[Geklärt] Error Meldung hinsichtlich Repositories
@thomas-braun Hallo Thomas,
Danke für Deine Nachricht.
Hier die gewünschten Angabenpi@raspberrypi:~ $ iob repo list stable : http://download.iobroker.net/sources-dist.json latest : http://download.iobroker.net/sources-dist-latest.json Active repo: stable pi@raspberrypi:~ $
pi@raspberrypi:~ $ iob update -i Used repository: stable failed to download new sources, no cached sources available Cannot download json from https://raw.githubusercontent.com/MeisterTR/ioBroker.kress/master/io-package.json. Error: 404: Not Found Cannot download json from https://raw.githubusercontent.com/MeisterTR/ioBroker.mihome-lamp/master/package.json. Error: Error: ESOCKETTIMEDOUT Cannot download json from https://raw.githubusercontent.com/frankjoke/ioBroker.radar2/master/io-package.json. Error: Error: ESOCKETTIMEDOUT [Wed Jan 12 2022 18:24:21 GMT+0100 (Central European Standard Time)] Following packages cannot be read: kress, radar2 update done Adapter "admin" : 5.2.1 , installed 5.2.3 Adapter "alexa2" : 3.11.2 , installed 3.11.2 Adapter "backitup" : 2.2.2 , installed 2.2.2 Adapter "cloud" : 4.1.0 , installed 4.1.0 Adapter "cul" : 1.3.5 , installed 1.3.5 Adapter "daswetter" : 3.0.9 , installed 3.0.9 Adapter "discovery" : 2.7.3 , installed 2.7.3 Adapter "dwd" : 2.7.7 , installed 2.7.7 Adapter "feiertage" : 1.0.23 , installed 1.0.23 Adapter "fhem" : 1.6.3 , installed 1.6.3 Adapter "flot" : 1.10.7 , installed 1.10.7 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "history" : 1.9.14 , installed 1.9.14 Adapter "hm-rega" : 3.0.33 , installed 3.0.33 Adapter "hm-rpc" : 1.14.50 , installed 1.14.50 Adapter "ical" : 1.11.4 , installed 1.11.4 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-png" : 1.0.2 , installed 1.0.2 Adapter "icons-open-icon-library-png": 0.1.2 , installed 0.1.3 Adapter "influxdb" : 1.9.5 , installed 1.9.5 Adapter "info" : 1.9.8 , installed 1.9.8 Adapter "iot" : 1.8.24 , installed 1.8.24 Adapter "jarvis" : 2.2.1 , installed 2.2.2 Adapter "javascript" : 5.2.13 , installed 5.2.13 Controller "js-controller" : 3.3.21 , installed 3.3.22 Adapter "mihome" : 1.3.7 , installed 1.3.7 Adapter "mihome-vacuum" : 3.3.1 , installed 3.3.1 Adapter "rpi2" : 1.3.1 , installed 1.3.1 Adapter "samsung" : 0.2.9 , installed 0.2.9 Adapter "scenes" : 2.3.8 , installed 2.3.8 Adapter "shelly" : 4.0.7 , installed 5.0.0 Adapter "shuttercontrol": 1.2.1 , installed 1.2.1 Adapter "simple-api" : 2.6.1 , installed 2.6.1 Adapter "socketio" : 3.1.4 , installed 3.1.4 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "telegram" : 1.10.0 , installed 1.10.0 Adapter "text2command" : 2.1.1 , installed 2.1.1 Adapter "trashschedule" : 1.2.0 , installed 1.2.0 Adapter "vis" : 1.4.5 , installed 1.4.5 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-hqwidgets" : 1.1.7 , installed 1.1.7 Adapter "vis-metro" : 1.1.2 , installed 1.1.2 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7 Adapter "vis-weather" : 2.5.5 , installed 2.5.5 Adapter "weatherunderground": 3.3.1 , installed 3.3.1 Adapter "web" : 3.4.9 , installed 3.4.9 Adapter "yr" : 3.0.5 , installed 3.0.5 Adapter "zigbee" : 1.6.6 , installed 1.6.6 pi@raspberrypi:~ $
Mit freundlichen Grüßen
Michael -
@altersrentner sagte in Error Meldung hinsichtlich Repositories:
was ist das denn?
@homoran sagte in Error Meldung:
was ist das denn?
Verstehe ich leider nicht,
Kann nicht heruntergeladen werden, aber warum?
MfG Michael -
wo hast du die Adapter her?
etwa Github????? -
etwa Github?????Ich kenne die Adapter nicht
Kress, radar2
Habe nur einen mihome .0, V 1.3.7 der ist stable
MfG Michael -
@altersrentner dann erstelle dir mal einen weiteren Rep-Pfad mit:
http://iobroker.live/repo/sources-dist.json
und wähle den unter Grundeinstellungen aus
habe ich gemacht,1 stable http://download.iobroker.net/sources-dist.json 2 latest http://download.iobroker.net/sources-dist-latest.json 3 Grndeinstellungen http://iobroker.live/repo/sources-dist.json
MfG Michael
habe ich gemacht,
nee
Das war auch ein Tippfehler
Du solldt den mit irgendeinem dir passenden Namen eintragen, dann im Reuter "Grundeinstellungen" da wo du zwischen stable und Beta umschaltest dieses "neue" stable-repo auswählen-
Dann auf Adapter gehen und oben links auf reload -
OK, jetzt stehen 3 Adapter mit Aktualisierung bereit,
wenn Update fertig, wieder auf stable umstellen?
MfG Michael -
das ist stable
Da sollte dein Pfad eigentlich hin umgeleitet werden.
Das kannst du jetzt lassen -
Bitte,pi@raspberrypi:~ $ iob update -i Used repository: live hash unchanged, use cached sources update done Adapter "admin" : 5.2.3 , installed 5.2.3 Adapter "alexa2" : 3.11.2 , installed 3.11.2 Adapter "backitup" : 2.2.2 , installed 2.2.2 Adapter "cloud" : 4.1.0 , installed 4.1.0 Adapter "cul" : 1.3.5 , installed 1.3.5 Adapter "daswetter" : 3.0.9 , installed 3.0.9 Adapter "discovery" : 2.7.3 , installed 2.7.3 Adapter "dwd" : 2.7.7 , installed 2.7.7 Adapter "feiertage" : 1.1.0 , installed 1.0.23 [Updateable] Adapter "fhem" : 1.6.3 , installed 1.6.3 Adapter "flot" : 1.10.7 , installed 1.10.7 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "history" : 1.9.14 , installed 1.9.14 Adapter "hm-rega" : 3.0.33 , installed 3.0.33 Adapter "hm-rpc" : 1.15.0 , installed 1.14.50 [Updateable] Adapter "ical" : 1.11.4 , installed 1.11.4 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-png" : 1.0.2 , installed 1.0.2 Adapter "icons-open-icon-library-png": 0.1.2 , installed 0.1.3 Adapter "influxdb" : 1.9.5 , installed 1.9.5 Adapter "info" : 1.9.8 , installed 1.9.8 Adapter "iot" : 1.8.24 , installed 1.8.24 Adapter "jarvis" : 2.2.1 , installed 2.2.2 Adapter "javascript" : 5.2.13 , installed 5.2.13 Controller "js-controller" : 3.3.22 , installed 3.3.22 Adapter "mihome" : 1.3.7 , installed 1.3.7 Adapter "mihome-vacuum" : 3.3.1 , installed 3.3.1 Adapter "rpi2" : 1.3.1 , installed 1.3.1 Adapter "samsung" : 0.2.9 , installed 0.2.9 Adapter "scenes" : 2.3.8 , installed 2.3.8 Adapter "shelly" : 4.0.7 , installed 5.0.0 Adapter "shuttercontrol": 1.2.1 , installed 1.2.1 Adapter "simple-api" : 2.6.1 , installed 2.6.1 Adapter "socketio" : 3.1.4 , installed 3.1.4 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "telegram" : 1.10.0 , installed 1.10.0 Adapter "text2command" : 2.1.1 , installed 2.1.1 Adapter "trashschedule" : 1.4.1 , installed 1.2.0 [Updateable] Adapter "vis" : 1.4.5 , installed 1.4.5 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-hqwidgets" : 1.1.7 , installed 1.1.7 Adapter "vis-metro" : 1.1.2 , installed 1.1.2 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7 Adapter "vis-weather" : 2.5.5 , installed 2.5.5 Adapter "weatherunderground": 3.3.1 , installed 3.3.1 Adapter "web" : 3.4.9 , installed 3.4.9 Adapter "yr" : 3.0.5 , installed 3.0.5 Adapter "zigbee" : 1.6.6 , installed 1.6.6 pi@raspberrypi:~ $
Bitte
passt - alles aktuelle stable-Versionen, die da angeboten werden.
Warum das bei dir so lange(????) schon nicht mehr aktualisiert wurde weiß ich auch nicht.
Das ist nicht erst seit paar Tagen -
@homoran sagte in Error Meldung hinsichtlich Repositories:
Seit etwa einer Woche als ich das Shelly Problem hatte.
MfG Michael -
das passt nicht. Da sind Versionen drin, zu denen es schon länger updates gab
das sollte aber so sein.
max 10 Tage aber mit Sicherheit nicht mehr.
MfG Michael -
@thomas-braun sagte in Error Meldung hinsichtlich Repositories:
Dann hoch damit:
pi@raspberrypi:~ $ iob upgrade This upgrade of "trashschedule" will at least introduce the following changes: ========================================================================== -> 1.4.1: Updated dependencies -> 1.4.0: Allow to hide "not found" warnings for single trash types (like christmas tree pickup) Added limit option for VIS widget Added option for VIS widget to hide the name -> 1.3.6: Require new version for translated instance objects Fixed timeout issues -> 1.3.5: Added checks for calendar description -> 1.3.4: Translated all objects -> 1.3.3: Translated admin table headers -> 1.3.2: Fixed missing VIS widget ========================================================================== Would you like to upgrade trashschedule from @1.2.0 to @1.4.1 now? [(y)es, (n)o]: y Update trashschedule from @1.2.0 to @1.4.1 NPM version: 6.14.15 npm install iobroker.trashschedule@1.4.1 --loglevel error --prefix "/opt/iobroker" (System call) upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png Adapter "system.adapter.vis.0" restarted. upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json Update "system.adapter.trashschedule.0" upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json Adapter "trashschedule" updated This upgrade of "hm-rpc" will introduce the following changes: ========================================================================== -> 1.15.0: added image for `HmIP-STE2-PCB` we now handle `replaceDevice` requests by deleting old device and creating new one (closes #420) ========================================================================== Would you like to upgrade hm-rpc from @1.14.50 to @1.15.0 now? [(y)es, (n)o]: y Update hm-rpc from @1.14.50 to @1.15.0 NPM version: 6.14.15 npm install iobroker.hm-rpc@1.15.0 --loglevel error --prefix "/opt/iobroker" (System call) Update "system.adapter.hm-rpc.0" Update "system.adapter.hm-rpc.1" Update "system.adapter.hm-rpc.2" upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/93_hm-es-pmsw1-pl_thumb.png icons/93_hm-es-pmsw1-pl_thumb.png image/png upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/46_hm-lc-sw4-pcb_thumb.png icons/46_hm-lc-sw4-pcb_thumb.png image/png upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/187_hmip-rcb1_thumb.png icons/187_hmip-rcb1_thumb.png image/png upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/178_hmip-etrv-b1_thumb.png icons/178_hmip-etrv-b1_thumb.png image/png upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/168_hmip-smi55_thumb.png icons/168_hmip-smi55_thumb.png image/png upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/14_hm-sec-key_thumb.png icons/14_hm-sec-key_thumb.png image/png upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png Adapter "hm-rpc" updated This upgrade of "feiertage" will introduce the following changes: ========================================================================== -> 1.1.0: Formatting fixed error with the events in the next year ========================================================================== Would you like to upgrade feiertage from @1.0.23 to @1.1.0 now? [(y)es, (n)o]: y Update feiertage from @1.0.23 to @1.1.0 NPM version: 6.14.15 npm install iobroker.feiertage@1.1.0 --loglevel error --prefix "/opt/iobroker" (System call) upload [4] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/words.js words.js application/javascript Update "system.adapter.feiertage.0" upload [3] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/index_m.html index_m.html text/html upload [2] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/index.html index.html text/html upload [1] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/holidays.js holidays.js application/javascript upload [0] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/feiertage.png feiertage.png image/png Adapter "feiertage" updated pi@raspberrypi:~ $
Ist jetzt alles gut?
MfG Michael -
nochmal anschauen.
Danke,
hier bitte,pi@raspberrypi:~ $ iob update -i Used repository: live hash unchanged, use cached sources update done Adapter "admin" : 5.2.3 , installed 5.2.3 Adapter "alexa2" : 3.11.2 , installed 3.11.2 Adapter "backitup" : 2.2.2 , installed 2.2.2 Adapter "cloud" : 4.1.0 , installed 4.1.0 Adapter "cul" : 1.3.5 , installed 1.3.5 Adapter "daswetter" : 3.0.9 , installed 3.0.9 Adapter "discovery" : 2.7.3 , installed 2.7.3 Adapter "dwd" : 2.7.7 , installed 2.7.7 Adapter "feiertage" : 1.1.0 , installed 1.1.0 Adapter "fhem" : 1.6.3 , installed 1.6.3 Adapter "flot" : 1.10.7 , installed 1.10.7 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "history" : 1.9.14 , installed 1.9.14 Adapter "hm-rega" : 3.0.33 , installed 3.0.33 Adapter "hm-rpc" : 1.15.0 , installed 1.15.0 Adapter "ical" : 1.11.4 , installed 1.11.4 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-png" : 1.0.2 , installed 1.0.2 Adapter "icons-open-icon-library-png": 0.1.2 , installed 0.1.3 Adapter "influxdb" : 1.9.5 , installed 1.9.5 Adapter "info" : 1.9.8 , installed 1.9.8 Adapter "iot" : 1.8.24 , installed 1.8.24 Adapter "jarvis" : 2.2.1 , installed 2.2.2 Adapter "javascript" : 5.2.13 , installed 5.2.13 Controller "js-controller" : 3.3.22 , installed 3.3.22 Adapter "mihome" : 1.3.7 , installed 1.3.7 Adapter "mihome-vacuum" : 3.3.1 , installed 3.3.1 Adapter "rpi2" : 1.3.1 , installed 1.3.1 Adapter "samsung" : 0.2.9 , installed 0.2.9 Adapter "scenes" : 2.3.8 , installed 2.3.8 Adapter "shelly" : 4.0.7 , installed 5.0.0 Adapter "shuttercontrol": 1.2.1 , installed 1.2.1 Adapter "simple-api" : 2.6.1 , installed 2.6.1 Adapter "socketio" : 3.1.4 , installed 3.1.4 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "telegram" : 1.10.0 , installed 1.10.0 Adapter "text2command" : 2.1.1 , installed 2.1.1 Adapter "trashschedule" : 1.4.1 , installed 1.4.1 Adapter "vis" : 1.4.5 , installed 1.4.5 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-hqwidgets" : 1.1.7 , installed 1.1.7 Adapter "vis-metro" : 1.1.2 , installed 1.1.2 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7 Adapter "vis-weather" : 2.5.5 , installed 2.5.5 Adapter "weatherunderground": 3.3.1 , installed 3.3.1 Adapter "web" : 3.4.9 , installed 3.4.9 Adapter "yr" : 3.0.5 , installed 3.0.5 Adapter "zigbee" : 1.6.6 , installed 1.6.6 pi@raspberrypi:~ $ nochmal anschauen.
Gute Nacht.
Melde mich morgen.
Mit freundlichen grüßen
Michael
