    4. Test Adapter EnOcean v0.5.x
    • Jey Cee
      Jey Cee Developer @michif100 last edited by
      @michif100 dann ist das Problem das der rebuild vom adapter nicht klappt.
      michif100 2 Replies Last reply Reply Quote 0
      • michif100
        michif100 @Jey Cee last edited by
        @jey-cee Adapter löschen und neu installieren? Kann ich meine Geräte vorher exportieren, oder muss ich die wieder neu anlegen?
        • michif100
          @jey-cee Eben mal den Adapter komplett gelöscht und versucht neu zu installieren:
          $ iobroker url https://github.com/Jey-Cee/ioBroker.enocean --host ubuntu-20-lts-vm --debug
          install Jey-Cee/ioBroker.enocean#b8dd92c56002e1d2ef27e25c4e92c33149461149
          NPM version: 6.14.15
          npm install Jey-Cee/ioBroker.enocean#b8dd92c56002e1d2ef27e25c4e92c33149461149 --prefix "/opt/iobroker" (System call)
          npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          + iobroker.enocean@0.6.0updated 1 package in 8.065s
          45 packages are looking for funding run `npm fund` for details
          upload [6] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/words.js words.js application/javascript
          upload [5] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/style.css style.css text/css
          upload [4] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/index_m.html index_m.html text/html
          upload [3] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/github.js github.js application/javascript
          upload [2] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/enocean.png enocean.png image/png
          upload [1] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/components.js components.js application/javascript
          upload [0] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/admin.d.ts admin.d.ts video/mp2t
          Process exited with code 0
          • Jey Cee
            @michif100 du kannst die Objekte exportieren und später wieder importieren, dann kannst du dir das neu anlernen Sparen.
            michif100 1 Reply Last reply Reply Quote 0
            • michif100
              @jey-cee Habe ich gemacht, aber jetzt bekomme ich den Adapter gar nicht mehr installiert, weder 0.5.4 noch 0.6.0, siehe oben...
              • Jey Cee
                @michif100 versteh ich nicht, die Installation zeigt keine Fehler.
                Hast du den auch eine Instanz hinzugefügt?
                • michif100
                  @jey-cee Ähm doch, exited with code 0 ?
                  Oder habe ich da etwa sfalsch verstanden. Über die Admin Oberfläche kann ich jedenfalls kein Instanz erstellen. Muss ich das über die Konsole machen?
                  • Jey Cee
                    Exit code 0 bedeutet keine Fehler.
                    Im Adapter Tab siehst du den Adapter mit der Installierten Version. Dort kannst du mit dem + eine Instanz hinzufügen.
                      Homoran Global Moderator Administrators @Jey Cee last edited by
                      @jey-cee sagte in Test Adapter EnOcean v0.5.x:
                      @michif100
                      https://www.iobroker.net/de/tutorial/media/Instance_new.gif
                      • michif100
                        michif100 @Homoran last edited by michif100
                        @homoran said in Test Adapter EnOcean v0.5.x:
                        @michif100
                        So kannte ich das eigentlich auch, war aber nichts da. Nach nochmaligem Neustart war der Adapter nun zu sehen, ich konnte eine Instanz erstellen und nun funktioniert alles wieder!! Tausend Dank!
                        @Jey-Cee P.S.: Ich stelle dir gerne einen Afriso CO2 Sensor zur Verfügung, wenn du denn implementieren kannst.
                        Ich meine, dass der auch recht gut dokumentiert ist.
                        Bei Bedarf gerne PM.
                        • Jey Cee
                          Ab sofort geht es Hier mit der version 0.6.1 weiter.
                          31.7k
                          79.8k
                          enocean enocean adapter
                          13
                          90
                          8007
