    4. Test Adapter EnOcean v0.5.x
    • michif100
      michif100 @Jey Cee last edited by
      @jey-cee Ich verwende Komma. War von Beginn an so eingestellt.
      Habe eben zum test mal iobroker neugestartet und mir dann den LOG dazu angeschaut. Es soll auch immer der Enocean Adapter nue aufgebaut werden. Nach einem Adapter Update verstehe ich das ja, das wurde aber ja nun schon gemacht, und es wird trotzdem ein Rebuild angestoßen:
      host.ubuntu-20-lts-vm
      2022-01-02 18:13:20.465	error	instance system.adapter.enocean.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2022-01-02 18:13:20.465	error	Caught by controller[0]: }
      2022-01-02 18:13:20.465	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      2022-01-02 18:13:20.465	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
      2022-01-02 18:13:20.465	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      2022-01-02 18:13:20.465	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      2022-01-02 18:13:20.465	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
      2022-01-02 18:13:20.465	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
      2022-01-02 18:13:20.464	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
      2022-01-02 18:13:20.464	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      2022-01-02 18:13:20.464	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      2022-01-02 18:13:20.464	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      2022-01-02 18:13:20.464	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
      2022-01-02 18:13:20.464	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      2022-01-02 18:13:20.464	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
      2022-01-02 18:13:20.464	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
      2022-01-02 18:13:20.464	error	Caught by controller[0]: was compiled against a different Node.js version using
      2022-01-02 18:13:20.463	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
      2022-01-02 18:13:20.463	error	Caught by controller[0]: ^
      2022-01-02 18:13:20.463	error	Caught by controller[0]: throw e;
      2022-01-02 18:13:20.463	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
      • Jey Cee
        Jey Cee Developer @michif100 last edited by
        @michif100 dann ist das Problem das der rebuild vom adapter nicht klappt.
        michif100 2 Replies Last reply Reply Quote 0
        • michif100
          @jey-cee Adapter löschen und neu installieren? Kann ich meine Geräte vorher exportieren, oder muss ich die wieder neu anlegen?
          • michif100
            @jey-cee Eben mal den Adapter komplett gelöscht und versucht neu zu installieren:
            $ iobroker url https://github.com/Jey-Cee/ioBroker.enocean --host ubuntu-20-lts-vm --debug
            install Jey-Cee/ioBroker.enocean#b8dd92c56002e1d2ef27e25c4e92c33149461149
            NPM version: 6.14.15
            npm install Jey-Cee/ioBroker.enocean#b8dd92c56002e1d2ef27e25c4e92c33149461149 --prefix "/opt/iobroker" (System call)
            npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            + iobroker.enocean@0.6.0updated 1 package in 8.065s
            45 packages are looking for funding run `npm fund` for details
            upload [6] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/words.js words.js application/javascript
            upload [5] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/style.css style.css text/css
            upload [4] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/index_m.html index_m.html text/html
            upload [3] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/github.js github.js application/javascript
            upload [2] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/enocean.png enocean.png image/png
            upload [1] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/components.js components.js application/javascript
            upload [0] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/admin.d.ts admin.d.ts video/mp2t
            Process exited with code 0
            • Jey Cee
              @michif100 du kannst die Objekte exportieren und später wieder importieren, dann kannst du dir das neu anlernen Sparen.
              michif100 1 Reply Last reply Reply Quote 0
              • michif100
                @jey-cee Habe ich gemacht, aber jetzt bekomme ich den Adapter gar nicht mehr installiert, weder 0.5.4 noch 0.6.0, siehe oben...
                • Jey Cee
                  @michif100 versteh ich nicht, die Installation zeigt keine Fehler.
                  Hast du den auch eine Instanz hinzugefügt?
                  • michif100
                    @jey-cee Ähm doch, exited with code 0 ?
                    Oder habe ich da etwa sfalsch verstanden. Über die Admin Oberfläche kann ich jedenfalls kein Instanz erstellen. Muss ich das über die Konsole machen?
                    • Jey Cee
                      Exit code 0 bedeutet keine Fehler.
                      Im Adapter Tab siehst du den Adapter mit der Installierten Version. Dort kannst du mit dem + eine Instanz hinzufügen.
                        Homoran Global Moderator Administrators @Jey Cee last edited by
                        @jey-cee sagte in Test Adapter EnOcean v0.5.x:
                        @michif100
                        https://www.iobroker.net/de/tutorial/media/Instance_new.gif
                        • michif100
                          michif100 @Homoran last edited by michif100
                          @homoran said in Test Adapter EnOcean v0.5.x:
                          @michif100
                          So kannte ich das eigentlich auch, war aber nichts da. Nach nochmaligem Neustart war der Adapter nun zu sehen, ich konnte eine Instanz erstellen und nun funktioniert alles wieder!! Tausend Dank!
                          @Jey-Cee P.S.: Ich stelle dir gerne einen Afriso CO2 Sensor zur Verfügung, wenn du denn implementieren kannst.
                          Ich meine, dass der auch recht gut dokumentiert ist.
                          Bei Bedarf gerne PM.
                          • Jey Cee
                            Ab sofort geht es Hier mit der version 0.6.1 weiter.
                            31.7k
                            79.8k
                            enocean enocean adapter
                            13
                            90
                            8006
