    4. FritzBox WLAN Passwort ändern
    • GuLi69
      GuLi69 last edited by GuLi69
      Sorry ... erledigt
      • Glasfaser
        Glasfaser @GuLi69 last edited by
        @GuLi69
        Nimm mal das …
        [{"tpl":"tplValueStringRaw","data":{"hm_id":"80101","digits":"","factor":1,"min":0,"max":1,"step":0.01,"visibility-cond":"==","visibility-val":1,"oid":"javascript.0.QR-Code.Gast","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"156px","top":"640px","width":"125px","height":"125px","border":"2px solid rgb(255, 255, 255)","border-radius":"5px","z-index":"44","color":"","background":"#ffffff","font-family":"Jura-DemiBold"},"widgetSet":"basic"}]
        GuLi69 1 Reply Last reply Reply Quote 0
        • GuLi69
          GuLi69 @Glasfaser last edited by
          @Glasfaser
          Sorry wo würde ich diesen Code einfügen?
          • Glasfaser
            @GuLi69
            • GuLi69
              @Glasfaser
              PERFEKT !!!
              VIELEN DANK Glasfaser !!!
              VG
              Günter
              • jolic
                jolic last edited by jolic
                Hi, habe hier was kurioses gefunden, nichts tragisches 😉
                Nutze das Script seit langem und lasse alle 24h das WLAN Passwort für Gast ändern.
                Nur bei einem Neustart des Raspi zickt das Script etwas.
                Das Passwort steht wie gehabt als Wert im Objekt "tr-064.0.states.wlanGuestPassword".
                Wenn dann das Script per cronjob ein neues Passwort generiert, wird der Wert gelöscht und erst nach dem nächsten Durchlauf (bei mir also 24h) wieder eingetragen. Dann funktioniert alles wieder so wie es soll und alle 24h wird ein neues Passwort generiert und als Wert dort eingetragen.
                Im Log sehe ich kein Fehler oder Hinweis warum dieser Wert gelöscht wird.
                Das ist nichts tragisches, da der QR-Code immer richtig erstellt wird. Benutze den Wert zur Kontrolle und für Gäste die den QR nicht scannen können.
                Frage: Kann das jemand nachvollziehen?
                Evtl. liegt es an der Fritz Labor Version. Diese benötige ich dringend wegen der SMB2+3 Unterstützung.
                Meine derzeitige Konfiguration:
                • Raspberry Pi 4 (BCM2835) mit Linux Kernel 4.19.118
                • ioBroker.admin 4.1.1
                • Node.js: v12.18.1
                • NPM: 6.14.5
                • TR-064 Adapter 4.0.8
                • FitzBox 7490 mit Labor Version: 07.19-79773
                // Quelle:
                // https://www.npmjs.com/package/qr-image
                // https://forum.iobroker.net/topic/4574/fritzbox-wlan-passwort-%C3%A4ndern/49
                var MySSID          = "Gast24h";                            // SSID Name
                var MyCrypt         = "WPA2 + WPA3";                        // [WEP|WPA|WPA2|WPA3]
                var MyVisibility    = "n";                                  // Hidden SSID?
                var cronStr         = "* 2 * * *"                           // Script wird jeden Tag um 2 Uhr ausgeführt
                //var cronStr         = "* * * * *"                        // jede Minute, nur zum Testen!
                var idQRZiel = "javascript.0.QR-Code.Gast";                       // Zieldatenpunkt für QR-Code
                var IdGPasswd = "tr-064.0.states.wlanGuestPassword";              // wlanGuestPassword
                if(MyVisibility == "y") {
                   var MyHidden="H:true";
                else {
                   MyHidden="";
                createState(idQRZiel, "", {
                    name: 'QR-Code für Gastpasswort',
                    desc: 'QR-Code für Gastpasswort',
                    type: 'string',
                    role: 'value'
                // Methode zur Erstellung eines Random-Passworts kann angepasst werden
                function randomString(length) {
                   return Math.round((Math.pow(36, length + 1) - Math.random() * Math.pow(36, length))).toString(36).slice(1);
                function createQRcode() {
                   var qr = require('qr-image');
                   var NewPasswd = randomString(10);   // 10 Stelliges Passwort
                   var svg_string = qr.imageSync('WIFI:S:'+MySSID+';T:'+MyCrypt+';P:'+NewPasswd+';'+MyHidden+';', { type: 'svg' });
                   setState(IdGPasswd, NewPasswd);
                   setState(idQRZiel, svg_string);
                   console.log('WLAN Gast QR-Code neu erstellt: ' + NewPasswd);
                // regelmässige Wiederholungen
                schedule(cronStr, createQRcode);
                jolic
                  Chrunchy @jolic last edited by
                  @jolic Ich vermute es liegt hier beim Neustart ein Timing-Problem vor.
                  Ich hatte ähnliches bei einem Script, was mir beim Neustart vom iobrkoer Lichter eingeschaltet hat.
                  Ich habe es dadurch gelöst, dass ich dem Script einen Timeout von 1 Minute voran gestellt habe, welcher nur beim ersten durchlauf, also beim Starten des Scripts greift.
                  Damit hatten dann alle Adapter die Chance sauber zu laufen, bevor der Javascript-Adapter die ganzen Scripte ausgeführt hat.
                  Vielleicht hilft es ja auch bei dir.
                  • jolic
                    @Chrunchy: Danke für deinen Hinweis. Tipps und Hinweise sind immer willkommen.
                    Denke nicht das es ein Timeout Problem ist. Sorry, vielleicht habe ich mich etwas unklar ausgedrückt.
                    • Script wird genau nach Plan ausgeführt (habe auch andere Zeiten probiert)
                    • zur Kontrolle logge ich den Wert (wurde korrekt generiert), steht aber erst am 2ten Tag in "tr-064.0.states.wlanGuestPassword" als Wert
                    • die Fritz nimmt immer das neue Passwort an und der QR-Code stimmt auch immer ab dem ersten Tag (so wie es sein soll)
                    Das rennt Wochen lang so, bis ich ein Kernel Update mache und den Raspi neu starte (sudo restart). Sonst wäre mir das nicht aufgefallen.
                    Siehe Bild, der Wert wurde um 9 Uhr von "javascript.0/admin" ab dem 2 Tag korrekt eingetragen
                    Wie schon erwähnt, nichts tragisches, kann damit gut leben. Würde mich dennoch interessieren was da falsch rennt.
                    Werde das weiter beobachten... 👁
                    jolic
                    jolic 1 Reply Last reply Reply Quote 0
                    • jolic
                      jolic @jolic last edited by jolic
                      Hi, hier ein Update. Ist noch nicht gelöst aber der Verusacher ist der TR-064 Adapter.
                      Diese Sache passiert immer einmalig bei einem Neustart des Adapters (keine Meldung im error log).
                      Jetzige Konfiguration (nutze neuen Raspi mit SSD):
                      • Raspberry Pi 4 (BCM2711) mit Linux Kernel 5.10.17
                      • ioBroker.admin 4.2.1
                      • Node.js: v12.22.1
                      • NPM: 6.14.12
                      • TR-064 Adapter 4.2.12
                      • FitzBox 7490 Version: 07.27
                      Kann das evtl. jemand bestätigen oder hat eine Idee wie ich das "Problemchen" lösen kann?
                      jolic
                      • V
                        Vickes last edited by
                        Hello,
                        ich würde diesen thread gerne noch einmal wiederbeleben:
                        Wäre es mit den o.g. Scripts (die hervorragend funktiponieren) möglich das ganze auch unter der lovelace vis anzeigen zu lassen? Mithilfe der direkten Einbindung in einer 'Picture' bzw 'Picture Element' Karte hatte ich bisher keinen Erfolg.
                        Any possible Ideas? 😰
                          Aushilfsarnie @jolic last edited by Aushilfsarnie
                          grundsätzlich habe ich die Einrichtung hinbekommen. Leider wird das Passwort nicht an meine Fritzbox 6590 Cable übertragen. Alle anderen Funktionen des Adatpers funktionieren. Hat jemand eine Idee dazu? Vielen Dank im Voraus!
                          • jolic
                            jolic @Aushilfsarnie last edited by jolic
                            Hallo, nach über zwei Jahren habe ich mich nochmal mit dem Thema beschäftigt, einige Optimierungen vorgenommen und den nervigen Fehler endlich behoben. Vielleicht ist das ja auch für jemand anderen nützlich. Viel Spaß damit!
                            Danke an das Team von ioBroker und einen guten Rutsch ins neue Jahr!
                            // QR-Image V24.12.008 -> ein paar Optimierungen und ein lästiger Fehler behoben.
                            // Nach jedem Neustart des TR-064 Adapter und ersten Start des Skripts war der DP "wlanGuestPassword" leer.
                            // Der Fehler war ein Timing-Problem. Das Passwort wurde gesetzt, aber der TR-064 Adapter verarbeitete es zu langsam.
                            // Durch den setState-Callback wird sichergestellt, dass der QR-Code erst nach erfolgreichem Speichern des Passworts generiert wird.
                            // Quelle:
                            // Das Modul 'qr-image' muss in den JS Adapter (Instanzen) eingetragen werden!
                            // Der ioBroker TR-064 Adapter bietet keine Möglichkeit, die Verschlüsselungsmethode des Gast-WLANs (z. B. "WPA2" oder "WPA2 + WPA3") zu ändern.
                            // Die Konfiguration der Verschlüsselung erfolgt über die Weboberfläche der FRITZ!Box.
                            var MySSID = "HalloGast";                            // SSID Name
                            var cronStr = "1 4 * * *";                           // Script wird jeden Tag um 04:01 ausgeführt
                            // var cronStr = "1 4 * * 1";                       // Einmal je Woche  um 04:01 | 1 = Montag (0 = Sonntag, 6 = Samstag)
                            // var cronStr = "1 4 1 * *";                       // Am 1. Tag jedes Monats um 04:01
                            var IdGPasswd = "tr-064.0.states.wlanGuestPassword"; // Datenpunkt für WLAN-Gastpasswort
                            var passwordLength = 20;                             // Länge des Passworts (mind. 8 Zeichen!)
                            if (MyVisibility === "y") {
                                var MyHidden = "H:true";
                            } else {
                                MyHidden = "";
                            // Erstelle den Datenpunkt für den QR-Code, falls nicht vorhanden
                                type: 'string',
                                role: 'value'
                            // Methode zur Erstellung eines zufälligen Passworts (keine Sonderzeichen am Anfang oder Ende)
                                var result = '';
                                var lowerChars = 'abcdefghijklmnopqrstuvwxyz';
                                var upperChars = 'ABCDEFGHIJKLMNOPQRSTUVWXYZ';
                                var digits = '0123456789';
                                var specialChars = '!?._-';
                                var allChars = lowerChars + upperChars + digits + specialChars;
                                // Ersten und letzten Charakter setzen (keine Sonderzeichen)
                                result += lowerChars.charAt(Math.floor(Math.random() * lowerChars.length)); // Kleinbuchstabe am Anfang
                                // Mittelteil auffüllen (inkl. Sonderzeichen)
                                for (var i = 1; i < length - 1; i++) {
                                    var char = allChars.charAt(Math.floor(Math.random() * allChars.length));
                                    result += char;
                                // Letztes Zeichen (keine Sonderzeichen, aber Klein-/Großbuchstabe oder Zahl)
                                result += lowerChars.concat(upperChars, digits).charAt(Math.floor(Math.random() * (lowerChars.length + upperChars.length + digits.length)));
                                // Stelle sicher, dass mindestens ein Sonderzeichen enthalten ist (außer am Anfang und Ende)
                                var specialIndex = Math.floor(Math.random() * (length - 2)) + 1;  // Position zwischen 1 und length-2
                                var specialChar = specialChars.charAt(Math.floor(Math.random() * specialChars.length));
                                result = result.substring(0, specialIndex) + specialChar + result.substring(specialIndex + 1);
                                return result;
                            // Methode zur Erstellung des QR-Codes
                            var qr;
                            try {
                            } catch (err) {
                                log('Modul qr-image konnte nicht geladen werden: ' + err);
                                if (!qr) return; // Abbrechen, falls qr-image nicht geladen werden konnte
                                var NewPasswd = randomString(passwordLength); // Passwortlänge dynamisch anpassbar
                                setState(IdGPasswd, NewPasswd, false, function(err) {
                                    if (err) {
                                        log('Fehler beim Setzen des Passworts: ' + err);
                                    } else {
                                        setTimeout(function() {
                                            setState(IdGPasswd, NewPasswd, true);  // Nach 2 Sekunden bestätigen
                                        }, 2000);
                                        var svg_string = qr.imageSync('WIFI:S:' + MySSID + ';T:WPA2;P:' + NewPasswd + ';' + MyHidden + ';', { type: 'svg' });
                                        setState(idQRZiel, svg_string, true);
                            // Erstelle den QR-Code einmalig beim ersten Start des Scripts
                            createQRcode();
                            // Planmäßige Wiederholungen der Erstellung des QR-Codes
                            M 1 Reply Last reply Reply Quote 2
                            • mcm1957
                              mcm1957 @simpixo last edited by mcm1957
                              deleted da Unsinn
                              Der Thread ist ja aus der Gruft gehiben worden ...
                                MartyBr @jolic last edited by
                                @jolic
                                Zuerst mal vielen dank für die Weiterentwicklung!
                                Ich habe aber ein Problem mit dem Script oder evtl. dem TR-06-Adapter. Wenn ich das Script laufen lassen (genauer: per CRON-Starte), dann schreibt er das WLAN-Gast Kennwort in das zentrale WLAN-Passwort. Danach fällt das WLAN logisch aus (da die Geräte ja das neue Kennwort nicht kennen).
                                Zu meiner Technik:
                                Debian 12, ioBroker aktuell aus dem Stable.
                                Fritz!Box 5690 Pro (DSL, wird nicht per Glasfaser betrieben).
                                Hier die Datenpunkte: (Gäste-WLAN hat Kennwort, wird aber nicht ausgelesen)
                                Was mir auffällt ist, dass der Adapter kein WLAN-60 kennt. Die 5690 Pro hat ja ein WLAN 6G.
                                  MartyBr @MartyBr last edited by
                                  @martybr
                                  @jolic
                                  Auch wenn ich manuell das Gäste-Wlan setze, dann schreibt der Adapter das Kennwort direkt als mein WLAN-Kennwort in die Fritz!Box. Das Problem scheint daher der TR-06-Adapter zu sein.
                                    @martybr
                                    Ich habe in GitHub TR-06 dazu ein Ticket angelegt.
                                    1.0k
                                    61
                                    9929
