    4. Adapter "smartmeter"
      apollon77 last edited by
      Ne an sich passt das schon …
      2017-03-16 18:28:46.734  - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/?!\r\n/ISk5MT174-0001\r" -> null
      2017-03-16 18:28:46.765  - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
      2017-03-16 18:28:46.766  - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/?!\r\n/ISk5MT174-0001\r\n" -> ["/ISk5MT174-0001\r\n","/ISk5MT174-0001"]
      2017-03-16 18:28:46.767  - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
      2017-03-16 18:28:46.770  - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
      2017-03-16 18:28:46.771  - [34mdebug[39m: smartmeter.0 MESSAGES TO SEND: 2
      2017-03-16 18:28:46.772  - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN GETNEXTMESSAGE
      2017-03-16 18:28:46.775  - [34mdebug[39m: smartmeter.0 TO SEND 2: 050
      2017-03-16 18:28:46.894  - [34mdebug[39m: smartmeter.0 DONE SEND 2
      2017-03-16 18:28:46.895  - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN GETNEXTMESSAGE
      2017-03-16 18:28:46.895  - [34mdebug[39m: smartmeter.0 BAUD CHANGEOVER TO 9600 baud
      2017-03-16 18:28:46.897  - [34mdebug[39m: smartmeter.0 BAUD CHANGEOVER DONE
      2017-03-16 18:28:46.898  - [34mdebug[39m: smartmeter.0 TO SEND 1:
      2017-03-16 18:28:46.899  - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 400000
      2017-03-16 18:28:46.900  - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN ISPROCESSCOMPLETE: false
      2017-03-16 18:28:46.902  - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING:
      2017-03-16 18:28:46.903  - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
      2017-03-16 18:28:46.905  - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "0\r" -> null
      2017-03-16 18:28:46.907  - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
      2017-03-16 18:28:46.908  - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "0\r\n" -> null
      2017-03-16 18:28:48.847  - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
      2017-03-16 18:28:48.848  - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "0\r\n\u0000" -> null
      Ich hab hier aktuell keinen Ansatzpunkt. Er bekommt die Identification-Message, sendet das Ack mit der neuen Baudrate, danach wird die Baudrate geändert und dann kommt nur müll. Bedeutet: Der Zähler hat die Baudrate-Änderung nicht bekommen bzw. reagiert nicht darauf. Warum - keine Ahnung
      Das einzige was ich hier sehe was ich noch nie gesehen habe ist, dass die Daten die gesendet werden auch einmalig gelesen werden. Also eine Art "Echo" … könnte mir nur vorstellen das das zu Problemen führt.
      Was ist da für ein LeseKopf dran? Sitzt der richtig?
      An sich kann ich jetzt nur sagen: versuch doch mal mit den Infos von volkszaehler ob DU es direkt mit nem terminalprogramm machen kannst und ob es da tut ...
      ALternative: Dreh die Wartezeit hoch und schreeib bei "baudrate overwrite "ne 300 rein ... dann sollte es gehen, aber eeeeeewig dauern 😞
        @apollon77:
        Der Zähler hat die Baudrate-Änderung nicht bekommen bzw. reagiert nicht darauf. Warum - keine Ahnung keine Ahnung, in der oben verlinkten Doku von Volkszähler steht: > Die Baudrate läßt sich auch auf 9600 Baud umstellen wenn man innerhalb von 2s nachdem der Zähler seine Identifikation geschickt hat, ein Acknowledge Paket (ACK050CRLF) schickt (Zahlen in <> in HEX). `
        Wird diese Zeit eingehalten??
        Rainer
          MichaelJaD last edited by
          Ich habe diesen: http://shop.weidmann-elektronik.de/inde … ct&info=24
          ioBroker lauft auf einem PI3
          Also der sitzt richtig sonst würde ich am Terminal ja keine Daten bekommen bzw auch senden können(Startbefehl) Die Umschaltung der Baudrate bekomme ich Manuel so auch nicht hin aber starten kann ich den Datenempfang im Terminal genauso wie dein Adapter das macht.
          Also die Geschwindigkeit ist glaube ich erstmal zu vernachlässigen.
          Das Problem scheint mir zu sein das der Adapter mit dem Datenempfang durcheinander kommt.
          Die Identifikation liest er ja noch sauber ein.
          2017-03-16 07:27:08.040  -  [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "/?!\r\n/ISk5MT174-0001" -> null
          2017-03-16 07:27:08.078  -  [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
          2017-03-16 07:27:08.080  -  [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "/?!\r\n/ISk5MT174-0001\r" -> null
          2017-03-16 07:27:08.107  -  [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
          2017-03-16 07:27:08.108  -  [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "/?!\r\n/ISk5MT174-0001\r\n" -> ["/ISk5MT174-0001\r\n","/ISk5MT174-0001"]
          2017-03-16 07:27:08.113  -  [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
          Terminal:
          /ISk5MT174-0001
          Dann werden Daten vom Adapter gesendet
          2017-03-16 07:27:08.119 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
          2017-03-16 07:27:08.120 - [34mdebug [39m: smartmeter.0 MESSAGES TO SEND: 2
          2017-03-16 07:27:08.121 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 3 IN GETNEXTMESSAGE
          2017-03-16 07:27:08.124 - [34mdebug [39m: smartmeter.0 TO SEND 2: 050
          2017-03-16 07:27:08.168 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
          2017-03-16 07:27:08.169 - [34mdebug [39m: smartmeter.0 MATCH-RESULT DATA: "\u0006" -> null
          2017-03-16 07:27:08.200 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
          2017-03-16 07:27:08.201 - [34mdebug [39m: smartmeter.0 MATCH-RESULT DATA: "\u00060" -> null
          2017-03-16 07:27:08.234 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
          2017-03-16 07:27:08.235 - [34mdebug [39m: smartmeter.0 MATCH-RESULT DATA: "\u000605" -> null
          2017-03-16 07:27:08.244 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 4 IN GETNEXTMESSAGE
          2017-03-16 07:27:08.245 - [34mdebug [39m: smartmeter.0 BAUD CHANGEOVER TO 9600 baud
          2017-03-16 07:27:08.246 - [34mdebug [39m: smartmeter.0 TO SEND 1:
          2017-03-16 07:27:08.247 - [34mdebug [39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 400000
          2017-03-16 07:27:08.248 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 4 IN ISPROCESSCOMPLETE: false
          2017-03-16 07:27:08.249 - [34mdebug [39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING: 05
          2017-03-16 07:27:08.250 - [34mdebug [39m: smartmeter.0 BAUD CHANGEOVER DONE
          2017-03-16 07:27:08.250 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
          2017-03-16 07:27:08.251 - [34mdebug [39m: smartmeter.0 MATCH-RESULT DATA: "\u0006050\r\n" -> null
          Diese kann ich im Terminal aber nicht sehen. Nachdem die Identifikation gesendet worden ist passiert ca. 2s nichts und dann werden die Daten vom Lesekopf gesendet.
          Terminal:
          nach ca 2s Pause:
          1-0:0.9.1*255(221923)
          1-0:0.9.2*255(0170316)
          1-0:0.0.0*255(63355730)
          Das heißt die Daten "2017-03-16 07:27:08.235 - [34mdebug [39m: smartmeter.0 MATCH-RESULT DATA: "\u000605" -> null" werden gar nicht gesendet sonder entstehen durch das senden des Adapters.[/b] **Wenn diese 2s abgelaufen sind (Sieht man auch an der Zeit!) fängt der an die Daten zu empfangen.Ab da werden auch Daten ins Terminal geschrieben wie oben schon mal gepostet! Aber durch das vorherige Senden kann der die Daten wohl nicht mehr "entziffern" und schreibt mit jeder Ziffer/Buchstabe eine zusätzliche \u0000 rein und macht das bis der Adapter aufhört zu senden.
          2017-03-16 07:27:10.196 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
          2017-03-16 07:27:10.196 - [34mdebug [39m: smartmeter.0 MATCH-RESULT DATA: "\u0006050\r\n\u0000" -> null
          2017-03-16 07:27:10.212 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
          2017-03-16 07:27:10.214 - [34mdebug [39m: smartmeter.0 MATCH-RESULT DATA: "\u0006050\r\n\u0000\u0000" -> null
          2017-03-16 07:27:10.237 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
          2017-03-16 07:27:10.238 - [34mdebug [39m: smartmeter.0 MATCH-RESULT DATA: "\u0006050\r\n\u0000\u0000\u0000\u0000" -> null
          Meine Fragen:
          Kann man das senden von Daten abstellen nach der Initialiserung? Der soll erstmal keine Bauratenänderungen oder so zum Lesekopf senden.
          Sonder nur sofort die Daten lesen.
          Ich denke mal da liegt das Problem.
          Danach kann man ich sich ja an die Änderungen der Baurate wagen.
          Gruß**
            Irgendwann nachdem diese Rückmeldung so lang wird das alle Adapter abschmieren :
            ! 2017-03-16 07:28:20.636 - [34mdebug [39m: smartmeter.0 MATCH-RESULT DATA: "\u0006050\r\n\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null[/spoiler]
            startet der Adapter neu und empfängt die Daten die ja noch weiterhin gesendet werden aber kann dann damit nichts mehr anfangen weil zu viel Müll am Anfang steht ( "3\u0004" \u0000\u0002\r\n):
            ! 2017-03-16 07:28:58.005 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0" -> null
            ! 2017-03-16 07:28:58.038 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.039 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:" -> null
            ! 2017-03-16 07:28:58.071 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.072 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1" -> null
            ! 2017-03-16 07:28:58.104 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.105 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1." -> null
            ! 2017-03-16 07:28:58.137 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.138 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6" -> null
            ! 2017-03-16 07:28:58.171 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.171 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6." -> null
            ! 2017-03-16 07:28:58.204 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.205 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6.3" -> null
            ! 2017-03-16 07:28:58.238 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.239 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6.3*" -> null
            ! 2017-03-16 07:28:58.284 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.286 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6.31" -> null
            ! 2017-03-16 07:28:58.304 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.306 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6.3
            15" -> null
            ! 2017-03-16 07:28:58.338 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.339 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6.315(" -> null
            ! 2017-03-16 07:28:58.374 - [34mdebug [39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
            ! 2017-03-16 07:28:58.374 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6.3
            15()" -> null
            ! 2017-03-16 07:29:06.277 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6.315()\r\n1-0:1.6.401()\r\n1-0:1.6.402()\r\n1-0:1.6.403()\r\n1-0:1.6.404()\r\n1-0:1.6.405()\r\n1-0:1.6.406()\r\n1-0:1.6.407()\r\n1-0:1.6.408()\r\n1-0:1.6.409()\r\n1-0:1.6.410()\r\n1-0:1.6.411()\r\n1-0:1.6.412()\r\n1-0:1.6.413()\r\n1-0:1.6.414()\r\n1-0:1.6.41" -> null
            ! 2017-03-16 07:29:10.900 - [34mdebug [39m: smartmeter.0 MATCH-RESULT SIGNON: "3\u0004" \u0000\u0002\r\n1-0:1.6.315()\r\n1-0:1.6.401()\r\n1-0:1.6.402()\r\n1-0:1.6.403()\r\n1-0:1.6.404()\r\n1-0:1.6.405()\r\n1-0:1.6.406()\r\n1-0:1.6.407()\r\n1-0:1.6.408()\r\n1-0:1.6.409()\r\n1-0:1.6.410()\r\n1-0:1.6.411()\r\n1-0:1.6.412()\r\n1-0:1.6.413()\r\n1-0:1.6.414()\r\n1-0:1.6.415()\r\n1-0:1.8.101(0007904.135kWh)\r\n1-0:1.8.102(0007660.326kWh)\r\n1-0:1.8.103(0007371.517kWh)\r\n1-0:1.8.104(0007104.603kWh)\r\n1-0:1.8.1" -> null[/spoiler]
              ALso ja wird innerhalb der 2 Sekunden gesendet:
              Identification wurde empfangen: 18:28:46.766
              Ack mit Baudrate <ack>050 gesendet: 18:28:46.894
              Baudrate changeover done; 18:28:46.897
              Ääähm ja … locker ;-))
              Es sei denn das ist zu schnell ... Bitte 0.5.4 vom Github versuchen. Damit mein "letzter" Versuch 🙂
              @MichaelJaD: Wenn Du es ohne Baudrate-Changeover willst dann wie oben gesagt "Baudrate Overwrite" auf 300 und dann bleibt er auf 300baud ... dann musst Du aber den Read-Timeout auf mind 6-x Minuten setzen bis er alles gelesen hat ... Am besten setzt auf 10 Minuten, lass es laufen und dann weisst DU wie lange er gebraucht hat.
              Aber gib der 0.5.4 noch nen Try :-)</ack>
                Nicht aufgeben 🙂
                Es wird besser. Er empfängt fast keine unsinnige Daten mehr.
                Ohne Baudratechange hat der bei der Identifikation Müll in der Rückmeldung.
                Mit Baudratechange klappt die Identifikation und Empfängt dann auch vernünftige Daten, aber am Anfang sind noch Zeichen die eine Verarbeitung verhindern.
                2314_iobroker.2017-03-17__mit_baudratechange_300_.log
                2314_iobroker.2017-03-17__ohne_baudratechange_.log
                  Ja geil … das passt alles, Du hast nur bei dem "ohne Baudrate Changover-Overwrite" zu früh abgebrochen!!
                  Die Mülldaten hat er korrekt ignoriert ...
                  2017-03-17 19:44:18.077  - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000/?!\r\n/ISk5MT174-0001\r\n" -> ["/ISk5MT174-0001\r\n","/ISk5MT174-0001"]
                  passt!
                  Lass mal ohne diesen Overwrite laufen bis er alle Daten hat (so wie es jetzt aussieht kannst auch ohne Debug machen und sollte klappen. Deiner sendet recht viele Daten, also dauert es auch mit 9600 baud ne kleine Weile.
                  klappt die Neue Version bei allen anderen auch noch?
                  • wendy2702
                    wendy2702 last edited by
                    Ich warte noch auf den neuen Zähler.
                    Wollte vorher kein Update machen da ich zur Zeit noch paar andere Baustellen habe.
                      Läuft problemlos! Gute Arbeit!
                      Rappi
                        Leider klappt es noch nicht ganz.
                        Es gibt noch Probleme mit der Auswertung.
                        Kannst du dir das nochmal anschauen?
                        Letze Nachricht:
                        ! 2017-03-18 20:25:46.060 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0006000\r\n\u00021-0:0.9.1255(201455)\r\n1-0:0.9.2255(0170318)\r\n1-0:0.0.0255(63355730)\r\n1-0:0.0.1255(1ISK0063355730)\r\n1-0:0.1.0255(33)\r\n1-0:0.2.0255(1.03)\r\n0-0:C.1.0255(63355730)\r\n0-0:C.1.6255(FDF5)\r\n0-0:C.51.1255(3)\r\n0-0:C.51.2255(1140716101053)\r\n0-0:C.51.201(1140716101053)\r\n0-0:C.51.202(0131211111412)\r\n0-0:C.51.203(0131211111407)\r\n1-0:1.6.0255(02.468kW)(1703100930)\r\n1-0:1.7.0255(0.908kW)\r\n1-0:1.8.0255(0008048.375kWh)\r\n1-0:1.8.1255(0008048.375kWh)\r\n1-0:1.8.2255(0000000.000kWh)\r\n1-0:1.8.3255(0000000.000kWh)\r\n1-0:1.8.4255(0000000.000kWh)\r\n1-0:2.6.0255(00.000kW)(1703182015)\r\n1-0:2.7.0255(0.000kW)\r\n1-0:2.8.0255(0000000.000kWh)\r\n1-0:2.8.1255(0000000.000kWh)\r\n1-0:2.8.2255(0000000.000kWh)\r\n1-0:2.8.3255(0000000.000kWh)\r\n1-0:2.8.4255(0000000.000kWh)\r\n0-0:F.F.0255(0000000)\r\n1-0:0.1.201(1703010000)\r\n1-0:0.1.202(1702010000)\r\n1-0:0.1.203(1701010000)\r\n1-0:0.1.204(1612010000)\r\n1-0:0.1.205(1611010000)\r\n1-0:0.1.206(1610010000)\r\n1-0:0.1.207(1609010000)\r\n1-0:0.1.208(1608010000)\r\n1-0:0.1.209(1607010000)\r\n1-0:0.1.210(1606010000)\r\n1-0:0.1.211(1605010000)\r\n1-0:0.1.212(1604010000)\r\n1-0:0.1.213(1603010000)\r\n1-0:0.1.214(1602010000)\r\n1-0:0.1.215(1601010000)\r\n1-0:1.6.001(03.258kW)(1702102000)\r\n1-0:1.6.002(03.308kW)(1701261830)\r\n1-0:1.6.003(02.838kW)(1612232045)\r\n1-0:1.6.004(03.398kW)(1611161800)\r\n1-0:1.6.005(02.964kW)(1610132000)\r\n1-0:1.6.006(03.356kW)(1609131845)\r\n1-0:1.6.007(03.888kW)(1608051945)\r\n1-0:1.6.008(03.102kW)(1607272045)\r\n1-0:1.6.009(02.844kW)(1606152000)\r\n1-0:1.6.010(03.850kW)(1605172115)\r\n1-0:1.6.011(03.756kW)(1604021130)\r\n1-0:1.6.012(04.190kW)(1603022015)\r\n1-0:1.6.013(03.764kW)(1602101845)\r\n1-0:1.6.014(03.768kW)(1601061730)\r\n1-0:1.6.015(03.806kW)(1512162045)\r\n1-0:1.8.001(0007904.135kWh)\r\n1-0:1.8.002(0007660.326kWh)\r\n1-0:1.8.003(0007371.517kWh)\r\n1-0:1.8.004(0007104.603kWh)\r\n1-0:1.8.005(0006820.722kWh)\r\n1-0:1.8.006(0006581.536kWh)\r\n1-0:1.8.007(0006334.294kWh)\r\n1-0:1.8.008(0006097.335kWh)\r\n1-0:1.8.009(0005862.843kWh)\r\n1-0:1.8.010(0005625.115kWh)\r\n1-0:1.8.011(0005358.178kWh)\r\n1-0:1.8.012(0005096.931kWh)\r\n1-0:1.8.013(0004800.953kWh)\r\n1-0:1.8.014(0004517.795kWh)\r\n1-0:1.8.015(0004224.392kWh)\r\n1-0:1.6.101(03.258kW)(1702102000)\r\n1-0:1.6.102(03.308kW)(1701261830)\r\n1-0:1.6.103(02.838kW)(1612232045)\r\n1-0:1.6.104(03.398kW)(1611161800)\r\n1-0:1.6.105(02.964kW)(1610132000)\r\n1-0:1.6.106(03.356kW)(1609131845)\r\n1-0:1.6.107(03.888kW)(1608051945)\r\n1-0:1.6.108(03.102kW)(1607272045)\r\n1-0:1.6.109(02.844kW)(1606152000)\r\n1-0:1.6.110(03.850kW)(1605172115)\r\n1-0:1.6.111(03.756kW)(1604021130)\r\n1-0:1.6.112(04.190kW)(1603022015)\r\n1-0:1.6.113(03.764kW)(1602101845)\r\n1-0:1.6.114(03.768kW)(1601061730)\r\n1-0:1.6.115(03.806kW)(1512162045)\r\n1-0:1.6.201()\r\n1-0:1.6.202()\r\n1-0:1.6.203()\r\n1-0:1.6.204()\r\n1-0:1.6.205()\r\n1-0:1.6.206()\r\n1-0:1.6.207()\r\n1-0:1.6.208()\r\n1-0:1.6.209()\r\n1-0:1.6.210()\r\n1-0:1.6.211()\r\n1-0:1.6.212()\r\n1-0:1.6.213()\r\n1-0:1.6.214()\r\n1-0:1.6.215()\r\n1-0:1.6.301()\r\n1-0:1.6.302()\r\n1-0:1.6.303()\r\n1-0:1.6.304()\r\n1-0:1.6.305()\r\n1-0:1.6.306()\r\n1-0:1.6.307()\r\n1-0:1.6.308()\r\n1-0:1.6.309()\r\n1-0:1.6.310()\r\n1-0:1.6.311()\r\n1-0:1.6.312()\r\n1-0:1.6.313()\r\n1-0:1.6.314()\r\n1-0:1.6.315()\r\n1-0:1.6.401()\r\n1-0:1.6.402()\r\n1-0:1.6.403()\r\n1-0:1.6.404()\r\n1-0:1.6.405()\r\n1-0:1.6.406()\r\n1-0:1.6.407()\r\n1-0:1.6.408()\r\n1-0:1.6.409()\r\n1-0:1.6.410()\r\n1-0:1.6.411()\r\n1-0:1.6.412()\r\n1-0:1.6.413()\r\n1-0:1.6.414()\r\n1-0:1.6.415()\r\n1-0:1.8.101(0007904.135kWh)\r\n1-0:1.8.102(0007660.326kWh)\r\n1-0:1.8.103(0007371.517kWh)\r\n1-0:1.8.104(0007104.603kWh)\r\n1-0:1.8.105(0006820.722kWh)\r\n1-0:1.8.106(0006581.536kWh)\r\n1-0:1.8.107(0006334.294kWh)\r\n1-0:1.8.108(0006097.335kWh)\r\n1-0:1.8.109(0005862.843kWh)\r\n1-0:1.8.110(0005625.115kWh)\r\n1-0:1.8.111(0005358.178kWh)\r\n1-0:1.8.112(0005096.931kWh)\r\n1-0:1.8.113(0004800.953kWh)\r\n1-0:1.8.114(0004517.795kWh)\r\n1-0:1.8.115(0004224.392kWh)\r\n1-0:1.8.201(0000000.000kWh)\r\n1-0:1.8.202(0000000.000kWh)\r\n1-0:1.8.203(0000000.000kWh)\r\n1-0:1.8.204(0000000.000kWh)\r\n1-0:1.8.205(0000000.000kWh)\r\n1-0:1.8.206(0000000.000kWh)\r\n1-0:1.8.207(0000000.000kWh)\r\n1-0:1.8.208(0000000.000kWh)\r\n1-0:1.8.209(0000000.000kWh)\r\n1-0:1.8.210(0000000.000kWh)\r\n1-0:1.8.211(0000000.000kWh)\r\n1-0:1.8.212(0000000.000kWh)\r\n1-0:1.8.213(0000000.000kWh)\r\n1-0:1.8.214(0000000.000kWh)\r\n1-0:1.8.215(0000000.000kWh)\r\n1-0:1.8.301(0000000.000kWh)\r\n1-0:1.8.302(0000000.000kWh)\r\n1-0:1.8.303(0000000.000kWh)\r\n1-0:1.8.304(0000000.000kWh)\r\n1-0:1.8.305(0000000.000kWh)\r\n1-0:1.8.306(0000000.000kWh)\r\n1-0:1.8.307(0000000.000kWh)\r\n1-0:1.8.308(0000000.000kWh)\r\n1-0:1.8.309(0000000.000kWh)\r\n1-0:1.8.310(0000000.000kWh)\r\n1-0:1.8.311(0000000.000kWh)\r\n1-0:1.8.312(0000000.000kWh)\r\n1-0:1.8.313(0000000.000kWh)\r\n1-0:1.8.314(0000000.000kWh)\r\n1-0:1.8.315(0000000.000kWh)\r\n1-0:1.8.401(0000000.000kWh)\r\n1-0:1.8.402(0000000.000kWh)\r\n1-0:1.8.403(0000000.000kWh)\r\n1-0:1.8.404(0000000.000kWh)\r\n1-0:1.8.405(0000000.000kWh)\r\n1-0:1.8.406(0000000.000kWh)\r\n1-0:1.8.407(0000000.000kWh)\r\n1-0:1.8.408(0000000.000kWh)\r\n1-0:1.8.409(0000000.000kWh)\r\n1-0:1.8.410(0000000.000kWh)\r\n1-0:1.8.411(0000000.000kWh)\r\n1-0:1.8.412(0000000.000kWh)\r\n1-0:1.8.413(0000000.000kWh)\r\n1-0:1.8.414(0000000.000kWh)\r\n1-0:1.8.415(0000000.000kWh)\r\n1-0:2.6.001(00.000kW)(1703010000)\r\n1-0:2.6.002(00.000kW)(1702010000)\r\n1-0:2.6.003(00.000kW)(1701010000)\r\n1-0:2.6.004(00.000kW)(1612010000)\r\n1-0:2.6.005(00.000kW)(1611010000)\r\n1-0:2.6.006(00.000kW)(1610010000)\r\n1-0:2.6.007(00.000kW)(1609010000)\r\n1-0:2.6.008(00.000kW)(1608010000)\r\n1-0:2.6.009(00.000kW)(1607010000)\r\n1-0:2.6.010(00.000kW)(1606010000)\r\n1-0:2.6.011(00.000kW)(1605010000)\r\n1-0:2.6.012(00.000kW)(1604010000)\r\n1-0:2.6.013(00.000kW)(1603010000)\r\n1-0:2.6.014(00.000kW)(1602010000)\r\n1-0:2.6.015(00.000kW)(1601010000)\r\n1-0:2.8.001(0000000.000kWh)\r\n1-0:2.8.002(0000000.000kWh)\r\n1-0:2.8.003(0000000.000kWh)\r\n1-0:2.8.004(0000000.000kWh)\r\n1-0:2.8.005(0000000.000kWh)\r\n1-0:2.8.006(0000000.000kWh)\r\n1-0:2.8.007(0000000.000kWh)\r\n1-0:2.8.008(0000000.000kWh)\r\n1-0:2.8.009(0000000.000kWh)\r\n1-0:2.8.010(0000000.000kWh)\r\n1-0:2.8.011(0000000.000kWh)\r\n1-0:2.8.012(0000000.000kWh)\r\n1-0:2.8.013(0000000.000kWh)\r\n1-0:2.8.014(0000000.000kWh)\r\n1-0:2.8.015(0000000.000kWh)\r\n1-0:2.6.101(00.000kW)(1703010000)\r\n1-0:2.6.102(00.000kW)(1702010000)\r\n1-0:2.6.103(00.000kW)(1701010000)\r\n1-0:2.6.104(00.000kW)(1612010000)\r\n1-0:2.6.105(00.000kW)(1611010000)\r\n1-0:2.6.106(00.000kW)(1610010000)\r\n1-0:2.6.107(00.000kW)(1609010000)\r\n1-0:2.6.108(00.000kW)(1608010000)\r\n1-0:2.6.109(00.000kW)(1607010000)\r\n1-0:2.6.110(00.000kW)(1606010000)\r\n1-0:2.6.111(00.000kW)(1605010000)\r\n1-0:2.6.112(00.000kW)(1604010000)\r\n1-0:2.6.113(00.000kW)(1603010000)\r\n1-0:2.6.114(00.000kW)(1602010000)\r\n1-0:2.6.115(00.000kW)(1601010000)\r\n1-0:2.6.201()\r\n1-0:2.6.202()\r\n1-0:2.6.203()\r\n1-0:2.6.204()\r\n1-0:2.6.205()\r\n1-0:2.6.206()\r\n1-0:2.6.207()\r\n1-0:2.6.208()\r\n1-0:2.6.209()\r\n1-0:2.6.210()\r\n1-0:2.6.211()\r\n1-0:2.6.212()\r\n1-0:2.6.213()\r\n1-0:2.6.214()\r\n1-0:2.6.215()\r\n1-0:2.6.301()\r\n1-0:2.6.302()\r\n1-0:2.6.303()\r\n1-0:2.6.304()\r\n1-0:2.6.305()\r\n1-0:2.6.306()\r\n1-0:2.6.307()\r\n1-0:2.6.308()\r\n1-0:2.6.309()\r\n1-0:2.6.310()\r\n1-0:2.6.311()\r\n1-0:2.6.312()\r\n1-0:2.6.313()\r\n1-0:2.6.314()\r\n1-0:2.6.315()\r\n1-0:2.6.401()\r\n1-0:2.6.402()\r\n1-0:2.6.403()\r\n1-0:2.6.404()\r\n1-0:2.6.405()\r\n1-0:2.6.406()\r\n1-0:2.6.407()\r\n1-0:2.6.408()\r\n1-0:2.6.409()\r\n1-0:2.6.410()\r\n1-0:2.6.411()\r\n1-0:2.6.412()\r\n1-0:2.6.413()\r\n1-0:2.6.414()\r\n1-0:2.6.415()\r\n1-0:2.8.101(0000000.000kWh)\r\n1-0:2.8.102(0000000.000kWh)\r\n1-0:2.8.103(0000000.000kWh)\r\n1-0:2.8.104(0000000.000kWh)\r\n1-0:2.8.105(0000000.000kWh)\r\n1-0:2.8.106(0000000.000kWh)\r\n1-0:2.8.107(0000000.000kWh)\r\n1-0:2.8.108(0000000.000kWh)\r\n1-0:2.8.109(0000000.000kWh)\r\n1-0:2.8.110(0000000.000kWh)\r\n1-0:2.8.111(0000000.000kWh)\r\n1-0:2.8.112(0000000.000kWh)\r\n1-0:2.8.113(0000000.000kWh)\r\n1-0:2.8.114(0000000.000kWh)\r\n1-0:2.8.115(0000000.000kWh)\r\n1-0:2.8.201(0000000.000kWh)\r\n1-0:2.8.202(0000000.000kWh)\r\n1-0:2.8.203(0000000.000kWh)\r\n1-0:2.8.204(0000000.000kWh)\r\n1-0:2.8.205(0000000.000kWh)\r\n1-0:2.8.206(0000000.000kWh)\r\n1-0:2.8.207(0000000.000kWh)\r\n1-0:2.8.208(0000000.000kWh)\r\n1-0:2.8.209(0000000.000kWh)\r\n1-0:2.8.210(0000000.000kWh)\r\n1-0:2.8.211(0000000.000kWh)\r\n1-0:2.8.212(0000000.000kWh)\r\n1-0:2.8.213(0000000.000kWh)\r\n1-0:2.8.214(0000000.000kWh)\r\n1-0:2.8.215(0000000.000kWh)\r\n1-0:2.8.301(0000000.000kWh)\r\n1-0:2.8.302(0000000.000kWh)\r\n1-0:2.8.303(0000000.000kWh)\r\n1-0:2.8.304(0000000.000kWh)\r\n1-0:2.8.305(0000000.000kWh)\r\n1-0:2.8.306(0000000.000kWh)\r\n1-0:2.8.307(0000000.000kWh)\r\n1-0:2.8.308(0000000.000kWh)\r\n1-0:2.8.309(0000000.000kWh)\r\n1-0:2.8.310(0000000.000kWh)\r\n1-0:2.8.311(0000000.000kWh)\r\n1-0:2.8.312(0000000.000kWh)\r\n1-0:2.8.313(0000000.000kWh)\r\n1-0:2.8.314(0000000.000kWh)\r\n1-0:2.8.315(0000000.000kWh)\r\n1-0:2.8.401(0000000.000kWh)\r\n1-0:2.8.402(0000000.000kWh)\r\n1-0:2.8.403(0000000.000kWh)\r\n1-0:2.8.404(0000000.000kWh)\r\n1-0:2.8.405(0000000.000kWh)\r\n1-0:2.8.406(0000000.000kWh)\r\n1-0:2.8.407(0000000.000kWh)\r\n1-0:2.8.408(0000000.000kWh)\r\n1-0:2.8.409(0000000.000kWh)\r\n1-0:2.8.410(0000000.000kWh)\r\n1-0:2.8.411(0000000.000kWh)\r\n1-0:2.8.412(0000000.000kWh)\r\n1-0:2.8.413(0000000.000kWh)\r\n1-0:2.8.414(0000000.000kWh)\r\n1-0:2.8.415(0000000.000kWh)\r\n!\r\n\u0003f" -> ["000\r\n\u00021-0:0.9.1255(201455)\r\n1-0:0.9.2255(0170318)\r\n1-0:0.0.0255(63355730)\r\n1-0:0.0.1255(1ISK0063355730)\r\n1-0:0.1.0255(33)\r\n1-0:0.2.0255(1.03)\r\n0-0:C.1.0255(63355730)\r\n0-0:C.1.6255(FDF5)\r\n0-0:C.51.1255(3)\r\n0-0:C.51.2255(1140716101053)\r\n0-0:C.51.201(1140716101053)\r\n0-0:C.51.202(0131211111412)\r\n0-0:C.51.203(0131211111407)\r\n1-0:1.6.0255(02.468kW)(1703100930)\r\n1-0:1.7.0255(0.908kW)\r\n1-0:1.8.0255(0008048.375kWh)\r\n1-0:1.8.1255(0008048.375kWh)\r\n1-0:1.8.2255(0000000.000kWh)\r\n1-0:1.8.3255(0000000.000kWh)\r\n1-0:1.8.4255(0000000.000kWh)\r\n1-0:2.6.0255(00.000kW)(1703182015)\r\n1-0:2.7.0255(0.000kW)\r\n1-0:2.8.0255(0000000.000kWh)\r\n1-0:2.8.1255(0000000.000kWh)\r\n1-0:2.8.2255(0000000.000kWh)\r\n1-0:2.8.3255(0000000.000kWh)\r\n1-0:2.8.4255(0000000.000kWh)\r\n0-0:F.F.0255(0000000)\r\n1-0:0.1.201(1703010000)\r\n1-0:0.1.202(1702010000)\r\n1-0:0.1.203(1701010000)\r\n1-0:0.1.204(1612010000)\r\n1-0:0.1.205(1611010000)\r\n1-0:0.1.206(1610010000)\r\n1-0:0.1.207(1609010000)\r\n1-0:0.1.208(1608010000)\r\n1-0:0.1.209(1607010000)\r\n1-0:0.1.210(1606010000)\r\n1-0:0.1.211(1605010000)\r\n1-0:0.1.212(1604010000)\r\n1-0:0.1.213(1603010000)\r\n1-0:0.1.214(1602010000)\r\n1-0:0.1.215(1601010000)\r\n1-0:1.6.001(03.258kW)(1702102000)\r\n1-0:1.6.002(03.308kW)(1701261830)\r\n1-0:1.6.003(02.838kW)(1612232045)\r\n1-0:1.6.004(03.398kW)(1611161800)\r\n1-0:1.6.005(02.964kW)(1610132000)\r\n1-0:1.6.006(03.356kW)(1609131845)\r\n1-0:1.6.007(03.888kW)(1608051945)\r\n1-0:1.6.008(03.102kW)(1607272045)\r\n1-0:1.6.009(02.844kW)(1606152000)\r\n1-0:1.6.010(03.850kW)(1605172115)\r\n1-0:1.6.011(03.756kW)(1604021130)\r\n1-0:1.6.012(04.190kW)(1603022015)\r\n1-0:1.6.013(03.764kW)(1602101845)\r\n1-0:1.6.014(03.768kW)(1601061730)\r\n1-0:1.6.015(03.806kW)(1512162045)\r\n1-0:1.8.001(0007904.135kWh)\r\n1-0:1.8.002(0007660.326kWh)\r\n1-0:1.8.003(0007371.517kWh)\r\n1-0:1.8.004(0007104.603kWh)\r\n1-0:1.8.005(0006820.722kWh)\r\n1-0:1.8.006(0006581.536kWh)\r\n1-0:1.8.007(0006334.294kWh)\r\n1-0:1.8.008(0006097.335kWh)\r\n1-0:1.8.009(0005862.843kWh)\r\n1-0:1.8.010(0005625.115kWh)\r\n1-0:1.8.011(0005358.178kWh)\r\n1-0:1.8.012(0005096.931kWh)\r\n1-0:1.8.013(0004800.953kWh)\r\n1-0:1.8.014(0004517.795kWh)\r\n1-0:1.8.015(0004224.392kWh)\r\n1-0:1.6.101(03.258kW)(1702102000)\r\n1-0:1.6.102(03.308kW)(1701261830)\r\n1-0:1.6.103(02.838kW)(1612232045)\r\n1-0:1.6.104(03.398kW)(1611161800)\r\n1-0:1.6.105(02.964kW)(1610132000)\r\n1-0:1.6.106(03.356kW)(1609131845)\r\n1-0:1.6.107(03.888kW)(1608051945)\r\n1-0:1.6.108(03.102kW)(1607272045)\r\n1-0:1.6.109(02.844kW)(1606152000)\r\n1-0:1.6.110(03.850kW)(1605172115)\r\n1-0:1.6.111(03.756kW)(1604021130)\r\n1-0:1.6.112(04.190kW)(1603022015)\r\n1-0:1.6.113(03.764kW)(1602101845)\r\n1-0:1.6.114(03.768kW)(1601061730)\r\n1-0:1.6.115(03.806kW)(1512162045)\r\n1-0:1.6.201()\r\n1-0:1.6.202()\r\n1-0:1.6.203()\r\n1-0:1.6.204()\r\n1-0:1.6.205()\r\n1-0:1.6.206()\r\n1-0:1.6.207()\r\n1-0:1.6.208()\r\n1-0:1.6.209()\r\n1-0:1.6.210()\r\n1-0:1.6.211()\r\n1-0:1.6.212()\r\n1-0:1.6.213()\r\n1-0:1.6.214()\r\n1-0:1.6.215()\r\n1-0:1.6.301()\r\n1-0:1.6.302()\r\n1-0:1.6.303()\r\n1-0:1.6.304()\r\n1-0:1.6.305()\r\n1-0:1.6.306()\r\n1-0:1.6.307()\r\n1-0:1.6.308()\r\n1-0:1.6.309()\r\n1-0:1.6.310()\r\n1-0:1.6.311()\r\n1-0:1.6.312()\r\n1-0:1.6.313()\r\n1-0:1.6.314()\r\n1-0:1.6.315()\r\n1-0:1.6.401()\r\n1-0:1.6.402()\r\n1-0:1.6.403()\r\n1-0:1.6.404()\r\n1-0:1.6.405()\r\n1-0:1.6.406()\r\n1-0:1.6.407()\r\n1-0:1.6.408()\r\n1-0:1.6.409()\r\n1-0:1.6.410()\r\n1-0:1.6.411()\r\n1-0:1.6.412()\r\n1-0:1.6.413()\r\n1-0:1.6.414()\r\n1-0:1.6.415()\r\n1-0:1.8.101(0007904.135kWh)\r\n1-0:1.8.102(0007660.326kWh)\r\n1-0:1.8.103(0007371.517kWh)\r\n1-0:1.8.104(0007104.603kWh)\r\n1-0:1.8.105(0006820.722kWh)\r\n1-0:1.8.106(0006581.536kWh)\r\n1-0:1.8.107(0006334.294kWh)\r\n1-0:1.8.108(0006097.335kWh)\r\n1-0:1.8.109(0005862.843kWh)\r\n1-0:1.8.110(0005625.115kWh)\r\n1-0:1.8.111(0005358.178kWh)\r\n1-0:1.8.112(0005096.931kWh)\r\n1-0:1.8.113(0004800.953kWh)\r\n1-0:1.8.114(0004517.795kWh)\r\n1-0:1.8.115(0004224.392kWh)\r\n1-0:1.8.201(0000000.000kWh)\r\n1-0:1.8.202(0000000.000kWh)\r\n1-0:1.8.203(0000000.000kWh)\r\n1-0:1.8.204(0000000.000kWh)\r\n1-0:1.8.205(0000000.000kWh)\r\n1-0:1.8.206(0000000.000kWh)\r\n1-0:1.8.207(0000000.000kWh)\r\n1-0:1.8.208(0000000.000kWh)\r\n1-0:1.8.209(0000000.000kWh)\r\n1-0:1.8.210(0000000.000kWh)\r\n1-0:1.8.211(0000000.000kWh)\r\n1-0:1.8.212(0000000.000kWh)\r\n1-0:1.8.213(0000000.000kWh)\r\n1-0:1.8.214(0000000.000kWh)\r\n1-0:1.8.215(0000000.000kWh)\r\n1-0:1.8.301(0000000.000kWh)\r\n1-0:1.8.302(0000000.000kWh)\r\n1-0:1.8.303(0000000.000kWh)\r\n1-0:1.8.304(0000000.000kWh)\r\n1-0:1.8.305(0000000.000kWh)\r\n1-0:1.8.306(0000000.000kWh)\r\n1-0:1.8.307(0000000.000kWh)\r\n1-0:1.8.308(0000000.000kWh)\r\n1-0:1.8.309(0000000.000kWh)\r\n1-0:1.8.310(0000000.000kWh)\r\n1-0:1.8.311(0000000.000kWh)\r\n1-0:1.8.312(0000000.000kWh)\r\n1-0:1.8.313(0000000.000kWh)\r\n1-0:1.8.314(0000000.000kWh)\r\n1-0:1.8.315(0000000.000kWh)\r\n1-0:1.8.401(0000000.000kWh)\r\n1-0:1.8.402(0000000.000kWh)\r\n1-0:1.8.403(0000000.000kWh)\r\n1-0:1.8.404(0000000.000kWh)\r\n1-0:1.8.405(0000000.000kWh)\r\n1-0:1.8.406(0000000.000kWh)\r\n1-0:1.8.407(0000000.000kWh)\r\n1-0:1.8.408(0000000.000kWh)\r\n1-0:1.8.409(0000000.000kWh)\r\n1-0:1.8.410(0000000.000kWh)\r\n1-0:1.8.411(0000000.000kWh)\r\n1-0:1.8.412(0000000.000kWh)\r\n1-0:1.8.413(0000000.000kWh)\r\n1-0:1.8.414(0000000.000kWh)\r\n1-0:1.8.415(0000000.000kWh)\r\n1-0:2.6.001(00.000kW)(1703010000)\r\n1-0:2.6.002(00.000kW)(1702010000)\r\n1-0:2.6.003(00.000kW)(1701010000)\r\n1-0:2.6.004(00.000kW)(1612010000)\r\n1-0:2.6.005(00.000kW)(1611010000)\r\n1-0:2.6.006(00.000kW)(1610010000)\r\n1-0:2.6.007(00.000kW)(1609010000)\r\n1-0:2.6.008(00.000kW)(1608010000)\r\n1-0:2.6.009(00.000kW)(1607010000)\r\n1-0:2.6.010(00.000kW)(1606010000)\r\n1-0:2.6.011(00.000kW)(1605010000)\r\n1-0:2.6.012(00.000kW)(1604010000)\r\n1-0:2.6.013(00.000kW)(1603010000)\r\n1-0:2.6.014(00.000kW)(1602010000)\r\n1-0:2.6.015(00.000kW)(1601010000)\r\n1-0:2.8.001(0000000.000kWh)\r\n1-0:2.8.002(0000000.000kWh)\r\n1-0:2.8.003(0000000.000kWh)\r\n1-0:2.8.004(0000000.000kWh)\r\n1-0:2.8.005(0000000.000kWh)\r\n1-0:2.8.006(0000000.000kWh)\r\n1-0:2.8.007(0000000.000kWh)\r\n1-0:2.8.008(0000000.000kWh)\r\n1-0:2.8.009(0000000.000kWh)\r\n1-0:2.8.010(0000000.000kWh)\r\n1-0:2.8.011(0000000.000kWh)\r\n1-0:2.8.012(0000000.000kWh)\r\n1-0:2.8.013(0000000.000kWh)\r\n1-0:2.8.014(0000000.000kWh)\r\n1-0:2.8.015(0000000.000kWh)\r\n1-0:2.6.101(00.000kW)(1703010000)\r\n1-0:2.6.102(00.000kW)(1702010000)\r\n1-0:2.6.103(00.000kW)(1701010000)\r\n1-0:2.6.104(00.000kW)(1612010000)\r\n1-0:2.6.105(00.000kW)(1611010000)\r\n1-0:2.6.106(00.000kW)(1610010000)\r\n1-0:2.6.107(00.000kW)(1609010000)\r\n1-0:2.6.108(00.000kW)(1608010000)\r\n1-0:2.6.109(00.000kW)(1607010000)\r\n1-0:2.6.110(00.000kW)(1606010000)\r\n1-0:2.6.111(00.000kW)(1605010000)\r\n1-0:2.6.112(00.000kW)(1604010000)\r\n1-0:2.6.113(00.000kW)(1603010000)\r\n1-0:2.6.114(00.000kW)(1602010000)\r\n1-0:2.6.115(00.000kW)(1601010000)\r\n1-0:2.6.201()\r\n1-0:2.6.202()\r\n1-0:2.6.203()\r\n1-0:2.6.204()\r\n1-0:2.6.205()\r\n1-0:2.6.206()\r\n1-0:2.6.207()\r\n1-0:2.6.208()\r\n1-0:2.6.209()\r\n1-0:2.6.210()\r\n1-0:2.6.211()\r\n1-0:2.6.212()\r\n1-0:2.6.213()\r\n1-0:2.6.214()\r\n1-0:2.6.215()\r\n1-0:2.6.301()\r\n1-0:2.6.302()\r\n1-0:2.6.303()\r\n1-0:2.6.304()\r\n1-0:2.6.305()\r\n1-0:2.6.306()\r\n1-0:2.6.307()\r\n1-0:2.6.308()\r\n1-0:2.6.309()\r\n1-0:2.6.310()\r\n1-0:2.6.311()\r\n1-0:2.6.312()\r\n1-0:2.6.313()\r\n1-0:2.6.314()\r\n1-0:2.6.315()\r\n1-0:2.6.401()\r\n1-0:2.6.402()\r\n1-0:2.6.403()\r\n1-0:2.6.404()\r\n1-0:2.6.405()\r\n1-0:2.6.406()\r\n1-0:2.6.407()\r\n1-0:2.6.408()\r\n1-0:2.6.409()\r\n1-0:2.6.410()\r\n1-0:2.6.411()\r\n1-0:2.6.412()\r\n1-0:2.6.413()\r\n1-0:2.6.414()\r\n1-0:2.6.415()\r\n1-0:2.8.101(0000000.000kWh)\r\n1-0:2.8.102(0000000.000kWh)\r\n1-0:2.8.103(0000000.000kWh)\r\n1-0:2.8.104(0000000.000kWh)\r\n1-0:2.8.105(0000000.000kWh)\r\n1-0:2.8.106(0000000.000kWh)\r\n1-0:2.8.107(0000000.000kWh)\r\n1-0:2.8.108(0000000.000kWh)\r\n1-0:2.8.109(0000000.000kWh)\r\n1-0:2.8.110(0000000.000kWh)\r\n1-0:2.8.111(0000000.000kWh)\r\n1-0:2.8.112(0000000.000kWh)\r\n1-0:2.8.113(0000000.000kWh)\r\n1-0:2.8.114(0000000.000kWh)\r\n1-0:2.8.115(0000000.000kWh)\r\n1-0:2.8.201(0000000.000kWh)\r\n1-0:2.8.202(0000000.000kWh)\r\n1-0:2.8.203(0000000.000kWh)\r\n1-0:2.8.204(0000000.000kWh)\r\n1-0:2.8.205(0000000.000kWh)\r\n1-0:2.8.206(0000000.000kWh)\r\n1-0:2.8.207(0000000.000kWh)\r\n1-0:2.8.208(0000000.000kWh)\r\n1-0:2.8.209(0000000.000kWh)\r\n1-0:2.8.210(0000000.000kWh)\r\n1-0:2.8.211(0000000.000kWh)\r\n1-0:2.8.212(0000000.000kWh)\r\n1-0:2.8.213(0000000.000kWh)\r\n1-0:2.8.214(0000000.000kWh)\r\n1-0:2.8.215(0000000.000kWh)\r\n1-0:2.8.301(0000000.000kWh)\r\n1-0:2.8.302(0000000.000kWh)\r\n1-0:2.8.303(0000000.000kWh)\r\n1-0:2.8.304(0000000.000kWh)\r\n1-0:2.8.305(0000000.000kWh)\r\n1-0:2.8.306(0000000.000kWh)\r\n1-0:2.8.307(0000000.000kWh)\r\n1-0:2.8.308(0000000.000kWh)\r\n1-0:2.8.309(0000000.000kWh)\r\n1-0:2.8.310(0000000.000kWh)\r\n1-0:2.8.311(0000000.000kWh)\r\n1-0:2.8.312(0000000.000kWh)\r\n1-0:2.8.313(0000000.000kWh)\r\n1-0:2.8.314(0000000.000kWh)\r\n1-0:2.8.315(0000000.000kWh)\r\n1-0:2.8.401(0000000.000kWh)\r\n1-0:2.8.402(0000000.000kWh)\r\n1-0:2.8.403(0000000.000kWh)\r\n1-0:2.8.404(0000000.000kWh)\r\n1-0:2.8.405(0000000.000kWh)\r\n1-0:2.8.406(0000000.000kWh)\r\n1-0:2.8.407(0000000.000kWh)\r\n1-0:2.8.408(0000000.000kWh)\r\n1-0:2.8.409(0000000.000kWh)\r\n1-0:2.8.410(0000000.000kWh)\r\n1-0:2.8.411(0000000.000kWh)\r\n1-0:2.8.412(0000000.000kWh)\r\n1-0:2.8.413(0000000.000kWh)\r\n1-0:2.8.414(0000000.000kWh)\r\n1-0:2.8.415(0000000.000kWh)\r\n!\r\n\u0003f","000\r\n\u00021-0:0.9.1255(201455)\r\n1-0:0.9.2255(0170318)\r\n1-0:0.0.0255(63355730)\r\n1-0:0.0.1255(1ISK0063355730)\r\n1-0:0.1.0255(33)\r\n1-0:0.2.0255(1.03)\r\n0-0:C.1.0255(63355730)\r\n0-0:C.1.6255(FDF5)\r\n0-0:C.51.1255(3)\r\n0-0:C.51.2255(1140716101053)\r\n0-0:C.51.201(1140716101053)\r\n0-0:C.51.202(0131211111412)\r\n0-0:C.51.203(0131211111407)\r\n1-0:1.6.0255(02.468kW)(1703100930)\r\n1-0:1.7.0255(0.908kW)\r\n1-0:1.8.0255(0008048.375kWh)\r\n1-0:1.8.1255(0008048.375kWh)\r\n1-0:1.8.2255(0000000.000kWh)\r\n1-0:1.8.3255(0000000.000kWh)\r\n1-0:1.8.4255(0000000.000kWh)\r\n1-0:2.6.0255(00.000kW)(1703182015)\r\n1-0:2.7.0255(0.000kW)\r\n1-0:2.8.0255(0000000.000kWh)\r\n1-0:2.8.1255(0000000.000kWh)\r\n1-0:2.8.2255(0000000.000kWh)\r\n1-0:2.8.3255(0000000.000kWh)\r\n1-0:2.8.4255(0000000.000kWh)\r\n0-0:F.F.0255(0000000)\r\n1-0:0.1.201(1703010000)\r\n1-0:0.1.202(1702010000)\r\n1-0:0.1.203(1701010000)\r\n1-0:0.1.204(1612010000)\r\n1-0:0.1.205(1611010000)\r\n1-0:0.1.206(1610010000)\r\n1-0:0.1.207(1609010000)\r\n1-0:0.1.208(1608010000)\r\n1-0:0.1.209(1607010000)\r\n1-0:0.1.210(1606010000)\r\n1-0:0.1.211(1605010000)\r\n1-0:0.1.212(1604010000)\r\n1-0:0.1.213(1603010000)\r\n1-0:0.1.214(1602010000)\r\n1-0:0.1.215(1601010000)\r\n1-0:1.6.001(03.258kW)(1702102000)\r\n1-0:1.6.002(03.308kW)(1701261830)\r\n1-0:1.6.003(02.838kW)(1612232045)\r\n1-0:1.6.004(03.398kW)(1611161800)\r\n1-0:1.6.005(02.964kW)(1610132000)\r\n1-0:1.6.006(03.356kW)(1609131845)\r\n1-0:1.6.007(03.888kW)(1608051945)\r\n1-0:1.6.008(03.102kW)(1607272045)\r\n1-0:1.6.009(02.844kW)(1606152000)\r\n1-0:1.6.010(03.850kW)(1605172115)\r\n1-0:1.6.011(03.756kW)(1604021130)\r\n1-0:1.6.012(04.190kW)(1603022015)\r\n1-0:1.6.013(03.764kW)(1602101845)\r\n1-0:1.6.014(03.768kW)(1601061730)\r\n1-0:1.6.015(03.806kW)(1512162045)\r\n1-0:1.8.001(0007904.135kWh)\r\n1-0:1.8.002(0007660.326kWh)\r\n1-0:1.8.003(0007371.517kWh)\r\n1-0:1.8.004(0007104.603kWh)\r\n1-0:1.8.005(0006820.722kWh)\r\n1-0:1.8.006(0006581.536kWh)\r\n1-0:1.8.007(0006334.294kWh)\r\n1-0:1.8.008(0006097.335kWh)\r\n1-0:1.8.009(0005862.843kWh)\r\n1-0:1.8.010(0005625.115kWh)\r\n1-0:1.8.011(0005358.178kWh)\r\n1-0:1.8.012(0005096.931kWh)\r\n1-0:1.8.013(0004800.953kWh)\r\n1-0:1.8.014(0004517.795kWh)\r\n1-0:1.8.015(0004224.392kWh)\r\n1-0:1.6.101(03.258kW)(1702102000)\r\n1-0:1.6.102(03.308kW)(1701261830)\r\n1-0:1.6.103(02.838kW)(1612232045)\r\n1-0:1.6.104(03.398kW)(1611161800)\r\n1-0:1.6.105(02.964kW)(1610132000)\r\n1-0:1.6.106(03.356kW)(1609131845)\r\n1-0:1.6.107(03.888kW)(1608051945)\r\n1-0:1.6.108(03.102kW)(1607272045)\r\n1-0:1.6.109(02.844kW)(1606152000)\r\n1-0:1.6.110(03.850kW)(1605172115)\r\n1-0:1.6.111(03.756kW)(1604021130)\r\n1-0:1.6.112(04.190kW)(1603022015)\r\n1-0:1.6.113(03.764kW)(1602101845)\r\n1-0:1.6.114(03.768kW)(1601061730)\r\n1-0:1.6.115(03.806kW)(1512162045)\r\n1-0:1.6.201()\r\n1-0:1.6.202()\r\n1-0:1.6.203()\r\n1-0:1.6.204()\r\n1-0:1.6.205()\r\n1-0:1.6.206()\r\n1-0:1.6.207()\r\n1-0:1.6.208()\r\n1-0:1.6.209()\r\n1-0:1.6.210()\r\n1-0:1.6.211()\r\n1-0:1.6.212()\r\n1-0:1.6.213()\r\n1-0:1.6.214()\r\n1-0:1.6.215()\r\n1-0:1.6.301()\r\n1-0:1.6.302()\r\n1-0:1.6.303()\r\n1-0:1.6.304()\r\n1-0:1.6.305()\r\n1-0:1.6.306()\r\n1-0:1.6.307()\r\n1-0:1.6.308()\r\n1-0:1.6.309()\r\n1-0:1.6.310()\r\n1-0:1.6.311()\r\n1-0:1.6.312()\r\n1-0:1.6.313()\r\n1-0:1.6.314()\r\n1-0:1.6.315()\r\n1-0:1.6.401()\r\n1-0:1.6.402()\r\n1-0:1.6.403()\r\n1-0:1.6.404()\r\n1-0:1.6.405()\r\n1-0:1.6.406()\r\n1-0:1.6.407()\r\n1-0:1.6.408()\r\n1-0:1.6.409()\r\n1-0:1.6.410()\r\n1-0:1.6.411()\r\n1-0:1.6.412()\r\n1-0:1.6.413()\r\n1-0:1.6.414()\r\n1-0:1.6.415()\r\n1-0:1.8.101(0007904.135kWh)\r\n1-0:1.8.102(0007660.326kWh)\r\n1-0:1.8.103(0007371.517kWh)\r\n1-0:1.8.104(0007104.603kWh)\r\n1-0:1.8.105(0006820.722kWh)\r\n1-0:1.8.106(0006581.536kWh)\r\n1-0:1.8.107(0006334.294kWh)\r\n1-0:1.8.108(0006097.335kWh)\r\n1-0:1.8.109(0005862.843kWh)\r\n1-0:1.8.110(0005625.115kWh)\r\n1-0:1.8.111(0005358.178kWh)\r\n1-0:1.8.112(0005096.931kWh)\r\n1-0:1.8.113(0004800.953kWh)\r\n1-0:1.8.114(0004517.795kWh)\r\n1-0:1.8.115(0004224.392kWh)\r\n1-0:1.8.201(0000000.000kWh)\r\n1-0:1.8.202(0000000.000kWh)\r\n1-0:1.8.203(0000000.000kWh)\r\n1-0:1.8.204(0000000.000kWh)\r\n1-0:1.8.205(0000000.000kWh)\r\n1-0:1.8.206(0000000.000kWh)\r\n1-0:1.8.207(0000000.000kWh)\r\n1-0:1.8.208(0000000.000kWh)\r\n1-0:1.8.209(0000000.000kWh)\r\n1-0:1.8.210(0000000.000kWh)\r\n1-0:1.8.211(0000000.000kWh)\r\n1-0:1.8.212(0000000.000kWh)\r\n1-0:1.8.213(0000000.000kWh)\r\n1-0:1.8.214(0000000.000kWh)\r\n1-0:1.8.215(0000000.000kWh)\r\n1-0:1.8.301(0000000.000kWh)\r\n1-0:1.8.302(0000000.000kWh)\r\n1-0:1.8.303(0000000.000kWh)\r\n1-0:1.8.304(0000000.000kWh)\r\n1-0:1.8.305(0000000.000kWh)\r\n1-0:1.8.306(0000000.000kWh)\r\n1-0:1.8.307(0000000.000kWh)\r\n1-0:1.8.308(0000000.000kWh)\r\n1-0:1.8.309(0000000.000kWh)\r\n1-0:1.8.310(0000000.000kWh)\r\n1-0:1.8.311(0000000.000kWh)\r\n1-0:1.8.312(0000000.000kWh)\r\n1-0:1.8.313(0000000.000kWh)\r\n1-0:1.8.314(0000000.000kWh)\r\n1-0:1.8.315(0000000.000kWh)\r\n1-0:1.8.401(0000000.000kWh)\r\n1-0:1.8.402(0000000.000kWh)\r\n1-0:1.8.403(0000000.000kWh)\r\n1-0:1.8.404(0000000.000kWh)\r\n1-0:1.8.405(0000000.000kWh)\r\n1-0:1.8.406(0000000.000kWh)\r\n1-0:1.8.407(0000000.000kWh)\r\n1-0:1.8.408(0000000.000kWh)\r\n1-0:1.8.409(0000000.000kWh)\r\n1-0:1.8.410(0000000.000kWh)\r\n1-0:1.8.411(0000000.000kWh)\r\n1-0:1.8.412(0000000.000kWh)\r\n1-0:1.8.413(0000000.000kWh)\r\n1-0:1.8.414(0000000.000kWh)\r\n1-0:1.8.415(0000000.000kWh)\r\n1-0:2.6.001(00.000kW)(1703010000)\r\n1-0:2.6.002(00.000kW)(1702010000)\r\n1-0:2.6.003(00.000kW)(1701010000)\r\n1-0:2.6.004(00.000kW)(1612010000)\r\n1-0:2.6.005(00.000kW)(1611010000)\r\n1-0:2.6.006(00.000kW)(1610010000)\r\n1-0:2.6.007(00.000kW)(1609010000)\r\n1-0:2.6.008(00.000kW)(1608010000)\r\n1-0:2.6.009(00.000kW)(1607010000)\r\n1-0:2.6.010(00.000kW)(1606010000)\r\n1-0:2.6.011(00.000kW)(1605010000)\r\n1-0:2.6.012(00.000kW)(1604010000)\r\n1-0:2.6.013(00.000kW)(1603010000)\r\n1-0:2.6.014(00.000kW)(1602010000)\r\n1-0:2.6.015(00.000kW)(1601010000)\r\n1-0:2.8.001(0000000.000kWh)\r\n1-0:2.8.002(0000000.000kWh)\r\n1-0:2.8.003(0000000.000kWh)\r\n1-0:2.8.004(0000000.000kWh)\r\n1-0:2.8.005(0000000.000kWh)\r\n1-0:2.8.006(0000000.000kWh)\r\n1-0:2.8.007(0000000.000kWh)\r\n1-0:2.8.008(0000000.000kWh)\r\n1-0:2.8.009(0000000.000kWh)\r\n1-0:2.8.010(0000000.000kWh)\r\n1-0:2.8.011(0000000.000kWh)\r\n1-0:2.8.012(0000000.000kWh)\r\n1-0:2.8.013(0000000.000kWh)\r\n1-0:2.8.014(0000000.000kWh)\r\n1-0:2.8.015(0000000.000kWh)\r\n1-0:2.6.101(00.000kW)(1703010000)\r\n1-0:2.6.102(00.000kW)(1702010000)\r\n1-0:2.6.103(00.000kW)(1701010000)\r\n1-0:2.6.104(00.000kW)(1612010000)\r\n1-0:2.6.105(00.000kW)(1611010000)\r\n1-0:2.6.106(00.000kW)(1610010000)\r\n1-0:2.6.107(00.000kW)(1609010000)\r\n1-0:2.6.108(00.000kW)(1608010000)\r\n1-0:2.6.109(00.000kW)(1607010000)\r\n1-0:2.6.110(00.000kW)(1606010000)\r\n1-0:2.6.111(00.000kW)(1605010000)\r\n1-0:2.6.112(00.000kW)(1604010000)\r\n1-0:2.6.113(00.000kW)(1603010000)\r\n1-0:2.6.114(00.000kW)(1602010000)\r\n1-0:2.6.115(00.000kW)(1601010000)\r\n1-0:2.6.201()\r\n1-0:2.6.202()\r\n1-0:2.6.203()\r\n1-0:2.6.204()\r\n1-0:2.6.205()\r\n1-0:2.6.206()\r\n1-0:2.6.207()\r\n1-0:2.6.208()\r\n1-0:2.6.209()\r\n1-0:2.6.210()\r\n1-0:2.6.211()\r\n1-0:2.6.212()\r\n1-0:2.6.213()\r\n1-0:2.6.214()\r\n1-0:2.6.215()\r\n1-0:2.6.301()\r\n1-0:2.6.302()\r\n1-0:2.6.303()\r\n1-0:2.6.304()\r\n1-0:2.6.305()\r\n1-0:2.6.306()\r\n1-0:2.6.307()\r\n1-0:2.6.308()\r\n1-0:2.6.309()\r\n1-0:2.6.310()\r\n1-0:2.6.311()\r\n1-0:2.6.312()\r\n1-0:2.6.313()\r\n1-0:2.6.314()\r\n1-0:2.6.315()\r\n1-0:2.6.401()\r\n1-0:2.6.402()\r\n1-0:2.6.403()\r\n1-0:2.6.404()\r\n1-0:2.6.405()\r\n1-0:2.6.406()\r\n1-0:2.6.407()\r\n1-0:2.6.408()\r\n1-0:2.6.409()\r\n1-0:2.6.410()\r\n1-0:2.6.411()\r\n1-0:2.6.412()\r\n1-0:2.6.413()\r\n1-0:2.6.414()\r\n1-0:2.6.415()\r\n1-0:2.8.101(0000000.000kWh)\r\n1-0:2.8.102(0000000.000kWh)\r\n1-0:2.8.103(0000000.000kWh)\r\n1-0:2.8.104(0000000.000kWh)\r\n1-0:2.8.105(0000000.000kWh)\r\n1-0:2.8.106(0000000.000kWh)\r\n1-0:2.8.107(0000000.000kWh)\r\n1-0:2.8.108(0000000.000kWh)\r\n1-0:2.8.109(0000000.000kWh)\r\n1-0:2.8.110(0000000.000kWh)\r\n1-0:2.8.111(0000000.000kWh)\r\n1-0:2.8.112(0000000.000kWh)\r\n1-0:2.8.113(0000000.000kWh)\r\n1-0:2.8.114(0000000.000kWh)\r\n1-0:2.8.115(0000000.000kWh)\r\n1-0:2.8.201(0000000.000kWh)\r\n1-0:2.8.202(0000000.000kWh)\r\n1-0:2.8.203(0000000.000kWh)\r\n1-0:2.8.204(0000000.000kWh)\r\n1-0:2.8.205(0000000.000kWh)\r\n1-0:2.8.206(0000000.000kWh)\r\n1-0:2.8.207(0000000.000kWh)\r\n1-0:2.8.208(0000000.000kWh)\r\n1-0:2.8.209(0000000.000kWh)\r\n1-0:2.8.210(0000000.000kWh)\r\n1-0:2.8.211(0000000.000kWh)\r\n1-0:2.8.212(0000000.000kWh)\r\n1-0:2.8.213(0000000.000kWh)\r\n1-0:2.8.214(0000000.000kWh)\r\n1-0:2.8.215(0000000.000kWh)\r\n1-0:2.8.301(0000000.000kWh)\r\n1-0:2.8.302(0000000.000kWh)\r\n1-0:2.8.303(0000000.000kWh)\r\n1-0:2.8.304(0000000.000kWh)\r\n1-0:2.8.305(0000000.000kWh)\r\n1-0:2.8.306(0000000.000kWh)\r\n1-0:2.8.307(0000000.000kWh)\r\n1-0:2.8.308(0000000.000kWh)\r\n1-0:2.8.309(0000000.000kWh)\r\n1-0:2.8.310(0000000.000kWh)\r\n1-0:2.8.311(0000000.000kWh)\r\n1-0:2.8.312(0000000.000kWh)\r\n1-0:2.8.313(0000000.000kWh)\r\n1-0:2.8.314(0000000.000kWh)\r\n1-0:2.8.315(0000000.000kWh)\r\n1-0:2.8.401(0000000.000kWh)\r\n1-0:2.8.402(0000000.000kWh)\r\n1-0:2.8.403(0000000.000kWh)\r\n1-0:2.8.404(0000000.000kWh)\r\n1-0:2.8.405(0000000.000kWh)\r\n1-0:2.8.406(0000000.000kWh)\r\n1-0:2.8.407(0000000.000kWh)\r\n1-0:2.8.408(0000000.000kWh)\r\n1-0:2.8.409(0000000.000kWh)\r\n1-0:2.8.410(0000000.000kWh)\r\n1-0:2.8.411(0000000.000kWh)\r\n1-0:2.8.412(0000000.000kWh)\r\n1-0:2.8.413(0000000.000kWh)\r\n1-0:2.8.414(0000000.000kWh)\r\n1-0:2.8.415(0000000.000*kWh)\r\n"]
                        Fehlerausgabe:
                        ! 2017-03-18 20:25:46.063 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN HANDLEMESSAGE
                        ! 2017-03-18 20:25:46.090 - [31merror[39m: smartmeter.0 uncaught exception: Invalid Obis String 000
                        ! 1-0:0.9.1255
                        ! 2017-03-18 20:25:46.091 - [31merror[39m: smartmeter.0 Error: Invalid Obis String 000
                        ! 1-0:0.9.1
                        255
                        ! at new ObisMeasurement (/opt/iobroker/node_modules/smartmeter-obis/lib/ObisMeasurement.js:46:23)
                        ! at D0Protocol.prepareResult (/opt/iobroker/node_modules/smartmeter-obis/lib/protocols/D0Protocol.js:176:24)
                        ! at D0Protocol.handleMessage (/opt/iobroker/node_modules/smartmeter-obis/lib/protocols/D0Protocol.js:150:27)
                        ! at SerialPort. <anonymous>(/opt/iobroker/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:58:41)
                        ! at emitOne (events.js:96:13)
                        ! at SerialPort.emit (events.js:188:7)
                        ! at SerialPort.raw (/opt/iobroker/node_modules/serialport/lib/parsers.js:7:13)
                        ! at SerialPort._emitData (/opt/iobroker/node_modules/serialport/lib/serialport.js:313:18)
                        ! at SerialPort. <anonymous>(/opt/iobroker/node_modules/serialport/lib/serialport.js:293:14)
                        ! at SerialPort. <anonymous>(/opt/iobroker/node_modules/serialport/lib/serialport.js:306:7)
                        ! 2017-03-18 20:25:46.094 - [33mwarn[39m: smartmeter.0 Exception: Error: Invalid Obis String 000
                        ! 1-0:0.9.1*255
                        ! 2017-03-18 20:25:46.098 - [34mdebug[39m: smartmeter.0 SERIALPORT CLOSE[/spoiler]</anonymous></anonymous></anonymous>
                        EDIT:
                        Ich denke mal da liegt das Problem:
                        Mein Zähler sendet eine 3 stellige Zahl darf aber eigentlich nur 2 sein. Die 255 sendet der öfters mit.
                        Dort ist der Wert 255 beschrieben:
                        https://www.dvgw-sc.de/fileadmin/DVGW_S … en_Gas.pdf
                          apollon77 last edited by
                          Ja, checke ich.
                          Aber eine Frage: Klappt es jetzt auch ohne den baudrate-overwrite auf 300? WEil dein Logfile heisst so als ob du immer noch nur mit 300 baud fährst
                          Das mit der 255 ists nicht, die ist oft bei mehreren Zählern … zweistellig wäre "FF" hex was auch 255 sind 🙂
                            MichaelJaD last edited by
                            Ja ohne klappt nicht.
                            Gesendet von meinem SM-G930F mit Tapatalk
                              So, hab mir jetzt nochmal meine logs vom Smartmeter angesehen, der Fehler:
                              ! 2017-03-18 09:53:10.120 - [32minfo[39m: smartmeter.0 D0 Protocol E (@) not fully supported! Let us try it :-) Please contact the developer if you have problems 2017-03-18 09:53:50.357 - [31merror[39m: smartmeter.0 uncaught exception: No or too long answer from Serial Device after last request. 2017-03-18 09:53:50.377 - [31merror[39m: smartmeter.0 Error: No or too long answer from Serial Device after last request. at SerialRequestResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:245:11) at null._onTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:108:26) at Timer.listOnTimeout (timers.js:92:15) 2017-03-18 09:53:50.388 - [33mwarn[39m: smartmeter.0 Exception: Error: No or too long answer from Serial Device after last request. 2017-03-18 09:53:50.905 - [32minfo[39m: smartmeter.0 terminating 2017-03-18 09:53:50.940 - [31merror[39m: host.ioBroker-BPi instance system.adapter.smartmeter.0 terminated with code 0 (OK) 2017-03-18 09:53:50.942 - [32minfo[39m: host.ioBroker-BPi Restart adapter system.adapter.smartmeter.0 because enabled 2017-03-18 09:54:20.977 - [32minfo[39m: host.ioBroker-BPi instance system.adapter.smartmeter.0 started with pid 23891 2017-03-18 09:54:26.453 - [32minfo[39m: smartmeter.0 starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.8.0 2017-03-18 09:54:27.833 - [32minfo[39m: smartmeter.0 D0 Protocol E (@) not fully supported! Let us try it :-) Please contact the developer if you have problems 2017-03-18 09:55:08.087 - [31merror[39m: smartmeter.0 uncaught exception: No or too long answer from Serial Device after last request. 2017-03-18 09:55:08.105 - [31merror[39m: smartmeter.0 Error: No or too long answer from Serial Device after last request. at SerialRequestResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:245:11) at null._onTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:108:26) at Timer.listOnTimeout (timers.js:92:15) !
                              taucht bis jetzt gar nicht mehr auf, super!
                              Dafür wird in größeren Abständen der Fehler:
                              2017-03-18 14:59:27.962 - [31merror[39m: smartmeter.0 Error: Invalid Obis String gF.F
                              at new ObisMeasurement (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/ObisMeasurement.js:46:23)
                              at D0Protocol.prepareResult (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/protocols/D0Protocol.js:176:24)
                              at D0Protocol.handleMessage (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/protocols/D0Protocol.js:150:27)
                              at SerialPort. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:58:41)
                              at emitOne (events.js:77:13)
                              at SerialPort.emit (events.js:169:7)
                              at SerialPort.module.exports.raw (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/parsers.js:7:13)
                              at SerialPort._emitData (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:313:18)
                              at SerialPort. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:293:14)
                              at SerialPort. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:306:7)
                              2017-03-18 14:59:27.972 - [33mwarn[39m: smartmeter.0 Exception: Error: Invalid Obis String gF.F
                              2017-03-18 14:59:28.495 - [32minfo[39m: smartmeter.0 terminating
                              2017-03-18 14:59:28.535 - [31merror[39m: host.ioBroker-BPi instance system.adapter.smartmeter.0 terminated with code 0 (OK)
                              2017-03-18 14:59:28.538 - [32minfo[39m: host.ioBroker-BPi Restart adapter system.adapter.smartmeter.0 because enabled
                              2017-03-18 14:59:58.577 - [32minfo[39m: host.ioBroker-BPi instance system.adapter.smartmeter.0 started with pid 24308
                              2017-03-18 15:00:04.168 - [32minfo[39m: smartmeter.0 starting. Version 0.5.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.8.0
                              2017-03-18 15:00:05.544 - [32minfo[39m: smartmeter.0 D0 Protocol E (@) not fully supported! Let us try it 🙂 Please contact the developer if you have problems
                              2017-03-18 15:00:22.561 - [32minfo[39m: smartmeter.0 Received 351 values, 351 updated</anonymous></anonymous></anonymous>
                              angezeigt, der aber scheinbar keine negativen Auswirkungen auf die Daten hat. Vielleicht sagt dir das ja was.
                              Der obere Fehler erscheint übrigens seit dem gestrigen Update auf die 0.5.4?? nicht mehr!
                              Rappi
                                Es sind aktuell zwei Themen.
                                Der erste idt er mit "invalid OBis" wo vor der OBIS Nummer noch Daten stehe die da nicht hingehören. Die Kommen scheinbar aufrund der Timing-Änderunge mit dem Baudrate-Changeover zustande.
                                Ich hab aber schon ne Idee wie ich die wegbekomme bei mir umgesetzt..
                                Das zweite Fehler ist der (sobald das erste gelöst war) der Zähler von MichaelJaD mehrere Ergebnisse für einen OBIS-Wert anders zurückgibt als ich es bisher geshen hab 🙂
                                Das muss ich noch umbauen.
                                Spätestens sobald die Kinder im Bett sind sollte das aber nicht so lange dauern … also später heute Abend kommt ein Update der hoffentlich beides fixt.
                                  0.5.5 auf Github …
                                  @MichaelJaD: Bitte dann auch nochmal logs ohne den Baudrate-overwrite schicken ... vllt sehe ich ja noch was ... sollte an sich gehen das der schneller arbeitet
                                    Die Version läuft erstmal problemlos 😄 , mögliche Fehlermeldungen kann ich erst morgen berichten.
                                    Rappi
                                      Also erstmal ein großes DANKE!
                                      Es läuft jetzt. Ich bekomme die Daten[emoji4] [emoji1]
                                      Es läuft auch ohne Wert in Baudratechange! Wahrscheinlich war das ein anderes Problem.
                                      Wie sich die Geschwindigkeit verhält muss ich jetzt mal in Ruhe testen!
                                      Gruß Michael
                                        Gestern gegen 20:00 Uhr aktualisiert, von da an nur eine Fehlermeldung, die aber für mich kein Problem darstellte, aber trotzdem für dich zu Auswerten:
                                        ! 2017-03-19 20:32:22.479 - [32minfo[39m: smartmeter.0 D0 Protocol E (@) not fully supported! Let us try it :-) Please contact the developer if you have problems 2017-03-19 20:32:38.513 - [32minfo[39m: smartmeter.0 Received 351 values, 3 updated 2017-03-19 20:33:09.758 - [32minfo[39m: smartmeter.0 D0 Protocol E (@) not fully supported! Let us try it :-) Please contact the developer if you have problems 2017-03-19 20:33:10.844 - [33mwarn[39m: host.ioBroker-BPi instance system.adapter.smartmeter.0 terminated due to SIGILL 2017-03-19 20:33:10.846 - [31merror[39m: host.ioBroker-BPi instance system.adapter.smartmeter.0 terminated with code null () 2017-03-19 20:33:10.848 - [32minfo[39m: host.ioBroker-BPi Restart adapter system.adapter.smartmeter.0 because enabled 2017-03-19 20:33:40.884 - [32minfo[39m: host.ioBroker-BPi instance system.adapter.smartmeter.0 started with pid 26233 2017-03-19 20:33:46.493 - [32minfo[39m: smartmeter.0 starting. Version 0.5.5 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.8.0 2017-03-19 20:33:47.874 - [32minfo[39m: smartmeter.0 D0 Protocol E (@) not fully supported! Let us try it :-) Please contact the developer if you have problems 2017-03-19 20:34:05.241 - [32minfo[39m: smartmeter.0 Received 351 values, 351 updated !
                                        Rappi
                                          Hey,
                                          SIGILL sehe ich zwar zum ersten mal, aber am Ende das gleiche wie SIGABRT und SIGSEGV … scheinbar ist das Speichermanagement von nodejs an der Stelle manchmal komisch ... Ich hab aufgegeben den Grund zu finden. Adapter wird neugestartet von ioBroker und damit gut ... man verliert maximal eine Minute oder so.
                                          Aber Danke für die Meldung!
                                            Also jetzt scheint alles zu laufen 🙂 Sogar mit Baudrate 9600 🙂
                                            Habe diese auf 9600 gestellt. Und die Daten waren bereits nach 13s da 🙂
                                            smartmeter.0 2017-03-21 12:57:32.099 info Received 343 values, 343 updated
                                            smartmeter.0 2017-03-21 12:57:19.357 info starting. Version 0.5.5 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.10.0
                                            Besten Dank nochmal wir die schnelle Programmanpassung.
                                            Du kannst den Zähler MT 174 zur kompatiblen Liste hinzufügen.
                                            DucLE 1 Reply Last reply Reply Quote 0
                                            1.2k
                                            3625
                                            2359122
