    5. Ical Termine an Telegram auseinander und zusammensetzen
    • SeiteBallon74
      SeiteBallon74 @David G. last edited by
      @david-g
      Guten Morgen, habs umgestellt. Einzig das Format der Anzeige gefällt mir nicht.
      Hast du so die Umstellung gemeint?
      <block xmlns="https://developers.google.com/blockly/xml" type="controls_if" id="SG1#fy:/LT+_LtWOw9:=" x="39.319948733669946" y="2932.8166729250734">
          <block type="logic_compare" id="~K9qxlSw$|iqluYn$=E[">
            <field name="OP">GT</field>
              <block type="get_value" id="A#AM49+2rPo@~*`kpOQQ">
                <field name="OID">ical.1.data.count</field>
              <block type="math_number" id="DE1qH{lXTOIL_qY{RJs#">
                <field name="NUM">0</field>
          <block type="variables_set" id="`%F3I5HDMm{W_0J_o3Y)">
            <field name="VAR" id="Nin}JW*y1Vp_$;},D.7Z">liste_term</field>
              <block type="get_value" id="mw}m)@^s7YhZ#N9.YJGR">
                <field name="OID">ical.1.data.table</field>
              <block type="controls_for" id="##,smlQZuUU$Hp)Deinv">
                <field name="VAR" id="1]Y7`n@:hU1lh4_N4rup">j</field>
                <value name="FROM">
                  <shadow type="math_number" id="A*J}_Qh+*662ncK7Jlh@">
                    <field name="NUM">1</field>
                <value name="TO">
                  <shadow type="math_number" id="2+Y:blScaLJrd?cNIno]">
                    <field name="NUM">10</field>
                  <block type="get_value" id="ZVp^WlNoFoFa)X$]=GVR">
                <value name="BY">
                  <shadow type="math_number" id="cf2:f+!=u[45[`5A^oR)">
                <statement name="DO">
                  <block type="variables_set" id="d3!_@rJ(=rJBet8eg*aw">
                    <field name="VAR" id="mOjNB}.j)RR3:k$kM.L7">obj_termin</field>
                      <block type="lists_getIndex" id="9T);!$t,Au-eE3B~1Gv;">
                          <block type="variables_get" id="KK36xP*]R#Wbj5[ySvU{">
                        <value name="AT">
                          <block type="variables_get" id="[9^LOR%D~X1zA:VdfwBl">
                      <block type="variables_set" id="9XU7hW*5T;uB$d$6ObCI">
                        <field name="VAR" id="%9%0UV]g*=a-{TDxkJ2t">termin</field>
                          <block type="get_attr" id="E0Mq^IGJM,XR/(-,}CrK">
                            <value name="PATH">
                              <shadow type="text" id="[(Cf+VL;Ft7YO0(FBwSv">
                                <field name="TEXT">event</field>
                            <value name="OBJECT">
                              <block type="variables_get" id="b_LG$ZW%TE8si5J(b:Mp">
                          <block type="variables_set" id="L-4nSiPs7tQK){NhuP}A">
                            <field name="VAR" id="HIJ%UiQd%]r!t2:`_t9{">termin_datum</field>
                              <block type="get_attr" id="zSyV5QdK]%VDm{0U--z[">
                                <value name="PATH">
                                  <shadow type="text" id="kqX{$-vh9,M%3YP5wYpE">
                                    <field name="TEXT">_date</field>
                                  <block type="variables_get" id="5h-v#4$+b6F~R#^F6q~?">
                              <block type="variables_set" id="jaM:)-h[SvzaVr$,1{ab">
                                <field name="VAR" id="wPep`OX`O^fEpJ%f1ug~">ort</field>
                                  <block type="get_attr" id="S@.?MCm42pqS,F.7ACRS">
                                    <value name="PATH">
                                      <shadow type="text" id="o#}lQtc57|^_4;Y_v?ZL">
                                        <field name="TEXT">location</field>
                                      <block type="variables_get" id="}=.Og}t-hG5EBFM#cyo#">
                                  <block type="controls_if" id="];.6ad~@C_k*YA=JZ5i9">
                                      <block type="logic_compare" id="W3Thh$n.r^`gcD#+i8rp">
                                        <field name="OP">NEQ</field>
                                          <block type="variables_get" id="#kvnaF6A0U`v9#.5WCE5">
                                          <block type="text" id="{=:*8e0i=^KG;@j4``p+">
                                            <field name="TEXT"></field>
                                      <block type="variables_set" id="ik!KO.`x;blY`Ov]_k6E">
                                        <field name="VAR" id=";b3g/W*e;GFH|}7)uzqt">text_ort</field>
                                          <block type="text_join" id="SO{-r$OY3{_Q63o]:XHk">
                                            <value name="ADD0">
                                              <block type="text" id="V$=2#]/uVg5v=;6;2U`i">
                                                <field name="TEXT"> - </field>
                                            <value name="ADD1">
                                              <block type="variables_get" id="aHEBYTk3^_wUHV(%(tdG">
                                      <block type="variables_set" id="Xw~K{!s8GsBtx5@tIcn5">
                                        <field name="VAR" id="b)m])isudJ]Z:`l}GrRL">anstehende_termine</field>
                                          <block type="text_join" id="^JUvnmon_{lP[DJIaZ+l">
                                            <mutation items="9"></mutation>
                                            <value name="ADD0">
                                              <block type="variables_get" id="8?NV/z=,lX$)}a)_`g4F">
                                            <value name="ADD1">
                                              <block type="text_newline" id="7R{vwZ4.$e7S-Pdi^@*)">
                                                <field name="Type">\n</field>
                                            <value name="ADD2">
                                              <block type="convert_from_date" id="`0LFOX!yru]-[dfKDn}G">
                                                <field name="OPTION">hh:mm</field>
                                                  <block type="variables_get" id="lUF[SJ-mp}FL]KEGtHLL">
                                            <value name="ADD3">
                                              <block type="text" id="GN9N$whLIIW,lY5P7Zo+">
                                                <field name="TEXT"> </field>
                                            <value name="ADD4">
                                              <block type="variables_get" id="iXe#+!7?SY/S9X]:9Cht">
                                            <value name="ADD5">
                                              <block type="variables_get" id="dLJn1$?9Zb38^?_[j_5-">
                  <block type="telegram" id="%R4ujjx,8M^2tV9xvj`^">
                    <field name="INSTANCE">.0</field>
                    <field name="LOG"></field>
                    <value name="MESSAGE">
                      <shadow type="text" id="|Y0fQkiSY@@x6f:|czT0">
                      <block type="variables_get" id=":NHFv)_bDjl2xvAC5Te~">
      • David G.
        David G. @SeiteBallon74 last edited by
        @seiteballon74
        Habe gemeint, dass du einfach den Datenpunkt
        (grad nicht am rechner um zu schauen wie der heißt)
        Per Telegram versendest.
        Falls du so viele Termine haben möchtest.
        Dann kannst du dir das ganze Skript sparen.
        Wenn es so bleiben soll wie jetzt, kannst du das ja noch was anpassen. Die Reihenfolge einfach im Text erstellen Block. Gibt auch noch Kürzel für fett und kursiv (grad nicht im Kopf). Oder noch eine leerzeile zur Übersichtlichkeit.
        SeiteBallon74 1 Reply Last reply Reply Quote 1
        • SeiteBallon74
          @david-g
          Habs soweit hinbekommen das es passt. Ich hab jetzt die Termine in eigene Ical Instanzen sortiert.
          Aber jetzt muss ich wahrschl nen neuen Thread aufmachen weil meine LED Laufschrift nur eine bestimmte Anzahl an Buchstaben ausgeben kann. Sprich der Text von den Terminen und dem Abfuhrkalender ist einfach zu lange.
          Weiß nicht wie ich das ändern kann. Ich müsste den Text aufteilen und dann wieder zusammensetzen können.
            @David-G
            @SeiteBallon74
            gehört euer Thema eigentlich noch in diesen Thread????
            • David G.
              David G. @Homoran last edited by David G.
              Nicht wirklich......
              Sind was vom Kurs abgekommen.......
              Letzte kurze Antwort.
              So könnte es klappen, falls du mehrere kurze Datenpunkte für die Anzeige brauchst.
              • SeiteBallon74
                SeiteBallon74 @Guest last edited by
                @David-G
                Okay, guter Tipp. Aber gibt es dann nicht Probleme mit meinem JSON Funktionsbaustein?
                Ich muss mal sehen wie ich das wo einpflegen kann.
                SeiteBallon74 2 Replies Last reply Reply Quote 0
                • SeiteBallon74
                  SeiteBallon74 @SeiteBallon74 last edited by
                  @David-G
                  sollte das so passen?
                  • SeiteBallon74
                    @David-G
                    So??
                    • David G.
                      David G. @SeiteBallon74 last edited by David G.
                      @seiteballon74
                      Tas text to json kannst du dir sparen.
                      (dein Display braucht denke nur normalen text oder?)
                      Bei den ganzen Zeilen danach ist die Frage ob dein Display die nacheinander abarbeitet oder wenn die neuen Zeichen kommen die vorherigen verwirft.
                      Sonst müsste man mal messen, wie lange er für 50 Zeichen braucht und überall eine Pause einbauen.
                      • SeiteBallon74
                        @david-g
                        also er überträgt den Datenpunkt so an den Ausgabepunkt. Aber das Display zeigt mir den Wert nicht an. Stimmt hier bei dem json was nicht?
                        • David G.
                          @seiteballon74
                          Hab keine Ahnung was das Display braucht....
                          Evtl stört er sich an dem \n
                          Kannst du ja zum testen mal alle entfernen.
                          • SeiteBallon74
                            @david-g
                            die \n sowie die \ interessieren ihn gar nicht. Wenn ich mehrere Zeilen lösche und dann auf Enter drücke dann gibt er sie aus. Also denke ich das es immer noch was mit der Anzahl der Buchstaben zu tun hat.
                            Aber wie löse ich das? So ein doofes Problem
                            • David G.
                              @seiteballon74
                              Wenn das Gerät nicht mehr kann auf weniger Zeichen gehen.
                              Hast das Skript ja.
                              Wie gesagt, die Frage ist ob die die Datenpunkte so schnell hintereinander hinsenden kannst.
                              Wobei ich das Ding nicht kenne und keine Ahnung habe was er kann oder erwartet.
                              • SeiteBallon74
                                @david-g
                                Was es natürlich auch sein könnte sind die MQTT Adapter Einstellungen..
                                Siehst du dort irgend einen Fehler?
                                • David G.
                                  @seiteballon74
                                  von mqtt hab ich keinen sitzen, noch nie benutzt.
                                  SeiteBallon74 1 Reply Last reply Reply Quote 0
                                  • SeiteBallon74
                                    @david-g
                                    Okay, schade. 120 Zeichen kann das Teil anscheinend verarbeiten aber es kommen mehr als 120 Zeichen an den Ausgabepunkt obwohl vorher mit den Bausteinen von "nimm Teil ab.." gearbeitet wird.
                                    Stimmt vielleicht doch etwas mit den Bausteinen nicht bzw dem Script?
                                    • SeiteBallon74
                                      SeiteBallon74 @SeiteBallon74 last edited by SeiteBallon74
                                      [gelöst]
                                      @David-G
                                      Egal jetzt. Wenn ich bei ical nur noch 5 Tage einstelle dann läuft es. Lass ich jetzt so.
                                      Aber bei deinem anderen Script von gestern ist mir ein Fehler aufgefallen. Es wird der Tag 4 nicht angezeigt. Soll ich da wieder im passendem Forum weiterschreiben?
                                      1067
