    4. [ESPHome] Beta release
      Thomas Braun Most Active @OPatrick last edited by Thomas Braun
      @opatrick
      Dann hast du dir python3 irgendwoher irgendwie ins System gekloppt.
      Dein erschwindeltes python3.8 wieder deinstallieren und die vorgesehene Version 3.9.2-3 installieren. Dann funktioniert auch die Installation des Adapters wie bei mir.
      Und bitte auch die Ausgabe auf die zweite Befehlskette noch liefern. Nicht das du dir das ähnlich schief ins System gedübelt hast.
      • O
        OPatrick @Thomas Braun last edited by OPatrick
        which geht jetzt aber immer noch Fehler...
        pi@mospi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
        /usr/bin/node
        /usr/bin/npm
        pi@mospi:~ $ iobroker add esphome
        NPM version: 6.14.15
        npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
        /usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py:24: UserWarning: Distutils was imported before Setuptools, but importing Setuptools also replaces the `distutils` module in `sys.modules`. This may lead to undesirable behaviors or errors. To avoid these issues, avoid using distutils directly, ensure that setuptools is installed in the traditional way (e.g. not an editable install), and/or make sure that setuptools is always imported before distutils.
          warnings.warn(
        /usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py:36: UserWarning: Setuptools is replacing distutils.
          warnings.warn("Setuptools is replacing distutils.")
        Traceback (most recent call last):
          File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
            main()
          File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main
            bootstrap(tmpdir=tmpdir)
          File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 119, in bootstrap
            import setuptools  # noqa
          File "/usr/local/lib/python3.8/site-packages/setuptools/__init__.py", line 8, in <module>
            import _distutils_hack.override  # noqa: F401
          File "/usr/local/lib/python3.8/site-packages/_distutils_hack/override.py", line 1, in <module>
            __import__('_distutils_hack').do_override()
          File "/usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py", line 73, in do_override
            ensure_local_distutils()
          File "/usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py", line 61, in ensure_local_distutils
            assert '_distutils' in core.__file__, core.__file__
        AssertionError: /usr/local/lib/python3.8/distutils/core.py
        Error: Exited with code 1.
            at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)
            at ChildProcess.emit (events.js:400:28)
            at maybeClose (internal/child_process.js:1058:16)
            at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! iobroker.esphome@0.2.4 install: `npip install`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the iobroker.esphome@0.2.4 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2022-01-02T20_55_04_809Z-debug.log
        host.mospi Cannot install iobroker.esphome@0.2.4: 1
        pi@mospi:~ $
        da scheint python immer noch verbogen zu sein.. 🙂 ok wie bekomme ich das weg?
          @opatrick
          sudo ln -s /usr/bin/node /usr/bin/nodejs
          Und wie hast du python3.8 nun ins System gekloppt? Muss ja von 'irgendwoher' manuell kommen, in den Repos liegt die Version ja nicht vor.
          Thomas Braun O 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
            @OPatrick
            Deine schiefe Installation ist übrigens was für einen eigenen, neuen Thread wert, das hat mit dem Beta-Testen des Adapters ja nix zu tun.
            • O
              ja das kam leider etwas unglücklich. Weil beim aller ersten Versuch der Adapter Installation kamen zig Fehler Meldungen weil das Modul cryptography von python gefehlt usw..
              Da habe ich dann wahrscheinlich python manuell installiert 😞
              jetzt habe ich es zwar manuel gelöscht.. Aber die ganzen Pfade stimmen nimmer 😞
              ein sudo und er which befehl brachten nix..
              pi@mospi:/usr/local/lib $ iobroker add esphome                                                            NPM version: 6.14.15
              Error: Python site module exited with code 1.
              Could not find platform independent libraries <prefix>
              Could not find platform dependent libraries <exec_prefix>
              Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
              Python path configuration:
                PYTHONHOME = (not set)
                PYTHONPATH = '/opt/iobroker/node_modules/iobroker.esphome'
                program name = 'python3.8'
              Thomas Braun A 3 Replies Last reply Reply Quote 0
                @opatrick sagte in [ESPHome] Beta release:
                Konkret? Du verfrickelst dein System immer mehr...
                  Noch konkreter? Ich sehe nicht was du da jetzt wie warum wo gemacht hast.
                  • O
                    naja ich habe über apt-get reinstall python3 etc.. versucht die Verzeichniss links richtig zu setzten..
                    pi@mospi:/usr/local/lib $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v14.18.2
                    v14.18.2
                    6.14.15
                    OK:1 http://phoscon.de/apt/deconz bullseye-beta InRelease
                    OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                    OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                    Paketlisten werden gelesen… Fertig
                    Abhängigkeitsbaum wird aufgebaut… Fertig
                    Statusinformationen werden eingelesen… Fertig
                    Alle Pakete sind aktuell.
                    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    nodejs:
                      Installiert:           14.18.2-deb-1nodesource1
                      Installationskandidat: 14.18.2-deb-1nodesource1
                      Versionstabelle:
                     *** 14.18.2-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                            100 /var/lib/dpkg/status
                         12.22.5~dfsg-2~11u1 500
                            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                    das sieht gut aus 🙂 aber beim
                    das nicht 😞
                      isolated = 0
                      environment = 1
                      user site = 1
                      import site = 1
                      sys._base_executable = '/usr/local/bin/python3.8'
                      sys.base_prefix = '/usr/local'
                      sys.base_exec_prefix = '/usr/local'
                      sys.executable = '/usr/local/bin/python3.8'
                      sys.prefix = '/usr/local'
                      sys.exec_prefix = '/usr/local'
                      sys.path = [
                        '/opt/iobroker/node_modules/iobroker.esphome',
                        '/usr/local/lib/python38.zip',
                        '/usr/local/lib/python3.8',
                        '/usr/local/lib/lib-dynload',
                    Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
                    Python runtime state: core initialized
                    ModuleNotFoundError: No module named 'encodings'
                    Current thread 0x76f87040 (most recent call first):
                    <no Python frame>
                        at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:106:16)
                    npm ERR! errno 1
                    npm ERR!
                    npm ERR!     /home/iobroker/.npm/_logs/2022-01-02T21_11_14_284Z-debug.log
                      Konkret?
                      Das bitte in einem eigenen Thread. Hat wie gesagt mit dem Adapter nix zu tun.
                      • draexler
                        draexler @e-s last edited by
                        @e-s said in [ESPHome] Beta release:
                        Werden denn im esphome Adapter Daten vom esp über api angezeigt, ich würde tippen das das passwort im esphome Adapter nicht drin steht.
                        Habe des ESP mal aus dem Adapter gelöscht und wieder mit hinzugefügt und zwar mit dem API Passwort was in der YAML hinterlegt. Die Meldung das das PW falsch ist, kommt aber immer noch...
                        Noch irgendeine Idee?
                          e-s @draexler last edited by
                          @draexler
                          Hast du mal ein extrem einfaches pw getestet und auf nicht gewünschte Leerzeichen geachtet?
                            liv-in-sky @Dutchman last edited by
                            @dutchman
                            sorry aber konnte mein thema nicht finden - wird aber sicher irgendwo stehen
                            habe 3 esphome devices. wollte heute nach einem jahr mal wieder etwas in einem device ändern (ich habe den adapter nicht installiert), und bekam auf meinem win10 bei "esphome run ...yaml" immer einen fehler
                            also wollte ich mal über den adapter probieren. der wird installiert und ich kann von hand die devices einbinden und bekomme datenpunkte
                            was ich nicht verstehe: wie bekomme ich nun die geräte in iobroker über das dashboard - das ist im moment leer - ich konnte auf dem pc das esphome wieder zum laufen bringen. mit "esphome dashboard config/" kann ich auf dem pc das dashboard aktivieren und erst dann sehe ich in iobroker auch ein dashboard - ist aber leer und zeigt keine devices an
                            was muss ich jetzt machen ? ich möchte das dashboard nicht auf dem pc starten, sondern immer haben - muss das auf dem iobroker server installiert werden ?
                            und .. wie bekomme ich dann die schon geflashten devices in dieses dashboard
                            sorry für die fragen - aber irgendwie check ich es nicht
                            • FredF
                              FredF Most Active Forum Testing @liv-in-sky last edited by
                              @liv-in-sky sagte in [ESPHome] Beta release:
                              Das liegt imho daran, dass das Dashboard im ESPHome Adapter älter ist, als das mit du deine ESP programmiert hast
                                liv-in-sky @FredF last edited by liv-in-sky
                                @fredf
                                und das bedeutet ??
                                sehe ich das richtig, dass ich auf dem iobroker server nichts außer phyton instaliert haben muss - und das sollte rein theoretisch funktionieren ?
                                FredF SBorg 2 Replies Last reply Reply Quote 0
                                • FredF
                                  @liv-in-sky Ganz verstehe ich das Problem nicht... und das was ich vorher schrieb ist blödsinn...
                                  Darüber öffnest du das Dashboard?
                                  Bei den Adapter Einstellungen ist die IP des ioBroker eingetragen?
                                  liv-in-sky 1 Reply Last reply Reply Quote 1
                                    @fredf
                                    ok - die iobroker adresse ist jetzt drin und ann geht es auch auf - ein problem weniger
                                    und warum ist das leer ?
                                    • SBorg
                                      SBorg Forum Testing Most Active @liv-in-sky last edited by
                                      @liv-in-sky Du hast wahrscheinlich nicht deine yaml-Dateien in den ioB kopiert? Dann weiß er auch im Dashboard IMO nichts von deinen Geräten.
                                      /opt/iobroker/iobroker-data/esphome.0/xyz.yaml
                                      liv-in-sky 4 Replies Last reply Reply Quote 2
                                        liv-in-sky @SBorg last edited by
                                        @sborg das mach ich gleich mal 🙂
                                          @sborg
                                          @FredF
                                          danke euch beiden
                                          FredF 1 Reply Last reply Reply Quote 1
                                          • FredF
                                            @liv-in-sky Du musstest also die yaml Dateien einfügen wie @SBorg geschrieben hat?
                                            591
                                            152431
