Iobroker stürzt täglich ab
Schaut erstmal gesund aus. Wenn du dir jetzt kein skript ins Unendliche gestrickt hast oder ein in sich rekursives Backup oder sowas sollte das eigentlich stabil laufen.
zumindest ist jetzt mal über Nacht ohne Absturz gelaufenHab im Systemlog auch nochmals nachgeschaut. Weißt du was diese Meldungen sind? Bekomme die relativ häufig...
Jan 12 06:58:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied Jan 12 06:59:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied Jan 12 06:59:30 raspberrypi4iobroker wpa_supplicant[468]: RRM: Ignoring radio measurement request: Not RRM network Jan 12 06:59:30 raspberrypi4iobroker wpa_supplicant[468]: RRM: Ignoring radio measurement request: Not RRM network Jan 12 07:00:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied Jan 12 07:01:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied Jan 12 07:01:36 raspberrypi4iobroker wpa_supplicant[468]: RRM: Ignoring radio measurement request: Not RRM network Jan 12 07:01:36 raspberrypi4iobroker wpa_supplicant[468]: RRM: Ignoring radio measurement request: Not RRM network Jan 12 07:01:47 raspberrypi4iobroker motion: [9:nc9:Camera2] [ERR] [NET] netcam_rtsp_handler: Normal resolution: Bad image. Reconnecting with camera.... Jan 12 07:01:47 raspberrypi4iobroker motion: [7:nc7:Camera4] [ERR] [NET] netcam_rtsp_handler: Normal resolution: Bad image. Reconnecting with camera.... Jan 12 07:01:48 raspberrypi4iobroker motion: [6:nc6:Camera3] [ERR] [NET] netcam_rtsp_handler: Normal resolution: Bad image. Reconnecting with camera.... Jan 12 07:01:48 raspberrypi4iobroker motion: [8:nc8:Camera1] [ERR] [NET] netcam_rtsp_handler: Normal resolution: Bad image. Reconnecting with camera.... Jan 12 07:02:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied Jan 12 07:03:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied Jan 12 07:04:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
leider hat er sich vorhin schon wieder aufgehängt. Musste den Pi vom Strom nehmen und wieder anstecken. Danach geht wieder alles. Ist aber leider keine Dauerlösung
syslog -
@robert_r sagte in Iobroker stürzt täglich ab:
Wann? Dein log hat (wenn du schon mal reingeschaut hast) 21 Stunden drin.
Wahrscheinlich hätte längeres Warten gereicht.
vermutlich in der letzten Stunde. Warum glaubst du das einfach warten was gebracht hätte?
Kann es an der Wlan Verbindung liegen=? -
Vermutlich hier:
Jan 12 20:55:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied Jan 12 20:56:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied Jan 12 20:57:26 raspberrypi4iobroker bash[647]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied Jan 12 20:26:18 raspberrypi4iobroker fake-hwclock[117]: Wed 12 Jan 19:17:02 UTC 2022 Jan 12 20:26:18 raspberrypi4iobroker systemd-fsck[140]: e2fsck 1.44.5 (15-Dec-2018) Jan 12 20:26:18 raspberrypi4iobroker systemd-fsck[140]: rootfs: clean, 225107/1899328 files, 1541486/7725184 blocks Jan 12 20:26:18 raspberrypi4iobroker systemd[1]: Started File System Check on Root Device.
Da ist auch ein merkwürdiger Zeitsprung drin. Gut, der Raspberry hat auch keine Uhr eingebaut.
@robert_r hau mal deine SD karte in die Tonne. Nimm mindestens einen USB Stick, besser noch eine SSD. Ich hatte das auch, mit den ständigen Abstürzen. Jetzt hängt eine M.2 SSD dran. Übrigens hatte ich auch schon Ärger mit einigen USB Sticks.
Gruß -
@helmut-knobling sagte in Iobroker stürzt täglich ab:
Wo kommen diese Vorurteile her?
Bei mir laufen diverse Raspis jahrelang auf SD Karte ohne Probleme.
Auf dem Haupttestsystem werden außerdem etwa 200 Datenpunkte im teilweise im Sekundentakt in History geloggt. -
Da scheint ein skript zu laufen, das im Minutentakt die cpu frequenz in Erfahrung bringen möchte. Das macht man aber eigentlich nicht an der Stelle, die Datei darf nur vom root gelesen werden.
Besser
/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
nehmen, das darf jeder lesen. -
@thomas-braun sagte in Iobroker stürzt täglich ab:
nö, das dürfte der rpi2-Adapter sein.
Irgendwann hat Debian beschlossen, dass es für diese Abfrage root-Rechte braucht@thomas-braun sagte in Iobroker stürzt täglich ab:
Besser
nehmen, das darf jeder lesen.lesen alleine reicht nicht. Da geb es schon mal eine intensive Diskussion, da dieser Wert angeblich nicht immer korrekt ist
@homoran sagte in Iobroker stürzt täglich ab:
Warum sollte man da mehr als lesen sollen? Willst du den kleinen Pi durch Eintrag von irgendwelchen Fantasie-Werten zum SuperComputer machen?
man soll da auch den richtigen Wert finden sollen
Oberflächlich betrachtet:
echad@chet:~ $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq 1800000 echad@chet:~ $ sudo cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq [sudo] password for echad: 1800000
ich sagte doch
Ich such jetzt den Thread von Anno Tobak nicht raus.
Da wurde wimre eine renommierte Computerzeitschrift zitiert -
@homoran Wobei die Frage auch ist, ob das für so'n Guck-Eisen-Adapter wie rpi2 nicht hinreichend genau ist.
@thomas-braun said in Iobroker stürzt täglich ab:
...ich verstehe nur Bahnhof....
Soll ich noch was ändern? -
Nein, ist an deinem Thema vorbei geredet. Sorry.
