    4. [Gelöst] IOT Pro Lizenz Problem
    • Bass-T
      Bass-T last edited by Bass-T
      Jetzt geht nichts mehr, ...
      host.iobroker
      2022-01-02 14:21:52.561	error	instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2022-01-02 14:21:52.561	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.iobroker
      2022-01-02 14:21:52.561	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.iobroker
      2022-01-02 14:21:52.561	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/remote.js:1:15)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
      host.iobroker
      2022-01-02 14:21:52.559	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
      host.iobroker
      2022-01-02 14:21:52.559	error	Caught by controller[0]: SyntaxError: Unexpected token '.'
      host.iobroker
      2022-01-02 14:21:52.559	error	Caught by controller[0]: ^
      host.iobroker
      2022-01-02 14:21:52.559	error	Caught by controller[0]: const networkInterfaces = obj?.native?.hardware?.networkInterfaces;
      host.iobroker
      2022-01-02 14:21:52.558	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.iot/lib/Utils.js:218
      Adapter wird nicht mehr grün und Anmeldedaten kann ich nicht mehr aktualisieren 😞
      URL Key in Datenpunkt bleibt bei (null)
      Auch nach sudo iobroker restart
        Thomas Braun Most Active last edited by Thomas Braun
        @bass-t sagte in IOT Pro Lizenz Problem:
        Wird ja auch nicht per sudo gemacht.
        iobroker stop
        iobroker fix
        iobroker start
        Bass-T 1 Reply Last reply Reply Quote 0
        • Bass-T
          Bass-T @Thomas Braun last edited by
          iobroker stop
          iobroker fix
          iobroker start
          gemacht, aber fehler bleibt 😞
          muss heute abend nochmal versuchen den iot richtig zu installieren.
            Thomas Braun Most Active @Bass-T last edited by
            Das war auch nicht anders zu erwarten.
            • Bass-T
              @thomas-braun sagte in IOT Pro Lizenz Problem:
              LOL 🤣
                apollon77 @Bass-T last edited by
                @bass-t Wie haste denn das jetzt hinbekommen? Welche nodejs Version?
                • Bass-T
                  Bass-T @apollon77 last edited by
                  @apollon77 sagte in IOT Pro Lizenz Problem:
                  v12.22.8
                  bin noch nicht dazu gekommen auf 14 zu upgraden, ... sry
                  J apollon77 2 Replies Last reply Reply Quote 0
                    Jan1 @Bass-T last edited by
                    @bass-t
                    das dauert keine 5 Minuten 😉
                      @bass-t Alles gut.
                      ich wrde jetzt mal folgendes tun:kopier idir die iot Einstellungen, dann deinstallierst du die Instanz UND den Adapter. Danach neu installieren und neu einrichten. Dann Skill neu verknüpfen. Tut es so?
                      • Meister Mopper
                        Meister Mopper last edited by
                        @bass-t Tatsächlich hatte ich das auch nach der Verlängerung der Pro-Lizenz.
                        Ich habe allerdings keine certs oder Ähnliches neu angefordert und musste lediglich im google home assistant die Verbindung zum ioBroker erneuern (reconnect account) und mit den alten Zugangsdaten bestätigen.
                        Das ist die übliche Vorgehensweise nach einer Verlängerung.
                          Jan1 @Meister Mopper last edited by
                          @meister-mopper
                          betrifft das nur Google? Ich habe Alexa und musst da noch nie was machen.
                          • Meister Mopper
                            Meister Mopper @Jan1 last edited by
                            @jan1 sagte in IOT Pro Lizenz Problem:
                            K. A. ich hatte bisher nur google. Es passierte aber im vorvorigen Jahr genau so.
                              @meister-mopper
                              Ich habe diesmal wegen nem Hänger am PC versehentlich gleich zwei mal verlängert und lief einfach alles weiter wie vorher auch. Jetzt habe ich halt für 2 Jahre ne Lizenz 🙂
                              Bass-T haselchen 2 Replies Last reply Reply Quote 0
                              • Bass-T
                                Bass-T @Jan1 last edited by
                                Bin leider gerade unterwegs. Werde das alles heute abend in ruhe versuchen.
                                • haselchen
                                  haselchen Most Active @Jan1 last edited by
                                  @jan1
                                  Gibt schlimmeres 😂
                                  • Bass-T
                                    Bass-T @apollon77 last edited by Bass-T
                                    @bass-t Alles gut.
                                    Genau das war auch meine idee, jedoch führte genau das zu den Fehlern in Post #15 (v1.8.25)
                                      @bass-t Also eine Neuinstallation der iot Adapters führt zu dem Problem das es nicht mehr tut?
                                        Bitte nimm iot 1.8.24 ... ich glaube die 25 hat da ein Issue mit nodejs 12
                                        Thomas Braun apollon77 2 Replies Last reply Reply Quote 1
                                          Thomas Braun Most Active @apollon77 last edited by
                                          node 12
                                          @Bass-T
                                          Oder gleich den Sprung auf node14 machen. Ist ja eh die empfohlene Version.
                                            apollon77 @apollon77 last edited by
                                            @apollon77 STOP!!!
                                            1.8.25 ist nicht das Problem ... wie hast du iot denn neu installiert? Sag bitte nicht über GitHub? Das wäre dann der Fehler. Nimm die 1.8.25 ganz normal
                                            lizenz iobroker
                                            3163
