    4. Adapter bleiben einfach im Status Gelb
    • Neues Video auf YouTube
    • Stefan H. 0
      Stefan H. 0 last edited by Homoran
      |Systemdata|
      daswetter.0
      	2022-01-08 15:30:28.827	info	cleaned everything up...
      daswetter.0
      	2022-01-08 15:30:28.298	info	Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      daswetter.0
      	2022-01-08 15:30:24.282	info	still wrong data structure from server received! repaired...
      daswetter.0
      	2022-01-08 15:30:06.161	info	starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.2, js-controller: 3.3.22
      daswetter.0
      	2022-01-08 15:15:29.586	info	cleaned everything up...
      daswetter.0
      	2022-01-08 15:15:29.072	info	Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      daswetter.0
      	2022-01-08 15:15:25.118	info	still wrong data structure from server received! repaired...
      daswetter.0
      	2022-01-08 15:15:10.139	info	starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.2, js-controller: 3.3.22
      daswetter.0
      	2022-01-08 15:00:29.026	info	cleaned everything up...
      dwd.0
      	2022-01-08 15:36:02.872	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      dwd.0
      	2022-01-08 15:36:01.987	info	starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22
      dwd.0
      	2022-01-08 15:35:07.219	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      dwd.0
      	2022-01-08 15:35:02.085	info	starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22
      dwd.0
      	2022-01-08 15:34:03.063	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      dwd.0
      	2022-01-08 15:34:02.124	info	starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22
      dwd.0
      	2022-01-08 15:33:02.915	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      openweathermap.0
      	2022-01-08 15:30:13.960	info	Terminated (NO_ERROR): Without reason
      openweathermap.0
      	2022-01-08 15:30:10.654	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.18.2, js-controller: 3.3.22
      openweathermap.0
      	2022-01-08 15:15:09.310	info	Terminated (NO_ERROR): Without reason
      openweathermap.0
      	2022-01-08 15:15:06.247	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node:
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: raspbian OS
      Node-Version: 14.18.2
      Nodejs-Version: 14.18.2
      NPM-Version: 6.14.15
      Installationsart: Manuell
      Image genutzt: Ja
      Ort/Name der Imagedatei: https://www.raspberrypi.com/software/operating-systems/#raspberry-pi-os-32-bit
      • Glasfaser
        Glasfaser last edited by
        @stefan-h-0
        Welche , die mit der Uhr !?
        Stefan H. 0 1 Reply Last reply Reply Quote 0
        • Stefan H. 0
          Stefan H. 0 @Glasfaser last edited by
          @glasfaser Hi danke für die schnelle Antowrt, ja
            Homoran Global Moderator Administrators @Stefan H. 0 last edited by
            @stefan-h-0
            was ist da gelb?
            • Glasfaser
              Glasfaser @Stefan H. 0 last edited by Glasfaser
              @stefan-h-0
              Die bleiben so ,
              die haben eine Cron , das heißt zu einer bestimmten Zeit werden sie Aktiviert.
              Glasfaser Stefan H. 0 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @Glasfaser last edited by Glasfaser
                @stefan-h-0
                Expertenmodus ...
                Beispiel :
                • Stefan H. 0
                  @glasfaser Hi Glasfase, danke aber ich meine ich hätte alle Timer schon rausgenommen aber wenn es ok ist dann lass ich es so nur wie schon im Log zu sehen sieht es halt immer aus als wenn er die kom abbricht. Also eurer Rat so lassen und alles funktioniert i.O?
                  Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                    @stefan-h-0 sagte in Adapter bleiben einfach im Status Gelb:
                    Wieso nimmst du Timer bei scheduled Adaptern raus?
                    wie sollen die denn dann arbeiten?
                    Wo genau?
                    • Stefan H. 0
                      Stefan H. 0 @Homoran last edited by
                      So wie ich das sehe gibt es heir garkeine
                      Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        ?? warum die Timer löschen .
                        Alle Adapter die so sind , werden nur einmal mit dem Cron aktiviert un gehen wieder schlafen .
                        Oder brauchst du . z.B . jede senkunde eine Abfrage !?
                        Stefan H. 0 Homoran 2 Replies Last reply Reply Quote 0
                        • Glasfaser
                          Schalte mal im Expertenmodus :
                          Ja werden so nicht angezeigt , wäre aber dann beim betroffenen Adapter ein Issues zu eröffnen .
                          • Stefan H. 0
                            @glasfaser HI,
                            nein brauche ich nicht aber ich schaue sie mir noch mal genauer an und werde das noch mal checken, danke erstmal für eure schnelle Hilfe (Ich binecht freudig überrascht und danke euch für eure Hilfe)
                              so ist es.
                              Es gibt Adapter die dauernd laufen, die haben eine "Ampel"
                              dann gibt es Adapter die zeitgesteuert starten, ihre Aufgabe abarbeiten und dann wieder stoppen
                              mit
                              @homoran sagte in Adapter bleiben einfach im Status Gelb:
                              Wo genau?
                              meinte ich den Logeintrag
                                Homoran Global Moderator Administrators @Glasfaser last edited by
                                @glasfaser sagte in Adapter bleiben einfach im Status Gelb:
                                eventuell meinte @Stefan-H-0 die restart-CRONs
                                256
