    4. io broker hängt sich auf...
      Thomas Braun Most Active @Peterfrosta last edited by
      @peterfrosta
      Das würde ich z. B. nicht über ein skript sondern über den dafür vorgesehenen Adapter machen. Der wird auch immer an neue Gegebenheiten angepasst.
        Peterfrosta @Glasfaser last edited by
        @glasfaser
        pi@raspberrypi:/opt/iobroker/log $ iobroker update - i
        Used repository: -
        failed to download new sources, use cached sources
        update done
        Adapter    "admin"         : 5.2.3    , installed 5.1.23 [Updateable]
        Adapter    "ble"           : 0.12.0   , installed 0.12.0
        Adapter    "devices"       : 1.0.9    , installed 1.0.9
        Adapter    "discovery"     : 2.7.3    , installed 2.7.3
        Adapter    "flot"          : 1.10.7   , installed 1.10.7
        Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
        Adapter    "history"       : 1.9.14   , installed 1.9.14
        Adapter    "info"          : 1.9.8    , installed 1.9.8
        Adapter    "javascript"    : 5.2.13   , installed 5.2.13
        Controller "js-controller" : 3.3.22   , installed 3.3.18 [Updateable]
        Adapter    "lovelace"      : 2.0.6    , installed 2.0.6
        Adapter    "node-red"      : 2.4.1    , installed 2.4.1
        Adapter    "ping"          : 1.5.0    , installed 1.5.0
        Adapter    "scenes"        : 2.3.8    , installed 2.3.8
        Adapter    "shelly"        : 4.0.7    , installed 4.0.7
        Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
        Adapter    "socketio"      : 3.1.4    , installed 3.1.4
        Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
        Adapter    "tesla-motors"  : 0.5.2    , installed 0.5.2
        Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
        Adapter    "vis"           : 1.4.5    , installed 1.4.5
        Adapter    "web"           : 3.4.9    , installed 3.4.9
        Adapter    "zwave2"        : 2.4.1    , installed 2.4.1
        pi@raspberrypi:/opt/iobroker/log $ iobroker list instances
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
          system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
          system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              - disabled
          system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.zwave2.0                 : zwave2                : raspberrypi                              - disabled
        + instance is alive
        pi@raspberrypi:/opt/iobroker/log $ iobroker status
        Objects type: file
        States  type: file
        pi@raspberrypi:/opt/iobroker/log $ iobroker version
        3.3.18
        pi@raspberrypi:/opt/iobroker/log $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
        pi@raspberrypi:/opt/iobroker/log $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.18.1
        v14.18.1
        6.14.15
        Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
        Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
        Holen:3 https://deb.nodesource.com/node_14.x buster InRelease [4.584 B]
        OK:4 https://download.docker.com/linux/raspbian buster InRelease
        Holen:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
        Holen:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
        Holen:7 https://deb.nodesource.com/node_14.x buster/main armhf Packages [780 B]
        Es wurden 13,5 MB in 55 s geholt (244 kB/s).
        Aktualisierung für 15 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
        OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        OK:2 https://download.docker.com/linux/raspbian buster InRelease
        OK:3 http://archive.raspberrypi.org/debian buster InRelease
        OK:4 https://deb.nodesource.com/node_14.x buster InRelease
        nodejs:
          Installiert:           14.18.1-deb-1nodesource1
          Installationskandidat: 14.18.3-deb-1nodesource1
          Versionstabelle:
             14.18.3-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         *** 14.18.1-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u1 500
          Peterfrosta @Thomas Braun last edited by
          mir ist kein Adapter bekannt, der das ganze Image backuped
            Thomas Braun Most Active @Peterfrosta last edited by Thomas Braun
            @peterfrosta
            Brauchts auch (meist) nicht.
            Vermutlich geht dir durch die Aktion nämlich der Speicher aus. Und Prozesse werden vom oom-reaper gekillt.
            P 2 Replies Last reply Reply Quote 0
              Peterfrosta @Thomas Braun last edited by Peterfrosta
              Brauchen und wollen ^^
              Ist halt zum wieder herstellen sehr bewequem
              Das Pi mit Iobroker an einem anderen Standort verfährt genaus so. Eigentlich machen das alle meine Pis so.. die meisten jedoch nur einmal die Woche
                Homoran Global Moderator Administrators @Peterfrosta last edited by
                @peterfrosta sagte in io broker hängt sich auf...:
                Das Pi mir der Iobroker an einem anderen Standort verwert
                  Peterfrosta @Homoran last edited by Peterfrosta
                  @homoran said in io broker hängt sich auf...:
                  war mit irgendeiner Tastenkombination zufrueh abgesendet worden
                    @thomas-braun said in io broker hängt sich auf...:
                    @peterfrosta
                    hm.. auf dem Pi läuft parallel noch PiHole drauf
                      Knallt dir hier offenbar auf die Füße.
                      Wollen kann man halt viel, ob es sinnvoll (und technisch stabil machbar) ist ist dann aber die Frage, die sich aber noch vor dem Wollen stellt.
                        @peterfrosta Ah - editiert!
                        Aber bloss weil es alle (Pi bei dir) machen, ist es deswegen doch nicht richtig.
                        Ich weiss nicht was du da willst und brauchst, aber je mehr das ist, desto mehr Ressourcen braucht es - bis hin zum Absturz.
                        Ich kann auch nicht glauben, dass deine Installation heute noch so ist, wie "schon immer".
                        Da wird einiges gewachsen sein und somit noch mehr Ressourcen brauchen. und die sind auch bei 4GB endlich
                          ich vergaß!
                          vor dem Backup wird ioBroker gestoppt und soll auch wieder gestartet werden.
                          Dann ist das vllt garkein ioBroker Problem?!
                          ich müsste in Erfahrung bringen, warum ioBroker nicht wieder startet.
                            naja... sein Linuxsystem mit DD bzw einem weit verbreitetem Script zu sichern ist jetzt auch nichts technisch ungewöhnliches oder sinnloses oder Gebastel. Fehler oder Änderungen können sich bei allem ergeben.
                              iobroker wird ja vor dem Backup gestoppt. Die Info fehlte. Mir ja anfangs auch.
                              doch doch.. ausser PiHole, iobroker und RaspiBackup passiert da "nichts" drauf.
                              Hatte die Tage nur an neuen Scripten gebastelt.
                              874
