    • wendy2702
      wendy2702 @s.bormann last edited by
      @s-bormann Hi,
      ich versuche gerade das Device-Counter Blockly zu nutzen stoße aber immer auf diese Error einträge im Log und sehe auch keine Veränderungen an den DP's wenn ich ein Fenster öffne.
      7.1.2022, 09:15:08.524	[info ]: javascript.0 (12048) Start javascript script.js.common.Home.DeviceCounter
      7.1.2022, 09:15:08.536	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: registered 0 subscriptions and 0 schedules
      7.1.2022, 09:15:08.635	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: ------ Offene Fenster EG ------ 0 von 0:
      7.1.2022, 09:15:08.679	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: ------ Offene Türen ------ 0 von 0:
      7.1.2022, 09:15:08.759	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: ------ Offene Fenster und Türen ------ 0 von 0:
      7.1.2022, 09:15:10.176	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: ------ LOWBAT ------ 0 von 1:
      7.1.2022, 09:15:11.204	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: ------ UNREACH ------ 0 von 1:
      7.1.2022, 09:15:12.283	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.283	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.283	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.284	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.284	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.284	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.285	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.286	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.286	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.286	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.288	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.288	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.288	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.289	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.289	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.289	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.290	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.290	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.292	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.292	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.292	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.293	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.293	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.293	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.294	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.294	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.294	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.295	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.295	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.295	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.296	[warn ]: javascript.0 (12048)     at deviceCounter (script.js.common.Home.DeviceCounter:131:50)
      7.1.2022, 09:15:12.296	[warn ]: javascript.0 (12048)     at addDeviceCounter (script.js.common.Home.DeviceCounter:42:3)
      7.1.2022, 09:15:12.296	[warn ]: javascript.0 (12048)     at script.js.common.Home.DeviceCounter:168:1
      7.1.2022, 09:15:12.300	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: ------ ERROR ------ 0 von 353:
      7.1.2022, 09:15:13.277	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: ------ MAINTENANCE ------ 0 von 0:
      7.1.2022, 09:15:14.290	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: ------ SABOTAGE ------ 0 von 0:
      7.1.2022, 09:15:15.269	[info ]: javascript.0 (12048) script.js.common.Home.DeviceCounter: ------ CONFIG_PENDING ------ 0 von 0:
      7.1.2022, 09:16:14.920	[info ]: javascript.0 (12048) Stop script script.js.common.Home.DeviceCounter
      Habe aktuell nur ein Fenster und eine Tür in den enums:
      Was mache ich falsch bzw. wo liegt mein Fehler?
      • da_Woody
        da_Woody @s.bormann last edited by
        @s-bormann hab jetzt versucht eine online liste zu erstellen.
        kommt allerdings nichts an.
        als was bindest du die liste dann ein? als widget? als background?
        auch mit lichtern scheitere ich kläglich. da bekomm ich wenigstens eine liste. allerdings viel schrott dabei...
        dslraser s.bormann 2 Replies Last reply Reply Quote 0
        • dslraser
          dslraser Forum Testing Most Active @s.bormann last edited by
          @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis:
          @dslraser sagte in Test Adapter iQontrol 1.11.x Vis:
          @s-bormann
          es gibt ja die Option die Höhe der Kachel an State anzupassen.
          Wäre diese Option auch für z.B. BACKGROUND_HTML möglich ?
          Das wäre für dynamische Inhalte wirklich prima.
          prinzipiell geht das, allerdings ist dafür eine postMessage-Kommunikation aus dem iFrame an iQontrol nötig. Der iFrame muss an iQontrol senden, wie hoch er selbst sein möchte.
          Hier ist die Codezeile, wie das der BackgroundView macht:
          window.parent.postMessage({ command: "adjustHeightToBackgroundView" , value: height }, "*");
          Das ganze ist dann noch an einen Resize-Observer geknüpft, der Änderungen der Höhe erkennt und nach außen "meldet". Hier das komplette Code-Fragment:
          	//ViewContent Resize-Observer
          	if(isBackgroundView && adjustHeightToBackgroundView){
          		console.log("Starting ViewMain resize observer");
          		var viewContentResizeObserver;
          		var viewContentResizeObserverOldHeight = 0;
          		if (viewContentResizeObserver){
          			viewContentResizeObserver.disconnect();
          		} else {
          			viewContentResizeObserver = new MutationObserver(function(mutationList){
          				mutationList.forEach(function(mutation){
          					if (mutation.attributeName === 'style'){
          						var delay = 10;
          						if($('html').hasClass('adjustHeightToBackgroundViewInitial')){
          							console.log("adjustHeightToBackgroundView initially delayed");
          							delay = 500;
          						setTimeout(function(){
          							console.log("adjustHeightToBackgroundView");
          							$('html').removeClass('adjustHeightToBackgroundViewInitial');
          							var height = $('#ViewMain').innerHeight();
          							if (viewContentResizeObserverOldHeight != height){
          								window.parent.postMessage({ command: "adjustHeightToBackgroundView" , value: (($('#ViewHeaderTitle').css('display') == 'none' ? 0 : 1) * $('#ViewHeaderTitle').outerHeight(true)) + ($('#ViewContent').innerHeight() * zoom) + 6 }, "*");
          							viewContentResizeObserverOldHeight = height;
          						}, delay);
          		viewContentResizeObserver.observe(document.querySelector('#ViewContent'), {attributes: true, attributeOldValue: true, childList: false, subtree: true});
          Wenn Du Dich da dran wagst, sag mir bescheid, dann helfe ich Dir.
          Ich habe jetzt schon eine ganze Weile damit "rumgefummelt" aber ich weiß nicht wie ich das ganze einbinden soll...?
          Eigentlich dachte ich auch, das Du das als Option, z.B. in Widget für BACKROUND_HTML einbauen könntest. Also so wie für STATE.
          Ich habe z.B. zum testen STATE leer gelassen und nur BACKROUND_HTML verlinkt auf ein eigenes dynamisches HTML. Die Kachel habe ich, wenn das Gerät aktiv ist auf 3x0,5. Wenn jetzt der Inhalt des HTML länger/größer wird, dann möchte ich das die Kachel sich in der Höhe anpasst. Das könnte man sicher für sehr viele "HTML" Sachen oder auch Listen usw. ganz gut gebrauchen. Man hätte dann keine "starre" Kachelgröße mehr.
          s.bormann 1 Reply Last reply Reply Quote 1
          • dslraser
            Hiermit wird es zukünftig möglich sein, sich
            offene Fenster
            eingeschaltete Lichter
            leere Batterien
            alle Steckdosen
            Servicemeldungen
            etc. etc.
            generieren und auch anzeigen zu lassen.
            Die Listen sind auch bedienbar, d.h. man kann z.B. die Lampen anklicken, um sie an- und auszuschalten.
            Ich glaube, die Möglichkeiten sind hier riesig und ich bin schon auf Eure kreativen Ideen und Anwendungen gespannt!
            Das ganze ist "Early Preview". Bei mir läuft es schon ganz OK, aber hier und da wird sich noch der ein oder andere Fehler verbergen. Und ein paar Funktionen sollen auch noch folgen, z.B. fest eingebaute oder zumindest importierbare Standard-Counter.
            Wenn ich Zeit habe teste ich das auch gern mit. Im Prinzip könnte ich dann meine Blocklys in Rente schicken, die machen ja genau das gleiche. (auch Licht/Steckdosen sind in meinen Blocklys schaltbar)
            • dslraser
              dslraser Forum Testing Most Active @da_Woody last edited by dslraser
              @da_woody
              mit den Lampen/Licht über meine Aufzählung bekomme ich z.B. alle eingeschalteten Lampen als Anzahl und auch als Liste. Wie man die zusätzlichen Angaben wie z.B. alias.0.Licht usw. entfernt erschließt sich mir auch noch nicht. Ich hätte da gen den Namen und nicht die ID. Wie man dann Icon einbindet und auch die Lichter schalten könnte weiß ich auch noch nicht ...?
              Als was man das einbindet (z.B. Widget) steht leider auch noch nirgends, jedenfalls habe ich nix gefunden.
              Wenn ich das Licht schalte, dann wird auch die Liste aktualisiert, das klappt schon mal
              da_Woody s.bormann 2 Replies Last reply Reply Quote 0
              • s.bormann
                s.bormann Most Active @wendy2702 last edited by
                @wendy2702 sagte in Test Adapter iQontrol 1.11.x Vis:
                @s-bormann Hi,
                gute Frage, sehe den Fehler jetzt auf den ersten Blick leider auch nicht.
                Aber, bevor wir da weiter einsteigen: Ich bin gerade dabei, diese Funktion in iQontrol zu integrieren. Deshalb empfehle ich da im Moment erst mal nicht weiter zu machen. Die neue Funktion läuft gerade im Alpha-Test (siehe ein paar Posts weiter). Sie steht als demnächst zur Verfügung und sollte dann die Blockly-Lösung ablösen.
                VG
                • s.bormann
                  s.bormann Most Active @da_Woody last edited by
                  @da_woody sagte in Test Adapter iQontrol 1.11.x Vis:
                  ich habe bei mir auch gar keine States mit der Rolle "online".
                  Ich habe indicator.reachable oder (viel mehr) indicator.unreach.
                  Probiers mal damit.
                  • s.bormann
                    @s-bormann
                    		} else {
                    						var delay = 10;
                    							delay = 500;
                    						}, delay);
                    Du könntest folgende beiden Optionen vielleicht nutzen:
                    • dslraser
                      Probiert und funktioniert nicht (und STATE ist bei mir leer)
                      • da_Woody
                        da_Woody @dslraser last edited by
                        hehe, seb machts wiedermal geheimnissvoll. immerhin hat er ja schöne bildchen gepostet... 😉
                        dabei fällt mir ein:
                        das wäre für mich so eine geschichte für einen eigenen threat, eventuell ein eigenes unterforum. da könnte man dann entspannt nach gewissen beiträgen suchen und tips zu einem speziellen thema finden. ich finde inzwischen in den >6000 nichts mehr. und wenn, kommen jede menge postings zu was anderem dazwischen...
                        wendy2702 1 Reply Last reply Reply Quote 3
                        • s.bormann
                          @da_woody
                          Dann erstelle ein Widget (z.B. über Widget automatisch erstellen) und wählen den Device-Counter:
                          Und bei den Widget-Einstellungen wählst Du unter Allgmein Deinen Counter aus
                          • wendy2702
                            wendy2702 @da_Woody last edited by wendy2702
                            Eigenes Unterforum mit einzelnen Themen fände ich auch sinnvoll.
                            Starte gerade mit iqontrol und dieser thread hier erschlägt mich gerade etwas.
                            • wendy2702
                              @s-bormann ok.
                              Dann spiele ich mal mit der neuen Version rum.
                              • dslraser
                                dslraser Forum Testing Most Active @s.bormann last edited by dslraser
                                wie bekomme ich ein Icon und vor allem, wie bekomme ich die Namen der Geräte ?
                                schalten funktioniert.
                                Icon habe ich jetzt gefunden
                                  martinschm @s.bormann last edited by
                                  @s-bormann said in Test Adapter iQontrol 1.11.x Vis:
                                  @martinschm sagte in Test Adapter iQontrol 1.11.x Vis:
                                  ich bastel gerade an meiner Heizungssteuerung über iQontrol für die ich den heatingcontrol Adapter verwende. Hab es jetzt endlich mal mit dem Date/Time Control hinbekommen und jetzt sieht es so aus:
                                  Bitte nur das unter "Zusätzliche Steuerelemente" beachten. Dort kommen jetzt aber noch 3 weitere Zeiten+Temperaturen rein. Lässt sich das noch irgendwie kompakter darstellen?
                                  Vielleicht in dem man die Controls direkt neben der Beschriftung anzeigt?
                                  Zweite Frage wäre, ob ich das Feld rund um die Uhrzeit anders darstellen kann?
                                  Diese riesige Textbox sieht nicht so cool aus.
                                  ciao
                                  Martin
                                  Hi Martin,
                                  aktuell graust es mir ehrlich gesagt davor, die Additional-Controls noch mal umzumodeln, auch wenn es optional ist. Das ganze war ziemlich aufwändig (Stichwort: Verschiedene Browser!) und hat wirklich tage gedauert, bis es überall gepasst hat.
                                  Wenn Du mir die notwendigen CSS-Codes liefern könntest, die das ganze möglich machen, dann könnte ich aber eine Option einbauen, die den Controls eine Klasse verpasst, mit denen man Deinen CSS-Code dann anwenden könnte.
                                  LG
                                  Hi, alles gut, verstehe ich sehr gut. Bin leider nicht fit in CSS, das ich dir das liefern könnte. Ich dachte ich frage einfach mal, fragen kostet ja nichts 😉
                                  • s.bormann
                                    Kannst Du statt BACKGROUND_HTML nicht STATE befüllen?
                                    • dslraser
                                      dann wird nicht angezeigt.
                                      • dslraser
                                        Wäre das nicht z.B. für Deine neue Listenfunktion gut brauchbar ? Wenn man eine kurze Liste hat und dann werden Geräte eingeschaltet und dann wächst die Kachel mit ?
                                        • dslraser
                                          bei mir wird die Liste "falsch" dargestellt. Keine Geräte Namen
                                          M dslraser 2 Replies Last reply Reply Quote 0
                                            Tschaeens @dslraser last edited by Tschaeens
                                            @dslraser
                                            darf ich dich fragen, wie du das EPG paar Einträge weiter oben in iQontrol eingebunden hast? Ich könnte ein json von meiner Box abfragen.
                                            Lieben Gruß
                                            295
                                            7634
                                            6647948
