    4. Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed
    • N
      nhet @OliverIO last edited by nhet
      @oliverio Ok. Hab's dann jetzt über die Adapter gemacht:
       iobroker add rssfeed auto --host raspberrypi
      NPM version: 6.14.15
      npm install iobroker.rssfeed@1.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
      host.raspberrypi install adapter rssfeed
      upload [6] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/words.js words.js application/javascript
      upload [5] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/style.css style.css text/css
      upload [4] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/rssfeed-logo.png rssfeed-logo.png image/png
      upload [3] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/index_m.html.bak index_m.html.bak null
      upload [2] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/index_m.html index_m.html text/html
      upload [1] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.js build/index.js application/javascript
      upload [0] rssfeed.admin /opt/iobroker/node_modules/iobroker.rssfeed/admin/build/index.css build/index.css text/css
      host.raspberrypi object system.adapter.rssfeed created/updated
      host.raspberrypi create instance rssfeed
      host.raspberrypi object rssfeed.0.info.connection created
      host.raspberrypi object rssfeed.0.info created
      host.raspberrypi object system.adapter.rssfeed.0.logLevel created
      host.raspberrypi object system.adapter.rssfeed.0.sigKill created
      host.raspberrypi object system.adapter.rssfeed.0.eventLoopLag created
      host.raspberrypi object system.adapter.rssfeed.0.outputCount created
      host.raspberrypi object system.adapter.rssfeed.0.inputCount created
      host.raspberrypi object system.adapter.rssfeed.0.uptime created
      host.raspberrypi object system.adapter.rssfeed.0.memRss created
      host.raspberrypi object system.adapter.rssfeed.0.memHeapTotal created
      host.raspberrypi object system.adapter.rssfeed.0.memHeapUsed created
      host.raspberrypi object system.adapter.rssfeed.0.cputime created
      host.raspberrypi object system.adapter.rssfeed.0.cpu created
      host.raspberrypi object system.adapter.rssfeed.0.compactMode created
      host.raspberrypi object system.adapter.rssfeed.0.connected created
      host.raspberrypi object system.adapter.rssfeed.0.alive created
      host.raspberrypi Set default value of rssfeed.0.info.connection: false
      host.raspberrypi object system.adapter.rssfeed.0 created
      Process exited with code 0
      Leider auch so keine Widgets im VIS
      • OliverIO
        OliverIO @nhet last edited by
        @nhet
        und wieder keine widgets in vis gefunden?
        hm alles unauffällig.
        Findest du im Logfile irgendwelche Fehler?
        Nur um sicher zu gehen, du hast hier gesucht?
        Ich habe gerade in meiner Testinstallation den Adapter ebenfalls entfernt und neu installiert. Da ist alles da.
        Kannst du mir mal die Versionen von
        iobroker
        node
        Browser
        Evtl auch mal in die Browserkonsole (bei Chrome mit F12) gehen und dort im Reiter Console schauen ob da Fehler drin stehen.
        geben?
        OliverIO N 3 Replies Last reply Reply Quote 0
        • OliverIO
          OliverIO @OliverIO last edited by OliverIO
          Gib mal die folgende Adresse im Browser ein.
          IP bitte entsprechend anpassen
          http://192.168.1.80:8082/vis/widgets/rssfeed/js/rssfeed.js
          Verwendest du einen Webblocker wie Adblock oder ähnlich, den auch mal abschalten?
          • N
            @oliverio
            File widgets/rssfeed/js/rssfeed.js not found: {}
            Und einen Adblocker benutze ich nicht.
            OliverIO N 2 Replies Last reply Reply Quote 0
            • N
              @oliverio sagte in Test und Support Adapter rssfeed v1.x.x:
              iobroker 3.3.22
              node 6.4.15
              Browser Chrome Version 97.0.4692.71 (Offizieller Build) (64-Bit)
              • N
                @oliverio Ja genau da habe ich auch immer gesucht und leider nix gefunden
                • OliverIO
                  @nhet
                  ok, dann bitte mal die Ausgabe vom folgenden Befehl von der Konsole
                  iob upload rssfeed
                  es scheint so, das iobroker die notwendigen dateien nicht nach vis/web kopiert.
                  das erfolgt immer im rahmen der adapterinstallation
                  Das ist allerdings ein Problem von iobroker
                  • N
                    nhet @nhet last edited by
                    @nhet
                    iob upload rssfeed
                    Hier der Output:
                    /opt/iobroker/log $ iob upload rssfeed
                    • OliverIO
                      @nhet sagte in Test und Support Adapter rssfeed v1.x.x:
                      node 6.4.15
                      das ist die version von npm, dem packetmanager
                      hiermit die nodeversion
                      node -v
                      • N
                        nhet last edited by
                        node -v
                        v12.22.9
                        • OliverIO
                          @nhet
                          dann probieren wir mal noch
                          iob upload vis | grep rssfeed
                          • N
                            @oliverio Leider nix im Output. Ich habe dazu auch mal das grep weg gelassen
                            iob upload vis
                            upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                            upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                            upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                            upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                            upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png image/png
                            upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/refresh_01.png widgets/timeandweather/img/refresh_01.png image/png
                            upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/31-2.png widgets/timeandweather/img/clock/31-2.png image/png
                            upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
                            upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/js/widgets/materialdesign.viseditor.js widgets/materialdesign/js/widgets/materialdesign.viseditor.js application/javascript
                            upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/img/bar_chart.png widgets/materialdesign/img/bar_chart.png image/png
                            upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/img/openDoor.png widgets/hqwidgets/img/openDoor.png image/png
                            upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBool.png widgets/basic/img/Prev_ValueBool.png image/png
                            upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
                            upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
                            upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
                            upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
                            upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                            upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
                            upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
                            upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
                            upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                            upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                            upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
                            upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
                            upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                            upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
                            upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
                            upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
                            upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
                            upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
                            upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
                            upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
                            upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
                            upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
                            upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
                            upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
                            upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
                            upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
                            upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
                            upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
                            upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
                            upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
                            upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                            • N
                              nhet last edited by
                              Ich glaube ich habe es hinbekommen. Die Widgets sind nun da. Ich habe auf der Konsole noch ein
                              iob visdebug rssfeed
                              iob restart
                              ausgeführt.
                              • OliverIO
                                @nhet
                                ok
                                aber normal ist das nicht. irgendwas ist dann an deiner installation krumm
                                beobachte das mal auch bei der installation von anderen adaptern.
                                rssfeed ist bei über 400 installationen im einsatz.
                                gelegentlich gab es probleme, welche man mit upload all behoben konnte.
                                glaube aber das sind meist die, die ganz am anfang mal direkt von github installiert haben
                                das hier kam zum ersten mal vor.
                                • umbm
                                  umbm last edited by
                                  Ich kann in den Adapter-Einstellungen (V1.0.0) die Anzahl der zu lesende Max.Artikel nicht ändern.
                                  Die Eingabe springt immer wieder auf 100 zurück, mir würde 1 reichen.
                                  Der vorgegebene minimale Zeitintervall 60 bedeutet Minuten?
                                  Kann man den Wert bitte auch verkürzen?
                                  Ich würde gern jede 5 Minuten jeweils nur 1 Artikel aus einem Feed (nur die neuste GPS-Position) auslesen.
                                  • OliverIO
                                    OliverIO @umbm last edited by
                                    @umbm
                                    ich habe noch ein paar punkte, die an diesem adapter überarbeitet werden müssen.
                                    ich werde deine wünsche dann berücksichtigen.
                                    • O
                                      Oli @OliverIO last edited by
                                      @oliverio
                                      sorry für die blöde Frage, aber wie bekomme ich die Gesamtanzahl der Inhalte eines Feeds heraus?
                                      • OliverIO
                                        OliverIO @Oli last edited by
                                        @oli
                                        das kommt darauf an.
                                        Die Menge der Artikel werden durch gewisse Faktoren limitiert.
                                        1. Max Articles in der Adapterkonfiguration (standardmäßig 100)
                                        2. das Attribut rss_maxarticles in den jeweiligen widget
                                        alles das was dann noch übrigbleibt wird dann an das Ausgabe-Template in das Array articles übergeben.
                                        Nutzt du ein eigenes template zur Ausgabe der rss-Artikel?
                                        Das widget funktioniert ja intern mit einem ejs-Template (ist in der widget hilfe angegeben)
                                        Wenn du da die Gesamtmenge ausgeben willst habe ich dir das Template in zeile 2 ohne großen schnickschnack wie Formatierung hinzugefügt (articles.length)
                                        <%= meta.title %>
                                        <%= articles.length %>
                                        <% articles.forEach(function(item){ %>
                                        <p><small><%- vis.formatDate(item.pubdate, "TT.MM.JJJJ SS:mm") %></small></p>
                                        <h3><%- item.title %></h3>
                                        <p><%- item.description %></p>
                                        <div style="clear:both;" />
                                        • O
                                          @oliverio
                                          danke für deine schnelle Antwort.
                                          Ich benutze den RSS Feed der Produktwarnungen und möchte mir die Gesamtanzahl der Produktwarnungen gerne in meiner VIS anzeigen lassen, daher die Frage.
                                          Sorry hätte ich oben gleich mit dazu schreiben sollen.
                                          Jetzt habe ich allerdings noch eine Frage.
                                          ich habe gerade deine coole Slideshow entdeckt und natürlich gleich mal getestet, funktioniert super!!!!
                                          Aber wie bekomme ich die lästige Überschrift "Lebensmittelwarnung.de- Warnungen in Bayern" weg?
                                          Wenn ich das Script der Slidshow entferne, erscheint die Überschrift nicht
                                          Mit Slideshow:
                                          <script>
                                          // Konfigurationsbereich Anfang
                                          var fadeTime = 1000; //Zeit in Millisekunden zum Ein und Ausblenden eines Artikels
                                          var showTime = 4000; //Zeitdauer, wie lange ein Artikel angezeigt werden soll
                                          // Konfigurationsbereich Ende
                                          </script>
                                          <style>
                                          #{wname} .slideshow {
                                            position: relative;
                                          #{wname} .slideshow > div {
                                            position: absolute;
                                            display: none;
                                          #{wname} .slideshow >  div:nth-child(0n+1) {
                                              display: block;
                                          </style>
                                          <script>
                                          setInterval(function() {
                                            $('#{wname} .slideshow > div:first')
                                              .fadeOut(fadeTime)
                                              .next()
                                              .fadeIn(fadeTime)
                                              .end()
                                              .appendTo('#{wname} .slideshow');
                                          }, showTime);
                                          </script>
                                          <%= meta.title %>
                                          <div class="slideshow">
                                             <div>
                                          <p><item.pubdate style="color:Orange">Veröffentlichungsdatum: <%- vis.formatDate(item.pubdate, "TT.MM.JJJJ SS:mm")%> Uhr</p>
                                          <h3><item.title style="color:Lightgreen"><%- item.title %></h3>
                                          <p><small><%- item.description %></small></p>
                                             </div>
                                          </div>
                                          Ohne Slideshow:
                                          <div style="clear:both;" ></div>
                                          Wo habe ich den Fehler?
                                          • OliverIO
                                            OliverIO @Oli last edited by OliverIO
                                            @oli
                                            Das ist die Zeile 30
                                            <%= meta.title %>
                                            An das widget-Template werden 2 Variablen übergeben
                                            meta enthält alle Attribute zum rssfeed
                                            articles ist eine Auflistung aller Artikel als array.
                                            um die technischen Details zu sehen gibt es die beiden Hilfswidgets
                                            RSS Feed meta helper
                                            RSS Feed Article helper
                                            da nicht alles Feeds die selben Attribute beinhalten.
                                            Mit Hilfe dieser Informationen kann man sich seine individuelle Darstellung bauen.
                                            Nicht zu vergessen mein leider etwas verkannte widget JSON Helper, mit dem man das für jegliche Datenpunkte und JSON-Daten machen kann und sich so sein eigenes widget bauen kann (ok ein kleiner Nachteil gibt es, der nur bei großen Datenmengen oder häufigen Änderungen der Datenpunkte ins gewicht fällt.steht in der Beschreibung)
                                            Das ist mit der gleichen Technik erstellt worden
                                            adapter atom feed iobroker.rssfeed rdf rss vis widget
                                            34
                                            694
                                            154255
