    4. [gelöst] Samsung Internet Browser Problem mit ioBroker
      sigi234 Forum Testing Most Active @Rushmed last edited by sigi234
      @rushmed
      Deaktiviere mal den Info Adapter.
        Rushmed Most Active @sigi234 last edited by
        @sigi234 ja
        iobroker.admin@5.1.28
        socket.io.js:59 [2021-12-04T12:10:21.256Z] Try to connect
        socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619821257&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
        SocketClient.connect @ socket.io.js:91
        (anonymous) @ Connection.ts:239
        u @ runtime.js:63
        (anonymous) @ runtime.js:294
        (anonymous) @ runtime.js:119
        n @ asyncToGenerator.js:3
        i @ asyncToGenerator.js:25
        (anonymous) @ asyncToGenerator.js:32
        (anonymous) @ asyncToGenerator.js:21
        (anonymous) @ 5.fdbcba88.chunk.js:2
        (anonymous) @ Connection.ts:99
        socket.io.js:59 [2021-12-04T12:10:21.344Z] Start reconnect 0
        socket.io.js:61 [2021-12-04T12:10:21.345Z] ws connection error: CLOSE_ABNORMAL
        error @ socket.io.js:61
        socket.onclose @ socket.io.js:128
        socket.io.js:59 [2021-12-04T12:10:21.345Z] Reconnect is already running 0
        socket.io.js:59 [2021-12-04T12:10:21.368Z] Try to connect
        socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619821370&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
        (anonymous) @ socket.io.js:372
        socket.io.js:59 [2021-12-04T12:10:21.429Z] Start reconnect 1
        socket.io.js:61 [2021-12-04T12:10:21.430Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:59 [2021-12-04T12:10:21.430Z] Reconnect is already running 1
        socket.io.js:59 [2021-12-04T12:10:22.430Z] Try to connect
        socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619822432&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
        socket.io.js:59 [2021-12-04T12:10:22.520Z] Start reconnect 2
        socket.io.js:61 [2021-12-04T12:10:22.521Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:59 [2021-12-04T12:10:22.521Z] Reconnect is already running 2
        socket.io.js:59 [2021-12-04T12:10:24.521Z] Try to connect
        socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619824521&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
        socket.io.js:59 [2021-12-04T12:10:24.582Z] Start reconnect 3
        socket.io.js:61 [2021-12-04T12:10:24.583Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:59 [2021-12-04T12:10:24.583Z] Reconnect is already running 3
        socket.io.js:59 [2021-12-04T12:10:27.583Z] Try to connect
        socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619827584&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
        socket.io.js:59 [2021-12-04T12:10:27.674Z] Start reconnect 4
        socket.io.js:61 [2021-12-04T12:10:27.674Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:59 [2021-12-04T12:10:27.675Z] Reconnect is already running 4
        socket.io.js:59 [2021-12-04T12:10:31.675Z] Try to connect
        socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619831676&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
        socket.io.js:59 [2021-12-04T12:10:31.764Z] Start reconnect 5
        socket.io.js:61 [2021-12-04T12:10:31.767Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:59 [2021-12-04T12:10:31.775Z] Reconnect is already running 5
        socket.io.js:59 [2021-12-04T12:10:36.767Z] Try to connect
        socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619836768&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
        socket.io.js:59 [2021-12-04T12:10:36.857Z] Start reconnect 5
        socket.io.js:61 [2021-12-04T12:10:36.858Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:59 [2021-12-04T12:10:36.859Z] Reconnect is already running 5
        Glasfaser sigi234 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @Rushmed last edited by Glasfaser
          @rushmed sagte in Samsung Internet Browser Problem mit ioBroker Web UI:
          Mhh . hast du HTTPS , obwohl @Feuersturm es auch nicht nutzt
          EDIT :
          Laut
          ist bei dir HTTP ( ws )
            @rushmed
            Zeig mal Instanzeinstellungen: socketio.0
              Rushmed Most Active last edited by Rushmed
              Ich habe weder HTTPS noch eine socketio. Instanz.
              Ich leg mal eine an.
              Edit:
              Authentifizierung habe ich aktiv.
              Mit dem alten Admin UI komme ich schonmal zum Login Screen und bleibe danach hängen.
              • Feuersturm
                Feuersturm @Rushmed last edited by
                Ok, habe jetzt debug Zugriff auf den Samsung Browser.
                Wie hast du das gemacht?
                • Glasfaser
                  Glasfaser last edited by Glasfaser
                  Samsung (Android) Internet Browsern
                  Ohmm .. das ist aber Google laut deinem Screenshot
                    @Feuersturm Link
                    @Glasfaser siehe Link der Debugging Zugang aufs Telefon wird über Chrome gestartet.
                    Seffe 1 Reply Last reply Reply Quote 0
                    • Seffe
                      Seffe @Rushmed last edited by Seffe
                      @rushmed Konntest du das Problem lösen?
                      Hätte noch den Vorschlag den Hacken beim erzwingen der Websockets in der Instanz Web.0 zu deaktivieren.
                      Hiermit geht zumindest wieder der Zugriff auf die ViS mit dem neuen Samsung Internet Browser.Websocket.jpg
                      M R 2 Replies Last reply Reply Quote 0
                        MK-66 @Seffe last edited by
                        @seffe @Rushmed
                        Was aber beim neuen Samsung Internet Browser 16.0.2.19 trotzdem nicht mehr geht, ist der Zugriff auf Flot Diagramme, zumindest bei mir nicht (Websockets erzwingen ist deaktiviert). Sobald mehrere Flots geladen werden sollen, passiert außer einem derhenden Kreis einfach gar nichts und irgendwann stürzt der Browser dann auch noch ab. Wenn nur ein einzelnes Flot geladen werden soll, geht es. Mit Chrome und FF gibt es da keine Probleme.
                          Rushmed Most Active @Seffe last edited by
                          @seffe Nein, es funktionier immernoch nicht. Das Erzwingen der Websockets war bereits deaktiviert.
                          Ich sehe aber Licht am Ende des Tunnels. In der aktuellen Samsung Internet beta 16.2.1.25 komme ich wieder in die Admin Oberfläche. 👍
                          Flot und Vis habe ich nicht getestet, ich visualisiere alles mit einer Kombi aus Grafana und HabPanel und das ging beides immer.
                            Mit der aktuellen Version 16.2.1.56 von Samsung Internet besteht das Problem nichtmehr.
                            Feuersturm 1 Reply Last reply Reply Quote 1
                            • Feuersturm
                              @rushmed Dankeschön. Funktioniert bei mir jetzt auch wieder.
                              internet samsung webgui
                              949
