    • dslraser
      dslraser Forum Testing Most Active @metaxa last edited by
      @metaxa sagte in Test Adapter iQontrol 1.11.x Vis:
      Bitte ja, ich kriegs nicht zum Laufen, hab irgendwo einen Knopf.
       <block type="create" id="[LG$x7#Y7|~[O61,y$~3" x="-12" y="-363">
         <field name="NAME">0_userdata.0.TV_System.Sendung_Laufzeit_State</field>
           <block type="text" id="7Dr}3NQ$F[XDH7fR6-{r">
             <field name="TEXT">leer</field>
         <value name="COMMON">
           <block type="text" id="9eCdVHO5F`:B1II1TlY@">
             <field name="TEXT">{"role":"html","type":"string","read": true,"write": false,"name":"Sendung_Laufzeit_State"}</field>
           <block type="comment" id="8x!.9/=3d`N:9asS6|6t">
             <field name="COMMENT">für Title iQontrol</field>
           <block type="create" id="qPwzf!p(SYPjhG[zJtR0">
             <field name="NAME">0_userdata.0.TV_System.Sendung_Laufzeit_Additional_Info</field>
               <block type="text" id="dmRV[:WHaQPFSEY4kt8B">
               <block type="text" id="0OMs-Qi;]m$;.H{1cOaq">
                 <field name="TEXT">{"role":"html","type":"string","read": true,"write": false,"name":"Sendung_Laufzeit_Additional_Info"}</field>
               <block type="comment" id="p+WGXH?`Y7$Y,[uxT7y_">
                 <field name="COMMENT">Additional_Info</field>
               <block type="create" id="k+fwhGp9KEt*uv95m%08">
                 <field name="NAME">0_userdata.0.TV_System.Sendung_Laufzeit_Badge</field>
                   <block type="text" id="qe6Fs_xv1Tb7y]r+_D~k">
                   <block type="text" id="H.coc4AsRqyNEC[vDQ~`">
                     <field name="TEXT">{"role":"html","type":"string","read": true,"write": false,"name":"Sendung_Laufzeit_Badge"}</field>
                   <block type="comment" id="d_#wrYI+:TJOa)QLHY/h">
                     <field name="COMMENT">Badge</field>
                   <block type="on_ext" id="%V3%d$Nc-G@6HhNtkh@E">
                     <value name="OID0">
                       <shadow type="field_oid" id="7svi@GvteoPD%X?,,[;@">
                         <field name="oid">enigma2.0.enigma2.EVENTREMAINING_MIN</field>
                     <value name="OID1">
                       <shadow type="field_oid" id="9E_(4}]bYX:p/KIlv(8i">
                         <field name="oid">enigma2.0.enigma2.PROGRAMM</field>
                       <block type="comment" id="%:shuwC$*L|hSgM,,HXu">
                         <field name="COMMENT">State</field>
                           <block type="update" id=".v0*%_=|us6:i=a/QNnY">
                             <field name="OID">0_userdata.0.TV_System.Sendung_Laufzeit_State</field>
                               <block type="logic_ternary" id="s`K4kn_^n_-u3{GAw0|n">
                                 <value name="IF">
                                   <block type="logic_negate" id="C4n~8X_Ic=y`hfhi?.fT">
                                     <value name="BOOL">
                                       <block type="get_value" id="9wK1GF1,Grl3nd;biA|:">
                                         <field name="OID">enigma2.0.enigma2.STANDBY</field>
                                 <value name="THEN">
                                   <block type="text_join" id="2E/m8@-77G!Y%nUJdaR_">
                                     <mutation items="15"></mutation>
                                     <value name="ADD0">
                                       <block type="text" id="~3:aJZ{CV?15Ds`h[6(0">
                                         <field name="TEXT">&lt;b&gt;Sendung:&lt;/b&gt; </field>
                                     <value name="ADD1">
                                       <block type="get_value" id="#)sh!MUL`tD3`lWA2%@^">
                                         <field name="OID">enigma2.0.enigma2.PROGRAMM</field>
                                     <value name="ADD2">
                                       <block type="text" id="Xe/k#e[VM^mCV(b[]1oY">
                                         <field name="TEXT">&lt;br&gt;&lt;/br&gt; </field>
                                     <value name="ADD3">
                                       <block type="text" id="%.nx4Ev=.D2W@G[4}Q@k">
                                         <field name="TEXT">&lt;b&gt;Beginn:&lt;/b&gt; </field>
                                     <value name="ADD4">
                                       <block type="get_value" id="`!yBQ%V~NolMrO8dNc]L">
                                         <field name="OID">enigma2.0.enigma2.EVENT_TIME_START</field>
                                     <value name="ADD5">
                                       <block type="text" id="k)`kg-3hBf/dI(TS/`a3">
                                         <field name="TEXT"> Uhr &lt;b&gt;Ende:&lt;/b&gt; </field>
                                     <value name="ADD6">
                                       <block type="get_value" id="uvu(LC*}Qm4{tPS`n7h)">
                                         <field name="OID">enigma2.0.enigma2.EVENT_TIME_END</field>
                                     <value name="ADD7">
                                       <block type="text" id=".(PEZ2QaA0uYcLcJaiZ}">
                                         <field name="TEXT"> Uhr </field>
                                     <value name="ADD8">
                                       <block type="text" id="pPO=lCPwC^eGRNAC6TFV">
                                     <value name="ADD9">
                                       <block type="text" id="rj)KYN*%7E!K|YgIlmSM">
                                         <field name="TEXT">&lt;b&gt;läuft noch:&lt;/b&gt; </field>
                                     <value name="ADD10">
                                       <block type="get_value" id="+8pda6?/`H:KL=plL8O.">
                                         <field name="OID">enigma2.0.enigma2.EVENTREMAINING_MIN</field>
                                     <value name="ADD11">
                                       <block type="text" id="X-1gp,k]fRrBxx6%#+%=">
                                         <field name="TEXT"> Minuten </field>
                                     <value name="ADD12">
                                       <block type="text" id="9;m@^,^%/#=W/D.yWv7o">
                                         <field name="TEXT">&lt;meter max="100" min="0" value="</field>
                                     <value name="ADD13">
                                       <block type="get_value" id="owc[$}wdg:)Ux23w#+(]">
                                         <field name="OID">enigma2.0.enigma2.EVENT_PROGRESS_PERCENT</field>
                                     <value name="ADD14">
                                       <block type="text" id="W?JaYWS=`IGWoB|NQ??B">
                                         <field name="TEXT">"&lt;/meter</field>
                                 <value name="ELSE">
                                   <block type="text" id="|]]M2r4{Bog{b$+UrpQ7">
                                     <field name="TEXT"></field>
                               <block type="comment" id=")}7a18]*OP?+?}s~:s-%">
                                   <block type="update" id="=f}MqLi,lt|hmI~]saRX">
                                     <field name="OID">0_userdata.0.TV_System.Sendung_Laufzeit_Additional_Info</field>
                                       <block type="logic_ternary" id="w={uCm#,5q@9UfHP7t;1">
                                         <value name="IF">
                                           <block type="logic_negate" id="yp]YQWwKGn@;Si.`5OcU">
                                             <value name="BOOL">
                                               <block type="get_value" id="+W3Kq9sJ4.[B;yOA527O">
                                         <value name="THEN">
                                           <block type="text_join" id="*u,Zq(B^bbWpDj1wrTo0">
                                             <mutation items="10"></mutation>
                                             <value name="ADD0">
                                               <block type="get_value" id="yj,1hw6XVaf!E+H!nSR|">
                                             <value name="ADD1">
                                               <block type="text" id="{M6eEcfx*iBkUg}N?I?z">
                                             <value name="ADD2">
                                               <block type="get_value" id=",CBLy?Zc)@T1n`0(jZfg">
                                             <value name="ADD3">
                                               <block type="text" id="#IDcb7M/:Tvbmta/Z!1x">
                                             <value name="ADD4">
                                               <block type="text" id="uH,o0t9i3V6yTSGMo5Gx">
                                             <value name="ADD5">
                                               <block type="get_value" id="fqvWs}K1gfojj8^Gw?eF">
                                             <value name="ADD6">
                                               <block type="text" id=";tBl,[G[S(b#*|2Wkry6">
                                             <value name="ADD7">
                                               <block type="text" id=")5=uinWm{7E({E4{A~o8">
                                             <value name="ADD8">
                                               <block type="get_value" id="BMd7R=*z^PpCQrSAtSNW">
                                             <value name="ADD9">
                                               <block type="text" id="~L;(nC-r`uagky#k.nyj">
                                         <value name="ELSE">
                                           <block type="text" id="aG]mfoH^7yq2`3YrM4q|">
                                       <block type="comment" id="N?0n`s2a_bbm=cq.+*,p">
                                           <block type="update" id="i.w3/+S[Z71ztA6(GCIZ">
                                             <field name="OID">0_userdata.0.TV_System.Sendung_Laufzeit_Badge</field>
                                               <block type="text_join" id="g6bG7;v%XO?Rprb362*{">
                                                 <value name="ADD0">
                                                   <block type="logic_ternary" id=":x-KOEd;m0Cr%S~mJm:U">
                                                     <value name="IF">
                                                       <block type="logic_negate" id="QwHE;jKo|+Jr$@+8~3U$">
                                                         <value name="BOOL">
                                                           <block type="get_value" id="n6kP^:cQqpc7gYDlf)y)">
                                                     <value name="THEN">
                                                       <block type="text_join" id="2q54*JT^J%e0|rZc6^G;">
                                                         <value name="ADD0">
                                                           <block type="text" id="/uDB5yA{fZFGb}.Gi}Ww">
                                                             <field name="TEXT">&lt;meter max=100 min=0 value=</field>
                                                         <value name="ADD1">
                                                           <block type="get_value" id="^Th!HE._fe]^+6W,x0W3">
                                                         <value name="ADD2">
                                                           <block type="text" id="rZV2AE9maCJ6xx@@?R/!">
                                                             <field name="TEXT"> style="max-width:100%; max-width:calc(100% - 6px);"&gt;&lt;/meter&gt;</field>
                                                     <value name="ELSE">
                                                       <block type="text" id="};[sn?X*st4-p~,[LCvn">
      2022-01-02_iqontrol_0_selected_views.json
      metaxa 1 Reply Last reply Reply Quote 0
      • dslraser
        @dslraser sagte in Test Adapter iQontrol 1.11.x Vis:
        Wenn es damit noch nicht geht mache ich Dir einen Export meiner View
        Aber bitte keine Eile, hte werde ich nimma viel tun.
        An dieser Stelle: Danke @dslraser für deine Geduld!
        Wenn ich das Bild sehe, dann steht da noch die Bezeichnug Deines Gerätes in der Kachel ? Dann passt der Link nicht der da rein muss. Hast Du vielleicht mehrere Instanzen vom Enigma2 Adapter ?
        • s.bormann
          s.bormann Most Active @dslraser last edited by s.bormann
          In der aktuellen Github gibts auch einen neuen Knopf, um die Geräte-Optionen zu Ex- und Importieren. Damit könnt ihr ggf. die funktionierenden Einstellungen untereinander tauschen. Findet sich ganz unten in den Geräteeinstellungen:
          dslraser metaxa 3 Replies Last reply Reply Quote 1
          • dslraser
            Da habe ich "false" drinnen stehen, weil sonst wäre ja bei StandBy die Kachel aktiv
            Da hast Du zwar recht, aber bei mir stimmt es trotzdem so rum. (keine Ahnung warum ich das mal gemacht habe)
            • dslraser
              dslraser Forum Testing Most Active @s.bormann last edited by dslraser
              @s-bormann
              eine Frage, der Enigma2 Adapter pollt in regelmäßigen Abständen, dann ist für einen Mini Moment des Icon oben links weg und gleich wieder da. Das macht der Rest der Kachel nicht, obwohl die Daten auch vom Enigma2 Adapter kommen. Ich haben den Datenpunkt mal geloggt, der wird wirklich nur aktualisiert und nicht geändert. Liegt das an iQontrol ?
              Das RTL Logo meine ich (Beispiel)
              Edit: hier passiert das nicht: (Kachel aufgeklickt)
              dort ist es auch so.
              • dslraser
                @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis:
                @metaxa
                2022-01-02_iqontrol_0_options.json
                • s.bormann
                  @s-bormann
                  Hast Du das mal versucht?:
                  • dslraser
                    ja, bringt leider nichts. Hier findet anscheinend der "ständige" Reload statt.
                    • s.bormann
                      hast Du das Icon mittels Variable eingebunden (also |{enigma-icon-datenpunkt}-Schreibweise)?
                      Und was hast Du bei COVER_IMAGE angegeben?
                      Und die URL im Datenpunkt von enigma ist auch nicht kurz weg und kommt dann mit dem gleichen Wert wieder (könnte man prüfen mit last-change und timestamp des Datenpunktes - bei einer reinen Aktualisierung wird nur der timestamp neu gesetzt, der last-change bleibt aber gleich)?
                      • dslraser
                        Ja, ich habe das da drinn stehen. (Gerätename)
                        |Wohnzimmer: {enigma2.0.enigma2.CHANNEL}
                        Icon
                        |{0_userdata.0.TV_System.Picon_Pfad_USB}
                        Es wird nur der Zeitstempel neu gesetzt
                        Edit:
                        Der Rest ist ja ein zusammengesetztes HTML, da ändern sich die Werte natürlich. Also läuft noch und der Balken usw.
                        Das Picon bleibt auch gleich, wenn man nicht umschaltet.(Zeitstempel/Änderung)
                        Ich denke die ganze Kachel macht einen Reload, nur bei der Schrift sieht man es nicht….?
                        Sieht übrigens so aus
                        IMG_0491.MOV
                        Edit: Ich denke es liegt hier drann...Wenn ich ein Bild als Icon verlinke (nicht dynamisch) sieht man keinen Reload, auch in der Entwicklerkonsole nicht. Sobald ich diese Einstellung habe, dann ist der Reload da.
                        Das geschieht dann fortlaufend:
                        Force reload of image
                        index.js:7231 Set new variable image: http://192.168.1.53/media/usb/picon/1_0_1_30_5_85_C00000_0_0_0.png?forceReload = 16412063177
                        • metaxa
                          metaxa @s.bormann last edited by
                          Lieben Dank, ich scheitere allerdings schon am Filedownload (von @dslraser) hier aus dem Forum heraus, "Ziel speichern unter ..." wird mir im Contextmenü von Edge leider nicht angeboten. Beim Klick geht mein Text-Editor auf und ich kann das ganze rauskopieren, in eine eigene Datei einfügen, nach dem bestätigten Import der Eigenschaften waren aber keine Änderungen ersichtlich. Der View-Import hat wie gewohnt sofort funktioniert und reichte mir in diesem Fall.
                          LG, mxa
                          • metaxa
                            metaxa @dslraser last edited by
                            Lieben Dank, das hat mir nicht nur bei der dynamischen Gestaltung geholfen sondern auch sehr viele Ahaaa..-Erlebnisse bei Remote und wie man Sender darstellt und auswählt.
                            Da kann ich leider noch nicht mitreden, bei mir wird nix (nur broken image) angezeigt.
                            67ae1836-8aa0-4c61-9e7e-55f5c7c9eea7-image.png 68ddf341-ad1e-4b2f-be6a-2295b34b1855-image.png
                            http://192.168.0.58:80/picon/1_0_19_1330_3EF_1_C00000_0_0_0.png
                            LG, mxa
                            • dslraser
                              dslraser Forum Testing Most Active @metaxa last edited by dslraser
                              @metaxa
                              ich habe meine picon url ohne port :80 erstellt, auch wenn das original eine hat.
                              Edit: wenn Du Deinen Picon Link in den Browser kopierst, öffnet sich dann das passende Picon ?
                              Hier sieht man auch ob das Bild da ist
                              Open WebIF am iPhone
                              metaxa 2 Replies Last reply Reply Quote 0
                              • metaxa
                                ich jabe meine picon url ohne port :80 erstellt, auch wenn das original eine hat.
                                Leider nein 😞
                                http://192.168.0.58/picon/1_0_19_1330_3EF_1_C00000_0_0_0.png
                                Im Browser tuts mit/ohne Port:
                                Gibt es Einschränkungen beim Format @s-bormann ?
                                dslraser s.bormann 2 Replies Last reply Reply Quote 0
                                • metaxa
                                  Siehe oben, hat sich überschnitten.
                                  Direkt der Enigma DP funktioniert einwandfrei in meiner alten undynamischen Ansicht,
                                  • dslraser
                                    @metaxa
                                    nur um Tippfehler zu vermeiden, ich kopiere den Link der ID immer an dieser Stelle mit dem Klick auf das „zwei Blätter“ Symbol in die Zwischenablage und füge Ihn dann in iQontrol ein.
                                    Edit: Bild vergessen
                                    • metaxa
                                      @dslraser
                                      Detto, so mache sich es auch.
                                      • dslraser
                                        @metaxa
                                        hm, dann gehen mir im Moment die Ideen aus….
                                        @s-bormann ist die Bildgröße eventuell entscheidend bzw begrenzt ? (Picons gibt es in vielen Größen und Formaten/Formen)
                                        @metaxa
                                        Edit: übrigens habe ich mir noch „danach“ eingefügt.
                                        siehe hier im Beitrag, im Bild oder Video.
                                        https://forum.iobroker.net/post/732271
                                        Edit: steht denn der passende Link in der Entwicklerkonsole (ich nehme Chrome) wenn Du auf der View mit/in der Konsole ?
                                        • metaxa
                                          @dslraser @s-bormann
                                          mein Originalpicon
                                          • dslraser
                                            @metaxa
                                            ich habe eben über Deinem Beitrag nochmal editiert, gesehen ?
                                            296
                                            7637
                                            6947957
