    4. Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed
    • OliverIO
      OliverIO @nhet last edited by
      @nhet
      damit hast du eine instanz hinzugefügt.
      bitte den adapter im reiter adapter löschen und dann neu hinzufügen (+instanz)
      • N
        nhet @OliverIO last edited by nhet
        @oliverio Ok. Hab's dann jetzt über die Adapter gemacht:
         iobroker add rssfeed auto --host raspberrypi
        NPM version: 6.14.15
        npm install iobroker.rssfeed@1.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
        host.raspberrypi install adapter rssfeed
        upload [6] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/words.js words.js application/javascript
        upload [5] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/style.css style.css text/css
        upload [4] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/rssfeed-logo.png rssfeed-logo.png image/png
        upload [3] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/index_m.html.bak index_m.html.bak null
        upload [2] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/index_m.html index_m.html text/html
        upload [1] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.js build/index.js application/javascript
        upload [0] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.css build/index.css text/css
        host.raspberrypi object system.adapter.rssfeed created/updated
        host.raspberrypi create instance rssfeed
        host.raspberrypi object rssfeed.0.info.connection created
        host.raspberrypi object rssfeed.0.info created
        host.raspberrypi object system.adapter.rssfeed.0.logLevel created
        host.raspberrypi object system.adapter.rssfeed.0.sigKill created
        host.raspberrypi object system.adapter.rssfeed.0.eventLoopLag created
        host.raspberrypi object system.adapter.rssfeed.0.outputCount created
        host.raspberrypi object system.adapter.rssfeed.0.inputCount created
        host.raspberrypi object system.adapter.rssfeed.0.uptime created
        host.raspberrypi object system.adapter.rssfeed.0.memRss created
        host.raspberrypi object system.adapter.rssfeed.0.memHeapTotal created
        host.raspberrypi object system.adapter.rssfeed.0.memHeapUsed created
        host.raspberrypi object system.adapter.rssfeed.0.cputime created
        host.raspberrypi object system.adapter.rssfeed.0.cpu created
        host.raspberrypi object system.adapter.rssfeed.0.compactMode created
        host.raspberrypi object system.adapter.rssfeed.0.connected created
        host.raspberrypi object system.adapter.rssfeed.0.alive created
        host.raspberrypi Set default value of rssfeed.0.info.connection: false
        host.raspberrypi object system.adapter.rssfeed.0 created
        Process exited with code 0
        Leider auch so keine Widgets im VIS
        • OliverIO
          @nhet
          und wieder keine widgets in vis gefunden?
          hm alles unauffällig.
          Findest du im Logfile irgendwelche Fehler?
          Nur um sicher zu gehen, du hast hier gesucht?
          Ich habe gerade in meiner Testinstallation den Adapter ebenfalls entfernt und neu installiert. Da ist alles da.
          Kannst du mir mal die Versionen von
          iobroker
          node
          Browser
          Evtl auch mal in die Browserkonsole (bei Chrome mit F12) gehen und dort im Reiter Console schauen ob da Fehler drin stehen.
          geben?
          OliverIO N 3 Replies Last reply Reply Quote 0
          • OliverIO
            OliverIO @OliverIO last edited by OliverIO
            Gib mal die folgende Adresse im Browser ein.
            IP bitte entsprechend anpassen
            http://192.168.1.80:8082/vis/widgets/rssfeed/js/rssfeed.js
            Verwendest du einen Webblocker wie Adblock oder ähnlich, den auch mal abschalten?
            • N
              @oliverio
              File widgets/rssfeed/js/rssfeed.js not found: {}
              Und einen Adblocker benutze ich nicht.
              OliverIO N 2 Replies Last reply Reply Quote 0
              • N
                @oliverio sagte in Test und Support Adapter rssfeed v1.x.x:
                iobroker 3.3.22
                node 6.4.15
                Browser Chrome Version 97.0.4692.71 (Offizieller Build) (64-Bit)
                • N
                  @oliverio Ja genau da habe ich auch immer gesucht und leider nix gefunden
                  • OliverIO
                    @nhet
                    ok, dann bitte mal die Ausgabe vom folgenden Befehl von der Konsole
                    iob upload rssfeed
                    es scheint so, das iobroker die notwendigen dateien nicht nach vis/web kopiert.
                    das erfolgt immer im rahmen der adapterinstallation
                    Das ist allerdings ein Problem von iobroker
                    • N
                      nhet @nhet last edited by
                      @nhet
                      iob upload rssfeed
                      Hier der Output:
                      /opt/iobroker/log $ iob upload rssfeed
                      • OliverIO
                        @nhet sagte in Test und Support Adapter rssfeed v1.x.x:
                        node 6.4.15
                        das ist die version von npm, dem packetmanager
                        hiermit die nodeversion
                        node -v
                        • N
                          nhet last edited by
                          node -v
                          v12.22.9
                          • OliverIO
                            @nhet
                            dann probieren wir mal noch
                            iob upload vis | grep rssfeed
                            • N
                              @oliverio Leider nix im Output. Ich habe dazu auch mal das grep weg gelassen
                              iob upload vis
                              upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                              upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                              upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                              upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                              upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png image/png
                              upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/refresh_01.png widgets/timeandweather/img/refresh_01.png image/png
                              upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/31-2.png widgets/timeandweather/img/clock/31-2.png image/png
                              upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
                              upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/js/widgets/materialdesign.viseditor.js widgets/materialdesign/js/widgets/materialdesign.viseditor.js application/javascript
                              upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/img/bar_chart.png widgets/materialdesign/img/bar_chart.png image/png
                              upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/img/openDoor.png widgets/hqwidgets/img/openDoor.png image/png
                              upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBool.png widgets/basic/img/Prev_ValueBool.png image/png
                              upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
                              upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
                              upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
                              upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
                              upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                              upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
                              upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
                              upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
                              upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                              upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                              upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
                              upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
                              upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                              upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
                              upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
                              upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
                              upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
                              upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
                              upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
                              upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
                              upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
                              upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
                              upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
                              upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
                              upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
                              upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
                              upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
                              upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
                              upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
                              upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
                              upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                              • N
                                nhet last edited by
                                Ich glaube ich habe es hinbekommen. Die Widgets sind nun da. Ich habe auf der Konsole noch ein
                                iob visdebug rssfeed
                                iob restart
                                ausgeführt.
                                • OliverIO
                                  @nhet
                                  ok
                                  aber normal ist das nicht. irgendwas ist dann an deiner installation krumm
                                  beobachte das mal auch bei der installation von anderen adaptern.
                                  rssfeed ist bei über 400 installationen im einsatz.
                                  gelegentlich gab es probleme, welche man mit upload all behoben konnte.
                                  glaube aber das sind meist die, die ganz am anfang mal direkt von github installiert haben
                                  das hier kam zum ersten mal vor.
                                  • umbm
                                    umbm last edited by
                                    Ich kann in den Adapter-Einstellungen (V1.0.0) die Anzahl der zu lesende Max.Artikel nicht ändern.
                                    Die Eingabe springt immer wieder auf 100 zurück, mir würde 1 reichen.
                                    Der vorgegebene minimale Zeitintervall 60 bedeutet Minuten?
                                    Kann man den Wert bitte auch verkürzen?
                                    Ich würde gern jede 5 Minuten jeweils nur 1 Artikel aus einem Feed (nur die neuste GPS-Position) auslesen.
                                    • OliverIO
                                      OliverIO @umbm last edited by
                                      @umbm
                                      ich habe noch ein paar punkte, die an diesem adapter überarbeitet werden müssen.
                                      ich werde deine wünsche dann berücksichtigen.
                                      • O
                                        Oli @OliverIO last edited by
                                        @oliverio
                                        sorry für die blöde Frage, aber wie bekomme ich die Gesamtanzahl der Inhalte eines Feeds heraus?
                                        • OliverIO
                                          OliverIO @Oli last edited by
                                          @oli
                                          das kommt darauf an.
                                          Die Menge der Artikel werden durch gewisse Faktoren limitiert.
                                          1. Max Articles in der Adapterkonfiguration (standardmäßig 100)
                                          2. das Attribut rss_maxarticles in den jeweiligen widget
                                          alles das was dann noch übrigbleibt wird dann an das Ausgabe-Template in das Array articles übergeben.
                                          Nutzt du ein eigenes template zur Ausgabe der rss-Artikel?
                                          Das widget funktioniert ja intern mit einem ejs-Template (ist in der widget hilfe angegeben)
                                          Wenn du da die Gesamtmenge ausgeben willst habe ich dir das Template in zeile 2 ohne großen schnickschnack wie Formatierung hinzugefügt (articles.length)
                                          <%= meta.title %>
                                          <%= articles.length %>
                                          <% articles.forEach(function(item){ %>
                                          <p><small><%- vis.formatDate(item.pubdate, "TT.MM.JJJJ SS:mm") %></small></p>
                                          <h3><%- item.title %></h3>
                                          <p><%- item.description %></p>
                                          <div style="clear:both;" />
                                          • O
                                            @oliverio
                                            danke für deine schnelle Antwort.
                                            Ich benutze den RSS Feed der Produktwarnungen und möchte mir die Gesamtanzahl der Produktwarnungen gerne in meiner VIS anzeigen lassen, daher die Frage.
                                            Sorry hätte ich oben gleich mit dazu schreiben sollen.
                                            Jetzt habe ich allerdings noch eine Frage.
                                            ich habe gerade deine coole Slideshow entdeckt und natürlich gleich mal getestet, funktioniert super!!!!
                                            Aber wie bekomme ich die lästige Überschrift "Lebensmittelwarnung.de- Warnungen in Bayern" weg?
                                            Wenn ich das Script der Slidshow entferne, erscheint die Überschrift nicht
                                            Mit Slideshow:
                                            <script>
                                            // Konfigurationsbereich Anfang
                                            var fadeTime = 1000; //Zeit in Millisekunden zum Ein und Ausblenden eines Artikels
                                            var showTime = 4000; //Zeitdauer, wie lange ein Artikel angezeigt werden soll
                                            // Konfigurationsbereich Ende
                                            </script>
                                            <style>
                                            #{wname} .slideshow {
                                              position: relative;
                                            #{wname} .slideshow > div {
                                              position: absolute;
                                              display: none;
                                            #{wname} .slideshow >  div:nth-child(0n+1) {
                                                display: block;
                                            </style>
                                            <script>
                                            setInterval(function() {
                                              $('#{wname} .slideshow > div:first')
                                                .fadeOut(fadeTime)
                                                .next()
                                                .fadeIn(fadeTime)
                                                .end()
                                                .appendTo('#{wname} .slideshow');
                                            }, showTime);
                                            </script>
                                            <%= meta.title %>
                                            <div class="slideshow">
                                               <div>
                                            <p><item.pubdate style="color:Orange">Veröffentlichungsdatum: <%- vis.formatDate(item.pubdate, "TT.MM.JJJJ SS:mm")%> Uhr</p>
                                            <h3><item.title style="color:Lightgreen"><%- item.title %></h3>
                                            <p><small><%- item.description %></small></p>
                                               </div>
                                            </div>
                                            Ohne Slideshow:
                                            <div style="clear:both;" ></div>
                                            Wo habe ich den Fehler?
                                            adapter atom feed iobroker.rssfeed rdf rss vis widget
                                            34
                                            694
                                            154255
