    4. io broker hängt sich auf...
    • Neues Video auf YouTube
      Peterfrosta @Glasfaser last edited by
      @glasfaser
      pi@raspberrypi:/opt/iobroker/log $ iobroker update - i
      Used repository: -
      failed to download new sources, use cached sources
      update done
      Adapter    "admin"         : 5.2.3    , installed 5.1.23 [Updateable]
      Adapter    "ble"           : 0.12.0   , installed 0.12.0
      Adapter    "devices"       : 1.0.9    , installed 1.0.9
      Adapter    "discovery"     : 2.7.3    , installed 2.7.3
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
      Adapter    "history"       : 1.9.14   , installed 1.9.14
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "javascript"    : 5.2.13   , installed 5.2.13
      Controller "js-controller" : 3.3.22   , installed 3.3.18 [Updateable]
      Adapter    "lovelace"      : 2.0.6    , installed 2.0.6
      Adapter    "node-red"      : 2.4.1    , installed 2.4.1
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "scenes"        : 2.3.8    , installed 2.3.8
      Adapter    "shelly"        : 4.0.7    , installed 4.0.7
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "tesla-motors"  : 0.5.2    , installed 0.5.2
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
      Adapter    "vis"           : 1.4.5    , installed 1.4.5
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      Adapter    "zwave2"        : 2.4.1    , installed 2.4.1
      pi@raspberrypi:/opt/iobroker/log $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
        system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              - disabled
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zwave2.0                 : zwave2                : raspberrypi                              - disabled
      + instance is alive
      pi@raspberrypi:/opt/iobroker/log $ iobroker status
      Objects type: file
      States  type: file
      pi@raspberrypi:/opt/iobroker/log $ iobroker version
      3.3.18
      pi@raspberrypi:/opt/iobroker/log $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      pi@raspberrypi:/opt/iobroker/log $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.18.1
      v14.18.1
      6.14.15
      Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
      Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
      Holen:3 https://deb.nodesource.com/node_14.x buster InRelease [4.584 B]
      OK:4 https://download.docker.com/linux/raspbian buster InRelease
      Holen:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
      Holen:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
      Holen:7 https://deb.nodesource.com/node_14.x buster/main armhf Packages [780 B]
      Es wurden 13,5 MB in 55 s geholt (244 kB/s).
      Aktualisierung für 15 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 https://download.docker.com/linux/raspbian buster InRelease
      OK:3 http://archive.raspberrypi.org/debian buster InRelease
      OK:4 https://deb.nodesource.com/node_14.x buster InRelease
      nodejs:
        Installiert:           14.18.1-deb-1nodesource1
        Installationskandidat: 14.18.3-deb-1nodesource1
        Versionstabelle:
           14.18.3-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
       *** 14.18.1-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
        Peterfrosta @Thomas Braun last edited by
        mir ist kein Adapter bekannt, der das ganze Image backuped
          Thomas Braun Most Active @Peterfrosta last edited by Thomas Braun
          @peterfrosta
          Brauchts auch (meist) nicht.
          Vermutlich geht dir durch die Aktion nämlich der Speicher aus. Und Prozesse werden vom oom-reaper gekillt.
          P 2 Replies Last reply Reply Quote 0
            Peterfrosta @Thomas Braun last edited by Peterfrosta
            Brauchen und wollen ^^
            Ist halt zum wieder herstellen sehr bewequem
            Das Pi mit Iobroker an einem anderen Standort verfährt genaus so. Eigentlich machen das alle meine Pis so.. die meisten jedoch nur einmal die Woche
              Homoran Global Moderator Administrators @Peterfrosta last edited by
              @peterfrosta sagte in io broker hängt sich auf...:
              Das Pi mir der Iobroker an einem anderen Standort verwert
                Peterfrosta @Homoran last edited by Peterfrosta
                @homoran said in io broker hängt sich auf...:
                war mit irgendeiner Tastenkombination zufrueh abgesendet worden
                  @thomas-braun said in io broker hängt sich auf...:
                  @peterfrosta
                  hm.. auf dem Pi läuft parallel noch PiHole drauf
                    Knallt dir hier offenbar auf die Füße.
                    Wollen kann man halt viel, ob es sinnvoll (und technisch stabil machbar) ist ist dann aber die Frage, die sich aber noch vor dem Wollen stellt.
                      @peterfrosta Ah - editiert!
                      Aber bloss weil es alle (Pi bei dir) machen, ist es deswegen doch nicht richtig.
                      Ich weiss nicht was du da willst und brauchst, aber je mehr das ist, desto mehr Ressourcen braucht es - bis hin zum Absturz.
                      Ich kann auch nicht glauben, dass deine Installation heute noch so ist, wie "schon immer".
                      Da wird einiges gewachsen sein und somit noch mehr Ressourcen brauchen. und die sind auch bei 4GB endlich
                        ich vergaß!
                        vor dem Backup wird ioBroker gestoppt und soll auch wieder gestartet werden.
                        Dann ist das vllt garkein ioBroker Problem?!
                        ich müsste in Erfahrung bringen, warum ioBroker nicht wieder startet.
                          naja... sein Linuxsystem mit DD bzw einem weit verbreitetem Script zu sichern ist jetzt auch nichts technisch ungewöhnliches oder sinnloses oder Gebastel. Fehler oder Änderungen können sich bei allem ergeben.
                            iobroker wird ja vor dem Backup gestoppt. Die Info fehlte. Mir ja anfangs auch.
                            doch doch.. ausser PiHole, iobroker und RaspiBackup passiert da "nichts" drauf.
                            Hatte die Tage nur an neuen Scripten gebastelt.
                            874
