    4. Adapter mbus - Fehler im log
      apollon77 @bahnuhr last edited by
      @bahnuhr dann ist irgendwas mit dem master oder usb
      • bahnuhr
        bahnuhr Forum Testing Most Active @apollon77 last edited by bahnuhr
        @apollon77 sagte in Adapter mbus - Fehler im log:
        Wenn ich den Adapter starte, dann steht ja im log dass er connected (= true)
        Ich vermute mal, dass er das Gerät findet.
        Aber halt die id nicht übertragen wird.
        mbus.0
        2022-01-11 12:52:41.648	warn	M-Bus Devices with errors: 1 from 1
        mbus.0
        2022-01-11 12:52:41.646	warn	M-Bus ID 17834338B4090107 err: Error: Error: The selected secondary address does not match any device [17834338B4090107].
        mbus.0
        2022-01-11 12:52:40.595	debug	Process: 17834338B4090107
        mbus.0
        2022-01-11 12:52:40.219	debug	connected set to true
        mbus.0
        2022-01-11 12:52:40.217	debug	connected set to true
        mbus.0
        2022-01-11 12:52:40.144	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
        mbus.0
        2022-01-11 12:52:40.094	info	Schedule initialization for M-Bus-ID 17834338B4090107 with update interval 900
        mbus.0
        2022-01-11 12:52:40.089	info	Initialize M-Bus Serial to /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907T3PS-if00-port0 with 115200baud
        mbus.0
        2022-01-11 12:52:40.087	info	Default Update Interval: 900
        mbus.0
        2022-01-11 12:52:40.083	error	All M-Bus devices could not be read, reinitialize and start over
        mbus.0
        2022-01-11 12:52:40.081	warn	M-Bus Devices with errors: 1 from 1
        mbus.0
        2022-01-11 12:52:40.078	warn	M-Bus ID 17834338B4090107 err: Error: Error: The selected secondary address does not match any device [17834338B4090107].
        mbus.0
        2022-01-11 12:52:39.028	debug	Process: 17834338B4090107
        mbus.0
        2022-01-11 12:52:38.574	debug	connected set to true
        mbus.0
        2022-01-11 12:52:38.572	debug	connected set to true
        mbus.0
        2022-01-11 12:52:38.525	info	Schedule initialization for M-Bus-ID 17834338B4090107 with update interval 900
        mbus.0
        2022-01-11 12:52:38.519	info	Initialize M-Bus Serial to /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907T3PS-if00-port0 with 115200baud
        mbus.0
        2022-01-11 12:52:38.517	info	Default Update Interval: 900
        mbus.0
        2022-01-11 12:52:38.468	info	starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mbus, node: v14.18.2, js-controller: 3.3.22
        mbus.0
        2022-01-11 12:52:38.046	debug	Plugin sentry Initialize Plugin (enabled=true)
        Wäre dies ein HInweis: All M-Bus devices could not be read, reinitialize and start over
        P.S.
        Die ID war in der Instanz Sicherung eingetragen.
          @bahnuhr Naja am ENd e... entweder der Master oder das Kabel oder das mbus Gerät ... ... Die Meldung heisst das der slave nicht antwprtet ... effektiv würde ich annehmen das der Maste rok ist und vllt eher beim Gerät schauen ... bzw kannst das ding mal an nen WIndows PC anschliessen und mit WIndows MBus software mal lesen ... vllt sagt die was genaueres was los sein kann
          bahnuhr 1 Reply Last reply Reply Quote 1
          • bahnuhr
            Das ist ne gute Idee.
            Werde mal schauen wo ich so ne Software finde.
            Oder hast zufällig mal einen Link.
            Danke dir.
              @bahnuhr puuhh ... müsst ich suchen ... hatte damals mehrere versucht und nur eine tat gescheit in der freien version ... finde auf meinem PC eine "MBconf" installiert ... vllt ist die was (da es das einzige ist was ich noch installiert hab ist da ne gewisse chance das es die gescheite war) 🙂 Ohne gewähr
              • bahnuhr
                @apollon77
                So, Rückinfo von mir.
                1 von den 2 Kabeln am mbus Master war gebrochen.
                Neu dran gemacht und alles läuft wieder.
                Muss man auch erst einmal drauf kommen.
                Danke für die Hilfe und den Input.
                mfg
                Dieter
                  apollon77 @bahnuhr last edited by apollon77
                  @bahnuhr :-)) Cool das es so einfach war 🙂
                  Danke für Deine Rückmeldung
                  • bahnuhr
                    @apollon77
                    Nochmal von mir.
                    Irgendwie scheint immer noch etwas nicht zu stimmen.
                    Im log kommt immer mal wieder:
                    mbus.0
                    2022-01-12 19:28:44.668	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
                    mbus.0
                    2022-01-12 19:28:44.650	error	All M-Bus devices could not be read, reinitialize and start over
                    mbus.0
                    2022-01-12 19:28:44.648	warn	M-Bus Devices with errors: 1 from 1
                    mbus.0
                    2022-01-12 19:28:44.646	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
                    mbus.0
                    2022-01-12 19:28:41.102	error	All M-Bus devices could not be read, reinitialize and start over
                    mbus.0
                    2022-01-12 19:28:41.100	warn	M-Bus Devices with errors: 1 from 1
                    mbus.0
                    2022-01-12 19:28:41.096	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
                    mbus.0
                    2022-01-12 17:56:23.758	error	All M-Bus devices could not be read, reinitialize and start over
                    mbus.0
                    2022-01-12 17:56:23.757	warn	M-Bus Devices with errors: 1 from 1
                    mbus.0
                    2022-01-12 17:56:23.756	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
                    hm-rpc.0
                    2022-01-12 17:55:15.825	error	Cannot call setValue: XML-RPC fault: Failure
                    hm-rpc.0
                    2022-01-12 17:55:15.820	error	xmlrpc -> setValue ["MEQ0276622:1","STATE",true] BOOL
                    mbus.0
                    2022-01-12 17:26:13.635	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
                    mbus.0
                    2022-01-12 17:26:13.617	error	All M-Bus devices could not be read, reinitialize and start over
                    mbus.0
                    2022-01-12 17:26:13.617	warn	M-Bus Devices with errors: 1 from 1
                    mbus.0
                    2022-01-12 17:26:13.616	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
                    mbus.0
                    2022-01-12 17:26:08.276	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
                    mbus.0
                    2022-01-12 17:26:08.258	error	All M-Bus devices could not be read, reinitialize and start over
                    mbus.0
                    2022-01-12 17:26:08.257	warn	M-Bus Devices with errors: 1 from 1
                    mbus.0
                    2022-01-12 17:26:08.256	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
                    mbus.0
                    2022-01-12 17:26:02.852	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
                    mbus.0
                    2022-01-12 17:26:02.838	error	All M-Bus devices could not be read, reinitialize and start over
                    mbus.0
                    2022-01-12 17:26:02.837	warn	M-Bus Devices with errors: 1 from 1
                    mbus.0
                    2022-01-12 17:26:02.836	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
                    mbus.0
                    2022-01-12 17:25:57.463	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
                    Das hört auch wieder von alleine auf.
                    Hab eben in der config auch mal auf suchen geklickt. mbus wird nicht gefunden.
                    Geb ich die Zahl manuell ein wird der Wert im objekt aktualisiert.
                    Die Instanz ist grün.
                    Vielleicht hast du ja noch ne idee.
                    Da läuft noch etwas falsch.
                    Da der Wert ja aktualisiert wird, schließen ich jetzt mal das kabel aus.
                    Könnte eine Macke am Gerät selber sein; oder bei Adapter (oder meinem Raspi slave System) stimmt etwas nicht.
                    Hast du noch ne Idee wie ich da nun ran gehen könnte?
                      @bahnuhr naja nochmal anfangen mit usb ab und Master Stromlos machen. Vllt mal Rechner reboot.
                      Nächster Schritt wenn das nicht hilft wäre dann eher debug Modus. Das man mal genauer sieht was los ist.
                      • bahnuhr
                        master stromlos.
                        raspi neu gestartet.
                        Ist es normal, dass sowas beim smartmeter jedes mal bei neustart kommt:
                        adapter "smartmeter" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                        Und dann bei mbus debug ein.
                        Schaun wir mal.
                        Ich meld mich.
                          @bahnuhr sagte in Adapter mbus - Fehler im log:
                          Nope, hier siehe ANnleitung zum Rebuild von Smartmeter im Node.js Upgrade thread im Forum
                          • Hant0r
                            Hant0r last edited by
                            Moin zusammen,
                            ich habe den gleichen MBUS USB Master Adapter wie bahnuhr.
                            Habe heute meinen Wasserzähler angeschlossen, am Rechner kann ich mit der SW den Zähler auslesen (Baudrate 2400).
                            Angeschlossen an meiner Diskstation "/dev/ttyUSB1" kommt im MBUS Adapter (grün) aber leider immer folgendes im Log (alle paar Sekunden):
                            mbus.0
                            2022-06-06 23:45:12.840	error	All M-Bus devices could not be read, reinitialize and start over
                            mbus.0
                            2022-06-06 23:45:12.839	warn	M-Bus Devices with errors: 1 from 1
                            mbus.0
                            2022-06-06 23:45:12.838	warn	M-Bus ID 1 err: Error: Error: Failed to send/receive M-Bus request frame[1].
                            host.ioBroker
                            2022-06-06 23:45:10.924	info	instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            mbus.0
                            2022-06-06 23:45:10.158	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
                            mbus.0
                            2022-06-06 23:45:10.153	info	Schedule initialization for M-Bus-ID 1 with update interval 3600
                            mbus.0
                            2022-06-06 23:45:10.151	info	Initialize M-Bus Serial to /dev/ttyUSB1 with 2400baud
                            mbus.0
                            2022-06-06 23:45:10.151	info	Default Update Interval: 3600
                            Habe ich was vergesssen oder falsch gemacht?
                              apollon77 @Hant0r last edited by
                              @hant0r Zeig mal die Konfiguration ...
                              Hant0r 1 Reply Last reply Reply Quote 0
                              • Hant0r
                                Hant0r @apollon77 last edited by
                                apollon77 bahnuhr 3 Replies Last reply Reply Quote 0
                                  @hant0r ok, ich muss genauer sein ...die Konfig der Geräte
                                  • bahnuhr
                                    bahnuhr Forum Testing Most Active @Hant0r last edited by bahnuhr
                                    @hant0r
                                    Bei mir so:
                                    An meinem Raspi hängen:
                                    2 x Smartmeter
                                    1 x mbus
                                    Somit habe ich mir eine extra Rule erstellt.
                                    70-lesekopf.rules
                                    Diskussion war auch hier im Forum.
                                    pdf davon habe ich mal angehängt.
                                    smartmeter _ mbus - ttyUSB klar benennen - Seite 1 .pdf
                                    smartmeter _ mbus - ttyUSB klar benennen - Seite 2 .pdf
                                      apollon77 @Hant0r last edited by apollon77
                                      @hant0r hast Du mal verschiednee Baudrates versucht? Bzw ging die geräte erkennung mit 2400 Baud? Recht langsam 🙂
                                      Bzw die Frage ist ja ob die ID 1 korrekt ist
                                      • Hant0r
                                        @apollon77
                                        Sorry, kam erst jetzt dazu die Kommentare zu lesen.
                                        Danke, deine Nachfrage mit der ID war der Knackpunkt 😄
                                        Steht Standardmäßig auf "1" und meine ID vom Gerät war die "0". Das habe ich in der Konfigapp des Moduls gesehen.
                                        Also fix im Adapter auf 0 geändert und nun scheint es zu laufen. freu
                                        Nun bin ich gespannt wie der Adapter funktioniert, werde es mal paar Tage testen.
                                        @bahnuhr - vielen Dank, schaue ich mir die Woche mal an wenn ich was Zeit habe 🙂
                                        • Hant0r
                                          Hant0r last edited by Hant0r
                                          Sehe ich im Adapter nicht live (also nach Ablauf des Aktualisierungsintervals), wie der Wasserverbrauch ist?
                                          Habe mal den Wasserhahn aufgedreht, aber es tut sich nichts 🤷‍♂️
                                            @hant0r naja, welche EInheit meldet dein MBus-Wasserzähler denn ? Da gibts welche die Liter melden, 10l oder 100l oder halt nur den Kubikmeter ... Wenn ich die zahlen so bei Dir sehe hast Du den letzteren ... Damit lass mal 1000l laufen dann springt er auch 81 🙂 duck
                                            error mbus
                                            6477
