    4. [Redesign] wioBrowser für Windows
    • Wal
      Wal Developer @dos1973 last edited by
      @dos1973 ,
      das kann doch der windows-control Adapter schon.
      • BananaJoe
        BananaJoe Most Active @Wal last edited by BananaJoe
        @wal also, heute ist er wieder mit Out of memory hängengeblieben, in error stand dazu nichts.
        Hier das Log:
        2022-01-12 18:06:05.792  - error: wiobrowser.0 (2718414) Client error:Error: read ECONNRESET
        2022-01-12 18:06:05.793  - info: wiobrowser.0 (2718414) Disconnected from 192.168.1.63
        2022-01-12 18:06:34.339  - error: wiobrowser.0 (2718414) Client error:Error: connect EHOSTUNREACH 192.168.1.63:5000
        2022-01-12 18:06:47.395  - error: wiobrowser.0 (2718414) Client error:Error: connect EHOSTUNREACH 192.168.1.63:5000
        2022-01-12 18:07:28.873  - info: wiobrowser.0 (2718414) Connected to 192.168.1.63
        2022-01-12 18:08:01.094  - info: host.iobroker "system.adapter.wiobrowser.0" disabled
        2022-01-12 18:08:01.097  - info: host.iobroker stopInstance system.adapter.wiobrowser.0 (force=false, process=true)
        2022-01-12 18:08:01.101  - info: wiobrowser.0 (2718414) Got terminate signal TERMINATE_YOURSELF
        2022-01-12 18:08:01.101  - info: host.iobroker stopInstance system.adapter.wiobrowser.0 send kill signal
        2022-01-12 18:08:01.103  - info: wiobrowser.0 (2718414) terminating
        2022-01-12 18:08:01.104  - info: wiobrowser.0 (2718414) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-01-12 18:08:01.104  - info: wiobrowser.0 (2718414) Disconnected from 192.168.1.63
        2022-01-12 18:08:01.725  - info: host.iobroker instance system.adapter.wiobrowser.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-01-12 18:08:14.312  - info: host.iobroker "system.adapter.wiobrowser.0" enabled
        2022-01-12 18:08:14.421  - info: host.iobroker instance system.adapter.wiobrowser.0 started with pid 3706262
        2022-01-12 18:08:15.855  - info: wiobrowser.0 (3706262) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wiobrowser, node: v14.18.2, js-controller: 3.3.22
        2022-01-12 18:08:15.896  - info: wiobrowser.0 (3706262) Connected to 192.168.1.63
        2022-01-12 18:08:46.495  - info: wiobrowser.0 (3706262) Disconnected from 192.168.1.63
        2022-01-12 18:09:27.921  - info: wiobrowser.0 (3706262) Connected to 192.168.1.63
        2022-01-12 18:09:55.134  - info: wiobrowser.0 (3706262) Disconnected from 192.168.1.63
        2022-01-12 18:11:40.887  - info: host.iobroker "system.adapter.wiobrowser.0" disabled
        2022-01-12 18:11:40.892  - info: host.iobroker stopInstance system.adapter.wiobrowser.0 (force=false, process=true)
        2022-01-12 18:11:40.903  - info: wiobrowser.0 (3706262) Got terminate signal TERMINATE_YOURSELF
        2022-01-12 18:11:40.909  - info: host.iobroker stopInstance system.adapter.wiobrowser.0 send kill signal
        2022-01-12 18:11:40.907  - info: wiobrowser.0 (3706262) terminating
        2022-01-12 18:11:40.908  - info: wiobrowser.0 (3706262) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-01-12 18:11:41.497  - info: host.iobroker instance system.adapter.wiobrowser.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-01-12 18:11:56.565  - info: host.iobroker "system.adapter.wiobrowser.0" enabled
        2022-01-12 18:11:56.738  - info: host.iobroker instance system.adapter.wiobrowser.0 started with pid 3709135
        2022-01-12 18:11:57.398  - debug: wiobrowser.0 (3709135) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2022-01-12 18:11:57.446  - debug: wiobrowser.0 (3709135) Objects client ready ... initialize now
        2022-01-12 18:11:57.462  - debug: wiobrowser.0 (3709135) Objects create System PubSub Client
        2022-01-12 18:11:57.463  - debug: wiobrowser.0 (3709135) Objects create User PubSub Client
        2022-01-12 18:11:57.464  - debug: wiobrowser.0 (3709135) Objects client initialize lua scripts
        2022-01-12 18:11:57.501  - debug: wiobrowser.0 (3709135) Objects connected to redis: 0.0.0.0:9001
        2022-01-12 18:11:57.509  - debug: wiobrowser.0 (3709135) objectDB connected
        2022-01-12 18:11:57.511  - debug: wiobrowser.0 (3709135) Redis States: Use Redis connection: 127.0.0.1:6379
        2022-01-12 18:11:57.525  - debug: wiobrowser.0 (3709135) States create System PubSub Client
        2022-01-12 18:11:57.526  - debug: wiobrowser.0 (3709135) States create User PubSub Client
        2022-01-12 18:11:57.535  - debug: wiobrowser.0 (3709135) States connected to redis: 127.0.0.1:6379
        2022-01-12 18:11:57.536  - debug: wiobrowser.0 (3709135) statesDB connected
        2022-01-12 18:11:57.838  - info: wiobrowser.0 (3709135) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wiobrowser, node: v14.18.2, js-controller: 3.3.22
        2022-01-12 18:12:13.285  - info: wiobrowser.0 (3709135) Connected to 192.168.1.63
        2022-01-12 18:12:13.295  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.info.connection: {"val":true,"ack":true,"ts":1642007533291,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007533291}
        2022-01-12 18:12:13.296  - debug: wiobrowser.0 (3709135) info -> true
        2022-01-12 18:12:15.163  - debug: wiobrowser.0 (3709135) Typ: URL
        2022-01-12 18:12:15.169  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.receiveURL: {"val":"http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage","ack":true,"ts":1642007535167,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007371654}
        2022-01-12 18:12:15.169  - debug: wiobrowser.0 (3709135) receiveURL -> http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage
        2022-01-12 18:12:53.443  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.sendURL: {"val":"https://forum.iobroker.net/","ack":false,"ts":1642007573441,"q":0,"from":"system.adapter.admin.1","user":"system.user.admin","lc":1642007295702}
        2022-01-12 18:12:53.443  - debug: wiobrowser.0 (3709135) sendURL -> https://forum.iobroker.net/
        2022-01-12 18:12:53.452  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.error: {"val":false,"ack":true,"ts":1642007573450,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295808}
        2022-01-12 18:12:53.453  - debug: wiobrowser.0 (3709135) error -> false
        2022-01-12 18:12:57.196  - debug: wiobrowser.0 (3709135) Typ: URL
        2022-01-12 18:12:57.204  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.receiveURL: {"val":"https://forum.iobroker.net/","ack":true,"ts":1642007577201,"q":0,"from":"system.adapter wiobrowser.0","user":"system.user.admin","lc":1642007577201}
        2022-01-12 18:12:57.204  - debug: wiobrowser.0 (3709135) receiveURL -> https://forum.iobroker.net/
        2022-01-12 18:12:58.654  - debug: wiobrowser.0 (3709135) Typ: URL
        2022-01-12 18:12:58.659  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.receiveURL: {"val":"https://forum.iobroker.net/category/4/deutsch","ack":true,"ts":1642007578657,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007578657}
        2022-01-12 18:12:58.660  - debug: wiobrowser.0 (3709135) receiveURL -> https://forum.iobroker.net/category/4/deutsch
        2022-01-12 18:13:03.471  - debug: wiobrowser.0 (3709135) Typ: EVENT
        2022-01-12 18:13:10.482  - debug: wiobrowser.0 (3709135) Typ: BATTERY
        2022-01-12 18:13:10.490  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.battery: {"val":100,"ack":true,"ts":1642007590487,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295769}
        2022-01-12 18:13:10.491  - debug: wiobrowser.0 (3709135) battery -> 100
        2022-01-12 18:13:16.519  - debug: wiobrowser.0 (3709135) Typ: EVENT
        2022-01-12 18:13:27.670  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.sendURL: {"val":"http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage","ack":false,"ts":1642007607662,"q":0,"from":"system.adapter.admin.1","user":"system.user.admin","lc":1642007607662}
        2022-01-12 18:13:27.672  - debug: wiobrowser.0 (3709135) sendURL -> http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage
        2022-01-12 18:13:27.681  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.error: {"val":false,"ack":true,"ts":1642007607677,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295808}
        2022-01-12 18:13:27.681  - debug: wiobrowser.0 (3709135) error -> false
        2022-01-12 18:13:31.081  - debug: wiobrowser.0 (3709135) Typ: URL
        2022-01-12 18:13:31.088  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.receiveURL: {"val":"http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage","ack":true,"ts":1642007611086,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007611086}
        2022-01-12 18:13:31.089  - debug: wiobrowser.0 (3709135) receiveURL -> http://192.168.1.8:60008/vis/index.html?WinPAD#000-Startpage
        2022-01-12 18:13:55.216  - debug: wiobrowser.0 (3709135) Typ: EVENT
        2022-01-12 18:14:10.303  - debug: wiobrowser.0 (3709135) Typ: BATTERY
        2022-01-12 18:14:10.309  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.battery: {"val":100,"ack":true,"ts":1642007650307,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295769}
        2022-01-12 18:14:10.310  - debug: wiobrowser.0 (3709135) battery -> 100
        2022-01-12 18:14:16.869  - debug: wiobrowser.0 (3709135) Typ: EVENT
        2022-01-12 18:14:21.673  - debug: wiobrowser.0 (3709135) Typ: EVENT
        2022-01-12 18:15:10.327  - debug: wiobrowser.0 (3709135) Typ: BATTERY
        2022-01-12 18:15:10.348  - debug: wiobrowser.0 (3709135) stateChange wiobrowser.0.battery: {"val":100,"ack":true,"ts":1642007710345,"q":0,"from":"system.adapter.wiobrowser.0","user":"system.user.admin","lc":1642007295769}
        2022-01-12 18:15:10.349  - debug: wiobrowser.0 (3709135) battery -> 100
        Ich kann sehen das EVENT erscheint wenn ich die Seite wechsle
        Irgendwie habe ich auch eine View in der VIS, wenn ich die einmal anklicke geht es nicht mehr weiter. Fehler gefunden.
        Event kommt wenn ich mit der Maus klicke. Ich nutze Input Director um vom PC aus das Tablet zu bedienen. Wenn ich mit dem Finger tippse kommt kein Event
        • Wal
          Wal Developer @BananaJoe last edited by
          @bananajoe ,
          Typ: EVENT kommt nur wenn die Batteriedaten übertragen werden, alle 60sec.
          Typ:URL wen eine neue Seite aufgebaut wurde, da sehe ich das receiveURL bei dir auch geht, obwohl du das Gegenteil gesagt hast. 😉
          error -> true würde sagen das die angeforderte Webseite einen Fehler bringt, was ich aber in deinem Log nirgens sehe.
          Ich sehe nur das um 18:06:05 die Verbindung verloren wurde und um 18:12:13 die Verbindung hergestellt wurde, danach ist alles i.O.
          • BananaJoe
            BananaJoe Most Active last edited by
            Gegenprobe gemacht: Auf anderen Rechnern bei mir im Netzwerk funktioniert es auch nicht. Hab extra mal eben meinen Hauptrechner genommen
            • BananaJoe
              @wal EVENT kommt jedes mal wenn ich mit der Maus klicke Unabhängig davon ob ich damit eine Seite wechsle oder ins Nichts klicke. Der Mausklick wird aber durch die Software Input Director erzeugt. Wenn ich mit dem Finger tippe kommt nichts in Log.
              Und da sind keine 60 Sekunden zwischen den EVENT Ereignissen.
              Beim Start oder wenn ich die URL setzte wird receiveURL einmalig aktualisiert. Wenn ich die ioBroker-Forumseite nehme kommt sogar noch der Wechsel zu Deutschen Seite. Danach ist dann aber schluss.
              Und genau: Da erscheint dann nichts im Log wenn ich die Seiten wechsle
              Wal 2 Replies Last reply Reply Quote 0
              • Wal
                @bananajoe ,
                du hast Recht mit der Maus. Typ: Battery ist die Battery.
                • Wal
                  @bananajoe sagte in [Neuer Adapter] wioBrowser für Windows:
                  Und das auch bei deinem Hauptrechner ?
                  • BananaJoe
                    @wal jepp. Ich wollte gerade mal eine ältere Version probieren ... aber die sind nicht verfügbar 😞
                    • Wal
                      @bananajoe ,
                      Battery, Close, ScreenOn/Off gehen dann aber immernoch ?
                      • Wal
                        Die alten Versionen kannst du auf Github runterladen.
                        Browser alt
                        Du gehst auf Commits danach auf <> und du bekommst die Dateien angezeigt. Du mußt aber danach auch die alten Adapter installieren, das funktioniert genauso. Commits danach <> und die Url kopieren und als InstallationsURL bei ioBroker eintragen.
                        • BananaJoe
                          @wal
                          • close geht
                          • message geht
                          • screenoff geht
                          • screenon geht
                          • slide geht. Aber die Seitenwechsel durch das sliden werden nicht empfangen. Sliden per Mausklick beenden funktioniert
                          • zoom geht
                          • sendURL geht, receiveURL wird dabei aber nicht aktualisiert
                          • Wal
                            Wal Developer @BananaJoe last edited by Wal
                            @bananajoe ,
                            das ist der Hammer, bei receiveUrl habe ich im Quellcode seit der ersten Version damit nichts verändert.
                            edit: Battery geht auch noch ? Bei Battery und receiveURL wird was empfangen, alles andere wird an den Browser gesendet.
                            • BananaJoe
                              @wal Testest du bei dir lokal oder auch über das Netzwerk?
                              • Wal
                                Beides, geht Battery auch noch ? lese oben.
                                • BananaJoe
                                  @wal jepp geht auch noch.
                                  Wal 3 Replies Last reply Reply Quote 0
                                  • Wal
                                    @bananajoe ,
                                    ok teste mal die alten Versionen. Ich bin sprachlos.
                                    • Wal
                                      @bananajoe ,
                                      achso local muß ich aber die IP eingeben localhost funktioniert bei mir nicht.
                                      Local läuft der ioBroker aber in der WSL von Windows, damit ich Visual Studio Code testen kann.
                                      Mein normaler ioBroker läuft in einem Proxmoxcontainer.
                                      • Wal
                                        @bananajoe,
                                        mir fällt noch was ein, die Url wird erst übertragen wenn die Seite fertig geladen ist, wird sie bei dir evtl. nicht vollständig geladen ?
                                        • BananaJoe
                                          @wal also, auf meinem Server funktioniert es mit der 1.3.0 (Ist erst nicht gestartet weil die Edge Runtime fehlte)
                                          Auf meinem Tablet funktioniert die auch ... mit meiner Homepage https://znil.net
                                          Wenn ich auf das Forum gehe wechselt er von https://forum.iobroker.net/ noch um auf https://forum.iobroker.net/category/4/deutsch und dann passiert nichts mehr wenn ich die Beiträge wechsle etc.
                                          Das habe ich auf meinem Server und auf dem Tablet schon bei der 1.3.0
                                          Ich teste jetzt noch mal die 1.5.0 auf die gleiche Weise
                                          • BananaJoe
                                            @wal sagte in [Neuer Adapter] wioBrowser für Windows:
                                            @bananajoe,
                                            Interaktive Webseiten mit JavaScript ... sind die jemals fertig geladen?
                                            680
                                            111844
