      muuulle @s.bormann last edited by
      @s-bormann
      Du hast wieder ein unfassbares Tempo drauf 😳
        DocGame @s.bormann last edited by
        @s-bormann Nach diesem letzten Update wird der Adapter nicht mehr grün...
        host.iobroker	2022-01-09 19:13:43.713	warn	Do not restart adapter system.adapter.iqontrol.0 because restart loop detected
        host.iobroker	2022-01-09 19:13:43.713	info	Restart adapter system.adapter.iqontrol.0 because enabled
        host.iobroker	2022-01-09 19:13:43.713	error	instance system.adapter.iqontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker	2022-01-09 19:13:43.713	error	Caught by controller[0]: at Iqontrol.onReady (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:1014:15)
        host.iobroker	2022-01-09 19:13:43.713	error	Caught by controller[0]: at Iqontrol.createLists (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:413:16)
        host.iobroker	2022-01-09 19:13:43.712	error	Caught by controller[0]: TypeError: sorting.indexOf is not a function
        host.iobroker	2022-01-09 19:13:43.712	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
        iqontrol.0	2022-01-09 19:13:43.134	warn	(32360) Terminated (UNCAUGHT_EXCEPTION): Without reason
        iqontrol.0	2022-01-09 19:13:43.134	info	(32360) terminating
        iqontrol.0	2022-01-09 19:13:43.134	info	(32360) cleaned everything up...
        iqontrol.0	2022-01-09 19:13:43.133	info	(32360) Stop trigger intervals
        iqontrol.0	2022-01-09 19:13:43.131	error	(32360) sorting.indexOf is not a function
        iqontrol.0	2022-01-09 19:13:43.130	error	at Iqontrol.onReady (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:1014:15)
        iqontrol.0	2022-01-09 19:13:43.130	error	at Iqontrol.createLists (/opt/iobroker/node_modules/iobroker.iqontrol/main.js:413:16)
        iqontrol.0	2022-01-09 19:13:43.130	error	(32360) TypeError: sorting.indexOf is not a function
        iqontrol.0	2022-01-09 19:13:43.129	error	(32360) unhandled promise rejection: sorting.indexOf is not a function
        iqontrol.0	2022-01-09 19:13:43.129	error	(32360) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        iqontrol.0	2022-01-09 19:13:42.052	info	(32360) Creating List States...
        iqontrol.0	2022-01-09 19:13:42.052	info	(32360) Creating Widget States...
        iqontrol.0	2022-01-09 19:13:42.029	info	(32360) Creating Popup States...
        iqontrol.0	2022-01-09 19:13:41.982	info	(32360) starting. Version 1.11.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v14.17.0, js-controller: 3.3.22
        • s.bormann
          s.bormann Most Active @DocGame last edited by
          @docgame sagte in Test Adapter iQontrol 1.11.x Vis:
          Danke, probier es jetzt bitte noch mal.
          • wendy2702
            wendy2702 last edited by
            Haben die neuen Versionen neue Nummern oder sind wir noch bei 1.11.0 ?
              @s-bormann vielen Dank. Jetzt ist er wieder grün. Zum Testen werde ich heute leider nicht mehr kommen. Das Thema mit den Listen interessiert mich brennend, da ich das bisher auch immer über die Blocklys gemacht habe. Bis jetzt kann ich euch aber nicht folgen wie das Vorgehen genau ist.
              • s.bormann
                s.bormann Most Active @wendy2702 last edited by s.bormann
                @wendy2702 sagte in Test Adapter iQontrol 1.11.x Vis:
                1.11.0 ist die aktuelle Beta. Die läuft auch meines Wissens nach gut.
                Auf Github befindet sich die Alpha-Version. Diese hat keine eigene (neue) Versionsnummer. Hier wird gerade quasi "am offenen Herzen" gearbeitet. Deshalb gibt es hier auch so viele Bugs und alle paar Stunden ein Update.
                Die Listen-Funktion ist halt a) komplett neu , b) sehr umfangreich und nutzt c) erstmalig auch sehr viele Server-Funktionen. Und da jeder Server und jede Konfig anders ist, bin ich über jeden, der mir Fehler meldet dankbar - man muss sich aber im Klaren sein, dass die Funktion derzeit noch instabil ist und man ggf. zurück auf die Beta oder die Stable wechseln muss - was ja zum Glück kein Problem ist.
                Edit: Nur noch mal zur Erklärung (weils gerade anderweitig auch Thema war): Github-Versionen sollten nur in Rücksprache mit dem Entwickler installiert werden. Hier sind wir im Gespräch darüber und im Austausch - deshalb ist es kein Problem. Aber ich würde unbedingt davon abraten, sonstige Adapter ohne Rücksprache von Github zu installieren - da weiß man schlicht nicht, was man sich installiert.
                  martinschm @s.bormann last edited by
                  @s-bormann kurze Frage zum Export von Geräte Optionen. Sollte das auch addional controls etc übernehmen?
                  Hab das gerade mal probiert und da kam irgendwie nicht so richtig was beim Import an.
                  M s.bormann 2 Replies Last reply Reply Quote 0
                    martinschm @martinschm last edited by
                    kann mir das einer mal mit den Valve_States erklären?
                    Hab es so verstanden, das es die Öffnung des Ventils bedeutet, da steht dann ein Prozentwert drin. Aber wie zeigt ihr das bei euch an, also außer als Prozentwert?
                    ciao
                    Martin
                    s.bormann 1 Reply Last reply Reply Quote 1
                    • dslraser
                      dslraser Forum Testing Most Active @s.bormann last edited by
                      @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis:
                      @dslraser Überschrift und Boder-Styling sind online
                      morgen kann ich wieder etwas weiter testen.
                      • s.bormann
                        s.bormann Most Active @martinschm last edited by
                        @martinschm sagte in Test Adapter iQontrol 1.11.x Vis:
                        Hi, nein, betrifft nur die Optionen, nicht den Rest des Gerätes.
                        • s.bormann
                          ciao
                          Martin
                          Genau, es ist so gedacht, dass es die Ventilöffnung in Prozent darstellt. Im Prinzip ist es aber ähnlich, wie die ADDITIONAL_INFOs, es sollte jeden beliebigen Datenpunkt anzeigen können.
                          • wendy2702
                            Puh 320 Seiten.... was würdet Ihr von einem extra Unterforum für den Adapter halten?
                            Unabhängig davon hier meine ersten Fragen:
                            Was bedeutet das rot markierte:
                            Wenn ich das Drop Down öffne sehe ich da nichts mit "OC" kann aber auch die Spalte nicht größer machen oder wüsste nicht wo.
                            Zweite Frage: wo kann ich denn hier die Texte die vom Birthday Kalender kommen übersetzen?
                            In VIS geht das ja im Widget aber hier konnte ich es bisher nicht finden.
                            • dslraser
                              dslraser Forum Testing Most Active @s.bormann last edited by dslraser
                              Erstmal danke für Deinen Einsatz.
                              Die Überschrift wäre vielleicht „mittig“ besser platziert.
                              Edit:
                              kann ich für Badge gekippt und geöffnet irgendwie addieren, oder brauche ich ein kleines Blockly dafür ?
                              Ich habe versucht die Überschrift auf den Datenpunkt zu verlinken, aber da wird nur der Text dargestellt, geht das an dieser Stelle irgendwie ?
                              Überschrift
                              |Fenster geöffnet: {iqontrol.0.Lists.Fensterliste.Fenster_geöffnet}
                              • dslraser
                                Deshalb habe ich das Generieren der NAMES und PARENTNAMES-Listen im JSON-Format wieder rausgeschmissen, da das ganze unnötig und verwirrend ist.
                                Die Namen Listen finde ich schon sinnvoll. Mann kann die sehr gut "missbrauchen/gebrauchen", z.B. wenn man sich geöffnete oder auch gekippte Fenster über den Alexa2 Adapter ansagen lassen möchte.
                                Dazu nur ein Hinweis. Alexa hat ein Textlimit (wieviel weiß ich gerade nicht aus dem Kopf), das kann man aber "umgehen", wenn mit Semikolon getrennt wird (nicht mit Komma). Nach jedem Semikolon beginnt das Textlimit neu. Die Ansage ist dann nur etwas langsamer.
                                Also in so einer Liste mit Komma wird in speak (alexa2 Adapter) nichts angesagt, zu lang (oder extra mit Blockly erledigen ?)
                                Bad Fenster links, Bad Fenster rechts, Gästezimmer Fenster links, Gästezimmer Fenster rechts, Keller Heizung, Keller Sauna links, Keller Sauna rechts, Keller Vorrat, Keller W Baum, Keller Werkstatt, Keller Wohnzimmer links, Keller Wohnzimmer mitte, Keller Wohnzimmer rechts, Küche Fenster links, Küche Fenster mitte, Küche Fenster rechts, Schlafzimmer Fenster links, Schlafzimmer Fenster rechts, Wohnzimmer Fenster links, Wohnzimmer Fenster rechts
                                Diese Liste wird in speak (Alexa2 Adapter) angesagt
                                Bad Fenster links; Bad Fenster rechts; Gästezimmer Fenster links; Gästezimmer Fenster rechts; Keller Heizung; Keller Sauna links; Keller Sauna rechts; Keller Vorrat; Keller W Baum; Keller Werkstatt; Keller Wohnzimmer links; Keller Wohnzimmer mitte; Keller Wohnzimmer rechts; Küche Fenster links; Küche Fenster mitte; Küche Fenster rechts; Schlafzimmer Fenster links; Schlafzimmer Fenster rechts; Wohnzimmer Fenster links; Wohnzimmer Fenster rechts
                                • s.bormann
                                  ich fände das sehr gut! Meiner Meinung nach wären möglichst viel Unterforen das beste, was die Übersichtlichkeit angeht. Aber da gibt es bestimmt auch andere Meinungen zu. @Jey-Cee , wie siehts Du das? Ist so was sinnvoll / möglich?
                                  Bei lauter einzelnen Threads, die wild im Forum verteilt sind, weiß ich persönlich sonst gar nicht, wie ich die Übersicht behalten soll, wo ich welche Frage noch nicht beantwortet habe. Oder wie lösen das Andere?
                                  Hier dieser ewig lange Thread ist natürlich überhaupt null geeignet irgenwas nachzuschlagen. Für mich ist das eher wie ein Chat.
                                  Eigentlich sollte das so aussehen:
                                  In Chrome funktioniert das auch. Welchen Browser nutzt Du?
                                  Man kann damit die einzelnen Sektionen in "Collapsibles" verwandeln, also zuklappbare Sektionen.
                                  Im JSON-Table-Widget gibt es Übersetzungen hier:
                                  Hier kann man Wort-Paare eintragen, also z.B. Birthday,Geburtstag;age,Alter;birthYear,Geburtsjahr etc.
                                  Viel Erfolg und Spaß!
                                  da_Woody wendy2702 2 Replies Last reply Reply Quote 0
                                  • wendy2702
                                    Wenn ich das aufklappe kann ich das auch sehen was du zeigst. Bin nur über das "OC" verwundert gewesen.
                                    Das mit dem Widget werde ich testen.
                                    Danke.... wird noch ein langer harter weg für mich mit dem einrichten in iQontrol. Ich zähle auf euch 😉
                                    • s.bormann
                                      @dslraser sagte in Test Adapter iQontrol 1.11.x Vis:
                                      Versuch es mal so:
                                      <center>Überschrift</center>
                                      Sieht ja schon mal mega cool aus! Geht auf jeden Fall in eine gute Richtung!
                                      Kannst Du mir mal die Farbwerte schicken, die Du vergeben hast? Dann könnte ich die als Standard in das Widget hinterlegen.
                                      Edit:
                                      Zwei Wege:
                                      Einen neuen Counter anlegen, der sowohl offen, als auch gekippt zählt (also die Conditions mit ODER verknüpft):
                                      6fa13b5c-b0ee-48c7-92c0-33daa68e9317-image.png (Die Werte von gekippt und geöffnet müssten halt noch angepasst werden)
                                      Oder zweiter Weg:
                                      Eine neue Calculation anlegen, die die beiden Werte addiert:
                                      Überschrift
                                      Das ist (noch) nicht implementiert. Muss ich mal überlegen, ob das geht. Aber eigentlich denke ich, sollte sich die Funktion in das Widget einbauen lassen. Ich denk später mal drüber nach.
                                      dslraser 2 Replies Last reply Reply Quote 1
                                      • s.bormann
                                        s.bormann Most Active @dslraser last edited by s.bormann
                                        Könnte das Trennzeichen einfach wählbar machen. Kommt auf die ToDo-Liste. Du hast immer gute Ideen!
                                        • dslraser
                                          Versuch es mal so:
                                          Edit:
                                          Zwei Wege:
                                          Oder zweiter Weg:
                                          Überschrift
                                          Die Farbwerte sind
                                          #424242
                                          und
                                          white
                                          Hier mal mein Zwischenstand.
                                          iQontrol.pdf
                                          Edit: Das funktioniert 👍
                                          • wendy2702
                                            wendy2702 @s.bormann last edited by
                                            Sorry für die lästigen Anfänger fragen 😞
                                            Wie komme ich denn an diese Einstellungen wenn das Widget bereits erstellt ist?
                                            Wenn ich ein neues erstelle sehe ich das aber bei meinem bereits existierenden finde ich es nicht.
                                            dslraser da_Woody 2 Replies Last reply Reply Quote 0
                                            296
                                            7637
                                            6981925
