    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    • da_Woody
      da_Woody @Meistertr last edited by
      @meistertr ich denk mal, die sind sauer, weil viele roborocks bei denen drauf sind. oder gehören die zusammen?
        saeft_2003 Most Active last edited by saeft_2003
        Ich bin logischerweise auch betroffen. App geht wieder, beim Adapter geht die map nicht mehr. Diese Warnung im log kommt alle paar Sekunden…
        	{"statusCode":401,"body":"{\"code\":0,\"message\":\"auth err\"}","headers":{"server":"Tengine","date":"Fri, 31 Dec 2021 17:11:16 GMT","content-type":"text/plain; charset=utf-8","content-length":"31","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"de.api.io.mi.com","port":443,"hostname":"de.api.io.mi.com","hash":null,"search":null,"query":null,"pathname":"/app/home/getmapfileurl","path":"/app/home/getmapfileurl","href":"https://de.api.io.mi.com/app/home/getmapfileurl"},"method":"POST","headers":{"Content-Type":"application/x-www-form-urlencoded","x-xiaomi-protocal-flag-cli":"PROTOCAL-HTTP2","User-Agent":"Android-7.1.1-1.0.0-ONEPLUS A3010-136-9D28921C354D7 APP/xiaomi.smarthome APPV/62830","Cookie":"userId=1777607180; yetAnotherServiceToken/qnWzpOzCefijLqk0533HLH4U9U3YGxTnq1A5fpbZMSqza5DD649IKmyc7SdZ8Msg+c13EnUbGHInYzbQ+I1IJdY=; serviceToken=q9rKEhEI8ekLzRO10CxdUVlYF4tr+c13EnUbGHInYzbQ+I1IJdY=; locale=de_DE; timezone=GMT%2B01%3A00; is_daylight=1; dst_offset=3600000; channel=MI_APP_STORE","accept-encoding":"gzip, deflate","content-length":148}}}
        • haselchen
          haselchen Most Active @Meistertr last edited by haselchen
          @meistertr
          Hier ebenso
          mihome-vacuum.0	2021-12-31 19:40:34.356	warn	(10259) {"statusCode":401,"body":"{\"code\":2,\"message\":\"auth err\"}","headers":{"server":"Tengine","date":"Fri, 31 Dec 2021 18:40:34 GMT","content-type":"text/plain; charset=utf-8","content-length
          HTTP Error beim Drücken auf GetDevices
          mihome-vacuum.0	2021-12-31 19:42:03.479	info	(10259) discover HTTP ERROR
          mihome-vacuum.0	2021-12-31 19:42:03.478	error	(10259) null
          • gelberlemmy
            gelberlemmy @Meistertr last edited by gelberlemmy
            @meistertr da hänge ich mich dran. Aktuelle Version 3.3.1
            Wie bei den anderen auch der Fehler:
            mihome-vacuum.0
            2022-01-01 20:09:45.165	warn	{"statusCode":401,"body":"{\"code\":0,\"message\":\"auth err\"}","headers":{"server":"Tengine","date":"Sat, 01 Jan 2022 19:09:45 GMT","content-type":"text/plain; charset=utf-8","content-length":"31","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"de.api.io.mi.com","port":443,"hostname":"de.api.io.mi.com","hash":null,"search":null,"query":null,"pathname":"/app/home/getmapfileurl","path":"/app/home/getmapfileurl","href":"https://de.api.io.mi.com/app/home/getmapfileurl"},"method":"POST","headers":{"Content-Type":"application/x-www-form-urlencoded","x-xiaomi-protocal-flag-cli":"PROTOCAL-HTTP2","User-Agent":"Android-77 APP/xiaomi.smarthome APPV/","Cookie":"userId=0; yetAnotherServiceToken=A=; serviceToken=A=; locale=de_DE; timezone=GMT%2B01%3A00; is_daylight=1; dst_offset=3600000; channel=MI_APP_STORE","accept-encoding":"gzip, deflate","content-length":150}}}
              saeft_2003 Most Active @gelberlemmy last edited by
              @gelberlemmy
              Hast du dein token gekürzt?
              gelberlemmy 1 Reply Last reply Reply Quote 0
              • gelberlemmy
                gelberlemmy @saeft_2003 last edited by
                @saeft_2003 meinen Token ? Wie gekürzt ? Nein habe ich noch nicht gemacht.
                  saeft_2003 Most Active @gelberlemmy last edited by saeft_2003
                  @gelberlemmy
                  in der warn Meldung wo du gepostet hast ist dein token drin, den würde ich kürzen...
                  • gelberlemmy
                    @saeft_2003 ich habe einmal geschaut im Adapter. Dort ist der Token wesentlich kürzer. Wie soll man den dann noch kürzen. Wenn ich aber einmal dort die Geräte neu anfrage, bekomme ich auch einen HTTP Error. Wie gesagt auch die MAP wird nicht mehr aktualisiert.
                    • JB_Sullivan
                      JB_Sullivan @bahnuhr last edited by JB_Sullivan
                      @bahnuhr sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                      @meistertr
                      beim start der Instanz kommt sowas:
                      mihome-vacuum.0
                      2021-12-31 17:27:06.759	warn	{"statusCode":401,"body":"{\"code\":0,\"message\":\"auth err\"}","headers":{"server":"Tengine","date":"Fri, 31 Dec 2021 16:27:06 GMT","content-type":"text/plain; charset=utf-8","content-length":"31","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"de.api.io.mi.com","port":443,"hostname":"de.api.io.mi.com","hash":null,"search":null,"query":null,"pathname":"/app/home/getmapfileurl","path":"/app/home/getmapfileurl","href":"https://de.api.io.mi.com/app/home/getmapfileurl"},"method":"POST","headers":{"Content-Type":"application/x-www-form-urlencoded","x-xiaomi-protocal-flag-cli":"PROTOCAL-HTTP2","User-Agent":"Android-7.1.1-1.0.0-ONEPLUS A3010-136-9D28921C354D7 APP/xiaomi.smarthome APPV/62830","Cookie":"userId=1859580730; yetAnotherServiceToken=2jLptLTZl7Nib6yuI/b1+UavFv5+fTOMjdVL37UnxpvkV8RbwV9Cl9G8JDh+ISJWCrmHH1MH4RrOcUQ9rlQ1FiYv80gC4/VcNOs/tQYscg6lCCg=; serviceToken=2jLptLTZl7Nib6yuI/vtJPaXNiw51djOdZYAZO38Yd7qV137UnxpvkV8RbwV9Cl9G8JDh+ISJWCrmHH1MH4RrOcUQ9rlQ1FiYv80gC4/VcNOs/tQYscg6lCCg=; locale=de_DE; timezone=GMT%2B01%3A00; is_daylight=1; dst_offset=3600000; channel=MI_APP_STORE","accept-encoding":"gzip, deflate","content-length":148}}}
                      (habe die token etwas gekürzt)
                      Schließe mich dem mal an - bei mir auch das gleiche - habe es aber erst heute morgen gemerkt. Also erstmal kein Grund für wilden Aktionismus auf der User Seite?!?!
                      BtW: @Meistertr - bist du der (weiter) Entwickler von dem Adapter? Das das mi-vaccum Widget seit Monaten aus dem VIS Editor respektive komplett aus dem Admin verschwunden ist, ist bekannt?
                        dirkhe Developer @gelberlemmy last edited by
                        @gelberlemmy er meint, du sollst das hier aus dem Forumsbeitrag kürzen oder schwärzen
                        D gelberlemmy 2 Replies Last reply Reply Quote 0
                          dirkhe Developer @dirkhe last edited by
                          Auf github wurde geschrieben, das sich das auth Verfahren geändert hat, dass muss erst neu programmiert werden. Also abwarten.
                          • gelberlemmy
                            gelberlemmy @dirkhe last edited by
                            @dirkhe sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                            Ohhh Brett vor dem Kopf.... Na klar.... Danke für Eure Hinweise....... 🤦🏼‍♂️
                              saeft_2003 Most Active @Meistertr last edited by saeft_2003
                              @meistertr
                              Mir ist klar das die Priorität im Moment wo anders liegt. Aber ist geplant das der Adapter den S7 maxV unterstützt?
                              Meistertr 1 Reply Last reply Reply Quote 0
                              • D3ltoroxp
                                D3ltoroxp last edited by
                                durch den Umzug auf mein neues System ist mir aufgefallen, das ich keine Karte mehr habe und ich bekomme sie auch nicht mehr. Die DP's sind leer.
                                In der Log steht nichts. Wenn ich auf load map drücke tut sich auch nichts, in der Log taucht auch nichts auf.
                                Die DP's sind write : false, wenn ich es auf true setzte kommt in der Log
                                mihome-vacuum.0
                                	2022-01-03 18:48:20.831	warn	can not set mapURL
                                mihome-vacuum.0
                                	2022-01-03 18:48:17.651	warn	can not set map64
                                mihome-vacuum.0
                                	2022-01-03 18:47:26.281	warn	can not set map64
                                mihome-vacuum.0
                                	2022-01-03 18:47:23.679	warn	can not set mapURL
                                setzte ich sie wieder zurück auf original, kommt gar nichts mehr in der Log. Aber auch so bekomme ich die Map nicht mehr, auch nicht in der VIS.
                                  saeft_2003 Most Active @D3ltoroxp last edited by saeft_2003
                                  @d3ltoroxp
                                  Die map geht bei uns alle im Moment nicht, der Adapter muss angepasst werden.
                                  • D3ltoroxp
                                    D3ltoroxp @saeft_2003 last edited by
                                    @saeft_2003 Ah Gott sei Dank, ich dachte schon durch den Umzug, dann muss das grad zeitlich sich überschnitten haben, weil auf dem alten System gings noch. Ist mir nur am Tablet aufgefallen das auf einmal bei der VIS keine Karte mehr war.
                                    Würde es denn was ändern wenn der Roborock Valetudo drauf hat ? Oder läuft das dann mit dem Adapter gar nicht mehr ?
                                    • Christian Wöhrle
                                      Christian Wöhrle @Meistertr last edited by
                                      @meistertr bei mir läuft die Karte problemlos.
                                        Seit heut Nacht läuft der Adapter gar nicht mehr. Vorher ging alles bis auf die map. Habt ihr das auch?
                                        at JSON.parse ()
                                        at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:436:22)
                                        at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                        at Request.emit (events.js:400:28)
                                        at Request.emit (domain.js:475:12)
                                        at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                        at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                        at Object.onceWrapper (events.js:519:28)
                                        2022-01-04 07:14:16.469 - error: mihome-vacuum.0 (2943749) Unexpected token y in JSON at position 1
                                        2022-01-04 07:14:16.475 - error: mihome-vacuum.0 (2943749) Socket Close
                                        2022-01-04 07:14:16.544 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected token y in JSON at position 1
                                        2022-01-04 07:14:16.544 - error: host.iobroker Caught by controller[0]: at JSON.parse ()
                                        2022-01-04 07:14:16.544 - error: host.iobroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:436:22)
                                        2022-01-04 07:14:16.544 - error: host.iobroker Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                        2022-01-04 07:14:16.544 - error: host.iobroker Caught by controller[0]: at Request.emit (events.js:400:28)
                                        2022-01-04 07:14:16.544 - error: host.iobroker Caught by controller[0]: at Request.emit (domain.js:475:12)
                                        2022-01-04 07:14:16.544 - error: host.iobroker Caught by controller[0]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                        2022-01-04 07:14:16.544 - error: host.iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                        2022-01-04 07:14:16.544 - error: host.iobroker Caught by controller[0]: at Object.onceWrapper (events.js:519:28)
                                        2022-01-04 07:14:16.544 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2022-01-04 07:14:49.449 - error: mihome-vacuum.0 (2943767) uncaught exception: Unexpected token l in JSON at position 0
                                        2022-01-04 07:14:49.450 - error: mihome-vacuum.0 (2943767) SyntaxError: Unexpected token l in JSON at position 0
                                        at JSON.parse ()
                                        2022-01-04 07:14:49.451 - error: mihome-vacuum.0 (2943767) Unexpected token l in JSON at position 0
                                        2022-01-04 07:14:49.457 - error: mihome-vacuum.0 (2943767) Socket Close
                                        2022-01-04 07:14:49.524 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected token l in JSON at position 0
                                        2022-01-04 07:14:49.525 - error: host.iobroker Caught by controller[0]: at JSON.parse ()
                                        2022-01-04 07:14:49.525 - error: host.iobroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:436:22)
                                        2022-01-04 07:14:49.525 - error: host.iobroker Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                        2022-01-04 07:14:49.525 - error: host.iobroker Caught by controller[0]: at Request.emit (events.js:400:28)
                                        2022-01-04 07:14:49.525 - error: host.iobroker Caught by controller[0]: at Request.emit (domain.js:475:12)
                                        2022-01-04 07:14:49.525 - error: host.iobroker Caught by controller[0]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                        2022-01-04 07:14:49.525 - error: host.iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                        2022-01-04 07:14:49.525 - error: host.iobroker Caught by controller[0]: at Object.onceWrapper (events.js:519:28)
                                        2022-01-04 07:14:49.525 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2022-01-04 07:15:22.385 - error: mihome-vacuum.0 (2943853) uncaught exception: Unexpected token C in JSON at position 0
                                        2022-01-04 07:15:22.386 - error: mihome-vacuum.0 (2943853) SyntaxError: Unexpected token C in JSON at position 0
                                        at JSON.parse ()
                                        2022-01-04 07:15:22.386 - error: mihome-vacuum.0 (2943853) Unexpected token C in JSON at position 0
                                        2022-01-04 07:15:22.394 - error: mihome-vacuum.0 (2943853) Socket Close
                                        2022-01-04 07:15:22.471 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected token C in JSON at position 0
                                        2022-01-04 07:15:22.472 - error: host.iobroker Caught by controller[0]: at JSON.parse ()
                                        2022-01-04 07:15:22.472 - error: host.iobroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:436:22)
                                        2022-01-04 07:15:22.472 - error: host.iobroker Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                        2022-01-04 07:15:22.472 - error: host.iobroker Caught by controller[0]: at Request.emit (events.js:400:28)
                                        2022-01-04 07:15:22.472 - error: host.iobroker Caught by controller[0]: at Request.emit (domain.js:475:12)
                                        2022-01-04 07:15:22.472 - error: host.iobroker Caught by controller[0]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                        2022-01-04 07:15:22.472 - error: host.iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                        2022-01-04 07:15:22.472 - error: host.iobroker Caught by controller[0]: at Object.onceWrapper (events.js:519:28)
                                        2022-01-04 07:15:22.472 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2022-01-04 07:15:55.371 - error: mihome-vacuum.0 (2943901) uncaught exception: Unexpected token g in JSON at position 1
                                        2022-01-04 07:15:55.372 - error: mihome-vacuum.0 (2943901) SyntaxError: Unexpected token g in JSON at position 1
                                        at JSON.parse ()
                                        2022-01-04 07:15:55.373 - error: mihome-vacuum.0 (2943901) Unexpected token g in JSON at position 1
                                        2022-01-04 07:15:55.380 - error: mihome-vacuum.0 (2943901) Socket Close
                                        2022-01-04 07:15:55.467 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected token g in JSON at position 1
                                        2022-01-04 07:15:55.468 - error: host.iobroker Caught by controller[0]: at JSON.parse ()
                                        2022-01-04 07:15:55.468 - error: host.iobroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:436:22)
                                        2022-01-04 07:15:55.468 - error: host.iobroker Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                        2022-01-04 07:15:55.468 - error: host.iobroker Caught by controller[0]: at Request.emit (events.js:400:28)
                                        2022-01-04 07:15:55.468 - error: host.iobroker Caught by controller[0]: at Request.emit (domain.js:475:12)
                                        2022-01-04 07:15:55.468 - error: host.iobroker Caught by controller[0]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                        2022-01-04 07:15:55.469 - error: host.iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                        2022-01-04 07:15:55.469 - error: host.iobroker Caught by controller[0]: at Object.onceWrapper (events.js:519:28)
                                        2022-01-04 07:15:55.469 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2022-01-04 07:16:28.510 - error: mihome-vacuum.0 (2943924) uncaught exception: Unexpected token Y in JSON at position 0
                                        2022-01-04 07:16:28.511 - error: mihome-vacuum.0 (2943924) SyntaxError: Unexpected token Y in JSON at position 0
                                        at JSON.parse ()
                                        2022-01-04 07:16:28.512 - error: mihome-vacuum.0 (2943924) Unexpected token Y in JSON at position 0
                                        2022-01-04 07:16:28.520 - error: mihome-vacuum.0 (2943924) Socket Close
                                        2022-01-04 07:16:28.601 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected token Y in JSON at position 0
                                        2022-01-04 07:16:28.601 - error: host.iobroker Caught by controller[0]: at JSON.parse ()
                                        2022-01-04 07:16:28.602 - error: host.iobroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:436:22)
                                        2022-01-04 07:16:28.602 - error: host.iobroker Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                        2022-01-04 07:16:28.602 - error: host.iobroker Caught by controller[0]: at Request.emit (events.js:400:28)
                                        2022-01-04 07:16:28.602 - error: host.iobroker Caught by controller[0]: at Request.emit (domain.js:475:12)
                                        2022-01-04 07:16:28.602 - error: host.iobroker Caught by controller[0]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                        2022-01-04 07:16:28.602 - error: host.iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                        2022-01-04 07:16:28.602 - error: host.iobroker Caught by controller[0]: at Object.onceWrapper (events.js:519:28)
                                        2022-01-04 07:16:28.602 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2022-01-04 07:17:01.788 - error: mihome-vacuum.0 (2943942) uncaught exception: Unexpected token s in JSON at position 0
                                        2022-01-04 07:17:01.789 - error: mihome-vacuum.0 (2943942) SyntaxError: Unexpected token s in JSON at position 0
                                        at JSON.parse ()
                                        2022-01-04 07:17:01.789 - error: mihome-vacuum.0 (2943942) Unexpected token s in JSON at position 0
                                        2022-01-04 07:17:01.802 - error: mihome-vacuum.0 (2943942) Socket Close
                                        2022-01-04 07:17:01.883 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected token s in JSON at position 0
                                        2022-01-04 07:17:01.883 - error: host.iobroker Caught by controller[0]: at JSON.parse ()
                                        2022-01-04 07:17:01.883 - error: host.iobroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:436:22)
                                        2022-01-04 07:17:01.883 - error: host.iobroker Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                        2022-01-04 07:17:01.883 - error: host.iobroker Caught by controller[0]: at Request.emit (events.js:400:28)
                                        2022-01-04 07:17:01.883 - error: host.iobroker Caught by controller[0]: at Request.emit (domain.js:475:12)
                                        2022-01-04 07:17:01.883 - error: host.iobroker Caught by controller[0]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                        2022-01-04 07:17:01.883 - error: host.iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                        2022-01-04 07:17:01.883 - error: host.iobroker Caught by controller[0]: at Object.onceWrapper (events.js:519:28)
                                        2022-01-04 07:17:01.883 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2022-01-04 07:17:34.829 - error: mihome-vacuum.0 (2944014) uncaught exception: Unexpected token S in JSON at position 0
                                        2022-01-04 07:17:34.830 - error: mihome-vacuum.0 (2944014) SyntaxError: Unexpected token S in JSON at position 0
                                        at JSON.parse ()
                                        2022-01-04 07:17:34.830 - error: mihome-vacuum.0 (2944014) Unexpected token S in JSON at position 0
                                        2022-01-04 07:17:34.841 - error: mihome-vacuum.0 (2944014) Socket Close
                                        2022-01-04 07:17:34.910 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected token S in JSON at position 0
                                        2022-01-04 07:17:34.910 - error: host.iobroker Caught by controller[0]: at JSON.parse ()
                                        2022-01-04 07:17:34.910 - error: host.iobroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:436:22)
                                        2022-01-04 07:17:34.910 - error: host.iobroker Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                        2022-01-04 07:17:34.910 - error: host.iobroker Caught by controller[0]: at Request.emit (events.js:400:28)
                                        2022-01-04 07:17:34.910 - error: host.iobroker Caught by controller[0]: at Request.emit (domain.js:475:12)
                                        2022-01-04 07:17:34.910 - error: host.iobroker Caught by controller[0]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                        2022-01-04 07:17:34.910 - error: host.iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                        2022-01-04 07:17:34.910 - error: host.iobroker Caught by controller[0]: at Object.onceWrapper (events.js:519:28)
                                        2022-01-04 07:17:34.910 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2022-01-04 07:18:04.842 - warn: host.iobroker "system.host.raspberrypi" is offline
                                        2022-01-04 07:18:08.232 - error: mihome-vacuum.0 (2944057) uncaught exception: Unexpected token E in JSON at position 1
                                        2022-01-04 07:18:08.233 - error: mihome-vacuum.0 (2944057) SyntaxError: Unexpected token E in JSON at position 1
                                        at JSON.parse ()
                                        2022-01-04 07:18:08.233 - error: mihome-vacuum.0 (2944057) Unexpected token E in JSON at position 1
                                        2022-01-04 07:18:08.240 - error: mihome-vacuum.0 (2944057) Socket Close
                                        2022-01-04 07:18:08.302 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected token E in JSON at position 1
                                        2022-01-04 07:18:08.303 - error: host.iobroker Caught by controller[0]: at JSON.parse ()
                                        2022-01-04 07:18:08.303 - error: host.iobroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:436:22)
                                        2022-01-04 07:18:08.303 - error: host.iobroker Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                        2022-01-04 07:18:08.303 - error: host.iobroker Caught by controller[0]: at Request.emit (events.js:400:28)
                                        2022-01-04 07:18:08.303 - error: host.iobroker Caught by controller[0]: at Request.emit (domain.js:475:12)
                                        2022-01-04 07:18:08.303 - error: host.iobroker Caught by controller[0]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                        2022-01-04 07:18:08.303 - error: host.iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                        2022-01-04 07:18:08.303 - error: host.iobroker Caught by controller[0]: at Object.onceWrapper (events.js:519:28)
                                        2022-01-04 07:18:08.303 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2022-01-04 07:18:39.446 - error: mihome-vacuum.0 (2944108) adapter disabled
                                        2022-01-04 07:18:40.077 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                                        • JackDaniel
                                          JackDaniel last edited by
                                          ja, hab ihn gerade deaktiviert 😞
                                          • da_Woody
                                            da_Woody @JackDaniel last edited by
                                            @jackdaniel selbes thema
                                            https://forum.iobroker.net/topic/50898/anmeldung-an-xiaomi-cloud-nicht-möglich-error-http-error
                                            81.1k
                                            1198
                                            362589
