    4. [Anleitung] WireGuard mit WireGuard-UI auf Proxmox
    • Yogi 0
      Yogi 0 @CrunkFX last edited by
      @crunkfx
      Hier die Ausgabe, nachdem auf Apply Config geklickt wurde:
      root@wireguard:~# systemctl status wgui
      * wgui.service - Restart WireGuard
          Loaded: loaded (/etc/systemd/system/wgui.service; enabled; vendor preset: enabled)
          Active: failed (Result: exit-code) since Tue 2022-01-04 11:09:45 CET; 6s ago
      TriggeredBy: * wgui.path
         Process: 5792 ExecStart=/usr/bin/systemctl restart wg-quick@wg0.service (code=exited, status=203/EXEC)
        Main PID: 5792 (code=exited, status=203/EXEC)
             CPU: 511us
      Jan 04 11:09:45 wireguard systemd[1]: Starting Restart WireGuard...
      Jan 04 11:09:45 wireguard systemd[1]: wgui.service: Main process exited, code=exited, status=203/EXEC
      Jan 04 11:09:45 wireguard systemd[1]: wgui.service: Failed with result 'exit-code'.
      Jan 04 11:09:45 wireguard systemd[1]: Failed to start Restart WireGuard.
      CrunkFX 1 Reply Last reply Reply Quote 0
      • CrunkFX
        CrunkFX Forum Testing @Yogi 0 last edited by
        @yogi-0 Was zeigt:
        ls /bin
        • Yogi 0
          @crunkfx
          bin zeigt folgende Inhalte:
          root@wireguard:~# ls /bin
          bash          cat            domainname  gzip        lsmod       networkctl     ntfstruncate  rm         systemctl                       true             zegrep
          bunzip2       chgrp          dumpkeys    hostname    mkdir       nisdomainname  ntfsusermap   rmdir      systemd                         udevadm          zfgrep
          busybox       chmod          echo        ip          mknod       ntfs-3g        ntfswipe      rnano      systemd-ask-password            ulockmgr_server  zforce
          bzcat         chown          ed          journalctl  mktemp      ntfs-3g.probe  openvt        run-parts  systemd-escape                  umount           zgrep
          bzcmp         chvt           egrep       kbd_mode    more        ntfscat        pidof         sed        systemd-hwdb                    uname            zless
          bzdiff        cp             false       kill        mount       ntfscluster    ping          setfont    systemd-inhibit                 uncompress       zmore
          bzegrep       cpio           fgconsole   kmod        mountpoint  ntfscmp        ping4         setupcon   systemd-machine-id-setup        unicode_start    znew
          bzexe         dash           fgrep       ln          mt          ntfsfallocate  ping6         sh         systemd-notify                  vdir
          bzfgrep       date           findmnt     loadkeys    mt-gnu      ntfsfix        plymouth      sleep      systemd-sysusers                wdctl
          bzgrep        dd             fuser       login       mv          ntfsinfo       ps            ss         systemd-tmpfiles                which
          bzip2         df             fusermount  loginctl    nano        ntfsls         pwd           static-sh  systemd-tty-ask-password-agent  ypdomainname
          bzip2recover  dir            grep        lowntfs-3g  nc          ntfsmove       rbash         stty       tar                             zcat
          bzless        dmesg          gunzip      ls          nc.openbsd  ntfsrecover    readlink      su         tempfile                        zcmp
          bzmore        dnsdomainname  gzexe       lsblk       netcat      ntfssecaudit   red           sync       touch                           zdiff
          • CrunkFX
            @yogi-0 Kannst du bitte einmal folgendes ausführen :
            wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui-bin.service -O /etc/systemd/system/wgui.service
            und anschließend
            systemctl daemon-reload
            systemctl stop wgui
            systemctl start wgui
            Yogi 0 S 2 Replies Last reply Reply Quote 2
            • Yogi 0
              @crunkfx
              Okay ich habe den Dienst jetzt neu geladen und anschließend nochmal den Status ausgegeben, scheint jetzt zumindest vernünftig zu starten:
                   Active: inactive (dead) since Tue 2022-01-04 12:03:46 CET; 6min ago
                  Process: 7665 ExecStart=/bin/systemctl restart wg-quick@wg0.service (code=exited, status=0/SUCCESS)
                 Main PID: 7665 (code=exited, status=0/SUCCESS)
                      CPU: 1ms
              Jan 04 12:03:45 wireguard systemd[1]: Starting Restart WireGuard...
              Jan 04 12:03:46 wireguard systemd[1]: wgui.service: Succeeded.
              Jan 04 12:03:46 wireguard systemd[1]: Finished Restart WireGuard.
              Habe nochmal in der WireguardUI auf Apply Config geklickt, ich glaube da tut sich nach wie vor nichts, denn eigentlich müsste der Server ja neustarten, aber ich kann nach dem Klick in der UI unmittelbar weiter navigieren... ?
              • CrunkFX
                @yogi-0 Nein, der Server muss nicht Neustarten, nur der WireGuard Dienst um die neue Konfiguration anzunehmen. Du kannst das testen indem du einen neuen Client im UI anlegst und dieser direkt nach dem Klick auf Aplly Config funktioniert.
                Yogi 0 1 Reply Last reply Reply Quote 0
                • Yogi 0
                  Yogi 0 @CrunkFX last edited by Yogi 0
                  @crunkfx
                  leider funktioniert der Neustart des Dienstes über den Apply Config Button immer noch nicht, die VPN Verbindung schmeißt wieder den Handshake Error
                  2022-01-04 12:18:00.964: [TUN] [test] Handshake for peer 1 ([...]:51820) did not complete after 5 seconds, retrying (try 2)
                  Nachdem manuellen Neustart über systemctl stop/start wgui funktioniert der Client entsprechend dann. Woran könnte es noch liegen, dass der Button den Befehl nicht vernünftig an den Container weiterleiten kann? 😕
                  • N
                    nerg @CrunkFX last edited by
                    @crunkfx Thema Container-recyceln: sollte ich denn nicht den docker Kram etc runter werfen? Welche apt Pakete wären das?
                    • CrunkFX
                      @yogi-0 Entschuldige bitte die verspätete Rückmeldung, es scheint hierbei ein Problem mit dem systemctl Dienst zu geben. Je nach Distribution befindet sich dieser in /usr/bin/systemctl oder /bin/systemctl . Bei dir sind beide vorhanden, weshalb mein Skript etwas verwirrt zu sein schien. Ich habe nun geupdated, allerdings erfordert es eine Neuinstallation von Wireguard und Wireguard UI.
                      Ansonsten nach einer Änderung
                      systemctl restart wgui
                      • CrunkFX
                        CrunkFX Forum Testing @nerg last edited by CrunkFX
                        @nerg Je nachdem ob du noch mehrere Docker Container laufen hast, reicht es den Wireguard UI Container zu entfernen:
                        docker rm wgui
                        Möchtest du Docker und ALLES was dazu gehört entfernen (Genieß das mit Vorsicht wenn du nicht sicher bist ob noch mehr auf Docker läuft!):
                        sudo apt-get purge -y docker.io docker-compose
                        sudo apt-get autoremove -y --purge docker.io docker-compose
                        sudo rm -rf /var/lib/docker /etc/docker
                        sudo rm /etc/apparmor.d/docker
                        sudo groupdel docker
                        sudo rm -rf /var/run/docker.sock
                        sudo rm /usr/local/bin/docker-compose
                          MartyBr @CrunkFX last edited by
                          @crunkfx Ich hatte gestern die 1.20 auf einem neuen System installiert. Ich möchte jetzt ungern die 1.21 installieren. Was hat sich denn genau geändert? Kann ich ein Patch einspielen oder eine Datei austauschen?
                          • CrunkFX
                            CrunkFX Forum Testing @MartyBr last edited by
                            @martybr Wenn bei dir alles so funktioniert wie es soll, ist es nicht nötig 1.2.1 zu installieren.
                              @crunkfx 🤗
                                simi @CrunkFX last edited by simi
                                @crunkfx Herzlichen Dank für das Skript - ich habe es gerade in einem Ubuntu 20.04 LTS-LXC installiert und hatte zunächst ebenfalls das Problem, dass ich nach dem Anlegen eines Clients trotz "Apply Config" neustarten musste, bevor der Client connecten konnte. Mit den "Nacharbeiten" aus diesem Post (und einem Reboot), kann der neue Client jetzt wie gewünscht nach dem "Apply Config" direkt connecten.
                                Dann werde ich mal meinen priviligierten OpenVPN-Container abschalten... Wenn ich bedenke, was das für ein Gefrickel war, bevor OpenVPN auch über meine VLANs hinweg funktioniert hat, kann ich Dir gar nicht genug danken 🙂
                                Edit: Und auf Port 80 läuft es auch super 🙂
                                  Muchul @CrunkFX last edited by Muchul
                                  @crunkfx
                                  Danke.
                                  Nachdem ich eine Woche versucht habe die Fritz VPN auf dem Laptop einzurichten und kläglich gescheitert bin, habe ich dank deiner Anleitung nun vollen Zugriff auf mein Heimnetzwerk.
                                  Die Nachricht schicke ich gerade über den Tunnel 🙂
                                  Klasse Arbeit und sehr gut dokumentiert, Alle Daumen hoch (hab mir noch welche dafür geliehen).
                                  PS: Handy habe ich gar nicht erwähnt, aber beides geht super.
                                  Ich musste lediglich den Tunnelnamen für Windows ändern, da er anscheinend keine Leerzeichen mag.
                                  Thomas Braun CrunkFX 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @Muchul last edited by Thomas Braun
                                    @muchul sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                                    Leerzeichen mag in der IT eigentlich gar keiner. Immer ohne auskommen!
                                    • CrunkFX
                                      CrunkFX Forum Testing @Muchul last edited by
                                      @muchul Hi, kannst du das nochmal erklären so ganz verstehe ich das Problem nicht. Welchen tunnelnamen meinst du?
                                      LG
                                        @crunkfx
                                        gerne, nach der Installation http://ServerIP:5000 aufgerufen und alles ausgefüllt.
                                        Dummerweise bei Name vor -und zu- Name eingetragen.
                                        Am Handy QR Code gescannt und alles funktioniert.
                                        Am Laptop von https://download.wireguard.com/windows-client/wireguard-installer.exe den Installer runtergeladen installiert und die Datei "Vorname Nachname.conf" eingelesen und dabei die Fehlermeldung bekommen:
                                        Fehler: Importieren der Konfiguration nicht möglich: Der Tunnelname ist ungültig: "name Vorname"
                                        Habe dann die Datei umbenannt in "VornameNachname.conf", also das Leerzeichen zwischen vor und Nachname gelöscht und schon ging es.
                                        • CrunkFX
                                          @muchul Verstanden, das scheint aber ein Fehler in der Wireguard Desktop App zu sein, ich werde mal schauen ob es hierzu auf Github bereits ein Issue gibt, ansonsten lege ich eins an.
                                          Vielen Dank
                                            @crunkfx
                                            ich habe zu danken.
                                            81.1k
                                            portforwarding portfreigabe portfreischaltung proxmox vpn wireguard wireguard ios app
                                            64
                                            603
                                            166176
