    4. [Geklärt] Error Meldung hinsichtlich Repositories
      Altersrentner @Homoran last edited by
      OK, jetzt stehen 3 Adapter mit Aktualisierung bereit,
      wenn Update fertig, wieder auf stable umstellen?
      MfG Michael
        Thomas Braun Most Active @Altersrentner last edited by
        @altersrentner
        Lass Mal bitte
        iobroker update -i
        Sehen
          Homoran Global Moderator Administrators @Altersrentner last edited by
          @altersrentner sagte in Error Meldung hinsichtlich Repositories:
          das ist stable
          Da sollte dein Pfad eigentlich hin umgeleitet werden.
          Das kannst du jetzt lassen
            Altersrentner @Thomas Braun last edited by
            Bitte,
            pi@raspberrypi:~ $ iob update -i
            Used repository: live
            hash unchanged, use cached sources
            update done
            Adapter    "admin"         : 5.2.3    , installed 5.2.3
            Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
            Adapter    "backitup"      : 2.2.2    , installed 2.2.2
            Adapter    "cloud"         : 4.1.0    , installed 4.1.0
            Adapter    "cul"           : 1.3.5    , installed 1.3.5
            Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
            Adapter    "discovery"     : 2.7.3    , installed 2.7.3
            Adapter    "dwd"           : 2.7.7    , installed 2.7.7
            Adapter    "feiertage"     : 1.1.0    , installed 1.0.23 [Updateable]
            Adapter    "fhem"          : 1.6.3    , installed 1.6.3
            Adapter    "flot"          : 1.10.7   , installed 1.10.7
            Adapter    "harmony"       : 1.2.2    , installed 1.2.2
            Adapter    "history"       : 1.9.14   , installed 1.9.14
            Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
            Adapter    "hm-rpc"        : 1.15.0   , installed 1.14.50 [Updateable]
            Adapter    "ical"          : 1.11.4   , installed 1.11.4
            Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
            Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
            Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
            Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
            Adapter    "info"          : 1.9.8    , installed 1.9.8
            Adapter    "iot"           : 1.8.24   , installed 1.8.24
            Adapter    "jarvis"        : 2.2.1    , installed 2.2.2
            Adapter    "javascript"    : 5.2.13   , installed 5.2.13
            Controller "js-controller" : 3.3.22   , installed 3.3.22
            Adapter    "mihome"        : 1.3.7    , installed 1.3.7
            Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
            Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
            Adapter    "samsung"       : 0.2.9    , installed 0.2.9
            Adapter    "scenes"        : 2.3.8    , installed 2.3.8
            Adapter    "shelly"        : 4.0.7    , installed 5.0.0
            Adapter    "shuttercontrol": 1.2.1    , installed 1.2.1
            Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
            Adapter    "socketio"      : 3.1.4    , installed 3.1.4
            Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
            Adapter    "telegram"      : 1.10.0   , installed 1.10.0
            Adapter    "text2command"  : 2.1.1    , installed 2.1.1
            Adapter    "trashschedule" : 1.4.1    , installed 1.2.0 [Updateable]
            Adapter    "vis"           : 1.4.5    , installed 1.4.5
            Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
            Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
            Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
            Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
            Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
            Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
            Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
            Adapter    "web"           : 3.4.9    , installed 3.4.9
            Adapter    "yr"            : 3.0.5    , installed 3.0.5
            Adapter    "zigbee"        : 1.6.6    , installed 1.6.6
            pi@raspberrypi:~ $
              Bitte
              passt - alles aktuelle stable-Versionen, die da angeboten werden.
              Warum das bei dir so lange(????) schon nicht mehr aktualisiert wurde weiß ich auch nicht.
              Das ist nicht erst seit paar Tagen
                @altersrentner
                Schaut soweit I.O. aus
                Dann hoch damit:
                iobroker upgrade
                  @homoran sagte in Error Meldung hinsichtlich Repositories:
                  Seit etwa einer Woche als ich das Shelly Problem hatte.
                  MfG Michael
                    das passt nicht. Da sind Versionen drin, zu denen es schon länger updates gab
                      das sollte aber so sein.
                      max 10 Tage aber mit Sicherheit nicht mehr.
                      MfG Michael
                        @thomas-braun sagte in Error Meldung hinsichtlich Repositories:
                        Dann hoch damit:
                        pi@raspberrypi:~ $ iob upgrade
                        This upgrade of "trashschedule" will at least introduce the following changes:
                        -> 1.4.1:
                        Updated dependencies
                        -> 1.4.0:
                        Allow to hide "not found" warnings for single trash types (like christmas tree pickup)
                        Added limit option for VIS widget
                        Added option for VIS widget to hide the name
                        -> 1.3.6:
                        Require new version for translated instance objects
                        Fixed timeout issues
                        -> 1.3.5:
                        Added checks for calendar description
                        -> 1.3.4:
                        Translated all objects
                        -> 1.3.3:
                        Translated admin table headers
                        -> 1.3.2:
                        Fixed missing VIS widget
                        Would you like to upgrade trashschedule from @1.2.0 to @1.4.1 now? [(y)es, (n)o]: y
                        Update trashschedule from @1.2.0 to @1.4.1
                        NPM version: 6.14.15
                        npm install iobroker.trashschedule@1.4.1 --loglevel error --prefix "/opt/iobroker" (System call)
                        upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                        Adapter "system.adapter.vis.0" restarted.
                        upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                        Update "system.adapter.trashschedule.0"
                        upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        Adapter "trashschedule" updated
                        This upgrade of "hm-rpc" will introduce the following changes:
                        -> 1.15.0:
                        added image for `HmIP-STE2-PCB`
                        we now handle `replaceDevice` requests by deleting old device and creating new one (closes #420)
                        Would you like to upgrade hm-rpc from @1.14.50 to @1.15.0 now? [(y)es, (n)o]: y
                        Update hm-rpc from @1.14.50 to @1.15.0
                        npm install iobroker.hm-rpc@1.15.0 --loglevel error --prefix "/opt/iobroker" (System call)
                        Update "system.adapter.hm-rpc.0"
                        Update "system.adapter.hm-rpc.1"
                        Update "system.adapter.hm-rpc.2"
                        upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/93_hm-es-pmsw1-pl_thumb.png icons/93_hm-es-pmsw1-pl_thumb.png image/png
                        upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/46_hm-lc-sw4-pcb_thumb.png icons/46_hm-lc-sw4-pcb_thumb.png image/png
                        upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/187_hmip-rcb1_thumb.png icons/187_hmip-rcb1_thumb.png image/png
                        upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/178_hmip-etrv-b1_thumb.png icons/178_hmip-etrv-b1_thumb.png image/png
                        upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/168_hmip-smi55_thumb.png icons/168_hmip-smi55_thumb.png image/png
                        upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                        upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/14_hm-sec-key_thumb.png icons/14_hm-sec-key_thumb.png image/png
                        upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
                        upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
                        upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
                        upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                        upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
                        upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                        upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
                        upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
                        upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
                        upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
                        upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
                        upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
                        upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
                        upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
                        upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
                        upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
                        upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
                        upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
                        upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
                        upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
                        upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
                        upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
                        upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
                        upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                        Adapter "hm-rpc" updated
                        This upgrade of "feiertage" will introduce the following changes:
                        -> 1.1.0:
                        Formatting
                        fixed error with the events in the next year
                        Would you like to upgrade feiertage from @1.0.23 to @1.1.0 now? [(y)es, (n)o]: y
                        Update feiertage from @1.0.23 to @1.1.0
                        npm install iobroker.feiertage@1.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
                        upload [4] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/words.js words.js application/javascript
                        Update "system.adapter.feiertage.0"
                        upload [3] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/index_m.html index_m.html text/html
                        upload [2] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/index.html index.html text/html
                        upload [1] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/holidays.js holidays.js application/javascript
                        upload [0] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/feiertage.png feiertage.png image/png
                        Adapter "feiertage" updated
                        pi@raspberrypi:~ $
                        Ist jetzt alles gut?
                        MfG Michael
                          @altersrentner
                          Ja, schaut gut aus
                          iobroker update -i
                          nochmal anschauen.
                          A 2 Replies Last reply Reply Quote 0
                            nochmal anschauen.
                            Danke,
                            hier bitte,
                            update done
                            Adapter    "feiertage"     : 1.1.0    , installed 1.1.0
                            Adapter    "hm-rpc"        : 1.15.0   , installed 1.15.0
                            Adapter    "trashschedule" : 1.4.1    , installed 1.4.1
                            pi@raspberrypi:~ $ nochmal anschauen.
                            Gute Nacht.
                            Melde mich morgen.
                            Mit freundlichen grüßen
                            Michael
                              Möchte mich für Eure schnelle Hilfe Bedanken.
                              Bis jetzt keine Fehler mehr aufgetreten.
                              Damit ist das Problem geklärt.
                              Mit freundlichen Grüßen
                              Michael
                              error protokolle shelly.0
                              536
