    4. ZigBee neue Version 1.6.x
    • Newan
      Newan @Asgothian last edited by
      @asgothian
      Kannst du mir auch einen Tipp geben wie ich den Converter erstelle für den Bug hier
      https://github.com/ioBroker/ioBroker.zigbee/issues/1238
      zigbee.0
      2022-01-07 23:38:42.814	error	No converter available for '6735/6736/6737' with key 'rm01_row_2'
      zigbee.0
      2022-01-07 23:38:42.810	warn	ELEVATED Change state 'rm01_row_2' at device 0xd85def11a10049ce type '6735/6736/6737'
      zigbee.0
      2022-01-07 23:38:42.804	warn	ELEVATED: User stateChange zigbee.0.d85def11a10049ce.rm01_row_2 {"val":true,"ack":false,"ts":1641595122802,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1641595122802}
      zigbee.0
      2022-01-07 23:38:42.798	warn	SetState_typed called without type
      Newan created this issue in ioBroker/ioBroker.zigbee
      closed No converter available for '6735/6736/6737' with key 'rm01_row_2' #1238
        DocGame @Newan last edited by DocGame
        @newan @Asgothian Habe ihn nochmal gelöscht, neu angelernt die IEEE in zigbee.0.info.debugmessages eingetragen und 3 verschiedene Tasten gedrückt.
        Er bringt nur ein "announced itself" je Tastendruck:
        zigbee.0	2022-01-08 00:02:08.187	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
        zigbee.0	2022-01-08 00:01:56.514	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
        zigbee.0	2022-01-08 00:01:52.805	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
        zigbee.0	2022-01-08 00:01:07.074	info	(27496) Zigbee: stop joining
        zigbee.0	2022-01-08 00:00:34.039	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
        zigbee.0	2022-01-08 00:00:28.240	info	(27496) Device '0x0c4314fffe6000b1' is supported, identified as: Zemismart Smart 6 key scene switch (ZM-RM02)
        zigbee.0	2022-01-08 00:00:28.240	info	(27496) Successfully interviewed '0x0c4314fffe6000b1', device has succesfully been paired
        zigbee.0	2022-01-08 00:00:27.008	warn	(27496) Device '0x0c4314fffe6000b1' announced itself
        zigbee.0	2022-01-08 00:00:26.790	info	(27496) Starting interview of '0x0c4314fffe6000b1'
        zigbee.0	2022-01-08 00:00:05.806	info	(27496) Zigbee: allowing new devices to join.
        Nachtrag: Zigbee-Adapter ist der aktuelle aus Github (1.6.11 -- im Moment 16 Std. online)
          disaster123 last edited by
          ich habe einen Aqara Motion Sensor RTCGQ11LM diesen kann ich problemlos am coordinator anlernen. Sobald ich diesen aber weg bewege in Richtung eines Routers bekomme ich keine Daten mehr. Empfang steht auf 33 aber seit 2 Tagen keine Daten mehr. Verbindet sich aber auch nicht zum Router in 3m Entfernung. Kann jemand helfen?
          Grüße,
          Stefan
          • Asgothian
            Asgothian Developer @disaster123 last edited by
            @disaster123
            • Geräte immer da anlernen wo sie auch betrieben werden sollen. Wenn du sie da nicht anlernen kannst werden sie da auch nicht funktionieren
            • Funkbedingungen prüfen. (Netzabdeckung, Störquellen, dämpfende Effekte)
            A.
              disaster123 @Asgothian last edited by
              @asgothian mhm ok das hatte ich schon versucht aber der aqara bewegungssensor ließ sich am Zielort nicht anlernen 😞 Router ist ein Tuya 0121 Plug. Die aqara Vibrationssensoren ließen sich problemlos anlernen am Tuya Plug. Alles umbauen auf Ikea tradfri plugs als Router?
              • Asgothian
                @disaster123 schwer zu sagen. Ist die Position der Vibrationssensoren und der BWM denn identisch ? Wenn nein, was sind die Unterschiede ? Wodurch könnte die Kommunikation der BWM erschwert werden ?
                A.
                  @asgothian die vibrationssensoren von aqara sind weiter weg vom Router (5-11m) sonst fällt mir kein Unterschied ein.
                  • OstfrieseUnterwegs
                    OstfrieseUnterwegs last edited by
                    Ich habe gerade ein Update von 1.6.6 auf 1.6.12 gemacht. Dabei wurde meine Aldi L122CB63H11A9.0W in ein TuYa TS0505B umgewandelt. Zurück auf 1.6.6 und es ist wieder eine Aldi Birne.
                    • Asgothian
                      Asgothian Developer @OstfrieseUnterwegs last edited by
                      @ostfrieseunterwegs Poste doch mal bitte die Details des Gerätes, einmal unter 1.6.6 und einmal unter 1.6.12.
                      Es kann sein das durch eine Anpassung der Erkennung im Herdsman die Umbenennung stattgefunden hat.
                      A.
                      OstfrieseUnterwegs 1 Reply Last reply Reply Quote 0
                        OstfrieseUnterwegs @Asgothian last edited by
                        @asgothian
                        1.6.6
                        1.6.12
                        Die 'Innereien' werden wohl richtig erkannt. Nur das 'Gehäuse' nicht 😉
                        • Asgothian
                          @ostfrieseunterwegs sagte in ZigBee neue Version 1.6.x:
                          @asgothian
                          1.6.6
                          1.6.12
                          Leider nein. Willkommen in der Hölle die TuYa aufspannt:
                          mit der identischen ID (das was bei manufacturer angegeben ist) werden unterschiedliche Geräte angeboten. Während diese ID vorher eindeutig nur den Aldi Lampen zugeordnet waren ist sie zusammen mit den anderen Geräten den TuYa Geräten zugeschlagen. ich fürchte du wirst damit leben müssen.
                          Das ist (leider) kein bug sondern eine bewusste Umstellung (siehe hier: https://github.com/Koenkk/zigbee-herdsman-converters/commit/7d74703684a39e33e71f72f86b22711e9a2435b1)
                          A.
                          0 Koenkk committed to Koenkk/zigbee-herdsman-converters
                          Add 14153706L and L122CB63H11A9.0W to TS0505B (_TZ3000_kohbva1f). https://github.com/Koenkk/zigbee2mqtt/issues/10516
                            ist doch nur kosmetik..
                            • 1Topf
                              1Topf @1Topf last edited by 1Topf
                              @1topf sagte in ZigBee neue Version 1.6.x:
                              @arteck
                              Gibt es denn noch Hoffnung für mich? Bin mittlerweile auch bei 1.6.12. 😇
                              @arteck
                              Zum Gerät: Heiman HS2WDSR-E (Dimmer + Lampe). Adapter 1.6.8. von Katze.
                              Ein ähnliches Modell des Dimmers (Heiman HS2SS, ⭐EXP) ist laut Wiki wohl schon eingepflegt. Wird bei mir in der Geräteinfo so angezeigt:
                              Der Dimmer:
                              modelZigbee:ColorDimmerSw-EM-3.0
                                  type:EndDevice
                                  nwk:23752
                                  manuf id:4619
                                  manufacturer:HEIMAN
                                  power:Battery
                                  app version:18
                                  hard version:16
                                  zcl version:3
                                  stack version:2
                                  date code:2019.9.27
                                  interviewed:true
                                  configured:false
                                  endpoint:1
                                  profile:260
                                  input clusters:genBasic (0)
                                  genPowerCfg (1)
                                  genIdentify (3)
                                  genGroups (4)
                                  genScenes (5)
                                  haDiagnostic (2821)
                                  touchlink (4096)
                                  64644
                                  output clusters:genIdentify (3)
                                  genOnOff (6)
                                  genLevelCtrl (8)
                                  genOta (25)
                                  lightingColorCtrl (768)
                                  touchlink (4096)
                              und die Lampe:
                              modelZigbee:ColorLight
                                  type:Router
                                  nwk:64580
                                  manuf id:4619
                                  manufacturer:HEIMAN
                                  power:Mains (single phase)
                                  app version:25
                                  hard version:18
                                  zcl version:2
                                  stack version:2
                                  date code:20190925
                                  build:2000-1002
                                  interviewed:true
                                  configured:false
                                  endpoint:1
                                  profile:260
                                  genGroups (4)
                                  genIdentify (3)
                                  genOnOff (6)
                                  genLevelCtrl (8)
                                  genScenes (5)
                                  touchlink (4096)
                                  65533
                                  haDiagnostic (2821)
                                  output clusters:genOta (25)
                                  65533
                              Wäre super, wenn man die einpflegen könnte.
                              Wenn es da eine deutsche Anleitung von "Support new devices" geben würde, würde ich mich da auch selbst mal versuchen. 🙂
                              Viele Grüße,
                              Andi
                                @asgothian sagte in ZigBee neue Version 1.6.x:
                                A.
                                Blöd, aber solange sie sich verhalten, wie sie sollen, ist es nicht dramatisch.
                                Für mein Verständnis: Die Devices senden beim Interview ihre ModelID und zigbee-herdsman schaut dann nach was sie so alles können und verstehen? Und weil es einen Konflikt zwischen Aldi und Tuya gibt, wurde entschieden, Tuya die ModelID zuzuschlagen. Heisst das auch, dass wenn Xiaomi auf die Idee kommt einen Thermostaten mit der gleichen ModelID auf den Markt zu bringen, gibt es neue Konflikte?
                                • Asgothian
                                  Jein.
                                  Das Geschäft von TuYa selber ist nicht nur die Herstellung von Geräten sondern insbesondere die Bereitstellung einer Dienstleistung:
                                  • Hardwarekomponenten um eigene Smart-Devices zu erzeugen
                                  • Softwarekomponenten um darauf basierend eine eigene "Cloud" Lösung anzubieten
                                  • ein Server-Backend um diese Cloud Lösung zu hosten, so das minimale eigene Investitionen ausreichen um unter eigenem Namen smarte Geräte heraus zu geben.
                                  Dabei gilt eigentlich die Massgabe das die unterschiedlichen Hersteller die Identifikation der Zigbee Komponenten eindeutig machen, so das das System die Geräte eindeutig erkennen kann. Daran halten sich aber nicht alle, so das
                                  • es unter der gleichen "makroskopischen" Bezeichnung TS0601 alles mögliche gibt (Steckdosen, Schalter, Thermostate, Sensoren)
                                  • Geräte mit unterschiedlicher "mikroskopischen" Bezeichnung die gleiche hardware-Identifikation nutzen
                                  • die identische Zigbee-Steuereinheit (mit Bezeichnung und Hardware-Identifikation) in verschiedene Hardware eingebaut wird (die sich hoffentlich gleich verhält)
                                  Aldi ist gerade bei Elektronik für die eigene Kompetenz und das Qualitätsversprechen bekannt. (/ironie off) Das Aldi also auf TuYa Whitelabel Produkte setzt ist nicht weiter verwunderlich (macht Lidl ja auch).
                                  Xiaomi hat die Hardware Entwicklung bei sich im Haus und arbeitet da deutlich sauberer.
                                  A.
                                    @asgothian Danke Dir. Solange ein Licht nicht zum Thermostaten wird ist ja alles gut 🙂
                                    Die Aldi Birne hab ich einfach mal mitgenommen, um zu schauen, was ich mit zigbee machen kann und wie sich das System so im Vergleich zu z-wave verhält.
                                      Moin moin, ich versuche gerade seit 30 Minuten eine Ikea Tradfri Steckdose anzulernen. Gibt es da einen Trick?
                                      Mein vorgehen:
                                      1.) Pairing in iobroker starten
                                      2.) Reset Button an der Ikea Steckdose 5s drücken
                                      Danke!
                                      • BananaJoe
                                        BananaJoe Most Active @disaster123 last edited by
                                        @disaster123 ich kenne die Steckdose nicht aber ich würde wetten du musst 4x schnell hintereiander drücken und dann blinkt da was. Gibt es nur Reset?
                                          disaster123 @BananaJoe last edited by
                                          @bananajoe jo überall im Netz steht Reset ausführen und dann läuft der Anlernprozess automatisch. Dort wird allerdings auch in der Regel Model E1702 o.ä. besprochen ich habe hier E1703 ... probiere gerne auch 4 mal schnell 😉
                                            @bananajoe 3x , 4x oder 5x schnell bewirkt gar nichts.. nach dem Reset blinkt der INidikator als wäre er im Anlernmodus... aber danach passiert nichts (schon mit 3 Dosen getestet - kaputt ist also unwahrscheinlich) Alle Typ E1703
                                            mickym BananaJoe 2 Replies Last reply Reply Quote 0
                                            509
                                            100214
