    4. Test Adapter Birthdays
    • David G.
      David G. @lucajordi last edited by
      @lucajordi
      Im markierten Bereich können die Spaltenbreiten angepasst werden.
        <variables>
          <variable id="(m}dH@gw]g]CrCq4X:^O">Liste</variable>
          <variable id="^u_U-Az-`mhCz~(F_#oT">text</variable>
          <variable id="x(8OtWm-n$bsM}t4],DO">i</variable>
          <variable id="B=:MPlbZ]`U`oQR_H1ZO">obj</variable>
          <variable id="|9,SdA]rgGmj%K}^fKl*">Alter</variable>
          <variable id="2xs$M*SFSh^lkODi*Z,g">Name</variable>
          <variable id=";RHJ=)9w[N*6ii2YVbv#">Tage_bis_Geburtstag</variable>
          <variable id="[hejW*.Wk;gQUlv)`eJ|">Tag_Monat</variable>
          <variable id="e}Pk:{7j{A~j7#a%49!f">Geburtsjahr</variable>
        </variables>
        <block type="on" id="ubL@LBF!,o_rkk4*V?$c" x="238" y="138">
          <field name="OID">birthdays.0.summary.json</field>
            <block type="variables_set" id="W?1q7FaV,*wmZaIkPQ*o">
              <field name="VAR" id="(m}dH@gw]g]CrCq4X:^O">Liste</field>
                <block type="convert_json2object" id="-+dC_oJ;-(a!X+qq3ItL">
                    <block type="on_source" id="W9LY54G8%@AW$,Dv.c1;">
                <block type="variables_set" id="*Gbs7`LVq2ggdi|-gk1#">
                  <field name="VAR" id="^u_U-Az-`mhCz~(F_#oT">text</field>
                    <block type="text" id="D2QaAKbM6V%.nH8G!WO8">
                      <field name="TEXT"></field>
                    <block type="controls_for" id="VAh4_5skpQ(-58)cTsN5">
                      <field name="VAR" id="x(8OtWm-n$bsM}t4],DO">i</field>
                      <value name="FROM">
                        <shadow type="math_number" id="UtEruMTPhi^T~g$#4=X%">
                          <field name="NUM">1</field>
                      <value name="TO">
                        <shadow type="math_number" id="SL!L;!$5LE6b.-i2{-x8">
                          <field name="NUM">10</field>
                        <block type="lists_length" id="IA8x7(aD91K?{^4e{t?p">
                            <block type="variables_get" id="Uw=RBKOt~o^7pvz5@?jp">
                      <value name="BY">
                        <shadow type="math_number" id="X?ku5(f{C?`POZ9}Ykn$">
                      <statement name="DO">
                        <block type="variables_set" id="?x8p%;#1!zl^M{*-WeD_">
                          <field name="VAR" id="B=:MPlbZ]`U`oQR_H1ZO">obj</field>
                            <block type="lists_getIndex" id="!p81u1HNh}swg_ZCMWGd">
                                <block type="variables_get" id="3ETVK*E:VqCH}#kblamq">
                              <value name="AT">
                                <block type="variables_get" id="4ZY9FTQA,JoJx!nEg^nc">
                            <block type="variables_set" id="_?!N}.aye8u=,XQ}5rY{">
                              <field name="VAR" id="|9,SdA]rgGmj%K}^fKl*">Alter</field>
                                <block type="get_attr" id="V=ixw;0O?aW0sXtNbLyR">
                                  <value name="PATH">
                                    <shadow type="text" id="XE}T12XOKYB-U6A8etD(">
                                      <field name="TEXT">age</field>
                                  <value name="OBJECT">
                                    <block type="variables_get" id="Aqx9nyk[/uZhLuG|WKW]">
                                <block type="variables_set" id="C@RzukD_z2Vc[/_q1s4q">
                                  <field name="VAR" id="2xs$M*SFSh^lkODi*Z,g">Name</field>
                                    <block type="get_attr" id="si%nmaEYZ8yF2`)aXAA[">
                                      <value name="PATH">
                                        <shadow type="text" id="Vv?R@/OzO]p40i%9sCnd">
                                          <field name="TEXT">name</field>
                                        <block type="variables_get" id="Dv389p@`@/Y3}]gx``_e">
                                    <block type="variables_set" id=")z0aBTEtrg5l23)8iHRs">
                                      <field name="VAR" id=";RHJ=)9w[N*6ii2YVbv#">Tage_bis_Geburtstag</field>
                                        <block type="get_attr" id="`wPRO=fu4+XJSLOOaSO0">
                                          <value name="PATH">
                                            <shadow type="text" id="%IZ(eKv9iMml(NI-f]5P">
                                              <field name="TEXT">daysLeft</field>
                                            <block type="variables_get" id="3Hno*M89!AaJIE6(3=33">
                                        <block type="variables_set" id="J/6:.#/@k1b,K1u(Bpq/">
                                          <field name="VAR" id="[hejW*.Wk;gQUlv)`eJ|">Tag_Monat</field>
                                            <block type="get_attr" id=";tsY?ta87G!Ip{x3uz#T">
                                              <value name="PATH">
                                                <shadow type="text" id="HmVz%-OkrSIKER](18V:">
                                                  <field name="TEXT">dateFormat</field>
                                                <block type="variables_get" id="Vq9etR=Lc?:t?%0IUjP9">
                                            <block type="variables_set" id="$+EHiR+SK#`|(Fs[.{n~">
                                              <field name="VAR" id="e}Pk:{7j{A~j7#a%49!f">Geburtsjahr</field>
                                                <block type="get_attr" id="vr3`]9_k0Ke3+G;BPe0$">
                                                  <value name="PATH">
                                                    <shadow type="text" id="g}99n.xJZe2a;])BF`jI">
                                                      <field name="TEXT">birthYear</field>
                                                    <block type="variables_get" id="C?}|MWY(:zJSY(62Q!L-">
                                                <block type="variables_set" id=",AX3xaQpP,RI_FeH!Xx|">
                                                    <block type="text_join" id="oc7)%`;1Y7hZ,{LSK@n^">
                                                      <mutation items="12"></mutation>
                                                      <value name="ADD0">
                                                        <block type="variables_get" id="SjYSlvJOrj+1T]NFWCL0">
                                                      <value name="ADD1">
                                                        <block type="text" id="@UfRgRh#-n,^e{wnY,#$">
                                                          <field name="TEXT">&lt;td align=left&gt;</field>
                                                      <value name="ADD2">
                                                        <block type="variables_get" id="bJfAhLxPp7#nS|JLsb$2">
                                                      <value name="ADD3">
                                                        <block type="text" id="SmFyDO|0Dgd0$?eaA`Sg">
                                                          <field name="TEXT">&lt;/td&gt;&lt;td align=left&gt;</field>
                                                      <value name="ADD4">
                                                        <block type="variables_get" id=";1!SxOtb)P*,f@2txLG+">
                                                      <value name="ADD5">
                                                        <block type="text" id="l8zfR/C[-Z!s_7]xikn.">
                                                      <value name="ADD6">
                                                        <block type="variables_get" id="Q[EpsfEG%7ZI^$5T(QJ6">
                                                      <value name="ADD7">
                                                        <block type="text" id="KbAj1HeA#[JP1_F=;0jv">
                                                      <value name="ADD8">
                                                        <block type="variables_get" id="A]OKm4e`3x(zLzn6s(QN">
                                                      <value name="ADD9">
                                                        <block type="text" id=",/`NuXiO3ZIF~=~5{eSd">
                                                      <value name="ADD10">
                                                        <block type="variables_get" id=".b0/!U0*`T.0T[m3*H%p">
                                                      <value name="ADD11">
                                                        <block type="text" id="kRiD.ImYj;[z[KX9yG?I">
                                                          <field name="TEXT">&lt;/tr&gt; </field>
                        <block type="update" id="R]Q{qU0GhQRf6V6{NzYv">
                          <field name="OID">0_userdata.0.VIS.Tabellen.Geburtstage</field>
                            <block type="text_join" id=")4[foVL+;!xdhFv($WVn">
                              <value name="ADD0">
                                <block type="text" id="rqH.Tp+,./Gm@C8e99ZY">
                                  <field name="TEXT">&lt;table&gt;   &lt;tr&gt;     &lt;th width=100 align=left&gt;Name&lt;/th&gt;     &lt;th width=60 align=left&gt;Datum&lt;/th&gt;     &lt;th width=60 align=left&gt;Jahr&lt;/th&gt;     &lt;th width=60 align=left&gt;Alter&lt;/th&gt;     &lt;th width=60 align=left&gt;In Tagen&lt;/th&gt;   &lt;/tr&gt;   &lt;tr&gt;   &lt;td colspan="5"&gt;&lt;hr&gt;&lt;/td&gt;   &lt;/tr&gt;   &lt;tr&gt;</field>
                              <value name="ADD1">
                                <block type="variables_get" id="4R$*aP-tIeoXAU7-OHcp">
                              <value name="ADD2">
                                <block type="text" id="D^y@YucK42#e*.q0I~NK">
                                  <field name="TEXT"> &lt;/table&gt;</field>
        lucajordi @David G. last edited by
        @david-g
        Danke dir!
        Wie hast du denn den Datenpunkt angelegt?
        • David G.
          @lucajordi
          Der Datenpunkt in den die Tabelle geschrieben wird?
          Ist als string angelegt.
          Der Triggerdatenpunkt ist ja vom Adapter vorgegeben. Sollte bei die ja gleich sein (falls deine Instanz die selbe Nummer hat.).
          • Chaot
            Chaot @haus-automatisierung last edited by Chaot
            Gerade Version 0.1.7 installiert.
            Ich kann nicht mehr speichern.
            Ich habe die Geburtstage manuell eingetragen. Wenn ich dort etwas ändern möchte ist das Feld "Speichern" zwar aktiv, aber rot umrandet und funktioniert nicht.
            Edit:
            Wenn ich direkt die Jahreszahl eingebe kommt der Fehler.
            Wenn ich aber auf die kleinen Up- Down Button klicke springt er auf 1900 und lässt sich dann hochzählen. Dabei bleibt das Speichern aktiv.
            Sobald man aber den Cursor in das Zahlenfeld setzt ist der Button wieder aus mit dem roten Rand.
              @david-g
              Danke, funktioniert, aber irgendwie kann ich die Spaltenbreite nicht anpassen...
              egal was ich bei width einstelle, bleibt immer gleich...
              • David G.
                David G. @lucajordi last edited by David G.
                @lucajordi
                Das sind Pixelangaben. Evtl ist deine Auflösung so hoch oder gering, dass du ganz andere Werte brauchst.
                (Kann auch sein, dass meine Werte nicht logisch sind. Nutze die Tabelle in Lovelace. Da verhalten sich Tabellen manchmal was komisch.)
                Sonst probiere es man mit %. Glaube einfach das % hinter die Angabe hauen.
                Und natürlich pro Spalte eingeben.
                Also 5 Werte.
                EDIT:
                Neues Bild
                Quelle:
                klick
                • haus-automatisierung
                  haus-automatisierung Developer Most Active @Chaot last edited by haus-automatisierung
                  @chaot sagte in Test Adapter Birthdays:
                  Das ist ein Bug im Admin-Adapter. Muss ich noch ein Issue für öffnen:
                  https://github.com/ioBroker/ioBroker.admin/issues/1263
                  klein0r created this issue in ioBroker/ioBroker.admin
                  closed Validation issue in json components (tables) #1263
                    @david-g
                    Danke, funktioniert!
                    Und wie kann ich die Textgröße in der Tabelle ändern?
                      lucajordi @lucajordi last edited by lucajordi
                      ok, mit der Größe funktioniert, aber wie bekomme ich die Linie unter Namen, Datum... und Name, Datum... in eine Zeile und den Punkt weg?
                      Hier das Textfeld:
                      <table> <tr> <th width=90 align=left><font size=7></font>Name</th> <th width=80 align=left>Datum</th><th width=100 align=left>Geburtsjahr</th> <th width=60 align=left>Alter</th> <th width=60 align=left>In Tagen</th> </tr> <tr> <hr></td> <td colspan="5"></tr> <tr>
                      • David G.
                        @lucajordi
                        Macht für mich beides keinen Sinn.....
                        Die Linie habe ich bei mir ja unter den Überschriften.
                        Wird im Code durch das <hr> erzeugt.
                        Und der Punkt..... Ka
                        Erstelle dir mal ein Textdokument, füge den Code da ein und Speiche es dann als HTML anstatt txt.
                        Dann siehst du wie es der Browser anzeigt.
                        • wendy2702
                          wendy2702 last edited by
                          Gerade den Adapter installiert und mal konfiguriert. Kalender läuft auf einer Nextcloud installation.
                          Jetzt diesen Fehler im log:
                          Sorry geht am Tablet gerade leider nur als screenshot.
                          Was kann ich machen?
                          Den identischen Kalender kann ich in iCal auslesen mit Haken „Ignoriere Zertifikatsfehler“ gesetzt auslesen.
                            haus-automatisierung Developer Most Active @wendy2702 last edited by
                            @wendy2702 sagte in Test Adapter Birthdays:
                            Gucke ich mir an 👍
                              haus-automatisierung Developer Most Active last edited by
                              In Version 1.1.0 habe ich CardDAV Support hinzugefügt. Gerne mal testen. Habe ich bisher nur mit Synology Contacts getestet.
                              https://github.com/klein0r/ioBroker.birthdays/blob/master/docs/de/carddav.md
                              • DJMarc75
                                DJMarc75 last edited by
                                Habe seit dem gestrigen Update bei jeder Aktualisierung folgende Meldungen im Log...
                                birthdays.0
                                	2022-02-26 08:45:11.185	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.birthdays, node: v14.19.0, js-controller: 4.0.15
                                birthdays.0
                                	2022-02-26 08:45:08.490	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                birthdays.0
                                	2022-02-26 08:45:08.489	info	terminating
                                birthdays.0
                                	2022-02-26 08:45:08.487	warn	Got terminate signal. Checking desired PID: 0 vs own PID 5508
                                birthdays.0
                                	2022-02-26 08:30:11.433	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.birthdays, node: v14.19.0, js-controller: 4.0.15
                                birthdays.0
                                	2022-02-26 08:30:08.239	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  Thaibodo last edited by
                                  Habe nur ich das Problem, dass ich die Einstellungen nur sporadisch speichern kann. Die Speicherbutton sindf asgegraut und rot umrandet.Bildschirmfoto 2022-03-02 um 21.19.50.png
                                    MartyBr @Thaibodo last edited by
                                    @thaibodo
                                    Das Problem habe ich auch. Ich muss die Daten mit den Schaltflächen Jahr rauf/runter einstellen, dann kann ich speichern. Gebe ich das Geburtsjahr manuell ein, dann sind die Schaltflächen zum Speichern ausgegraut.
                                      Thaibodo @MartyBr last edited by
                                      @martybr
                                      Danke für de Tip, so funktioniert es bei mir auch.
                                      Wird sicher noch geändert.
                                        Thaibodo @Thaibodo last edited by
                                        @thaibodo
                                        Korrektur:
                                        beim 2. Eintrag funktioniert es so auch nicht mehr.
                                        M haus-automatisierung 2 Replies Last reply Reply Quote 0
                                          @thaibodo
                                          Dann jeden Tag nur einen Geburtstag eintragen 😀
                                            haus-automatisierung Developer Most Active @Thaibodo last edited by
                                            @thaibodo sagte in Test Adapter Birthdays:
                                            Bei mir schon 🙂 Ist ein Bug im Admin, habe ich Anfang des Jahres gemeldet und noch keine Rückmeldung dazu... Gerne dort kommentieren:
                                            31.7k
                                            79.9k
                                            adapter birthday erinnerung geburtstag tester
                                            55
                                            335
                                            47644
