    4. [Neuer Adapter] radar-trap
      helfi9999 @carsten04 last edited by
      @carsten04 Hallo,
      bekomme beim installieren folgenden Fehler:
      ERROR: Process exited with code 25
      weniger
      mehr
      $ iobroker url https://github.com/Steiger04/ioBroker.radar-trap --host iobroker
      install Steiger04/ioBroker.radar-trap#59772746bcfedabc4482b47115ca8584a1381bd5
      NPM version: 7.5.2
      npm install Steiger04/ioBroker.radar-trap#59772746bcfedabc4482b47115ca8584a1381bd5 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: feathers-nedb@6.0.0npm ERR! notsup Not compatible with your version of node/npm: feathers-nedb@6.0.0npm ERR! notsup Required: {"node":">= 14"}npm ERR! notsup Actual: {"npm":"7.5.2","node":"v12.21.0"}
      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-01-05T08_30_45_256Z-debug.log
      host.iobroker Cannot install Steiger04/ioBroker.radar-trap#59772746bcfedabc4482b47115ca8584a1381bd5: 1
      Latzi 1 Reply Last reply Reply Quote 0
      • Latzi
        Latzi @helfi9999 last edited by
        @helfi9999
        @helfi9999 sagte in [Neuer Adapter] radar-trap:
        NPM version: 7.5.2
        NPM-Version passt nicht!
        Installation geradeziehen, schau mal unter:
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          helfi9999 @Latzi last edited by
          @latzi bekomme immer noch Fehlermeldung Npm Version ist geändert:
          NPM version: 6.14.15npm install Steiger04/ioBroker.radar-trap#59772746bcfedabc4482b47115ca8584a1381bd5 --loglevel error --prefix "/opt/iobroker" (System call)
          npm ERR! Error while executing:
          npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.gitnpm ERR! npm ERR! Host key verification failed.npm ERR! fatal: Could not read from remote repository.npm ERR! npm ERR! Please make sure you have the correct access rightsnpm ERR! and the repository exists.npm ERR! npm ERR! exited with error code: 128
          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-01-05T09_43_37_559Z-debug.log
            Thomas Braun Most Active @helfi9999 last edited by
            Das aufräumen. Am besten eine Version aus dem Beta-Repo, in Stable gibt es den Adapter ja nicht.
            • carsten04
              carsten04 Developer @Oli last edited by carsten04
              @oli sagte in [Neuer Adapter] radar-trap:
              @carsten04
              danke für die neue Version.
              1. Nach dem Update musste ich die Route neu erstellen und die alte löschen, ist das so beabsichtigt?>
              2. Gibt es eine Möglichkeit, die kürzeste und nicht die schnellste Route anzeigen zu lassen?
              3. Gibt es eine Möglichkeit die durchschnittlich Fahrzeit auszulesen?
              zu 1) Die Daten für routes, directions und traps werden in einer NeDB abgelegt. Wenn Du die DB vor der Installation einer neuen Version sicherst und dann zurückspielst geht nichts verloren. Dazu wie folgt vorgehen:
              1. Mapbox Token und OpenCage ID sichern
              2. Instanz stoppen
              3. in das Verzeichnis iobroker/node_modules/iobroker.radar-trap/server/data gehen
              4. die Dateien routes.db, directions.db, traps.db sichern
              5. neue Adapterversion installieren
              6. Instanz stoppen
              7. gesicherte Dateien zurückspielen
              8. Instanz neu starten
              9. Mapbox Token und OpenCage ID zurückspielen
              zu 2) Die kürzeste Route entspricht am ehesten dem Profil walking. Die duration ist dann aber nicht sinnvoll verwendbar.
              zu 3) Die durchschnittliche Fahrzeit (Profil driving und driving-traffic) steht im duration-State der Route, oder was meinst Du?
              liv-in-sky O 2 Replies Last reply Reply Quote 0
                liv-in-sky @carsten04 last edited by
                @carsten04
                weißt du was das ist:
                carsten04 1 Reply Last reply Reply Quote 0
                • carsten04
                  carsten04 Developer @liv-in-sky last edited by carsten04
                  @liv-in-sky Stop mal die Instanz (falls noch grün), geh in den Object-Tree und lösche den radar-trap Subtree komplett, dann Instanz neu starten und alles müsste gut sein.
                    @carsten04
                    gab es nicht - habe den ganzen radar ordner gelöscht - dann instance wieder aktiviert - jetzt kommt gar kein ordner bzw dp mehr - vor dem löschen gab es nur einen dp und der war eher kryptisch (es war aber etwas mit der ersten route, die ich angegeben hatt
                    ich konnte nach dem eingeben der ersten route (die nicht angezeigt wurde) keine weiteren routen eingeben - ist jetzt auch so -
                    kann ich was im filesystem löschen ?
                    • carsten04
                      @liv-in-sky Was waren das denn für Routendaten und welchen Radarordner hast Du gelöscht?
                      liv-in-sky 4 Replies Last reply Reply Quote 0
                        @carsten04 anz normale
                        ich habe radar-trap.0 gelöscht - also den gesamten ordner
                          @carsten04
                          alles gelöscht - nochmal adapter und instanz installiert - jetzt schaut es besser aus 🙂
                            liv-in-sky @carsten04 last edited by liv-in-sky
                            @carsten04
                            bin zutiefst beeindruckt - hatte auch ein radarscript mit anzeige in map - aber dein adapter übertrift das - vor allem weil mn die routen sieht
                            tolle arbeit
                            • carsten04
                              @liv-in-sky Danke für das positive Feedback. Fehlt Dir denn noch irgendetwas (Widgets, States, ...)?
                                @carsten04
                                könnte man eine karte als widget haben, die alle blitzer anzeigt von allen routen anzeigt - evtl auch die endstandorte
                                der routenverlauf wäre mir da nicht so wichtig
                                z.b. so:
                                roter punkt ist blitzer
                                blaue dreiecke sind routen-enden
                                das iobroker symblo ist ausgangspunkt
                                könnte ich selber machen, da bräuchte ich aber die koordinaten der routen als dp
                                  @carsten04
                                  ich meinte dieses script https://forum.iobroker.net/topic/38168/script-radar-kontrolle-und-koordinaten-übersetzer?page=1
                                  würd ich für deinen adapter "einstampfen" 🙂
                                    @carsten04
                                    durch den feature port könnte ich wohl die gewünschte anzeige bekommen
                                    könntest du das ganze json nicht auch als dp anbieten ? also nur die routes würden mir reichen
                                    • carsten04
                                      @liv-in-sky Habe gerade mal ins Skript geschaut, da hast Du ja auch schon ne menge Logik reingebaut.
                                      Hab gesehen, dass Du auch die ATUDO-API verwendest. Da ist das Hauptproblem, dass Du immer nur eine Box als "Suchraum" angeben kannst und dann alle Treffer innerhalb der Box sind und nie entlang irgendeiner Strecke. Das ist auch der Grund, warum Du auf Verkehrslage.de keine Strecken eingeben kannst. Ich habe das so gelöst, dass ich entlang der Strecke kleine Boxen Abfrage, die doppelten Treffer rausnehme und von der Restmenge nur die Hindernisse zulasse, die maximal 10 Meter von der Strecke entfernt sind. Damit bekomme ich dann alle Treffer entlang der Strecke.
                                        @carsten04
                                        dann wird das nicht richtig klappen mit dem einem widget - wenn der blitzer nicht genau in der route ist, zeigst du das nicht an - bei mir wird einfach alles in einem radius angezeigt und die blitzer darin in der karte angezeigt
                                        oder hast du noch eine idee
                                        • carsten04
                                          @liv-in-sky Ich kann ein VIS-Widget bauen das alle Routen in einer Karte anzeigt. Die Idee ist ja gerade die Hindernisse entlang der tatsächlich gefahrenen Strecke anzuzeigen und nicht irgendwo 100m bis x km daneben. Was Du meinst wäre ein zusätzliches Feature / Widget bei dem Du zwei Punkte definierst und in dem entstandenen Rechteck alle Hindernisse anzeigst. Das ist das was Du in Deinen Skript (so habe ich es zumindest verstanden) machst.
                                          • JohGre
                                            JohGre last edited by
                                            Hab den Adapter nun auch installiert und muss sagen "Hut ab", echt toll was du da gemacht hast.
                                            Mache derzeit meine Routen- und Stauberechnungen mittels NodeRed und Bing-Maps. bei dir ist es extrem einfach.
                                            Hab aber noch eine Frage. Wie mach ich das, dass ich zur Laufzeit die Karten umstellen kann?
                                            222
                                            24662
