    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
      Thomas Braun Most Active @Maxim-777 last edited by
      @maxim-777
      cd /opt/iobroker
      npm ls canvas
      M da_Woody D3ltoroxp 3 Replies Last reply Reply Quote 0
        Maxim-777 @Thomas Braun last edited by
        Danke, habe ich gemacht:
        iobroker.inst@3.0.0 /opt/iobroker
        ├─┬ iobroker.iot@1.8.24
        │ └── UNMET OPTIONAL DEPENDENCY canvas@2.8.0
        └─┬ iobroker.mihome-vacuum@3.3.1
          └── canvas@2.8.0
        Wenn ich jetzt den Adapter installiere, bekomme ich folgende Fehler 💩
        Was mache ich nun falsch?🤦‍♂️ 🤦‍♂️ 🤦‍♂️
        mihome-vacuum.1
        	2022-01-07 15:23:54.277	warn	This object will not be created in future versions. Please report this to the developer.
        mihome-vacuum.1
        	2022-01-07 15:23:54.276	warn	Object mihome-vacuum.1.cleanmap.actualMap is invalid: obj.type has to exist
        mihome-vacuum.1
        	2022-01-07 15:23:51.105	info	create new room: 212001026817
        mihome-vacuum.1
        	2022-01-07 15:23:51.103	info	create new room: 212001026816
        mihome-vacuum.1
        	2022-01-07 15:23:51.098	info	create new room: 212001026818
        mihome-vacuum.1
        	2022-01-07 15:23:50.215	warn	State "mihome-vacuum.1.cleanmap.mapStatus" has no existing object, this might lead to an error in future versions
        mihome-vacuum.1
        	2022-01-07 15:23:50.105	warn	State "mihome-vacuum.1.cleanmap.actualMap" has no existing object, this might lead to an error in future versions
        mihome-vacuum.1
        	2022-01-07 15:23:50.041	info	create states for mop
        mihome-vacuum.1
        	2022-01-07 15:23:49.951	info	create states for water box mode
          @maxim-777 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
          Da stimmt was nicht. Die Dependency ist ja eigentlich bedient, das Modul canvas hängt ja unter dem iobroker.mihome-vacuum . Das sollte eigentlich von dort dann erfüllt werden. Wie man das fixt weiß ich aber im Moment auch nicht.
          • da_Woody
            da_Woody @Thomas Braun last edited by
            @thomas-braun habs auch mal gemacht...
            woody@ioBroker:~$ cd /opt/iobroker
            woody@ioBroker:/opt/iobroker$ npm ls canvas
            [sudo] Passwort für woody:
            ├─┬ iobroker.iot@1.8.25
            │ └── canvas@2.8.0
              └── canvas@2.8.0  deduped
               │      New major version of npm available! 6.14.15 → 8.3.0      │
               │   Changelog: https://github.com/npm/cli/releases/tag/v8.3.0   │
               │               Run npm install -g npm to update!               │
            kann mir nicht vorstellen, das ich das machen sollte... 😵
            Thomas Braun M 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @da_Woody last edited by Thomas Braun
              @da_woody sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
              Richtig! FINGER WEG! 😄
              Aber bei dir sieht man eine saubere Installation von canvas. Ohne UNMET DEPENDENCIES. So soll es sein.
                Maxim-777 @da_Woody last edited by
                @da_woody
                mach das NICHT!
                hast du auch noch kein Erfolg?
                • da_Woody
                  da_Woody @Maxim-777 last edited by
                  @maxim-777 hehe, keine angst, soweit bin ich geheilt... 😄
                  erfolg nur insofern, das die DP zwar gefüllt sind, aber es wird nicht mehr wie früher in meiner visu aktualisiert.
                  vor den ganzen problemen konnte ich da zuschauen, wie in der APP. jetzt nur mehr, wenn ich refreshe.
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @da_Woody last edited by
                    welches widget und wie eingebunden?
                    • da_Woody
                      da_Woody @bahnuhr last edited by
                      @bahnuhr das ist iQontrol...
                      • bahnuhr
                        das ist iQontrol...
                        ok, kenn ich nicht.
                          Maxim-777 @bahnuhr last edited by
                          Ich habe gerade ausprobiert mit nem neuen Pi (frisch installiert nodejs 14 und Iobroker)
                          mihome-vacuum 3.3.1 Installiert, da kommen folgende Fehler beim ersten Adapter Start raus:
                          ist es bei alle so? Wenn, man komplett von vorne anfängt.
                            @maxim-777
                            Welche Fehler siehst du da? Das sind nur Infos und Hinweise.
                              Sorry, natürlich sind es keine Fehler, sondern Hinweise, ich meine, die Karte wird nicht mehr erstellt mit neue Installation von mihome-vacuum Adapter. mit alte laufende Adapter bekomme ich schon hin, aber wenn ich neue Instanz erzeuge bekomme ich immer die gleiche hinweise, habe auch schon mit 2 Verschiedene iobroker ausprobiert, die komplett neu von der Installation sind.
                                guergen @Maxim-777 last edited by guergen
                                Die Instanz läuft, der Staubsauger S5 auch, aber die Karte wird nicht erneuert.
                                In der App läuft die Map.
                                Habe die Map-DP im IoB gelöscht.... nix...
                                Weiss zufällig jmd, wie man das wieder hinbiegt?
                                ? M 2 Replies Last reply Reply Quote 0
                                  A Former User @guergen last edited by
                                  @guergen kommt drauf an, warum.
                                    Maxim-777 @guergen last edited by
                                    @guergen
                                    ich kämpfe seit mehreren Tagen, bekomme aber immer noch nicht hin, die Map ladet einfach nicht in Iob.
                                      @maxim-777 Genau, es funktioniert alles, ausser der Map, da wurde seit mehreren Tagen keine neue generiert.
                                      Daher hab ich die DP gelöscht und neu anlegen lassen vom Adapter.
                                      • D3ltoroxp
                                        D3ltoroxp @Thomas Braun last edited by
                                        @thomas-braun Ich hab das auch mal gemacht, sieht bissel komisch aus oder ?
                                        iobroker.inst@2.0.3 /opt/iobroker
                                        ├── canvas@2.6.1
                                        │ └── canvas@2.8.0
                                          └── canvas@2.8.0
                                          Thomas Braun Most Active @D3ltoroxp last edited by
                                          @d3ltoroxp Da hast du vermutlich mal canvas 'daneben' geworfen.
                                          Sauber schaut das so ähnlich aus:
                                          echad@chet:/opt/iobroker $ npm ls canvas
                                          [sudo] password for echad:
                                          ├─┬ iobroker.echarts@1.0.3
                                          │ ├── canvas@2.8.0
                                          │ └─┬ jsdom@16.7.0
                                          │   └── canvas@2.8.0 deduped
                                          │ ├── canvas@2.8.0 deduped
                                          │ └─┬ jsdom@17.0.0
                                          ├─┬ iobroker.mihome-vacuum@3.3.1
                                          ├─┬ zigbee-herdsman-converters@14.0.339 extraneous
                                          │ ├─┬ jsdom@16.7.0 extraneous
                                          │ │ └── canvas@2.8.0 deduped
                                          │ └─┬ zigbee-herdsman@0.13.177 extraneous
                                          │   └─┬ jsdom@16.7.0 extraneous
                                          └─┬ zigbee-herdsman@0.13.178 extraneous
                                            Maxim-777 @D3ltoroxp last edited by Maxim-777
                                            @d3ltoroxp
                                            Ich glaube, du hast noch ein Ordner "canvas" unter /opt/iobroker. Der Ordner "canvas" muss hier sein: /opt/iobroker/node_modules.
                                            Kannst du es nachschauen?
                                            Ich habe es auch mittlerweile hinbekommen, hat aber NIX gebracht.
                                            │ └── canvas@2.8.0
                                              └── canvas@2.8.0
                                            1198
                                            363610
