    5. Blocky script
    Blocky script
    • I
      ingenii @Cinimod last edited by ingenii
      @cinimod
      Hallo ,
      meine Lieferung von Homematic ist nicht gekommen dann bin ich nur Provisorium aufgebaut und ich hab Geist schalterrung Troc Alle in Datenpunk auf False sind.
      Danke für jeder Tip
      • I
        @cinimod
        Mein Konfig:
        Kinderzimmer:
          <variables>
            <variable id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</variable>
          </variables>
          <block type="comment" id="_9LVB+mDFTm*bn-vUbQ{" x="-88" y="-1062">
            <field name="COMMENT">Kinderzimmer</field>
              <block type="on_ext" id="K,WN,pgM_?_@X4vx9kNn">
                <mutation xmlns="http://www.w3.org/1999/xhtml" items="5"></mutation>
                <value name="OID0">
                  <shadow type="field_oid" id="g^#UD(O)#46O[YL/yhiu">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
                <value name="OID1">
                  <shadow type="field_oid" id="GR{OtJXvaxmJ/8frKVV5">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
                <value name="OID2">
                  <shadow type="field_oid" id="AaDu2IdLTc;_8Y^(=#1u">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
                <value name="OID3">
                  <shadow type="field_oid" id="gz?y}5:(-k]7M;_c)L@c">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
                <value name="OID4">
                  <shadow type="field_oid" id="f,#bPavRADQa!^9vgT;r">
                    <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
                  <block type="controls_if" id="zr))xYp5q6uk7gWR:FLp">
                      <block type="logic_compare" id="(%ip:yl;!KUbNeYJO=Q.">
                        <field name="OP">EQ</field>
                          <block type="on_source" id="IQvqF`Ea*52V%WOo$(BG">
                          <block type="math_number" id="YaM59`_}h-7w]wlp%rz]">
                            <field name="NUM">1</field>
                      <block type="control" id="hS]=O?t$f/y`yv?xV.9v">
                        <field name="OID">0_userdata.0.Testordner.Kinderzimmer_temp_Heizung</field>
                          <block type="logic_boolean" id="@WvR96o@/GT_W,v[-k@;">
                          <block type="variables_set" id="]qW3c_5Vo7}]mwMJaX]u">
                            <field name="VAR" id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</field>
                              <block type="logic_boolean" id="%|=KaL92,D:1}t?+_kh@">
                    <value name="IF1">
                      <block type="logic_operation" id="NI74tl{Cv%y2nnZ2mq(_" inline="false">
                        <field name="OP">AND</field>
                          <block type="logic_operation" id="nBhW:|6IjFd#]:==r9MT" inline="false">
                              <block type="logic_operation" id="TzDrBAgL)l{6h%e)Nbix" inline="false">
                                  <block type="logic_compare" id="H-by~#=i7qLd];I!ss,u">
                                      <block type="get_value" id="G{e*#Ck_W4)[t!9NfppK">
                                        <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
                                      <block type="math_number" id="tV{:u[3b2[XI5;6o#uwv">
                                        <field name="NUM">0</field>
                                  <block type="logic_compare" id="(Bj)7ZJ(0pgXXEA`sjl4">
                                      <block type="get_value" id="CN}w9(9wU2-hnR|}zN~M">
                                        <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
                                      <block type="math_number" id="qxF?+P?(5WT4+Zh~VDzH">
                              <block type="logic_operation" id="iAW5jBZ|80_MVv0zs#04" inline="false">
                                  <block type="logic_compare" id="=FJ$#)NF)p%K+ci}.G+{">
                                      <block type="get_value" id="b0E:[G*)^Jkwfko9)-UG">
                                        <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
                                      <block type="math_number" id="y@6zGn;xb0N/DCub4E+j">
                                  <block type="logic_compare" id="7uPMqgWG]Q790FDLTidp">
                                      <block type="get_value" id="5o;cwewhu(gE!B3`kDDT">
                                        <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
                                      <block type="math_number" id="]T=$eX#l;JqAc9b,Y}+*">
                          <block type="logic_compare" id="(OQ76rw~]R]9Q_P/kA`V">
                              <block type="get_value" id="R-*;=g!1Qh_#Zl_G0VM4">
                                <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
                              <block type="math_number" id="aeH:*7-Gn3!c~HF5au^!">
                    <statement name="DO1">
                      <block type="variables_set" id="ceR.;izW_r3Ty20RG_EX">
                          <block type="logic_boolean" id="D=!E,]q}FEHKUapa+q=2">
                  <block type="on_ext" id="PbE+r6ibR_B!K.FQ}Fa$">
                    <value name="OID0">
                      <shadow type="field_oid" id="R*u+`^~1q(-5RFx%o(wQ">
                        <field name="oid">sonoff.0.Temparature_kinderzimmer(TH10).AM2301_Temperature</field>
                    <value name="OID1">
                      <shadow type="field_oid" id="%,@ga-xK38tS$Zg=d_y0">
                        <field name="oid">hm-rpc.1.000A1D8998382C.1.SET_POINT_TEMPERATURE</field>
                      <block type="controls_if" id="r*B?@=L`.guY]MLJ.H@.">
                          <block type="logic_operation" id="}2~Ew~gv@IZK*(xct$ew" inline="false">
                              <block type="logic_compare" id="r//HYzBmYjm~s0OP1M`z">
                                <field name="OP">LT</field>
                                  <block type="get_value" id="X%j!o4/4cvnH?_-=y8W-">
                                    <field name="OID">sonoff.0.Temparature_kinderzimmer(TH10).AM2301_Temperature</field>
                                  <block type="get_value" id="JTFkdm].gf$UMbo%^75a">
                                    <field name="OID">hm-rpc.1.000A1D8998382C.1.SET_POINT_TEMPERATURE</field>
                              <block type="logic_negate" id="uy%HA(W4G:,?!bqWeHm%">
                                <value name="BOOL">
                                  <block type="variables_get" id="d.x;V!*lz-mDZx7[Wa;a">
                          <block type="control" id="#5GKyB|4=F4zr^[k^cQk">
                              <block type="logic_boolean" id="wjLU9dHN#h7Y?!IU[;}G">
                        <value name="IF1">
                          <block type="logic_compare" id="9ky*iEK/IP-4$]#(bfJ3">
                            <field name="OP">GT</field>
                              <block type="get_value" id="bGYSrX7HR^lxGJ)+x_#p">
                              <block type="get_value" id="4h}L8%1PBaP2pIb3+y=z">
                          <block type="control" id="i@!4wAn+FGd4.YpiNN-=">
                              <block type="logic_boolean" id="ft~;-EU^W[TB:.[I(TFD">
        I 2 Replies Last reply Reply Quote 0
        • I
          ingenii @ingenii last edited by ingenii
          @Cinimod
          Schalfzimmer:
            <variables>
            </variables>
            <block type="comment" id="/0CV^O!1aoUk:BM=JQvY" x="-62" y="-1062">
              <field name="COMMENT">Schlafzimmer</field>
                  <value name="OID0">
                  <value name="OID1">
                  <value name="OID2">
                  <value name="OID3">
                  <value name="OID4">
                          <field name="OID">0_userdata.0.Testordner.Schalfzimmer_temp_Heizung</field>
                      <value name="IF1">
                      <value name="OID0">
                          <field name="oid">sonoff.0.Temparature_Schlafzimmer(TH16).SI7021_Temperature</field>
                      <value name="OID1">
                          <field name="oid">hm-rpc.1.000A1D89983B40.1.SET_POINT_TEMPERATURE</field>
                                      <field name="OID">sonoff.0.Temparature_Schlafzimmer(TH16).SI7021_Temperature</field>
                                      <field name="OID">hm-rpc.1.000A1D89983B40.1.SET_POINT_TEMPERATURE</field>
                                  <value name="BOOL">
                          <value name="IF1">
          • I
            @Cinimod
            Datenpunkt:
              <block type="on_ext" id="PbE+r6ibR_B!K.FQ}Fa$" x="-20" y="-547">
                <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
                <value name="OID0">
                    <field name="oid">0_userdata.0.Testordner.Kinderzimmer_temp_Heizung</field>
                <value name="OID1">
                  <shadow type="field_oid" id="d(7kaO!c#|rUIt#UbB={">
                    <field name="oid">0_userdata.0.Testordner.Schalfzimmer_temp_Heizung</field>
                <value name="OID2">
                  <shadow type="field_oid" id="DC]}pm|WdYkqYH*s(U9Y">
                    <field name="oid">0_userdata.0.Testordner.Gastezimmer_temp_Heizung</field>
                <value name="OID3">
                    <field name="oid">0_userdata.0.Testordner.Bad_1og_temp_Heizung</field>
                      <block type="logic_operation" id="HX[~7p30kaYu$)lN#N?|" inline="false">
                        <field name="OP">OR</field>
                          <block type="logic_operation" id="(1lKe/~%[/ym5C0WEI+)" inline="false">
                              <block type="logic_compare" id="hJ?OQP@wN3Qj7(`eg2RC">
                                  <block type="get_value" id="=a~[{q/wL_8NvB0GYBKy">
                                  <block type="logic_boolean" id="~)rU]Uf|RxwC*L;6:-ob">
                              <block type="logic_compare" id=":Sq$w}$5=)O`pmo=2yf;">
                                  <block type="get_value" id="AkjL]g},C{TRi-.EI~bP">
                                  <block type="logic_boolean" id=";Dgi8Kou1OA5*{Kno*:B">
                          <block type="logic_operation" id="+JV5hbNlN?udb*8%+_wB" inline="false">
                              <block type="logic_compare" id="(d7~t,DzVnE%Uw?Vdt1D">
                                  <block type="get_value" id="lCutf)+r1!K)FN7WmI![">
                                    <field name="OID">0_userdata.0.Testordner.Bad_1og_temp_Heizung</field>
                                  <block type="logic_boolean" id="8?~ty)5jrT/G=W1G0Y,7">
                              <block type="logic_compare" id="#~vQ_5RX|_OzdP,gvbXs">
                                  <block type="get_value" id="NN^Pp*t0!]Ex-q:um~.H">
                                    <field name="OID">0_userdata.0.Testordner.Gastezimmer_temp_Heizung</field>
                                  <block type="logic_boolean" id="12ipKo{9_9HGRQa*E_N1">
                      <block type="control" id="B=1I|N7S`4~26PlSAQ-%">
                        <field name="OID">sonoff.0.Heizung_R08.POWER8</field>
                          <block type="logic_boolean" id="y3;43=:xLQ(0wRm`(^`}">
                          <block type="control" id="~P;l$0_#%wUL.ixiKHxX">
                            <field name="OID">sonoff.0.Heizung_R08.POWER7</field>
                              <block type="logic_boolean" id="E^)mfO(7;lQ@6`d3r$5d">
                    <value name="IF1">
                          <block type="logic_operation" id="x0;06[4!-J-wM?6Xg-O:" inline="false">
                              <block type="logic_operation" id=",`JZOgL5aBSu8HVPZ0NW" inline="false">
                                      <block type="logic_boolean" id="O=x2`^..rQlbo?6Ng!xs">
                                  <block type="logic_compare" id="BV^sU|2@;Fh{+tPIUP6*">
                                      <block type="get_value" id="+=iCY2C6oN%.dQ/^kxe{">
                                      <block type="logic_boolean" id="Hsk~I1ACC%z$h!rX)wHd">
                              <block type="logic_compare" id="Yu*GN1tHPn|]JAtxBnAd">
                                  <block type="get_value" id="N;ZrYsp838;u5R=`Lh`H">
                                  <block type="logic_boolean" id="0h4:VOw~9d0+03^9HqNd">
                          <block type="logic_compare" id="/l,p+tv-nab=p0o3q=#]">
                              <block type="get_value" id="T|(8__(z0vg?@DK,})PM">
                              <block type="logic_boolean" id="b[}@z,E%pfC_t+azaXqk">
                      <block type="control" id="WLLdD.vKC!_^=OYxX*Rp">
                          <block type="logic_boolean" id="ldc#N@{RI=c{~~U$;#vk">
                          <block type="control" id="M;TncfhU?kR;[#Dn_Z)_">
                              <block type="logic_boolean" id="o@IGbqby.SrxA-ZhATy#">
            • I
              @Cinimod
              Was gehört hier ?
              Switch oder State ?
              • Cinimod
                Cinimod Most Active @ingenii last edited by
                @ingenii sagte in Blocky script:
                @Cinimod
                Was gehört hier ?
                Switch oder State ?
                State
                Was genau ist denn jetzt dein Problem ?
                • I
                  @cinimod
                  es hat immer was Heizung für 1 bis 2 Minuten eingeschaltet auch wen Temperatur zu hoch wahr.Problem wahr das ich immer zu spät gesehen hab und nicht nachvollziehen kann von wo das kommt.
                  Dann Detail suche und bin drauf gekommen das ein Temp sensor bei Sonoff kaputt ist liefert ab und zu verschiedene Daten.
                  Jetzt passt alles,
                  • I
                    @cinimod
                    hab ein kleines Problem, in Verwendung sind deine Scripts .In Wohnzimmer passiert das mir etwas Datenpunkt auf False steuert und ich weiß nicht was. Ich hab schon ein neuen Datenpunk erstellt das der nicht unabsichtlich irgendwo in anders drinnen ist und passiert wieder, ich stelle Set Point Temp um 2 Grad mehr das ich weiss das sicher Heizung ganze zeit lauf.
                    Es ist ein Fußboden Heizung deswegen rennt Heizung nur cca 45 Minuten und Dann geht automatisch heizung auf OFF aber nicht Datenpunkt denn steuere ich mit einem Script der heist Restart Datenpunk aber bei dem hab ich 90Minuten also muss Heizung starten(Datenpunk) und Datenpunk wen Temp nicht erreicht Set Temp musst erst nach 90Minuten auf Datenpunkt False und dan soll wieder Staten, aber bei mir auch wen ich dieser Neustart Datenpunk deaktiviere geht jeden cca 10 Minuten Datenpunk auf False und gleich wieder auf True.
                    Script :
                      <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;" x="-287" y="-787">
                        <value name="OID0">
                          <shadow type="field_oid" id="S5Ja?RFgi-amy%b3nasc">
                            <field name="oid">hm-rpc.1.000A9D899F65CB.1.ACTUAL_TEMPERATURE</field>
                        <value name="OID1">
                          <shadow type="field_oid" id=",x^o!!V53@cT%;x8@hr]">
                            <field name="oid">hm-rpc.1.000A9D899F65CB.1.SET_POINT_TEMPERATURE</field>
                          <block type="controls_if" id="^IQpxvAC2OFS~7?Wb54p">
                              <block type="logic_compare" id="wv?fv3Sv#4)xrUA!h,;d">
                                  <block type="get_value" id="~FmMS%jS(50Pu}fG;xD(">
                                    <field name="OID">hm-rpc.1.000A9D899F65CB.1.ACTUAL_TEMPERATURE</field>
                                  <block type="get_value" id="29K2ZhjmlM^.$R%?*O?r">
                                    <field name="OID">hm-rpc.1.000A9D899F65CB.1.SET_POINT_TEMPERATURE</field>
                              <block type="control" id="BCFn=IlgKqu+C@xy)z`p">
                                <field name="OID">0_userdata.0.Testordner.Wohnzimmer_heizung</field>
                                  <block type="logic_boolean" id="CjsW,Fb567aTJf@*m@?U">
                            <value name="IF1">
                              <block type="logic_compare" id="r*KEn=z,[kyIxuL5}P;p">
                                <field name="OP">GTE</field>
                                  <block type="get_value" id="2T7[PNo`#A#Y.u(Q`c*H">
                                  <block type="get_value" id="E+-PcFA;?0rjyn;u~35W">
                              <block type="control" id="@*N1BGqFp,k14kZ$emx]">
                                  <block type="logic_boolean" id="knxl8#k^UDaS0z/qJVoA">
                    Restart Datenpunkt
                      <block type="on" id="g^ts;K(Z?cyM6vDaU%4X" x="-162" y="-420">
                          <block type="control" id="J.Vb7Iz{qxWpi`hHY_:6">
                            <field name="DELAY_MS">90</field>
                              <block type="logic_boolean" id="tw;W8Kimp?RG,kGR5}(e">
                    • Cinimod
                      @ingenii
                      Dein Skript welches nach 90 min. automatisch die Heizung abschaltet ist das Problem. Jedesmal wenn die Heizung Wahr angesteuert wird, wir dein Abschalt-block neu angestoßen mit 90 minütiger Verzögerung.
                      Dieser wird immer und immer wieder angestoßen, und lässt sich nicht stoppen.
                      Probier mal das:
                        <variables>
                        </variables>
                        <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;" x="-238" y="-787">
                          <value name="OID0">
                          <value name="OID1">
                                <block type="logic_operation" id=".lsG$2HZt^DVJB*6ws~|" inline="false">
                                    <block type="logic_negate" id="hBnvi-LmQ(j=.^{v)hq3">
                                      <value name="BOOL">
                                        <block type="get_value" id="1MBCiGjZW$VJF?c^n+R.">
                                          <field name="OID">ID auswählen</field>
                              <value name="IF1">
                                <block type="logic_operation" id="8J!J=QuO[VRTAwL--$??" inline="false">
                                    <block type="get_value" id="7(Ir`)[bFBmxYn!Eq^cZ">
                            <block type="on" id="g^ts;K(Z?cyM6vDaU%4X">
                                <block type="timeouts_cleartimeout" id="J0R;547HQ}}x15c(FKl:">
                                    <block type="controls_if" id="BCO@@c0uweSQ/iFZ4i.6">
                                        <block type="on_source" id="X=x!S!Z(EN`|N_%s/rwU">
                                        <block type="timeouts_settimeout" id="Vop9tK*z:cv$14_4.[B+">
                                          <field name="DELAY">90</field>
                        <block type="comment" id="T+k|y}jvRS_RuIjyrW(j" x="338" y="-637">
                          <field name="COMMENT">&lt;- hier noch Wohnzimmer_Heizung eintragen</field>
                        <block type="comment" id="/tI;IUq6a#gMH4?[s|MR" x="237" y="-537">
                      • I
                        @cinimod
                        Ja das Problem ist das fussboden Heizung eine Träge ist ich brauche das Heizung nur cca 45 lauft und dann gewisse zeit aus ist weil die warme Boden gibt gewisse zeit wärme ab erst nach gewisse zeit soll das wieder starten.
                        • Cinimod
                          @ingenii
                          Also nach 45 Minuten an, soll die Heizung auf jeden fall aus gehen, und wie lange soll sie mindestens aus bleiben, bis sie wieder an gehen darf ?
                          • I
                            @cinimod
                            am Relle was Heizung einschaltet und abschaltet hab ich (Tasmota:Pulsetime cca 45 minuten) das geht nach einschalten automatisch auf AUS aber nicht Datenpunkt Wohnzimmer, aber das hab ich schon geschrieben, ja zeit 120 minuten.
                            • Cinimod
                              @ingenii
                              Ich denke das entspricht etwa deiner Vorstellung :
                              Die Zeiten kannst du ja anpassen, und dein zweites Skript ganz weg lassen.
                                <variables>
                                  <variable id="eXyCA~sNI-z]Gw*blb(Q">sperre</variable>
                                  <variable type="timeout" id="timeout2">timeout2</variable>
                                </variables>
                                <block type="variables_set" id="2;(@A~;1iYQo@dys$@4E" x="-313" y="-812">
                                  <field name="VAR" id="eXyCA~sNI-z]Gw*blb(Q">sperre</field>
                                    <block type="logic_boolean" id="_*@_O2V@z)nbx}2a}ABw">
                                    <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;">
                                      <value name="OID0">
                                      <value name="OID1">
                                                <block type="logic_operation" id="eF6.mJ8)tZyOk]FLkTs/" inline="false">
                                                      <value name="BOOL">
                                                    <block type="logic_negate" id="-/QD8C}5Tjf-sJ3C)yE-">
                                                      <value name="BOOL">
                                                        <block type="variables_get" id="_{`SnXEPu~xnz!QQ;HIg">
                                                <block type="variables_set" id="NpRPBz7Hf6OrB9tVI/7]">
                                                    <block type="logic_boolean" id="HK7*w];WI5DxeR|H%([2">
                                                    <block type="timeouts_settimeout" id="}DJ},dg?Mi)VpfdMRY9{">
                                                      <field name="DELAY">45</field>
                                                        <block type="control" id="?sZli[f~Dg(yt|nc.o7.">
                                                            <block type="logic_boolean" id="}JIStyb]!4X!,7OnDcO@">
                                                        <block type="timeouts_settimeout" id="m|w:|K(tQvZk+Ivqybk~">
                                                            <block type="variables_set" id="JY3sfC=._q~axwH|VG#!">
        <block type="logic_boolean" id="f!j:dr|hTSbTHpM20JJ(">
                                          <value name="IF1">
                                                <block type="timeouts_cleartimeout" id="I{OA]-{AEf|djZqwmIP#">
                                <block type="comment" id="T+k|y}jvRS_RuIjyrW(j" x="262" y="-638">
                                <block type="comment" id="/tI;IUq6a#gMH4?[s|MR" x="163" y="-337">
                              • I
                                @cinimod
                                Ich werde das jetzt laufen lassen und Bericht Morgen.
                                • Cinimod
                                  @ingenii
                                  Gerne,
                                  so richtig verstehe ich aber garnicht wieso du überhaupt Pulsetime benutzt, lass das Skript doch ein und ausschalten. Abgesehen davon muss das abschalten mit Pulsetime aber doch auch den Datenpunkt wieder auf false setzen 🤔 oder ist das Heizung-Relais nicht der Datenpunkt den wir hier ansteuern ?
                                  • I
                                    @cinimod
                                    es Funk.. super, nach Minuten hab ich das nicht kontrolliert aber schaut besser aus meine Lösung.
                                    Sollte was mit Iobroker passieren brauche ich mir keine sorgen machen das Heizung ganze Tag rennt, Pulsetime ist Back Up.
                                    • Cinimod
                                      @ingenii
                                      Sehr schön das freut mich. 👍
                                      • I
                                        @cinimod
                                        heute ist das passiert, Datenpunkt hat sich nicht neu gestartet und seitdem hat Heizung nicht mehr gestartet, wahr leider nicht zu hause dann ich ich zu spät auf das gekommen.
                                        ich hab auch Scheduller für Script instantz Neustarten aber das bringt nichts weil Datenpunk wahr schon auf True und er rechnet erst von False auf True die 90 Minuten.
                                        Es gehört was anderes für Datenpunkt Restart.
                                        Eine idee ?
                                        • I
                                          @ingenii
                                          Kann das die Ursachen sein ? Was passiert wen dieser 90 Minuten zeit rennt und der Scheduller Startet die Ganze Script Instanz neu ?
                                          • I
                                            @cinimod
                                            Hilft das da :
                                            <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="xDq%i~$rGx~A.83cmM%;" x="-227" y="-848">
                                              <value name="OID0">
                                                  <field name="oid">sonoff.0.Heizung_R08.POWER6</field>
                                                          <field name="OID">sonoff.0.Heizung_R08.POWER6</field>
                                                        <block type="logic_boolean" id="4AB~efGz{|usYULCq%,U">
                                                      <field name="OID">0_userdata.0.Testordner.Wohnzimmer_temp_Heizung</field>
                                            5642
