    • BananaJoe
      BananaJoe Most Active @AlexHO last edited by
      @alexho coole Idee!
      • MichMein
        MichMein @Simes62 last edited by
        @simes62
        Hi, hier hat@jomjol einen Adapterring mit Aussparung zur Verfügung gestellt, diesen habe ich verwendet.
        • Andreas_Z
          Andreas_Z last edited by Andreas_Z
          @jomjol
          Ich hätte da noch einen weiteren Interessanten Fehler:
          mqtt.1	2022-01-02 21:36:56.202	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          mqtt.1	2022-01-02 19:44:17.605	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          mqtt.1	2022-01-02 18:41:14.522	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 18:36:23.759	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 18:31:32.678	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 18:26:41.703	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 18:21:23.913	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 18:16:32.771	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 18:11:41.903	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 18:06:50.754	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 18:01:59.758	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:57:09.044	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:52:17.754	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:47:26.849	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:42:35.905	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:37:12.179	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:32:21.008	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:27:29.951	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:22:39.043	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:17:48.147	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:12:56.814	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:08:05.759	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 17:03:15.105	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:58:24.006	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:53:33.176	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:43:06.194	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:38:15.114	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:33:24.050	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:28:33.292	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:23:42.145	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:18:51.085	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:14:00.206	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:09:09.302	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 16:04:18.218	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 15:44:54.267	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 15:40:03.161	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 15:35:12.249	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 15:30:21.306	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 15:25:30.239	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 15:20:39.243	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "string" but received type "number"
          mqtt.1	2022-01-02 14:46:57.126	info	send2Server mqtt.1.awtrix.notify[awtrix/notify]
          mqtt.1	2022-01-02 14:46:52.131	info	send2Server mqtt.1.awtrix.notify[awtrix/notify]
          mqtt.1	2022-01-02 14:07:25.489	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          mqtt.1	2022-01-02 09:48:52.413	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          mqtt.1	2022-01-02 08:45:49.740	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          mqtt.1	2022-01-02 05:48:51.180	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          mqtt.1	2022-01-02 05:11:43.492	info	send2Server mqtt.1.awtrix.customapp[awtrix/customapp]
          mqtt.1	2022-01-02 05:01:43.493	info	send2Server mqtt.1.awtrix.customapp[awtrix/customapp]
          mqtt.1	2022-01-02 03:12:04.256	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          mqtt.1	2022-01-02 03:07:13.467	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          mqtt.1	2022-01-02 02:47:49.248	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          mqtt.1	2022-01-02 02:42:58.285	info	State value to set for "mqtt.1.gaszaehler.main.raw" has to be type "number" but received type "string"
          Mal darfs "number" sein und dann wieder "string". Kein Reboot in dem Zeitraum laut Log
            jomjol @Andreas_Z last edited by
            @alexho sagte in Wasserzähler - Version 2 - all-in-device:
            @steffi
            Das Problem mit Spiegelung konnte ich mit Hilfe der "Einleger aus 3D Drucker" in Griff bekommen.
            Das Problem kommt daher, dass seit Version 10 bei einem fehlerhaften Wert kein Value übertragen wird, sondern ein leerer String: "". Wenn jemand eine bessere Idee hat, bitte gerne melden. Das scheint bei mehrerer zu Verwirrung zu führen.
            • Hasont
              Hasont last edited by Hasont
              @jomjol
              Hallo und gesundes neues Jahr.
              Ich hab zum Jahreswechsel meinen Gas und Wasserzähler von 6.4 auf 10.2 upgedatet.
              Wasser läuft soweit prima aber Gas macht mir die 6 und 9 Probleme.
              Du hast mir damals die dig0840s1q.tflite dafür gebaut. Die hab ich jetzt auch probiert aber er erkennt mir die 9 an der dritten Stelle immer wieder mal als 0 obwohl die sich ja gar nicht ändert. An der 5 und 6 Stelle erkennt er die 6 und 9 bisher ganz gut. Anbei die Ziffern 5, 6 und 9.
              9_dig3_20220103-105110.zip
              Hab jetzt auch schon mit der Größe gespielt aber nach mehreren richtigen kommt immer wieder die 0.
              Was genau macht eigentlich der Eintrag "ModelInputSize = 20 32" kann man da ev. was tun?
              Die Größe der Zahlen beim Konfigurieren ist dx 60 dy 107
              Anbei auch meine Config.ini config.ini
              Freu mich schon auf deine Antwort
              LG Horst
              • Fanatikz
                Fanatikz last edited by
                @jomjol Erstmal, geiles Projekt!
                @all
                Ich hätte zwei Fragen zu dem Projekt, neben der normalen Wasseruhr würde ich gerne meine Warmwasserzähler tracken.
                1. Ich hab schon gesehen, dass nicht unbedingt 4 Analogzeiger zum errechnen des Zählerstandes notwendig sind, Frage ob der Wasserzähler im Bild funktioniert, ich gehe da aktuell davon aus.
                2. Wie man ebenfalls auf dem Bild erkennt hab ich im Heizkreisverteiler nur 7-8 cm Platz, die Linse wäre dann nur ca. 5cm von der Uhr weg. Krieg ich das scharf, reicht der Winkel vom Objektiv und ist die Bilderkennung darauf angewiesen die volle Rundung der Uhr zu erkennen?
                Rupert S. 1 Reply Last reply Reply Quote 0
                • Hasont
                  Hasont @AlexHO last edited by Hasont
                  @alexho
                  Ist ja lustig, selber Zähler und Zählerstand
                  • Rupert S.
                    Rupert S. @Fanatikz last edited by
                    @fanatikz said in Wasserzähler - Version 2 - all-in-device:
                    Ja, der geht. Du musst den Parameter DecimalShift = -3 setzen.
                    Die volle Rundung ist nicht nötig. Wenn Du das Bild nicht scharf bekommst oder die kurze Entfernung zu starke Verzerrung erzeugt, versuch's mit einem Spiegel.
                    W Fanatikz 2 Replies Last reply Reply Quote 0
                      wusa @Rupert S. last edited by
                      @rupert-s sagte in Wasserzähler - Version 2 - all-in-device:
                      Bist du dir hier sicher?
                      Es geht ja bei DecimalShift und die digitalen Ziffern?
                      Bei der Beschreibung zu DecimalShif steht: Shift the digit separator within the digital digits (positiv and negativ)
                      Ich habe bei mir in den analogen ROI's einfach nur 3 angelegt und somit auch nur 3 Kreise um die analogen Zeiger gemacht. Bisher klappt das gut.
                      Bei DecimalShift steht bei mir 0
                      J Fanatikz 2 Replies Last reply Reply Quote 0
                        wusa @jomjol last edited by wusa
                        @jomjol
                        Erstmal vielen Dank für deine tolle Arbeit. Schätze ich wirklich sehr!
                        Ich hätte aber nochmal eine Frage zu den Werten.
                        Habe die neuste Version geflasht über das OTA Update:
                        Und hier gleich das Bild mit den Zählerständen.
                        Die analogen Zeiger werden richtig ausgelesen (der letzte Zeiger würde zwar schon auf der 4 stehen, aber das ist nicht so schlimm), allerdings, wird oben schon 310 erkannt. Ist zwar grundsätzlich von der Erkennung richtig, aber dennoch Logik mäßig falsch. Es sind nämlich 309.953
                        Heißt ich habe noch knapp 50 Liter bis wirklich 310 richtig wäre. Ich weiß das ist jetzt ein blödes Beispiel, aber das passiert auch, wenn es noch ungefähr 200 Liter sind.
                        Kann hier von meiner Seite aus in der Config was verbessert werden?
                        Oder ist hier die Programmierlogik gefragt?
                          jomjol @Hasont last edited by
                          @hasont Hallo Horst,
                          ich nehme dein Bilder ins nächste Training auf. Aber wenn du die dig0840s1q.tflite verwendest, darf sich an der Erkennungsgenauigkeit nichts ändern. Daran hat sich nichts geändert.
                          Gruß,
                          jomjol
                          • Fanatikz
                            Fanatikz @Rupert S. last edited by
                            @rupert-s vielen dank, ich probier es mal aus.
                              jomjol @wusa last edited by
                              @wusa sagte in Wasserzähler - Version 2 - all-in-device:
                              Mit DecimalShift ist das so:
                              Das Komma liegt immer zwischen den analogen und digitalen Ziffern. Relativ dazu kann es über den Parameter verschoben werden. Wenn es keine analogen Zeiger gibt, dann ist die Zahl erstmal ohne Ziffern und kann dann über DecimalShift entsprechend verschoben werden.
                                @jomjol
                                Dafür gibt es im Expertenmodus den Parameter:
                                Der übernimmt genau diese Konistenzprüfung. Nachdem du ihn aktiviert hast, kann du über SetPrevalue den richtigen Wert setzen.
                                • Fanatikz
                                  Fanatikz @wusa last edited by
                                  @wusa ich hätte den Digital shift jetzt für die 3 roten Werte nach dem Komma verstanden.
                                    wusa @Fanatikz last edited by
                                    @fanatikz
                                    So ist es auch.
                                    Es war mein Fehler. Ich hatte es irgendwie falsch verstanden.
                                    @jomjol hat mich dann wieder auf die richtige Spur gebracht.
                                    Sorry
                                      Jezinka @jomjol last edited by
                                      @jomjol
                                      Hallo, also ich habe wieder von Version 9 aktualisiert und letzteres funktioniert bei mir einfach nicht. Er misst nicht mehr, schneidet, startet neu und verhält sich seltsam. Hier ist der Teil des Logs vor und nach dem Update. Ich habe über OTA-HTML und Firmware aktualisiert
                                      2022-01-03T22:20:57: task_autodoFlow - next round - Round #6
                                      2022-01-03T22:20:57: 	FlowControll.doFlow - ClassFlowMakeImage
                                      2022-01-03T22:21:07: 	FlowControll.doFlow - ClassFlowAlignment
                                      2022-01-03T22:21:27: 	FlowControll.doFlow - ClassFlowDigit
                                      2022-01-03T22:21:55: 	FlowControll.doFlow - ClassFlowAnalog
                                      2022-01-03T22:22:11: 	FlowControll.doFlow - ClassFlowPostProcessing
                                      2022-01-03T22:22:11: 	FlowControll.doFlow - ClassFlowMQTT
                                      2022-01-03T22:22:11: sent publish successful in MQTTPublish, msg_id=25884, watermeter/connection, connected
                                      2022-01-03T22:22:11: sent publish successful in MQTTPublish, msg_id=4027, watermeter/uptime, 1533
                                      2022-01-03T22:22:11: sent publish successful in MQTTPublish, msg_id=64775, watermeter/freeMem, 2986376
                                      2022-01-03T22:22:11: sent publish successful in MQTTPublish, msg_id=31858, watermeter/value, 44.8473
                                      2022-01-03T22:22:12: sent publish successful in MQTTPublish, msg_id=11321, watermeter/error, no error
                                      2022-01-03T22:22:12: sent publish successful in MQTTPublish, msg_id=17308, watermeter/rate, 0.000000
                                      2022-01-03T22:22:12: sent publish successful in MQTTPublish, msg_id=7904, watermeter/timestamp, 2022-01-03T22:21:05
                                      2022-01-03T22:22:12: sent publish successful in MQTTPublish, msg_id=53655, watermeter/json, {"value":44.8473,"error":"no error","rate":0.000000,"timestamp":"2022-01-03T22:21:05"}
                                      2022-01-03T22:22:12: task_autodoFlow - round done
                                      2022-01-03T22:22:12: CPU Temperature: 56.7
                                      2022-01-03T22:22:16: handler_ota_update
                                      2022-01-03T22:22:16: upload_post_handler
                                      2022-01-03T22:22:25: download_get_handler
                                      2022-01-03T22:22:28: handler_ota_update
                                      2022-01-03T22:22:28: upload_post_handler
                                      2022-01-03T22:22:29: download_get_handler
                                      2022-01-03T22:22:41: handler_ota_update
                                      2022-01-03T22:23:20: handler_ota_update
                                      2022-01-03T22:23:30: handler_reboot
                                      2022-01-03T22:23:30: Reboot in 5sec
                                      2022-01-03T22:23:53: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2022-01-03T22:23:53: =============================================================================================
                                      2022-01-03T22:23:53: =================================== Main Started ============================================
                                      2022-01-03T22:24:00: Time zone set to CET-1CEST
                                      2022-01-03T22:24:00: task_autodoFlow - next round - Round #1
                                      2022-01-03T22:24:00: 	FlowControll.doFlow - ClassFlowMakeImage
                                      2022-01-03T22:24:11: 	FlowControll.doFlow - ClassFlowAlignment
                                      2022-01-03T22:24:26: 	FlowControll.doFlow - ClassFlowCNNGeneral
                                      2022-01-03T23:02:11: info_get_handler
                                      2022-01-03T23:02:20: info_get_handler
                                      2022-01-03T23:02:21: info_get_handler
                                      2022-01-03T23:02:31: download_get_handler
                                      2022-01-03T23:02:32: download_get_handler
                                      2022-01-03T23:03:07: info_get_handler
                                      2022-01-03T23:04:30: info_get_handler
                                      2022-01-03T23:08:21: info_get_handler
                                      2022-01-03T23:08:51: info_get_handler
                                      2022-01-03T23:08:56: info_get_handler
                                      2022-01-03T23:08:59: download_get_handler
                                      2022-01-03T23:09:00: download_get_handler
                                      2022-01-03T23:09:36: download_get_handler
                                      2022-01-03T23:10:35: download_get_handler
                                      2022-01-03T23:11:32: info_get_handler
                                      2022-01-03T23:12:01: download_get_handler
                                      2022-01-03T23:12:04: download_get_handler
                                      2022-01-03T23:12:54: download_get_handler
                                      2022-01-03T23:13:39: handler_reboot
                                      2022-01-03T23:13:39: Reboot in 5sec
                                      2022-01-03T23:13:55: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2022-01-03T23:13:55: =============================================================================================
                                      2022-01-03T23:13:55: =================================== Main Started ============================================
                                      2022-01-03T23:14:02: Time zone set to CET-1CEST
                                      2022-01-03T23:14:02: task_autodoFlow - next round - Round #1
                                      2022-01-03T23:14:02: 	FlowControll.doFlow - ClassFlowMakeImage
                                      2022-01-03T23:14:12: 	FlowControll.doFlow - ClassFlowAlignment
                                      2022-01-03T23:14:27: 	FlowControll.doFlow - ClassFlowCNNGeneral
                                      2022-01-03T23:16:58: download_get_handler
                                      2022-01-03T23:17:00: download_get_handler
                                      2022-01-03T23:18:07: info_get_handler
                                      2022-01-03T23:18:48: download_get_handler
                                      2022-01-03T23:19:36: info_get_handler
                                      2022-01-03T23:22:12: info_get_handler
                                      2022-01-03T23:23:02: download_get_handler
                                      2022-01-03T23:34:01: handler_reboot
                                      2022-01-03T23:34:01: Reboot in 5sec
                                      2022-01-03T23:34:24: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2022-01-03T23:34:24: =============================================================================================
                                      2022-01-03T23:34:24: =================================== Main Started ============================================
                                      2022-01-03T23:34:31: Time zone set to CET-1CEST
                                      2022-01-03T23:34:31: task_autodoFlow - next round - Round #1
                                      2022-01-03T23:34:31: 	FlowControll.doFlow - ClassFlowMakeImage
                                      2022-01-03T23:34:40: 	FlowControll.doFlow - ClassFlowAlignment
                                      2022-01-03T23:34:55: 	FlowControll.doFlow - ClassFlowCNNGeneral
                                      2022-01-03T23:35:34: download_get_handler
                                      2022-01-03T23:35:36: download_get_handler
                                        Jezinka @Jezinka last edited by Jezinka
                                        @jezinka
                                        Die Bilder zeigen, wie es sich verhält. Es ist nicht möglich, ein Bild als Referenz usw. zu laden. Jetzt habe ich Version 9 zurückgegeben und es funktioniert nicht mehr wie zuvor. Im Grunde misst es nicht, sondern zeigt die Bilder zumindest richtig an.
                                        J J 2 Replies Last reply Reply Quote 0
                                          @jezinka version 9
                                            jomjol @Jezinka last edited by
                                            @jezinka sagte in Wasserzähler - Version 2 - all-in-device:
                                            @jezinka
                                            Grundsätzlich läuft Version 10 deutlich stabiler. Wenn es jetzt bei dir weder mit v9, noch mit v10 stabil läuft, liegt es wohl eher an der Hardware. Eventuell ist deine SD-Karte zerschossen, im schlimmeren Fall hast du einen Hardwarefehler.
                                            Ich kann nur empfehlen, alles nochmals komplett neu aufzusetzen:
                                            1. ESP32 erst Erease, dann flashen
                                            2. SD-Karte formatieren und erstmal mit der Grundkonfiguration bespielen.
                                            Viel Erfolg,
                                            jomjoil
                                            S J 2 Replies Last reply Reply Quote 0
                                            238
                                            3411
                                            2011146
