    4. Ram läuft voll
    Ram läuft voll
    • D3ltoroxp
      D3ltoroxp last edited by
      Ich habe mal das System neu gestartet, danach sehe ich gleich sowas in der Log...
      host.iobroker
      	2022-01-08 12:18:44.683	warn	adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
      host.iobroker
      	2022-01-08 12:18:44.682	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      	2022-01-08 12:18:44.682	error	Caught by controller[0]: }
      host.iobroker
      	2022-01-08 12:18:44.682	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      host.iobroker
      	2022-01-08 12:18:44.682	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
      host.iobroker
      	2022-01-08 12:18:44.682	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.iobroker
      	2022-01-08 12:18:44.682	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.iobroker
      	2022-01-08 12:18:44.682	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
      host.iobroker
      	2022-01-08 12:18:44.682	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
      host.iobroker
      	2022-01-08 12:18:44.682	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
      host.iobroker
      	2022-01-08 12:18:44.682	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: was compiled against a different Node.js version using
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node'
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: ^
      host.iobroker
      	2022-01-08 12:18:44.681	error	Caught by controller[0]: throw e;
      host.iobroker
      	2022-01-08 12:18:44.680	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
      host.iobroker
      	2022-01-08 12:18:42.573	warn	adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      host.iobroker
      	2022-01-08 12:18:42.572	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      	2022-01-08 12:18:42.572	error	Caught by controller[0]: }
      host.iobroker
      	2022-01-08 12:18:42.572	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      host.iobroker
      	2022-01-08 12:18:42.571	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
      host.iobroker
      	2022-01-08 12:18:42.571	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.iobroker
      	2022-01-08 12:18:42.570	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.iobroker
      	2022-01-08 12:18:42.570	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
      host.iobroker
      	2022-01-08 12:18:42.570	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
      host.iobroker
      	2022-01-08 12:18:42.570	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
      host.iobroker
      	2022-01-08 12:18:42.569	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.iobroker
      	2022-01-08 12:18:42.569	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.iobroker
      	2022-01-08 12:18:42.569	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.iobroker
      	2022-01-08 12:18:42.569	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
      host.iobroker
      	2022-01-08 12:18:42.568	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.iobroker
      	2022-01-08 12:18:42.568	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
      host.iobroker
      	2022-01-08 12:18:42.568	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
      host.iobroker
      	2022-01-08 12:18:42.568	error	Caught by controller[0]: was compiled against a different Node.js version using
      host.iobroker
      	2022-01-08 12:18:42.568	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node'
      host.iobroker
      	2022-01-08 12:18:42.568	error	Caught by controller[0]: ^
      host.iobroker
      	2022-01-08 12:18:42.568	error	Caught by controller[0]: throw e;
      host.iobroker
      	2022-01-08 12:18:42.568	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
      Kann das sein das die Updates auf nodejs und Co nicht richtig funktioiniert haben damals ?
        Homoran Global Moderator Administrators @D3ltoroxp last edited by
        @d3ltoroxp sagte in Ram läuft voll:
        Ist das noch eine Baustelle?
        Da gab es schon eine Anfrage im Forum. Ich weiß gar nicht was dabei rausgekommen ist.
        Dieses Feature gibt es laut nodejs.org erst ab node 15
        ggf. ist da etwas durch up und downgrade verwurschtelt
        • D3ltoroxp
          D3ltoroxp @Homoran last edited by
          @homoran said in Ram läuft voll:
          Ich hatte noch nie ein downgrade gemacht nur das upgrade von 12 auf 14
          Eigentlich nicht, zumindest wüsste ich es nicht, der läuft einwandfrei und ohne Probleme.
            Thomas Braun Most Active @D3ltoroxp last edited by
            @d3ltoroxp
            Da muss der Adapter neugebaut werden. Das wird automatisch versucht, funktioniert aber nicht immer. Voraussetzung dafür ist halt eine saubere Installation von nodeJS.
            • D3ltoroxp
              D3ltoroxp last edited by D3ltoroxp
              @thomas-braun Die installation wurde weiter oben geprüft und wurde für gut befunden, mehr kann ich dazu leider nicht sagen.
              Wie kann ich den denn rebuilden ? Einfach
              npm rebuild zigbee
              Schade es denn wenn ich einfach alle Adapter neu bauen lassen würde ? Ich meine ja auch das der weatherunderground und der dasWetter nicht rund laufen.
              Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                @d3ltoroxp
                iobroker stop
                iobroker rebuild zigbee
                  crunchip Forum Testing Most Active @D3ltoroxp last edited by
                  liegt vllt daran, das du keine eigene station hast?
                  und zigbee hatte ich schon weiter oben angesprochen, das der nicht läuft
                  • D3ltoroxp
                    D3ltoroxp @crunchip last edited by
                    @crunchip Komisch das die Zigbee Geräte aber rein kommen und auch die States, daher ist mir das nicht aufgefallen..
                    Station habe ich keine eigene, aber das war bisher nie das Problem.
                    Thomas Braun Chaot 2 Replies Last reply Reply Quote 0
                      @d3ltoroxp
                      Was war denn die Ausgabe beim rebuild?
                      • D3ltoroxp
                        D3ltoroxp @Thomas Braun last edited by
                        @thomas-braun Uff da habe ich ehrlicherweise nicht drauf geachtet. Er war dann fertig ich habe wieder iob gestartet und habe nichts mehr gesehen dergleichen. Kann ich das im nach hinein noch anschauen ?
                        • Chaot
                          Chaot @D3ltoroxp last edited by
                          @d3ltoroxp Leg mal in dem Weatherundergound Adapter den Ort neu an bzw. ändere die Station.
                          War bei mir auch mal. Das passiert wenn eine Station wegfällt auf die sich deine Konfiguration bezieht.
                            @d3ltoroxp
                            Ja läuft der Adapter nun sauber oder nicht?
                            • D3ltoroxp
                              @thomas-braun Er lief auch davor schon nur eben mit den Logeinträgen, die habe ich beim starten nicht gesehen.
                              @Chaot Danke für den Tipp schau ich mir mal an.
                              • D3ltoroxp
                                Sooooo,
                                also eindeutig schon mal die Quelle eingekreist woher der Überlauf kommt.
                                Ganz klar zu sehen, hab nahezu alle Scripte deaktiviert und seither über mehrere Tage ruhe. Jetzt muss ich schauen, welches Script da so rein haut. Also das heißt jetzt jeden Tag ein Script dazu und überwachen. So sollte ich ja dann erst mal den Übeltäter heraus finden. Dann würde ich das Script hier mal posten ob ihr dann seht was da der Fehler ist. Also ich geht voran.
                                • Feuersturm
                                  Feuersturm @D3ltoroxp last edited by
                                  @d3ltoroxp oder du aktivierst im ersten Schritt die Hälfte der Skripte und beobachtest es. Wenn es dort keine Auffälligkeiten gibt, die erste Hälfte abschalten und den Rest aktivierten. So kannst du es etwas schneller einkreisen.
                                    crunchip Forum Testing Most Active @Feuersturm last edited by crunchip
                                    @feuersturm er hat doch 2 script Instanzen laufen, einfach erstmal testen zwischen Instanz 0 und 1, hatte ich ihm aber schon vor Tagen vor geschlagen
                                    • D3ltoroxp
                                      @crunchip hä ich habe doch keine zwei Instanzen ??
                                      Oder wie meinst du das ?
                                        @d3ltoroxp ich war der Meinung in einem deiner Problem Threads gesehen zu haben, dass du 2 Instanzen laufen hast.
                                        Dann scheint wohl eine Verwechslung vor zu liegen.
                                        • D3ltoroxp
                                          @crunchip Hätte ich ja vllt auch übersehen können aber läuft nur eine. So ich hab mal ein paar aktiviert und beobachte... Wenigstens Safe ein Script das ist doch schon mal eine gute Nachricht, dann läuft der Rest ja soweit.
                                          • D3ltoroxp
                                            Das der Ram sich mit der Zeit füllt ist normal ?
                                            Startet ihr immer wieder mal den ioB neu ? Oder die VM in der er läuft ?
                                            1.2k
                                            196
                                            22346
