    4. Fritzdect neue Version 2.2.0
      frankyboy73 @foxthefox last edited by frankyboy73
      @foxthefox Hi, habe jetzt doch Probleme. Nach dem ich jetzt den HKmode bei einem Thermostat geändert (Fenster Zu) habe bekomme ich Fehler und die Instanz stoppt.
      2022-01-08 12:54:33.254  - info: host.raspberrypi Restart adapter system.adapter.fritzdect.0 because enabled
      2022-01-08 12:55:03.301  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 32725
      2022-01-08 12:55:04.830  - info: fritzdect.0 (32725) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.18.2, js-controller: 3.3.22
      2022-01-08 12:55:04.866  - info: fritzdect.0 (32725) fritzdect entered ready
      2022-01-08 12:55:04.904  - info: fritzdect.0 (32725) fritzdect uses USER: dect
      2022-01-08 12:55:05.512  - info: fritzdect.0 (32725) checking user permissions
      2022-01-08 12:55:05.714  - info: fritzdect.0 (32725) the rights are : {"Name":["Dial","App","HomeAuto","BoxAdmin","Phone"],"Access":["2","2","2","2","2"]}
      2022-01-08 12:55:05.715  - info: fritzdect.0 (32725) start creating devices/groups
      2022-01-08 12:55:06.025  - info: fritzdect.0 (32725) CREATE Devices 8
      2022-01-08 12:55:06.138  - info: fritzdect.0 (32725) setting up temperatur
      2022-01-08 12:55:06.140  - info: fritzdect.0 (32725) setting up temperatur
      2022-01-08 12:55:06.144  - info: fritzdect.0 (32725) setting up temperatur
      2022-01-08 12:55:06.146  - info: fritzdect.0 (32725) setting up temperatur
      2022-01-08 12:55:06.147  - info: fritzdect.0 (32725) setting up temperatur
      2022-01-08 12:55:06.155  - info: fritzdect.0 (32725) setting up temperatur
      2022-01-08 12:55:06.159  - info: fritzdect.0 (32725) setting up thermostat
      2022-01-08 12:55:06.160  - info: fritzdect.0 (32725) setting up thermostat
      2022-01-08 12:55:06.163  - info: fritzdect.0 (32725) setting up thermostat
      2022-01-08 12:55:06.164  - info: fritzdect.0 (32725) setting up thermostat
      2022-01-08 12:55:06.165  - info: fritzdect.0 (32725) setting up thermostat
      2022-01-08 12:55:06.169  - info: fritzdect.0 (32725) setting up thermostat
      2022-01-08 12:55:06.183  - info: fritzdect.0 (32725) setting up alert
      2022-01-08 12:55:06.199  - info: fritzdect.0 (32725) setting up blind
      2022-01-08 12:55:06.207  - info: fritzdect.0 (32725) setting up levelcontrol
      2022-01-08 12:55:06.218  - info: fritzdect.0 (32725) setting up thermostat nextchange
      2022-01-08 12:55:06.228  - info: fritzdect.0 (32725) setting up thermostat nextchange
      2022-01-08 12:55:06.238  - info: fritzdect.0 (32725) setting up thermostat nextchange
      2022-01-08 12:55:06.243  - info: fritzdect.0 (32725) setting up thermostat nextchange
      2022-01-08 12:55:06.263  - info: fritzdect.0 (32725) setting up thermostat nextchange
      2022-01-08 12:55:06.268  - info: fritzdect.0 (32725) setting up thermostat nextchange
      2022-01-08 12:55:06.399  - info: fritzdect.0 (32725) finished creating devices/groups (if any)
      2022-01-08 12:55:06.399  - info: fritzdect.0 (32725) start creating templates
      2022-01-08 12:55:06.668  - info: fritzdect.0 (32725) finished creating templates (if any)
      2022-01-08 12:55:06.669  - info: fritzdect.0 (32725) start initial updating devices/groups
      2022-01-08 12:55:07.934  - info: fritzdect.0 (32725) finished initial updating devices/groups
      2022-01-08 12:55:07.934  - info: fritzdect.0 (32725) going over to cyclic polling, messages to poll activity only in debug-mode
      2022-01-08 12:55:09.065  - info: node-red.0 (31135) 8 Jan 12:55:09 - [info] [debug:fabf11fb.586e7] Heizung Küche Ungleich
      2022-01-08 12:55:09.078  - info: fritzdect.0 (32725) DECT ID: 099951017547 identified for command (tsoll) : 17.5
      2022-01-08 12:55:09.091  - info: fritzdect.0 (32725) DECT ID: 099951017547 identified for command (hkrmode) : 0
      2022-01-08 12:56:32.564  - info: node-red.0 (31135) Save /opt/iobroker/iobroker-data/node-red/flows.json
      2022-01-08 12:57:16.521  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.absenk deleted
      2022-01-08 12:57:16.542  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.battery deleted
      2022-01-08 12:57:16.568  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.batterylow deleted
      2022-01-08 12:57:16.593  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.boostactive deleted
      2022-01-08 12:57:16.619  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.boostactiveendtime deleted
      2022-01-08 12:57:16.640  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.boostactivetime deleted
      2022-01-08 12:57:16.671  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.celsius deleted
      2022-01-08 12:57:16.686  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.devicelock deleted
      2022-01-08 12:57:16.700  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.endperiod deleted
      2022-01-08 12:57:16.713  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.errorcode deleted
      2022-01-08 12:57:16.724  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.fwversion deleted
      2022-01-08 12:57:16.739  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.hkrmode deleted
      2022-01-08 12:57:16.753  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.holidayactive deleted
      2022-01-08 12:57:16.765  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.id deleted
      2022-01-08 12:57:16.776  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.komfort deleted
      2022-01-08 12:57:16.799  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.lock deleted
      2022-01-08 12:57:16.810  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.manufacturer deleted
      2022-01-08 12:57:16.822  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.name deleted
      2022-01-08 12:57:16.834  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.offset deleted
      2022-01-08 12:57:16.845  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.operationlist deleted
      2022-01-08 12:57:16.857  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.operationmode deleted
      2022-01-08 12:57:16.869  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.present deleted
      2022-01-08 12:57:16.880  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.productname deleted
      2022-01-08 12:57:16.929  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.summeractive deleted
      2022-01-08 12:57:16.942  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.tchange deleted
      2022-01-08 12:57:16.952  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_099950697379.tist
      2022-01-08 12:57:16.961  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.tist deleted
      2022-01-08 12:57:16.987  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.txbusy deleted
      2022-01-08 12:57:17.000  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.windowopenactiv deleted
      2022-01-08 12:57:17.013  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.windowopenactiveendtime deleted
      2022-01-08 12:57:17.025  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099950697379.windowopenactivetime deleted
      2022-01-08 12:57:17.047  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.absenk deleted
      2022-01-08 12:57:17.064  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.battery deleted
      2022-01-08 12:57:17.086  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.batterylow deleted
      2022-01-08 12:57:17.113  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.boostactive deleted
      2022-01-08 12:57:17.138  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.boostactiveendtime deleted
      2022-01-08 12:57:17.162  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.boostactivetime deleted
      2022-01-08 12:57:17.174  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.celsius deleted
      2022-01-08 12:57:17.185  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.devicelock deleted
      2022-01-08 12:57:17.197  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.endperiod deleted
      2022-01-08 12:57:17.215  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.errorcode deleted
      2022-01-08 12:57:17.227  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.fwversion deleted
      2022-01-08 12:57:17.240  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.hkrmode deleted
      2022-01-08 12:57:17.253  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.holidayactive deleted
      2022-01-08 12:57:17.265  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.id deleted
      2022-01-08 12:57:17.277  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.komfort deleted
      2022-01-08 12:57:17.296  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.lasttarget deleted
      2022-01-08 12:57:17.308  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.lock deleted
      2022-01-08 12:57:17.319  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.manufacturer deleted
      2022-01-08 12:57:17.331  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.name deleted
      2022-01-08 12:57:17.343  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.offset deleted
      2022-01-08 12:57:17.355  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.operationlist deleted
      2022-01-08 12:57:17.376  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.operationmode deleted
      2022-01-08 12:57:17.389  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.present deleted
      2022-01-08 12:57:17.400  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.productname deleted
      2022-01-08 12:57:17.442  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.summeractive deleted
      2022-01-08 12:57:17.454  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.tchange deleted
      2022-01-08 12:57:17.464  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_099951017547.tist
      2022-01-08 12:57:17.468  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.tist deleted
      2022-01-08 12:57:17.484  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.tsoll deleted
      2022-01-08 12:57:17.496  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.txbusy deleted
      2022-01-08 12:57:17.508  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.windowopenactiv deleted
      2022-01-08 12:57:17.521  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.windowopenactiveendtime deleted
      2022-01-08 12:57:17.535  - info: fritzdect.0 (32725) state fritzdect.0.DECT_099951017547.windowopenactivetime deleted
      2022-01-08 12:57:17.561  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.absenk deleted
      2022-01-08 12:57:17.575  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.battery deleted
      2022-01-08 12:57:17.587  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.batterylow deleted
      2022-01-08 12:57:17.599  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.boostactive deleted
      2022-01-08 12:57:17.611  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.boostactiveendtime deleted
      2022-01-08 12:57:17.623  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.boostactivetime deleted
      2022-01-08 12:57:17.634  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.celsius deleted
      2022-01-08 12:57:17.646  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.devicelock deleted
      2022-01-08 12:57:17.658  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.endperiod deleted
      2022-01-08 12:57:17.670  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.errorcode deleted
      2022-01-08 12:57:17.682  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.fwversion deleted
      2022-01-08 12:57:17.694  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.hkrmode deleted
      2022-01-08 12:57:17.707  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.holidayactive deleted
      2022-01-08 12:57:17.719  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.id deleted
      2022-01-08 12:57:17.731  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.komfort deleted
      2022-01-08 12:57:17.753  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.lock deleted
      2022-01-08 12:57:17.765  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.manufacturer deleted
      2022-01-08 12:57:17.777  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.name deleted
      2022-01-08 12:57:17.788  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.offset deleted
      2022-01-08 12:57:17.800  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.operationlist deleted
      2022-01-08 12:57:17.812  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.operationmode deleted
      2022-01-08 12:57:17.825  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.present deleted
      2022-01-08 12:57:17.864  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.productname deleted
      2022-01-08 12:57:17.904  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.summeractive deleted
      2022-01-08 12:57:17.916  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.tchange deleted
      2022-01-08 12:57:17.925  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_119600221368.tist
      2022-01-08 12:57:17.929  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.tist deleted
      2022-01-08 12:57:17.953  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.txbusy deleted
      2022-01-08 12:57:17.964  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.windowopenactiv deleted
      2022-01-08 12:57:17.976  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.windowopenactiveendtime deleted
      2022-01-08 12:57:17.988  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600221368.windowopenactivetime deleted
      2022-01-08 12:57:18.008  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.absenk deleted
      2022-01-08 12:57:18.020  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.battery deleted
      2022-01-08 12:57:18.046  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.batterylow deleted
      2022-01-08 12:57:18.075  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.boostactive deleted
      2022-01-08 12:57:18.103  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.boostactiveendtime deleted
      2022-01-08 12:57:18.115  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.boostactivetime deleted
      2022-01-08 12:57:18.126  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.celsius deleted
      2022-01-08 12:57:18.138  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.devicelock deleted
      2022-01-08 12:57:18.149  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.endperiod deleted
      2022-01-08 12:57:18.162  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.errorcode deleted
      2022-01-08 12:57:18.173  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.fwversion deleted
      2022-01-08 12:57:18.184  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.hkrmode deleted
      2022-01-08 12:57:18.197  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.holidayactive deleted
      2022-01-08 12:57:18.211  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.id deleted
      2022-01-08 12:57:18.221  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.komfort deleted
      2022-01-08 12:57:18.234  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.lasttarget deleted
      2022-01-08 12:57:18.247  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.lock deleted
      2022-01-08 12:57:18.261  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.manufacturer deleted
      2022-01-08 12:57:18.274  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.name deleted
      2022-01-08 12:57:18.286  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.offset deleted
      2022-01-08 12:57:18.298  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.operationlist deleted
      2022-01-08 12:57:18.311  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.operationmode deleted
      2022-01-08 12:57:18.323  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.present deleted
      2022-01-08 12:57:18.335  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.productname deleted
      2022-01-08 12:57:18.376  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.summeractive deleted
      2022-01-08 12:57:18.388  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.tchange deleted
      2022-01-08 12:57:18.399  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_119600808296.tist
      2022-01-08 12:57:18.402  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.tist deleted
      2022-01-08 12:57:18.419  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.tsoll deleted
      2022-01-08 12:57:18.433  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.txbusy deleted
      2022-01-08 12:57:18.446  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.windowopenactiv deleted
      2022-01-08 12:57:18.460  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.windowopenactiveendtime deleted
      2022-01-08 12:57:18.477  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600808296.windowopenactivetime deleted
      2022-01-08 12:57:18.503  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.absenk deleted
      2022-01-08 12:57:18.517  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.battery deleted
      2022-01-08 12:57:18.538  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.batterylow deleted
      2022-01-08 12:57:18.566  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.boostactive deleted
      2022-01-08 12:57:18.611  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.boostactiveendtime deleted
      2022-01-08 12:57:18.628  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.boostactivetime deleted
      2022-01-08 12:57:18.639  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.celsius deleted
      2022-01-08 12:57:18.651  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.devicelock deleted
      2022-01-08 12:57:18.662  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.endperiod deleted
      2022-01-08 12:57:18.673  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.errorcode deleted
      2022-01-08 12:57:18.684  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.fwversion deleted
      2022-01-08 12:57:18.703  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.hkrmode deleted
      2022-01-08 12:57:18.712  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.holidayactive deleted
      2022-01-08 12:57:18.726  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.id deleted
      2022-01-08 12:57:18.738  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.komfort deleted
      2022-01-08 12:57:18.750  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.lasttarget deleted
      2022-01-08 12:57:18.761  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.lock deleted
      2022-01-08 12:57:18.772  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.manufacturer deleted
      2022-01-08 12:57:18.783  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.name deleted
      2022-01-08 12:57:18.795  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.offset deleted
      2022-01-08 12:57:18.806  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.operationlist deleted
      2022-01-08 12:57:18.818  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.operationmode deleted
      2022-01-08 12:57:18.829  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.present deleted
      2022-01-08 12:57:18.842  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.productname deleted
      2022-01-08 12:57:18.885  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.summeractive deleted
      2022-01-08 12:57:18.896  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.tchange deleted
      2022-01-08 12:57:18.912  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_119600824952.tist
      2022-01-08 12:57:18.920  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.tist deleted
      2022-01-08 12:57:18.934  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.tsoll deleted
      2022-01-08 12:57:18.947  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.txbusy deleted
      2022-01-08 12:57:18.959  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.windowopenactiv deleted
      2022-01-08 12:57:18.970  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.windowopenactiveendtime deleted
      2022-01-08 12:57:18.982  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119600824952.windowopenactivetime deleted
      2022-01-08 12:57:19.002  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.absenk deleted
      2022-01-08 12:57:19.014  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.battery deleted
      2022-01-08 12:57:19.037  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.batterylow deleted
      2022-01-08 12:57:19.060  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.boostactive deleted
      2022-01-08 12:57:19.084  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.boostactiveendtime deleted
      2022-01-08 12:57:19.106  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.boostactivetime deleted
      2022-01-08 12:57:19.123  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.celsius deleted
      2022-01-08 12:57:19.136  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.devicelock deleted
      2022-01-08 12:57:19.147  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.endperiod deleted
      2022-01-08 12:57:19.159  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.errorcode deleted
      2022-01-08 12:57:19.171  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.fwversion deleted
      2022-01-08 12:57:19.183  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.hkrmode deleted
      2022-01-08 12:57:19.195  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.holidayactive deleted
      2022-01-08 12:57:19.212  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.id deleted
      2022-01-08 12:57:19.223  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.komfort deleted
      2022-01-08 12:57:19.235  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.lasttarget deleted
      2022-01-08 12:57:19.246  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.lock deleted
      2022-01-08 12:57:19.258  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.manufacturer deleted
      2022-01-08 12:57:19.270  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.name deleted
      2022-01-08 12:57:19.284  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.offset deleted
      2022-01-08 12:57:19.300  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.operationlist deleted
      2022-01-08 12:57:19.313  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.operationmode deleted
      2022-01-08 12:57:19.347  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.present deleted
      2022-01-08 12:57:19.359  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.productname deleted
      2022-01-08 12:57:19.399  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.summeractive deleted
      2022-01-08 12:57:19.410  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.tchange deleted
      2022-01-08 12:57:19.419  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_119621022208.tist
      2022-01-08 12:57:19.424  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.tist deleted
      2022-01-08 12:57:19.440  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.tsoll deleted
      2022-01-08 12:57:19.453  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.txbusy deleted
      2022-01-08 12:57:19.467  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.windowopenactiv deleted
      2022-01-08 12:57:19.481  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.windowopenactiveendtime deleted
      2022-01-08 12:57:19.490  - info: node-red.0 (31135) 8 Jan 12:57:19 - [info] [debug:fabf11fb.586e7] Heizung Küche Ungleich
      2022-01-08 12:57:19.496  - info: fritzdect.0 (32725) state fritzdect.0.DECT_119621022208.windowopenactivetime deleted
      2022-01-08 12:57:19.546  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.endpositionsset deleted
      2022-01-08 12:57:19.556  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.fwversion deleted
      2022-01-08 12:57:19.567  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.id deleted
      2022-01-08 12:57:19.579  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.lastalertchgtimestamp deleted
      2022-01-08 12:57:19.600  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.level deleted
      2022-01-08 12:57:19.613  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.levelpercentage deleted
      2022-01-08 12:57:19.627  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.manufacturer deleted
      2022-01-08 12:57:19.642  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.mode deleted
      2022-01-08 12:57:19.660  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.name deleted
      2022-01-08 12:57:19.672  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.present deleted
      2022-01-08 12:57:19.684  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.productname deleted
      2022-01-08 12:57:19.697  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.state deleted
      2022-01-08 12:57:19.713  - info: fritzdect.0 (32725) state fritzdect.0.DECT_142760502742-1.txbusy deleted
      2022-01-08 12:57:20.422  - info: node-red.0 (31135) 8 Jan 12:57:20 - [info] [debug:c425436.d9f49c] Heizung Wohnen Ungleich
      2022-01-08 12:57:20.936  - info: node-red.0 (31135) 8 Jan 12:57:20 - [info] [debug:b54d082.015d0f8] Heizung Essen Ungleich
      2022-01-08 12:57:21.442  - info: node-red.0 (31135) 8 Jan 12:57:21 - [info] [debug:fa1bc61a.3cddc8] Heizung Ankleide Ungleich
      2022-01-08 12:57:31.012  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=true)
      2022-01-08 12:57:31.031  - info: fritzdect.0 (32725) Got terminate signal TERMINATE_YOURSELF
      2022-01-08 12:57:31.032  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 send kill signal
      2022-01-08 12:57:31.037  - info: fritzdect.0 (32725) cleaned everything up...
      2022-01-08 12:57:31.038  - info: fritzdect.0 (32725) terminating
      2022-01-08 12:57:31.040  - info: fritzdect.0 (32725) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-08 12:57:31.624  - info: host.raspberrypi instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-08 12:57:34.130  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 1823
      2022-01-08 12:57:35.794  - info: fritzdect.0 (1823) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.18.2, js-controller: 3.3.22
      2022-01-08 12:57:35.830  - info: fritzdect.0 (1823) fritzdect entered ready
      2022-01-08 12:57:35.871  - info: fritzdect.0 (1823) fritzdect uses USER: dect
      2022-01-08 12:57:36.511  - info: fritzdect.0 (1823) checking user permissions
      2022-01-08 12:57:36.695  - info: fritzdect.0 (1823) the rights are : {"Name":["Dial","App","HomeAuto","BoxAdmin","Phone"],"Access":["2","2","2","2","2"]}
      2022-01-08 12:57:36.696  - info: fritzdect.0 (1823) start creating devices/groups
      2022-01-08 12:57:36.993  - info: fritzdect.0 (1823) CREATE Devices 8
      2022-01-08 12:57:37.288  - info: fritzdect.0 (1823) setting up temperatur
      2022-01-08 12:57:37.292  - info: fritzdect.0 (1823) setting up temperatur
      2022-01-08 12:57:37.293  - info: fritzdect.0 (1823) setting up temperatur
      2022-01-08 12:57:37.303  - info: fritzdect.0 (1823) setting up temperatur
      2022-01-08 12:57:37.308  - info: fritzdect.0 (1823) setting up temperatur
      2022-01-08 12:57:37.310  - info: fritzdect.0 (1823) setting up temperatur
      2022-01-08 12:57:37.319  - info: fritzdect.0 (1823) setting up thermostat
      2022-01-08 12:57:37.325  - info: fritzdect.0 (1823) setting up thermostat
      2022-01-08 12:57:37.327  - info: fritzdect.0 (1823) setting up thermostat
      2022-01-08 12:57:37.334  - info: fritzdect.0 (1823) setting up thermostat
      2022-01-08 12:57:37.344  - info: fritzdect.0 (1823) setting up thermostat
      2022-01-08 12:57:37.347  - info: fritzdect.0 (1823) setting up thermostat
      2022-01-08 12:57:37.369  - info: fritzdect.0 (1823) setting up alert
      2022-01-08 12:57:37.417  - info: fritzdect.0 (1823) setting up blind
      2022-01-08 12:57:37.444  - info: fritzdect.0 (1823) setting up levelcontrol
      2022-01-08 12:57:37.505  - info: fritzdect.0 (1823) setting up thermostat nextchange
      2022-01-08 12:57:37.511  - info: fritzdect.0 (1823) setting up thermostat nextchange
      2022-01-08 12:57:37.533  - info: fritzdect.0 (1823) setting up thermostat nextchange
      2022-01-08 12:57:37.536  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_099951017547.tist
      2022-01-08 12:57:37.551  - info: fritzdect.0 (1823) setting up thermostat nextchange
      2022-01-08 12:57:37.565  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_119600808296.tist
      2022-01-08 12:57:37.557  - info: fritzdect.0 (1823) setting up thermostat nextchange
      2022-01-08 12:57:37.649  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_119600824952.tist
      2022-01-08 12:57:37.677  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_099950697379.tist
      2022-01-08 12:57:37.699  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_119621022208.tist
      2022-01-08 12:57:37.818  - info: fritzdect.0 (1823) setting up thermostat nextchange
      2022-01-08 12:57:37.829  - info: sql.0 (11264) disabled logging of fritzdect.0.DECT_119600221368.tist
      2022-01-08 12:57:37.912  - info: fritzdect.0 (1823) finished creating devices/groups (if any)
      2022-01-08 12:57:37.912  - info: fritzdect.0 (1823) start creating templates
      2022-01-08 12:57:38.166  - info: fritzdect.0 (1823) finished creating templates (if any)
      2022-01-08 12:57:38.166  - info: fritzdect.0 (1823) start initial updating devices/groups
      2022-01-08 12:57:39.224  - info: fritzdect.0 (1823) finished initial updating devices/groups
      2022-01-08 12:57:39.224  - info: fritzdect.0 (1823) going over to cyclic polling, messages to poll activity only in debug-mode
      2022-01-08 12:58:36.813  - info: fritzdect.0 (1823) DECT ID: 099950697379 identified for command (hkrmode) : 0
      2022-01-08 12:58:36.819  - error: fritzdect.0 (1823) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-01-08 12:58:36.819  - error: fritzdect.0 (1823) unhandled promise rejection: undefined
      2022-01-08 12:58:36.820  - error: fritzdect.0 (1823) undefined
      2022-01-08 12:58:36.827  - info: fritzdect.0 (1823) cleaned everything up...
      2022-01-08 12:58:36.828  - info: fritzdect.0 (1823) terminating
      2022-01-08 12:58:36.829  - warn: fritzdect.0 (1823) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-01-08 12:58:37.469  - error: host.raspberrypi instance system.adapter.fritzdect.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-01-08 12:58:37.474  - info: host.raspberrypi Restart adapter system.adapter.fritzdect.0 because enabled
      2022-01-08 12:58:37.474  - warn: host.raspberrypi Do not restart adapter system.adapter.fritzdect.0 because restart loop detected
      Und bei einigen Werten steht jetzt "null" drin.
      Edit: So, jetzt habe ich das Log auch vernümpftig eingefügt, war mir wohl vorher ein Fehler unterlaufen, sorry.
      Edit2: Ich hatte das Adapter Update gemacht während 2 meiner Thermostate im Mode 1 (Aus) waren, den Objektbaum hatte ich auch gelöscht. Dadurch das die Thermostate Aus waren habe ich wohl für Tsoll und last target keine Werte bekommen. Heute morgen beim Fenster schließen, wurde der HK Mode auf 0 geschrieben und dann gabs die Fehler und der Adapter stoppte.
      Ich habe jetzt in der Fritzbox alle Thermostate auf Ein gestellt, den Objektbaum nochmal gelöscht und den Adapter gestartet. Jetzt läuft es erstmal wieder, die Tsoll und lastTarget werden auch angezeigt. Allerdings steht in diesen 3 Datenpunkten immer noch "Null" drin.
        frankyboy73 @Chaot last edited by
        @chaot Hi, in der Box kann man da nichts einstellen, aber direkt am Thermostat. Wenn man die Boost Funktion aktiviert (2 Sekunden Menü Taste drücken) kann man mit + und - ne Zeit auswählen 5 / 10 / 15 Minuten usw. Standart am Thermostat ist 15 Minuten. Aber die Zeit hat nichts mit der im Adapter zu tun.
        Klappt das eigentlich gut mit der Boost Funktion über den Adapter? Die Thermostate kommunizieren ja nur alle 15 Minuten mit der Fritzbox. Kann ich die boostactive Zeit und booststatus gleichzeitig setzen oder sollte man erst die Zeit setzen und kurz darauf dann erst den status auf true nehmen?
        • Chaot
          Chaot @frankyboy73 last edited by
          @frankyboy73 Ich setze zuerst die Zeit (im Idealfall einmalig) und dann aktiviere ich den Boost über die VIS. Dann wird mir in der VIS auch die Boost Endzeit angezeigt.
          Wenn ich es eilig habe und den Boost sofort haben will drücke ich nach dem Aktivieren in der VIS noch ganz kurz irgendeine Taste am Thermostat. Dann wird der Boost sofort aktiviert.
          Ich nutze das hauptsächlich um mein Badezimmer hochzufahren wenn meine Kids baden gehen. Da macht 15 Minuten Verspätung meist auch nichts aus, da ich das ja sowieso etwa eine Stunde vorher aktiviere.
          • BananaJoe
            @foxthefox ich habe irgendwie auch seit 2-3 Tagen (und dem letzten Update) das Problem das die Heizkörper kalt bleiben.
            Ich nutze 3 x Comet DECT und 3 x FritzDECT 301.
            Bei mir haben die Fenster ZigBee-Kontakte und per Script werden die Thermostate zwischen MIN und MAX hin und her geschaltet über den Datenpunkt hkrmode mit 2 für MAX (open) und 1 für MIN (closed).
            Die letzten 3 Tage klappte das nicht, heute morgen habe ich extra erst in meine VIS geschaut in der ich sowohl den Türsensor also auch die Heizkörpersensoren drin habe.
            Da war die Tür offen und die Heizkörper aus, dann habe ich die Tür geschlossen und die Heizkörper sind auch an gegangen. Also hkrmode wurde auf 2 gesetzt. Wenn ich dann kurz die Taste am FritzDECT drücke übernimmt er das dann normalerweise sofort, aber nichts passierte. Ich hab dann in der VIS noch mal aus und wieder an geschaltet und erst dann ging es.
            Ich habe mal das gemacht was @frankyboy73 gemacht habe und berichte morgen noch mal
            Nachtrag: Absenktemperatur ist bei mir halt MIN und Komforttemperatur MAX
            • BananaJoe
              BananaJoe Most Active @BananaJoe last edited by BananaJoe
              @bananajoe ich sehe da gerade setmodeauto, setmodeoff und setmodeon ... seit wann sind die denn da ... Ich nehme an die machen das gleiche wie hkrmode? Und operationmode zeigt es dann an?
              Und wenn ich in der FritzBox auf AUS schalte ändert sich der hkrmode auch gar nicht mehr. Ich baue mal um auf die 3 Datenpunkte oben
              • BananaJoe
                Ich will das hier nicht zuspammen ... aber nachdem ich da ein wenig rumgeklickt habe ist der Adapter abgestürzt, gleiches Bild wie bei @frankyboy73
                Der Ehefrauen und Tochter-Akzeptanzfaktor sinkt gerade wegen kaltem Zimmern, ich bin auf Version 2.1.15 zurück gegangen
                  frankyboy73 @BananaJoe last edited by
                  @bananajoe sagte in Fritzdect neue Version 2.2.0:
                  Hi, die gibts seit der 2.1.0. Habe ich aber noch nie benutzt, da meine Logik auch alles über den HKR Mode macht.
                  Das Problem habe ich auch immer noch mit der 2.2.0, sobald ich einen Datenpunkt ändern will, wo "Null" bzw. nichts drin steht, gibts wieder Fehlermeldungen und der Adapter startet neu bzw. bleibt dann irgendwann auf stopp. Wenn ich die Datenpunke nicht anfasse läuft soweit erst mal alles.
                    foxthefox Developer @frankyboy73 last edited by
                    @frankyboy73
                    sorry für die Probleme, aber im log kann ich nicht allzuviel sehen. Der Text scheint beschnitten zu sein.
                    Aus dem log sehe ich, daß sich der Adapter beim neuen Einlesen der Daten von der Fritzbox aufhängt.
                    Was ist denn in der Zwischenzeit geändert?
                    Bzw. was heißt HKmode am Thermostat geändert (Fenster zu)?
                    Ist das eine Einstellung am Thermostat selbst oder eine im Adapter auf den Datenpunkt hkrmode?
                    Ich konnte es bei mir noch nicht nachstellen, solange ich nicht weiß woran sich heir was verschlucktt, wird es schwierig.
                    Wäre es möglich aus dem Adapterlog mehr zu erfahren, ggf. im debug mode?
                    Es hilft ungemein weiter wenn da noch etwas mehr zur uncaught exception stehen würde.
                    Klaus
                      foxthefox Developer @BananaJoe last edited by
                      @bananajoe
                      Ist nicht meine Absicht, daß der Akzeptanzfaktor sinkt.
                      Aber es gibt auch noch die Möglichkeit die Thermostate aus der FB zu steuern oder mit der App.
                      Also wenn die Instanz von iobroker nicht mehr läuft, dann ist das zumindest immer eine Rückfalloption.
                      Aber nun zum eigentlichen, was genau wurde denn angeklickt, was zum Absturz führt?
                      Was ist die Ausgangsposition und was war die Aktion?
                      Ist es möglich im debug die Meldungen kurz vorher und während des Abstützens zu posten?
                      Bei mir funktioniert derzeitig die ganze Klickerei in der 2.2.2.
                      F BananaJoe 2 Replies Last reply Reply Quote 0
                        @foxthefox Hi, das Log ist vom Restart des Adapters. Erst mal ist ja auch alles korrekt.
                        Dann habe ich den Datenpunkt hkrmode von 1 auf 0 gesetzt (im Log zu sehen) und dann einen Temperatursollwert in den Datenpunkt Tsoll geschrieben (Number 20), da sind dann die Fehlermeldungen gekommen und der Adapter war gestoppt.
                        Wie ich schon geschrieben hatte, zu dem Zeitpunkt stand in dem Datenpunkt Tsoll vorher "Null" drin. Jetzt wo ich alle Thermostate vorher auf ein gestellt habe und dann den Objektbaum gelöscht habe und den Adapter wieder gestartet habe, steht in dem Datenpunkt nicht mehr "Null" und ich kann die Temperaturen und den Mode jetzt steuern ohne Fehler im Log.
                        Das Log ist eigentlich nicht beschnitten, das ist die Ausgabe von
                        iobroker logs --watch
                        Ich versuche gleich noch mal ob ich den Fehler reproduzieren kann. Und stelle mal auf debug
                        Edit:
                        @foxthefox sagte in Fritzdect neue Version 2.2.0:
                        Dafür brauchst du dich nicht entschuldigen, die Version ist ja auch noch nicht stable und du hattest ja geschrieben das es getestet werden soll. Ich wusste worauf ich mich da einlasse und vielleicht hilft es ja dir oder anderen.
                        Mit dem Adapter hatte ich sonst noch keine Probleme, super Teil. Danke für die tolle Arbeit.
                        Und ich kann ja jederzeit wieder zurück auf nen stable Version
                          @foxthefox Hi, ich konnte es jetzt noch mal nachstellen.
                          Ich habe ein Thermostat auf Aus (hkrMode 1) gestellt. Adapter gestoppt, Objektbaum gelöscht, Adapter gestartet. Dann bekomme ich keine Werte bei Tsoll und LastTarget, da steht "Null" drin. Dann stelle ich hkrMode auf 0 und dann kommen die Fehler und der Adapter startet neu und das immer wieder wenn ich bei hkrMode 0 eingebe. Erst wenn ich dann wieder den Adapter stoppe per Fritzbox das Thermostat auf Ein stelle, den Objektbaum lösche und den Apdater starte kann ich wieder alles steuern ohne Fehler.
                          Hier die Debug Ausgabe zu dem Zeitpunkt vom Protokoll
                          fritzdect.0
                          2022-01-08 23:46:12.084	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          fritzdect.0
                          2022-01-08 23:46:12.082	info	terminating
                          fritzdect.0
                          2022-01-08 23:46:12.079	info	cleaned everything up...
                          fritzdect.0
                          2022-01-08 23:46:12.065	error	undefined
                          fritzdect.0
                          2022-01-08 23:46:12.064	error	unhandled promise rejection: undefined
                          fritzdect.0
                          2022-01-08 23:46:12.062	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          fritzdect.0
                          2022-01-08 23:46:12.049	info	DECT ID: 099950697379 identified for command (hkrmode) : 0
                          fritzdect.0
                          2022-01-08 23:46:12.048	debug	ack is not set! -> command
                          fritzdect.0
                          2022-01-08 23:46:12.046	debug	state fritzdect.0.DECT_099950697379.hkrmode changed: 0 (ack = false)
                          fritzdect.0
                          2022-01-08 23:45:25.140	debug	state fritzdect.0.DECT_119600221368.hkrmode changed: 0 (ack = true)
                          Und hier die Ausgabe von Log Watch
                          2022-01-08 23:45:25.140  - debug: fritzdect.0 (17475) state fritzdect.0.DECT_119600221368.hkrmode changed: 0 (ack = true)
                          2022-01-08 23:46:12.046  - debug: fritzdect.0 (17475) state fritzdect.0.DECT_099950697379.hkrmode changed: 0 (ack = false)
                          2022-01-08 23:46:12.048  - debug: fritzdect.0 (17475) ack is not set! -> command
                          2022-01-08 23:46:12.049  - info: fritzdect.0 (17475) DECT ID: 099950697379 identified for command (hkrmode) : 0
                          2022-01-08 23:46:12.062  - error: fritzdect.0 (17475) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2022-01-08 23:46:12.064  - error: fritzdect.0 (17475) unhandled promise rejection: undefined
                          2022-01-08 23:46:12.065  - error: fritzdect.0 (17475) undefined
                          2022-01-08 23:46:12.079  - info: fritzdect.0 (17475) cleaned everything up...
                          2022-01-08 23:46:12.082  - info: fritzdect.0 (17475) terminating
                          2022-01-08 23:46:12.084  - warn: fritzdect.0 (17475) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2022-01-08 23:46:12.672  - error: host.raspberrypi instance system.adapter.fritzdect.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2022-01-08 23:46:12.677  - info: host.raspberrypi Restart adapter system.adapter.fritzdect.0 because enabled
                          2022-01-08 23:46:12.677  - warn: host.raspberrypi Do not restart adapter system.adapter.fritzdect.0 because restart loop detected
                            foxthefox Developer @frankyboy73 last edited by foxthefox
                            @frankyboy73 sagte in Fritzdect neue Version 2.2.0:
                            die Erläuterung machen es nun klarer.
                            Ich habe zwar schon eine 2.2.3 erstellt mit
                            • einem Abfangen von tsoll lesen
                            • boost/windowtime im admin config änderbar
                            • setmodeon/off/auto mit false als Intialwert eines Tasters
                            -> bei mir kommt auch tsoll/lasttarget unbesetzt, aber Absturz konnte ich mit 2.2.3 nicht provozieren
                            aber die Geschichte mit Ersatzwerten bei deiner Fehlerbeschreibung muß ich mir noch anschauen.
                              @foxthefox Hi, wenn ich den Fehler erzwungen habe reicht es auch das Thermostat per Fritzbox auf Ein zu stellen (bzw. ne Temperatur einzustellen) und dann den Adapter wieder zu starten, den Objektbaum brauche ich nicht löschen.
                              Ich habe auch mal meine Heizungslogik (Node Red) deaktiviert, ich stelle nur direkt in dem Datenpunkt unter Objekte den hkrMode von 1 auf 0, es wird in dem Moment kein anderer Datenpunkt beschrieben
                              • BananaJoe
                                BananaJoe Most Active @foxthefox last edited by BananaJoe
                                @bananajoe
                                Sollte kein Vorwurf sein, der Adapter ist toll und wir (meine Familie) möchten den nicht mehr missen. Hat jetzt mehr als ein Jahr für warme Zimmer gesorgt (weil ständig das wieder andrehen vergessen wurde)
                                Oder von Hand. Es haben sich halt alle dran gewöhnt das es "zauber zauber zauber" passiert. Und bekamen es vorher schon nicht auf die Reihe.
                                Ich hab zwischen den verschiedenen setmode hin und her geklickt um zu sehen wie es sich ändert und zeitgleich in der FritzBox geschaut. Dabei schmierte er ab, ich schau morgen noch mal nach den Logs
                                Bis vor 3 Tagen hatte ich die Comet noch an einer 7390 mit 6er Firmware (Wegen Firmwareupdate Comet wegen ständigen Auf/Zudrehen), da hatte der Adapter Fehler über falsche Rückmeldungen der Box gemeldet. Ich wollte die Comet eh schon.länger auf die 6591 umziehen (V7.21) deshalb habe ich mir nichts dabei gedacht
                                Also noch mal: Tolle Arbeit, Danke für den Adapter
                                J F 2 Replies Last reply Reply Quote 0
                                  Jan1 @BananaJoe last edited by
                                  @bananajoe
                                  Die Setmodis sind Button und auf Dein Beitrag hier habe ich auch mal dran rum gefummelt. Kurz, das ist ne dumme Idee und heute morgen hatte ich 23° in der Bude. Hab dann einfach die Objekte des Adapter gelöscht und den Adapter neu gestartet und nun macht mein Script wieder was es soll.
                                  @foxthefox
                                  Deshalb mal die Frage, was bewirken diese Modis überhaupt, außer, dass dann irgendwie alle anderen DP die zur Regelung dienen nicht mehr wirklich so funktionieren wie sie sollen.
                                  So ist die Welt bei in Ordnung:
                                    foxthefox Developer @Jan1 last edited by
                                    @jan1 sagte in Fritzdect neue Version 2.2.0:
                                    @bananajoe
                                    Die Existenz von Datenpunkten sollte keinen Einfluss auf scripte haben, die diese gar nicht benutzen. Aber ggf. reagiert das Script anders, wenn die Randbedingungen verstellt sind.
                                    Beim Neustart des Adapters werden die Datenpunkte wieder angelegt.
                                    @foxthefox
                                    Ich glaube nicht das die Datenpunkte selbst etwas durcheinanderbringen, sondern die Vorbesetzung auf einen definierten Wert fehlt. Die stehen auf „null“, was datentechnisch nichts Auswertbares ist, deswegen kann das Abfragen ein Problem gehabt haben.
                                    Wozu ist es gedacht:
                                    • für das Umschalten zwischen den Modi
                                    • ist als Taster gedacht, ist auch so als Button definiert
                                    • ist eine zusätzliche Möglichkeit zu tsoll und hkrmode für Moduswechsel
                                    • da ich nicht weiß wie die vis aufgebaut wird, ist das die elegante Möglichkeit mit Buttons mit Direktzugriff zu haben.
                                    Boostactive, windowopenactive ändert zwar auch den Modus, hat aber keinen Einfluss auf hkrmode und tsoll. Das die beiden wieder abgestellt sind, löst das nächste Update von der FRITZ!Box.
                                    Klaus
                                      foxthefox Developer @BananaJoe last edited by foxthefox
                                      Kannst du noch nachvollziehen, welche Fehler das dort waren? Auch wenn alte FB-Firmware nicht alles kann und Daten übermittelt, sollte der Adapter dennoch in diesen Grenzen funktionieren.
                                      Danke für das Feedback.
                                        Jan1 @foxthefox last edited by
                                        @foxthefox
                                        Eigentlich hast alles bestätigt, was ich auch schon wusste 😉
                                        So lange ich an den 3 "neuen" DPs nix ändere, läuft auch mein Script wie es soll und ich verwende dort den "hkrmode" DP um das zu steuern, weshalb es mich eben auch wundert, dass wenn ich über die Button den Modi ändere, mein Script über den alten DP das nicht wieder richten kann.
                                        Wenn die Button DPs nicht definiert sind und "null" drin steht, ist das für mich OK, denn so funktioniert auch alles und das eben nach dem neu Anlegen der Objekte.
                                        Ansonsten alles top.
                                        • BananaJoe
                                          @foxthefox
                                          Zuerst die Fehlermeldungen die kamen als ich an setmode rumgespielt habe:
                                          2022-01-08 19:11:38.115  - error: fritzdect.0 (171548) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-08 19:11:38.120  - error: fritzdect.0 (171548) unhandled promise rejection: undefined
                                          2022-01-08 19:11:38.120  - error: fritzdect.0 (171548) undefined
                                          2022-01-08 19:11:38.786  - error: host.iobroker instance system.adapter.fritzdect.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2022-01-08 19:11:38.791  - info: host.iobroker Restart adapter system.adapter.fritzdect.0 because enabled
                                          2022-01-08 19:11:39.854  - info: host.iobroker instance system.adapter.fritzdect.0 started with pid 246567
                                          2022-01-08 19:11:42.225  - error: fritzdect.0 (246567) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-08 19:11:42.232  - error: fritzdect.0 (246567) unhandled promise rejection: undefined
                                          2022-01-08 19:11:42.233  - error: fritzdect.0 (246567) undefined
                                          2022-01-08 19:11:42.843  - error: host.iobroker instance system.adapter.fritzdect.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2022-01-08 19:11:42.844  - info: host.iobroker Restart adapter system.adapter.fritzdect.0 because enabled
                                          2022-01-08 19:11:43.889  - info: host.iobroker instance system.adapter.fritzdect.0 started with pid 246595
                                          2022-01-08 19:12:02.319  - error: fritzdect.0 (246595) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-08 19:12:02.324  - error: fritzdect.0 (246595) unhandled promise rejection: undefined
                                          2022-01-08 19:12:02.324  - error: fritzdect.0 (246595) undefined
                                          2022-01-08 19:12:02.974  - error: host.iobroker instance system.adapter.fritzdect.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2022-01-08 19:12:02.975  - info: host.iobroker Restart adapter system.adapter.fritzdect.0 because enabled
                                          2022-01-08 19:12:02.976  - warn: host.iobroker Do not restart adapter system.adapter.fritzdect.0 because restart loop detected
                                          Hier was der Adapter in Verbindung mit der 7390 ausgeworfen hat (ich hab alle Logs durchsucht und per grep das zusammengestellt):
                                          Das ist noch mit der Version 2.2.0 (fritzdect.1 ist die alte Box)
                                          2022-01-04 17:07:54.976  - error: fritzdect.1 (2925559) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-04 17:07:55.055  - error: fritzdect.1 (2925559) unhandled promise rejection: undefined
                                          2022-01-04 17:07:55.055  - error: fritzdect.1 (2925559) undefined
                                          2022-01-04 17:07:55.178  - info: host.iobroker stopInstance system.adapter.fritzdect.0 (force=false, process=true)
                                          2022-01-04 17:07:55.200  - info: host.iobroker stopInstance system.adapter.fritzdect.1 (force=false, process=true)
                                          2022-01-04 17:07:55.431  - info: host.iobroker stopInstance system.adapter.fritzdect.0 send kill signal
                                          2022-01-04 17:07:55.436  - info: host.iobroker stopInstance system.adapter.fritzdect.1 send kill signal
                                          2022-01-04 17:07:56.529  - info: host.iobroker stopInstance system.adapter.fritzdect.0 killing pid 2925552
                                          2022-01-04 17:07:56.557  - info: host.iobroker stopInstance system.adapter.fritzdect.1 killing pid 2925559
                                          2022-01-04 17:07:58.915  - warn: host.iobroker instance system.adapter.fritzdect.0 terminated due to SIGTERM
                                          2022-01-04 17:07:58.915  - info: host.iobroker instance system.adapter.fritzdect.0 terminated with code null ()
                                          2022-01-04 17:07:59.347  - warn: host.iobroker instance system.adapter.fritzdect.1 terminated due to SIGTERM
                                          2022-01-04 17:07:59.347  - info: host.iobroker instance system.adapter.fritzdect.1 terminated with code null ()
                                          2022-01-04 17:10:39.258  - info: host.iobroker instance system.adapter.fritzdect.0 started with pid 2329736
                                          2022-01-04 17:11:19.284  - info: host.iobroker instance system.adapter.fritzdect.1 started with pid 2330253
                                          2022-01-04 17:11:20.910  - error: fritzdect.1 (2330253) errorHandlerTypeError: Converting circular structure to JSON
                                          2022-01-04 17:11:20.912  - error: fritzdect.1 (2330253) fritzbox returned this {}
                                          2022-01-04 17:11:20.913  - error: fritzdect.1 (2330253) no response part in returned message
                                          2022-01-04 17:12:56.952  - info: host.iobroker stopInstance system.adapter.fritzdect.1 (force=false, process=true)
                                          2022-01-04 17:12:56.959  - info: host.iobroker stopInstance system.adapter.fritzdect.1 send kill signal
                                          2022-01-04 17:12:56.974  - error: fritzdect.1 (2330253) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-04 17:12:56.975  - error: fritzdect.1 (2330253) unhandled promise rejection: undefined
                                          2022-01-04 17:12:56.975  - error: fritzdect.1 (2330253) undefined
                                          2022-01-04 17:12:57.615  - info: host.iobroker instance system.adapter.fritzdect.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-01-04 17:13:00.082  - info: host.iobroker instance system.adapter.fritzdect.1 started with pid 2331270
                                          2022-01-04 17:13:01.700  - error: fritzdect.1 (2331270) errorHandlerTypeError: Converting circular structure to JSON
                                          2022-01-04 17:13:01.704  - error: fritzdect.1 (2331270) fritzbox returned this {}
                                          2022-01-04 17:13:01.705  - error: fritzdect.1 (2331270) no response part in returned message
                                          2022-01-04 17:14:44.855  - info: host.iobroker stopInstance system.adapter.fritzdect.1 (force=false, process=true)
                                          2022-01-04 17:14:44.866  - info: host.iobroker stopInstance system.adapter.fritzdect.1 send kill signal
                                          2022-01-04 17:14:45.516  - info: host.iobroker instance system.adapter.fritzdect.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-01-04 17:14:47.970  - info: host.iobroker instance system.adapter.fritzdect.1 started with pid 2332389
                                          2022-01-04 17:14:58.923  - error: fritzdect.1 (2332389) fritzbox returned this {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.200","port":80}
                                          2022-01-04 17:14:58.925  - error: fritzdect.1 (2332389) no response part in returned message
                                          2022-01-04 17:15:09.459  - info: host.iobroker "system.adapter.fritzdect.1" disabled
                                          2022-01-04 17:15:09.461  - info: host.iobroker stopInstance system.adapter.fritzdect.1 (force=false, process=true)
                                          2022-01-04 17:15:09.477  - info: host.iobroker stopInstance system.adapter.fritzdect.1 send kill signal
                                          2022-01-04 17:15:09.604  - error: fritzdect.1 (2332389) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-04 17:15:09.607  - error: fritzdect.1 (2332389) unhandled promise rejection: undefined
                                          2022-01-04 17:15:09.608  - error: fritzdect.1 (2332389) undefined
                                          2022-01-04 17:15:10.089  - info: host.iobroker instance system.adapter.fritzdect.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-01-04 17:16:13.388  - info: host.iobroker "system.adapter.fritzdect.1" enabled
                                          2022-01-04 17:16:13.602  - info: host.iobroker instance system.adapter.fritzdect.1 started with pid 2333440
                                          2022-01-04 17:16:15.101  - error: fritzdect.1 (2333440) errorHandlerTypeError: Converting circular structure to JSON
                                          2022-01-04 17:16:15.103  - error: fritzdect.1 (2333440) fritzbox returned this {}
                                          2022-01-04 17:16:15.103  - error: fritzdect.1 (2333440) no response part in returned message
                                          2022-01-04 17:16:32.457  - info: host.iobroker "system.adapter.fritzdect.1" disabled
                                          2022-01-04 17:16:32.460  - info: host.iobroker stopInstance system.adapter.fritzdect.1 (force=false, process=true)
                                          2022-01-04 17:16:32.468  - info: host.iobroker stopInstance system.adapter.fritzdect.1 send kill signal
                                          2022-01-04 17:16:32.483  - error: fritzdect.1 (2333440) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-04 17:16:32.484  - error: fritzdect.1 (2333440) unhandled promise rejection: undefined
                                          2022-01-04 17:16:32.484  - error: fritzdect.1 (2333440) undefined
                                          2022-01-04 17:16:33.133  - info: host.iobroker instance system.adapter.fritzdect.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-01-04 17:17:51.644  - info: host.iobroker "system.adapter.fritzdect.1" enabled
                                          2022-01-04 17:17:51.767  - info: host.iobroker instance system.adapter.fritzdect.1 started with pid 2334446
                                          2022-01-04 17:17:53.245  - error: fritzdect.1 (2334446) errorHandlerTypeError: Converting circular structure to JSON
                                          2022-01-04 17:17:53.249  - error: fritzdect.1 (2334446) fritzbox returned this {}
                                          2022-01-04 17:17:53.249  - error: fritzdect.1 (2334446) no response part in returned message
                                          2022-01-04 17:18:57.497  - error: fritzdect.1 (2334446) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-04 17:18:57.499  - error: fritzdect.1 (2334446) unhandled promise rejection: undefined
                                          2022-01-04 17:18:57.499  - error: fritzdect.1 (2334446) undefined
                                          2022-01-04 17:18:57.519  - error: fritzdect.1 (2334446) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-04 17:18:57.520  - error: fritzdect.1 (2334446) unhandled promise rejection: undefined
                                          2022-01-04 17:18:57.520  - error: fritzdect.1 (2334446) undefined
                                          2022-01-04 17:18:58.102  - error: host.iobroker instance system.adapter.fritzdect.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2022-01-04 17:18:58.103  - info: host.iobroker Restart adapter system.adapter.fritzdect.1 because enabled
                                          2022-01-04 17:19:28.147  - info: host.iobroker instance system.adapter.fritzdect.1 started with pid 2335151
                                          2022-01-04 17:19:29.553  - error: fritzdect.1 (2335151) errorHandlerTypeError: Converting circular structure to JSON
                                          2022-01-04 17:19:29.555  - error: fritzdect.1 (2335151) fritzbox returned this {}
                                          2022-01-04 17:19:29.555  - error: fritzdect.1 (2335151) no response part in returned message
                                          2022-01-05 09:25:07.849  - error: fritzdect.1 (2335151) errorHandlerTypeError: Converting circular structure to JSON
                                          2022-01-05 09:25:07.854  - error: fritzdect.1 (2335151) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-05 09:25:07.854  - error: fritzdect.1 (2335151) unhandled promise rejection: Converting circular structure to JSON
                                          2022-01-05 09:25:07.855  - error: fritzdect.1 (2335151) TypeError: Converting circular structure to JSON
                                              at Fritzdect.errorHandler (/opt/iobroker/node_modules/iobroker.fritzdect/main.js:1052:52)
                                              at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:355:29
                                          2022-01-05 09:25:07.856  - error: fritzdect.1 (2335151) Converting circular structure to JSON
                                          2022-01-05 09:25:07.870  - error: fritzdect.1 (2335151) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-05 09:25:07.871  - error: fritzdect.1 (2335151) unhandled promise rejection: undefined
                                          2022-01-05 09:25:07.871  - error: fritzdect.1 (2335151) undefined
                                          2022-01-05 09:25:08.513  - error: host.iobroker instance system.adapter.fritzdect.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2022-01-05 09:25:08.519  - info: host.iobroker Restart adapter system.adapter.fritzdect.1 because enabled
                                          2022-01-05 09:25:38.578  - info: host.iobroker instance system.adapter.fritzdect.1 started with pid 2922341
                                          2022-01-05 09:25:40.360  - error: fritzdect.1 (2922341) errorHandlerTypeError: Converting circular structure to JSON
                                          2022-01-05 09:25:40.365  - error: fritzdect.1 (2922341) fritzbox returned this {}
                                          2022-01-05 09:25:40.366  - error: fritzdect.1 (2922341) no response part in returned message
                                          2022-01-05 09:38:23.923  - info: host.iobroker "system.adapter.fritzdect.1" disabled
                                          2022-01-05 09:38:23.928  - info: host.iobroker stopInstance system.adapter.fritzdect.1 (force=false, process=true)
                                          2022-01-05 09:38:23.946  - info: host.iobroker stopInstance system.adapter.fritzdect.1 send kill signal
                                          2022-01-05 09:38:23.952  - error: fritzdect.1 (2922341) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2022-01-05 09:38:23.953  - error: fritzdect.1 (2922341) unhandled promise rejection: undefined
                                          2022-01-05 09:38:23.954  - error: fritzdect.1 (2922341) undefined
                                          2022-01-05 09:38:24.559  - info: host.iobroker instance system.adapter.fritzdect.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-01-05 09:53:59.056  - info: host.iobroker stopInstance system.adapter.fritzdect.0 (force=false, process=true)
                                          2022-01-05 09:53:59.067  - info: host.iobroker stopInstance system.adapter.fritzdect.0 send kill signal
                                          2022-01-05 09:53:59.786  - info: host.iobroker instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-01-05 09:54:02.213  - info: host.iobroker instance system.adapter.fritzdect.0 started with pid 2940153
                                          2022-01-05 10:00:00.833  - info: host.iobroker iobroker del fritzdect.1
                                          2022-01-05 10:00:03.005  - info: host.iobroker iobroker Delete adapter "fritzdect.1"
                                          2022-01-05 10:00:03.033  - info: host.iobroker iobroker host.iobroker Counted 1 instances of fritzdect.1
                                          2022-01-05 10:00:03.093  - info: host.iobroker iobroker host.iobroker Counted 3 channels of fritzdect.1
                                          2022-01-05 10:00:03.115  - info: host.iobroker iobroker host.iobroker Counted 75 states of fritzdect.1
                                          2022-01-05 10:00:03.134  - info: host.iobroker iobroker host.iobroker Counted 14 states of system.adapter.fritzdect.1
                                          2022-01-05 10:00:03.178  - info: host.iobroker iobroker host.iobroker Counted 66 states (fritzdect.1.*) from states
                                          2022-01-05 10:00:03.188  - info: host.iobroker iobroker host.iobroker Counted 14 states (system.adapter.fritzdect.1.*) from states
                                          2022-01-05 10:00:09.843  - info: host.iobroker object deleted system.adapter.fritzdect.1
                                          2022-01-05 19:21:07.308  - info: host.iobroker stopInstance system.adapter.fritzdect.0 (force=false, process=true)
                                          2022-01-05 19:21:07.606  - info: host.iobroker stopInstance system.adapter.fritzdect.0 send kill signal
                                          2022-01-05 19:21:10.790  - info: host.iobroker instance system.adapter.fritzdect.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2022-01-05 19:23:55.714  - info: host.iobroker instance system.adapter.fritzdect.0 started with pid 3288867
                                          ab Version 2.2.2 habe ich nichts, da hatte ich den Adapter schon gelöscht und die Comet Geräte auf die andere Box umgezogen
                                            foxthefox Developer @foxthefox last edited by
                                            @foxthefox
                                            Ich habe nochmal geschaut was die Ursache für tsoll=null und lasttarget=0 ist.
                                            Wenn wie beschrieben der Objektbaum gelöscht wird und vorher auf hkrmode =1/2 gestellt wurde, dann wird durch beim update von der FB natürlich off oder on mitgeteilt.
                                            Mit den 2 Werten wird auch nichts in tsoll/lasttarget geschrieben und so sieht man 'null'.
                                            Das gibt keinen verlässlichen Wert für tsoll, der beim nächsten Umschalten auf hkrmode=0 (auto) wirksam ist.
                                            Wenn ich sozusagen tsoll auf 8°C oder 28°C setzen würde, dann wäre das der falsche Sollwert.
                                            Von daher würde ich über die Adapterconfig eine einstellbare Voreinstellung übernehmen.
                                            Solange tsoll nicht geändert wird, wäre die Voreinstellung wirksam.
                                            Damit wäre dann dieser Sonderfall auch abgefangen.
                                            31.7k
                                            79.8k
                                            4863
