    4. Raspi 3 Model B mit Samsung SSD 500GB
      JürgenIO @JürgenIO last edited by
      @jürgenio
      -- Logs begin at Wed 2022-01-05 14:05:21 CET, end at Wed 2022-01-05 18:51:12 CET. --
      Jan 05 14:05:21 ioBroker kernel: Booting Linux on physical CPU 0x0
      Jan 05 14:05:21 ioBroker kernel: Linux version 5.10.17-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 2
      Jan 05 14:05:21 ioBroker kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
      Jan 05 14:05:21 ioBroker kernel: CPU: div instructions available: patching division code
      Jan 05 14:05:21 ioBroker kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      Jan 05 14:05:21 ioBroker kernel: OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
      Jan 05 14:05:21 ioBroker kernel: Memory policy: Data cache writealloc
      Jan 05 14:05:21 ioBroker kernel: Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
      Jan 05 14:05:21 ioBroker kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      Jan 05 14:05:21 ioBroker kernel: Zone ranges:
      Jan 05 14:05:21 ioBroker kernel:   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
      Jan 05 14:05:21 ioBroker kernel:   Normal   empty
      Jan 05 14:05:21 ioBroker kernel: Movable zone start for each node
      Jan 05 14:05:21 ioBroker kernel: Early memory node ranges
      Jan 05 14:05:21 ioBroker kernel:   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
      Jan 05 14:05:21 ioBroker kernel: Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
      Jan 05 14:05:21 ioBroker kernel: On node 0 totalpages: 242688
      Jan 05 14:05:21 ioBroker kernel:   DMA zone: 2133 pages used for memmap
      Jan 05 14:05:21 ioBroker kernel:   DMA zone: 0 pages reserved
      Jan 05 14:05:21 ioBroker kernel:   DMA zone: 242688 pages, LIFO batch:63
      Jan 05 14:05:21 ioBroker kernel: percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
      Jan 05 14:05:21 ioBroker kernel: pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
      Jan 05 14:05:21 ioBroker kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      Jan 05 14:05:21 ioBroker kernel: Built 1 zonelists, mobility grouping on.  Total pages: 240555
      Jan 05 14:05:21 ioBroker kernel: Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2
      Jan 05 14:05:21 ioBroker kernel: Kernel parameter elevator= does not have any effect anymore.
                                       Please use sysfs to set IO scheduler for individual devices.
      Jan 05 14:05:21 ioBroker kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      Jan 05 14:05:21 ioBroker kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      Jan 05 14:05:21 ioBroker kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
      Jan 05 14:05:21 ioBroker kernel: Memory: 879832K/970752K available (9216K kernel code, 1311K rwdata, 2940K rodata, 1024K init, 860K bss, 25384K reserved, 65536K cma-reserved)
      Jan 05 14:05:21 ioBroker kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      Jan 05 14:05:21 ioBroker kernel: ftrace: allocating 31910 entries in 63 pages
      Jan 05 14:05:21 ioBroker kernel: ftrace: allocated 63 pages with 6 groups
      Jan 05 14:05:21 ioBroker kernel: rcu: Hierarchical RCU implementation.
      Jan 05 14:05:21 ioBroker kernel:         Rude variant of Tasks RCU enabled.
      Jan 05 14:05:21 ioBroker kernel:         Tracing variant of Tasks RCU enabled.
      Jan 05 14:05:21 ioBroker kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      Jan 05 14:05:21 ioBroker kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      Jan 05 14:05:21 ioBroker kernel: random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=0
      Jan 05 14:05:21 ioBroker kernel: arch_timer: cp15 timer(s) running at 19.20MHz (phys).
      Jan 05 14:05:21 ioBroker kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
      Jan 05 14:05:21 ioBroker kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
      Jan 05 14:05:21 ioBroker kernel: Switching to timer-based delay loop, resolution 52ns
      Jan 05 14:05:21 ioBroker kernel: Console: colour dummy device 80x30
      Jan 05 14:05:21 ioBroker kernel: printk: console [tty1] enabled
      Jan 05 14:05:21 ioBroker kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
      Jan 05 14:05:21 ioBroker kernel: pid_max: default: 32768 minimum: 301
      Jan 05 14:05:21 ioBroker kernel: LSM: Security Framework initializing
      Jan 05 14:05:21 ioBroker kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      und das von "journalctl -b"
        Thomas Braun Most Active @JürgenIO last edited by
        @jürgenio
        Welches Terminal-Programm zaubert eigentlich immer diese zerhackten logfiles? puTTY?
        J Homoran 2 Replies Last reply Reply Quote 0
          JürgenIO @Thomas Braun last edited by
          ja.
          sorry - ich weiß es nicht besser... 🙂
            @thomas-braun sagte in Raspi 3 Model B mit Samsung SSD 500GB:
            @jürgenio
            Ja, wenn man das Fenster nicht breit genug hat
              Dann muss ich meine 'Warum-ich-puTTY-nicht-nutze'-Liste noch um einen Punkt erweitern.
                ich fürchte das gilt auch für andere Terminals.
                Wenn dort ein Zeilenumbruch erzeugt wird scheint das hier im Forum mit vielen Tabs oder Leerzeichen in einer Zeile aneinandergehängt zu werden
                J Thomas Braun 2 Replies Last reply Reply Quote 0
                  JürgenIO @Homoran last edited by
                  seht ihr da ein "Hasenfuß"?
                    Homoran Global Moderator Administrators @JürgenIO last edited by
                    @jürgenio sagte in Raspi 3 Model B mit Samsung SSD 500GB:
                    was meinst du damit?
                    Sieh dir dein log mal an:
                    https://forum.iobroker.net/topic/51046/raspi-3-model-b-mit-samsung-ssd-500gb/23?_=1641405869024
                    Die Zeilen sind total auseinandergerissen
                      PowerShell macht das nicht. Ganz stumpf per C&P hier reingekloppt:
                      echad@chet:~ $ dmesg -T
                      [Fri Dec 31 18:12:18 2021] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
                      [Fri Dec 31 18:12:18 2021] Linux version 5.10.63-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1488 SMP PREEMPT Thu Nov 18 16:16:16 GMT 2021
                      [Fri Dec 31 18:12:18 2021] random: fast init done
                        Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                        dmesg -T
                        waren da Zeilenumbrüche in der Shell?
                        Hier mit schmalem puTTy Fenster und Zeilenumbrüchen
                        Mal sehen:
                        pi@raspberrypi:~ $ dmesg -T
                        [Fr Nov  5 15:48:53 2021] Booting Linux on physical CPU 0x0
                        [Fr Nov  5 15:48:53 2021] Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1459 SMP Wed Oct 6 16:41:57 BST 2021
                        [Fr Nov  5 15:48:53 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                        EDIT:
                        auch alles gut.
                        Dann weiß ich nicht mehr wo ich das Problem mit den langen Leerzeichen/Tabs hatte 😞
                        muss dann wohl ein Windoof Tool gewesen sein
                        (aber wieso habe ich da Ubuntu/Linaro auf einem Pi4?????)
                        EDIT2:
                        geht doch 🙂
                        Das Gegenteil von gut ist gut gemeint!
                        Wenn man nachträglich das Fenster größer zieht und dann kopiert...
                        [Fr Nov  5 15:48:53 2021] Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-g        nueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ub        untu) 2.34) #1459 SMP Wed Oct 6 16:41:57 BST 2021
                        [Fr Nov  5 15:48:53 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr        =30c5383d
                          Thomas Braun Most Active @Homoran last edited by Thomas Braun
                          @homoran sagte in Raspi 3 Model B mit Samsung SSD 500GB:
                          Logisch. Sonst wäre das ja keine Aussage. Ist aber auch OT.
                          Nachträglich aufgezogen aber auch kein Ding:
                            und jetzt?
                              @jürgenio
                              Da ich das so nicht im Einsatz habe:
                              Du bootest von der SD-Karte und die Partition auf der SSD wird dann (über die fstab?) beim Boot-Vorgang eingehängt?
                                Nein. Keine SD Karte. Komplett von SSD
                                  @jürgenio
                                  nur so eine Idee:
                                  Wenn ich eine minimal Konfiguration auf SD Karte mache. Ohne ioBroker. Dann alles auf die SSD.
                                  Sollte das laufen, mit ioBroker weiter machen????
                                    @jürgenio
                                    Kann ich dir nicht sagen.
                                      vielleicht hat ja noch jemand eine Idee, was ich probieren kann.
                                      Wenn nicht, würde ich das mal testen...
                                      Grüße und Danke für eure Hilfe
                                        ich bin mir nicht sicher, aber ich denke @Thomas-Braun wollte dir sagen, dass dmesg diese Konfiguration ausspuckt.
                                        Kann mich aber auch irren
                                          Ich bin nicht sicher. Aber ich meine da wären Hinweise auf eine SD-Karte drin, stimmt.
                                          @JürgenIO
                                          cat /etc/fstab
                                          blkid
                                          sagt?
                                            cat /etc/fstab
                                            proc            /proc           proc    defaults          0       0
                                            PARTUUID=4c6fdb90-01  /boot           vfat    defaults          0       2
                                            PARTUUID=4c6fdb90-02  /               ext4    defaults,noatime  0       1
                                            # a swapfile is not a swap partition, no line here
                                            #   use  dphys-swapfile swap[on|off]  for that
                                            86
                                            4046
