited by
        @boronsbruder sagte in [Linux Shell-Skript] WLAN-Wetterstation:
        @andre105
        Frohes neues noch:)
        home
          |- andre105
          |- iobroker
          |- wetter
        Und die Dateien in wetter zum Beispiel
        @da_woody sagte in [Linux Shell-Skript] WLAN-Wetterstation:
        @andre105 kannst schon machen, nur musst das halt dann überall so eingeben.
        ich habs halt direkt im home/woody. bekennend fauler hund. 😉
        IMHO besser, du lässt iobroker weg, direkt in deinem home ein wetter verzeichniss.
        und vergiss die ws_updater.sh nicht mit zu kopieren!
        Wollte eben ein neues Verzeichnis im home machen,da kommt die Meldung das ich keine Berechtigung habe.
        Mache es mit Filezilla.
        Aber ich hatte doch schon mal ein Verzeichniss erstellen können,siehe oben.
        Was kann das sein?
        Oder sollte ich mal WinSCP probieren?
        Boronsbruder 1 Reply Last reply Reply Quote 0
        • Boronsbruder
          Boronsbruder @Andre105 last edited by Boronsbruder
          @andre105
          das macht keinen Unterschied ob mit Filezilla oder winSCP
          der Benutzer mit dem du dich verbindest hat keine Berechtigungen in home ein Verzeichnis anzulegen und das ist auch richtig so.
          Benutze doch das wetter Verzeichnis aus deinem Screenshot also home/andre105/wetter
            @boronsbruder
            so sollte es doch gehen oder?
            • SBorg
              SBorg Forum Testing Most Active @Rene55 last edited by
              Erstmal euch allen ein frohes Neues 🍾
              Ich muss gleich mal weg, werde also erst etwas später auf alles eingehen können 😉
              @rene55 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
              @SBorg Ich wüsste nicht, wer da noch auf den gleichen, doch recht speziellen Datenpunkt schreiben sollte. Meine Test-Instanzen laufen derzeit nicht und es wär auch ein anderer ioB. Da muss ich wohl dranbleiben. Aber erstmal wünsche ich, auch allen Mitlesern, einen guten Rutsch ins nächste Jahr, mit viel Erfolg und bester Gesundheit.
              LG Rainer
              Ich hab mal nachgeschaut, ich schreibe zu keiner Zeit einen Dummy-Wert von "-999". Da er sich nie ändert, kann es auch keine Fehlberechnung sein (es wird nichts limitiert oder begrenzt, müsste dann also bspw. auch mal -998 oder -1000 etc. sein). Er kommt auch gelegentlich vor "meinem" Datenpaket. Ich bin zwar ganz gut, so gut bin ich dann aber auch nicht. Mein Fluxkompensator ist noch in Arbeit 😂
              Du kannst aber mal den Datenpunkt verändern:
              in der sub ganz oben ändern
              von
               DP_DRUCK_TENDENZ=${PRE_DP}.Druck_Tendenz
              in
               DP_DRUCK_TENDENZ=${PRE_DP}.Druck_Tendenz_neu
              Dann (bei default-Einstellungen) den DP javascript.0.Wetterstation.Druck_Tendenz klonen und als Druck_Tendenz_neu benennen.
              Service neu starten systemctl restart wetterstation
              Jetzt sollte die Drucktendenz nur noch im neuen DP landen (+ da es ihn bis dato nicht gab, greift da zu 100% auch kein anderes was auch immer darauf zu[außer es gäbe einen Selector]).
              • SBorg
                SBorg Forum Testing Most Active @da_Woody last edited by
                genügts da einfach auf 2 umzustellen, oder brauchts da noch mehr? hab das nicht ganz begriffen...
                Im Prinzip ja; die "WS_ID" kann man einfach lassen, die wird dann nur nicht mehr benutzt.
                Du musst natürlich noch die Station auf Ecowitt umstellen 😉
                ...ist aber im Grunde gleich, nur Protokoll ändern und beim "Pfad" dann ein / eintragen (wie Screeny in der WiKi).
                • SBorg
                  SBorg Forum Testing Most Active @Nashra last edited by
                  @nashra sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                  Nun zum Problem...
                  (Wieder) geändertes Datenformat. Ich hoffe es kann jetzt endlich mal so bleiben...
                  Im Script ersetzen (am Anfang, so ~#55 ff):
                  let helper;
                  if (typeof(formathelp)=="object") {helper=getState(id).val[0];}  else{helper=JSON.parse(getState(id).val)}
                  helper={ ...helper, ...obj2, ...obj3}
                  in
                  let helper;
                     else if (typeof(formathelp)=="string") {helper=getState(id).val
                                                             helper=JSON.parse(helper.substring(1, (getState(id).val).length-1));}
                     else {helper=JSON.parse(getState(id).val);}
                  Nashra 1 Reply Last reply Reply Quote 1
                  • SBorg
                    SBorg Forum Testing Most Active @Boronsbruder last edited by
                    Nutzt du die aktuelle Version von GitHub? Der legt den Datenpunkt noch als "Object" an und meckert dann zu Recht, dass ein String hinein geschrieben werden soll.
                    Aktuelle Version (stimmt hier mit String):
                    • SBorg
                      SBorg Forum Testing Most Active @Andre105 last edited by
                      @andre105 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                      Jepp, in dem Verzeichnis hast du als User auch die nötigen Rechte 😉
                      • SBorg
                        SBorg Forum Testing Most Active last edited by SBorg
                        Der kpl. Vorgang der Statistik zum Jahreswechsel hat funktioniert 😎
                        Alle Werte resettet, Jahreswerte geschrieben und auch der Jahrestemperaturdurchschnitt (wenn man mindestens seit 01.01.2020 gesammelt hat) geht, wenn auch Min und Max gleich sind. Ist aber logisch, bei einem einzigen Wert geht das etwas schlecht. Sieht dann nächstes Jahr besser aus 😉
                        SBorg Negalein 2 Replies Last reply Reply Quote 0
                        • Nashra
                          Nashra Most Active Forum Testing @SBorg last edited by
                          @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                          Nun zum Problem...
                          let helper;
                          in
                          let helper;
                          Geändert aber beim Start kommt
                          13:09:13.523	error	javascript.0 (611) script.js.Wetter.Statistik-tabelle: SyntaxError: Unexpected token : in JSON at position 12
                          13:09:13.524	error	javascript.0 (611) at script.js.Wetter.Statistik-tabelle:62:56
                          13:09:13.524	error	javascript.0 (611) at dataStuff (script.js.Wetter.Statistik-tabelle:51:15)
                          13:09:13.524	error	javascript.0 (611) at main (script.js.Wetter.Statistik-tabelle:164:4)
                          • Boronsbruder
                            Boronsbruder @SBorg last edited by
                            @sborg said in [Linux Shell-Skript] WLAN-Wetterstation:
                            /* Wetterstation-Statistiken
                               (c)2020-2021 by SBorg
                               V1.0.0 - 02.10.2021  ~Bugfixing Werte VorJahresMonat
                                                    +Kompatibilität mit JSC 3.3.x hergestellt (Änderung JSON -> Array)
                                                    ~Rekordwerte werden nun korrekt am Tag des Ereignisses gespeichert
                               V0.2.2 - 01.02.2021  ~Bugfixing Regenmenge Jahr + Monat
                                                    ~Frosttage (Korrektur: Tiefstwert unter 0°C)
                               V0.0.3 - 15.09.2020  +Frosttage (Min. unter 0°C) / kalte Tage (Max. unter 10°C)
                               V0.0.2 - 12.09.2020  +warme Tage über 20°C / Sommertage über 25°C / heiße Tage über 30°C
                               V0.0.1 - 11.09.2020   erste Beta + Temp-Min/Temp-Max/Temp-Durchschnitt/max. Windböe/max. Regenmenge pro Tag
                                  ToDo: ---
                                  known issues: keine
                            aber im aktuellen Skript vom GIT ist auch
                            createState(PRE_DP+monatsdatenpunkt,'',{ name: "Monatsstatistik für "+monatsname[datum.getMonth()]+' '+datum.getFullYear(), type: "object", role: "json" }, () => { setState(PRE_DP+monatsdatenpunkt, json, true); });
                            in Zeile 346 drin?
                            • SBorg
                              Zuerst das einfache 😉
                              @boronsbruder schau mal auf GitHub, seit 13 Tagen gibt es die V1.0.1 😉
                              • SBorg
                                @nashra Auch bei dir alles aktuell, gerade Statistik-Skript?
                                Sollte so aussehen für den Dez21:
                                • Rene55
                                  Rene55 @SBorg last edited by
                                  @sborg Ebenfalls ein frohes Neues. Ich habe gestern mal den Container für 2 Stunden gestoppt und danach wieder eingeschaltet. Seit dem ist (bis jetzt) Ruhe. Bin mal gespannt, obs irgendwann wieder los geht. Auch Danke für den Tip mit dem zweiten Datenpunkt.
                                  • SBorg
                                    SBorg Forum Testing Most Active @SBorg last edited by
                                    Zumindest zu 99%
                                    Die °C fehlen bei der Jahresdurchschnittstemperatur 😉
                                    • Nashra
                                      Überprüft und genau wie in deinen Bildern. Problem war ja das ich nach der
                                      Änderung des Skriptes beim Start eine Fehlermeldung bekam s.o.
                                      Und jetzt kommt es, unter 0_userdata.0.Statistik.Wetter.Data.2021.12 sind Daten vorhanden
                                      [{"Tiefstwert":-4.77,"Hoechstwert":12.38,"Temp_Durchschnitt":4.86,"Max_Windboe":38.46,"Max_Regenmenge":12.9,"Regenmenge_Monat":82.8,"warme_Tage":0,"Sommertage":0,"heisse_Tage":0,"Frost_Tage":10,"kalte_Tage":27,"Eistage":0,"sehr_kalte_Tage":0}]
                                      nur in der VIS wird mir "undefined" für Dezember angezeigt.
                                      • da_Woody
                                        da_Woody @SBorg last edited by
                                        @sborg wie immer, kaum post abgesetzt, hats klick gemacht... 😄
                                        custom in ws_view geändert, im script auf 2, sollte passen...
                                          Andre105 last edited by Andre105
                                          @sborg
                                          Jetzt muss ich per Putty diesen Befehl ausführen?
                                          chmod +x wetterstation.sh
                                          Wenn ja,wie mach ich das?
                                          Wie führe ich den Befehl aus?
                                          Ist glaube ich noch ein langer Weg,aber ich will da nicht aufgeben.
                                          Ich sehe hier echt nur Spezialisten:)
                                          • Boronsbruder
                                            @andre105
                                            kannst du auch in Filezilla mit der rechten Maustaste -> Dateiberechtigungen -> bei Ausführen die Haken setzen
                                            152
                                            5657
                                            3670466
