    4. Javascript Adapter rot
      Genau deswegen... Das /home vom root hat da eigentlich nix zu suchen...
      ChrisPrefect 1 Reply Last reply Reply Quote 0
      • ChrisPrefect
        ChrisPrefect @Thomas Braun last edited by
        @thomas-braun Habs nochmals mit einem User ausgeführt:
        pi@ioBrokerVM:~$ cd /opt/iobroker
        pi@ioBrokerVM:/opt/iobroker$ sudo -H -u iobroker npm cache clean --force
        [sudo] Passwort für pi:
        npm WARN using --force I sure hope you know what you are doing.
        Hat aber nichts geändert.
          Homoran Global Moderator Administrators @ChrisPrefect last edited by
          @chrisprefect sagte in Javascript Adapter rot:
          wobei?
          hast du danach nochmal iob update -i ausgeführt?
          Was kam denn da diesmal?
          • ChrisPrefect
            ChrisPrefect @Homoran last edited by
            pi@ioBrokerVM:/opt/iobroker$ iobroker upgrade iobroker.javascript@latest
            Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
                at parse (<anonymous>)
                at Object.Module._extensions..json (internal/modules/cjs/loader.js:1128:22)
                at Module.load (internal/modules/cjs/loader.js:950:32)
                at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                at Module.require (internal/modules/cjs/loader.js:974:19)
                at require (internal/modules/cjs/helpers.js:93:18)
                at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:368:27)
                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:276:26
                at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2623:45)
                at processImmediate (internal/timers.js:466:21)
            pi@ioBrokerVM:/opt/iobroker$ iob update -i
            Used repository: beta
            hash unchanged, use cached sources
            update done
            Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.javascript/io-package.json: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
            Adapter    "admin"         : 5.2.3    , installed 5.2.3
            Adapter    "alexa2"        : 3.12.0   , installed 3.12.0
            Adapter    "backitup"      : 2.2.3    , installed 2.2.3
            Adapter    "cloud"         : 4.1.0    , installed 4.1.0
            Adapter    "deconz"        : 1.3.19   , installed 1.3.19
            Adapter    "discovery"     : 2.7.5    , installed 2.7.5
            Adapter    "email"         : 1.0.10   , installed 1.0.10
            Adapter    "find-my-iphone": 0.2.17   , installed 0.2.17
            Adapter    "flot"          : 1.10.7   , installed 1.10.7
            Adapter    "geofency"      : 1.0.3    , installed 1.0.3
            Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
            Adapter    "history"       : 1.10.5   , installed 1.10.5
            Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
            Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
            Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
            Adapter    "influxdb"      : 2.4.0    , installed 2.4.0
            Adapter    "info"          : 1.9.16   , installed 1.9.16
            Adapter    "iot"           : 1.8.25   , installed 1.8.25
            Adapter    "iqontrol"      : 1.11.0   , installed 1.11.0
            Adapter    "jarvis"        : 3.0.7    , installed 3.0.7
            Controller "js-controller" : 3.3.22   , installed 3.3.22
            Adapter    "lifx"          : 0.1.1    , installed 0.1.1
            Adapter    "linkeddevices" : 1.4.3    , installed 1.4.3
            Adapter    "material"      : 1.1.2    , installed 1.1.2
            Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
            Adapter    "mobile"        : 1.0.1    , installed 1.0.1
            Adapter    "modbus"        : 3.4.17   , installed 3.4.17
            Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
            Adapter    "node-red"      : 2.4.1    , installed 2.4.1
            Adapter    "octoprint"     : 2.1.1    , installed 2.1.1
            Adapter    "onvif"         : 0.4.4    , installed 0.4.4
            Adapter    "ping"          : 1.5.0    , installed 1.5.0
            Adapter    "proxy"         : 1.2.2    , installed 1.2.2
            Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
            Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
            Adapter    "samsung"       : 0.2.9    , installed 0.2.9
            Adapter    "scenes"        : 2.3.8    , installed 2.3.8
            Adapter    "shelly"        : 5.0.0    , installed 5.0.0
            Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
            Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
            Adapter    "socketio"      : 3.1.5    , installed 3.1.5
            Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
            Adapter    "statistics"    : 1.0.10   , installed 1.0.10
            Adapter    "stockmarket"   : 0.0.2    , installed 0.0.2
            Adapter    "sureflap"      : 1.0.9    , installed 1.0.9
            Adapter    "swiss-weather-api": 1.0.2   , installed 1.0.2
            Adapter    "telegram"      : 1.10.0   , installed 1.10.0
            Adapter    "tesla-motors"  : 1.0.7    , installed 1.0.7
            Adapter    "tileboard"     : 0.3.1    , installed 0.3.1
            Adapter    "tr-064"        : 4.2.15   , installed 4.2.15
            Adapter    "unifi"         : 0.5.10   , installed 0.5.10
            Adapter    "vis"           : 1.4.6    , installed 1.4.7
            Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
            Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
            Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
            Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
            Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
            Adapter    "vis-hqwidgets" : 1.1.9    , installed 1.1.9
            Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
            Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
            Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
            Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
            Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
            Adapter    "vis-material"  : 0.1.3    , installed 0.1.3
            Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.9
            Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
            Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
            Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
            Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
            Adapter    "web"           : 3.4.16   , installed 3.4.16
            Adapter    "windows-control": 0.1.5   , installed 0.1.5
            Adapter    "yahka"         : 0.13.1   , installed 0.13.1
            Adapter    "zigbee"        : 1.6.12   , installed 1.6.12
              Thomas Braun Most Active @ChrisPrefect last edited by
              Dann warst du zuvor da als root unterwegs?
              • ChrisPrefect
                ChrisPrefect @Thomas Braun last edited by ChrisPrefect
                @thomas-braun ja. Als user bekomme ich sonst zu oft Fehlermeldungen wenn wieder irgend was root Berechtigungen braucht. Das stresst mich dann zu oft.
                  immer noch
                    Homoran Global Moderator Administrators @Homoran last edited by Homoran
                    und jetzt hast du das System zu sehr gestresst
                    Wahrscheinlich sind die Rechte durch die nutzung von root verbogen
                    iobroker stop
                    iobroker fix
                    iobroker start
                    als USER
                      Und mich stressen Systeme, die von Leuten, die selbst ernannt 'keine Ahnung haben' mit dem root kaputt gefummelt werden.
                      Ich bin dann raus.
                      ChrisPrefect 1 Reply Last reply Reply Quote 1
                      • ChrisPrefect
                        @thomas-braun Ich musste erst rumfummeln nachdem das System nicht mehr ging.
                        • ChrisPrefect
                          @homoran Also das Cache-Löschen geht beim zweiten Mal sehr schnell, das heisst beim ersten Mal wurde viel gelöscht.
                          Habe nochmals rebootet, den Fixer laufen lassen und nochmals update gemacht.
                          Der Javascript-Adapter ist aber noch immer auf der Version .18 und rot.
                            @chrisprefect
                            NEIN. mit dem root muss man nie rumfummenln. Gerade nicht ohne Ahnung was man da überhaupt fummelt.
                            • ChrisPrefect
                              @thomas-braun Kann sein. Das ist aber nicht das Problem.
                              Thomas Braun Homoran 3 Replies Last reply Reply Quote -1
                                Ich behaupte das Gegenteil.
                                  woher weisst du das?
                                  Arbeiten mit dem Root verbiegt Rechte, mit denen der user iobroker dann nicht mehr arbeiten darf
                                    was sagt denn jetzt iob update -i??
                                    und vorher nichts anderes!!!
                                    • ChrisPrefect
                                      @homoran weil das System nach dem Update von ioBroker nicht mehr ging und ich mich erst dann per ssh eingeloggt habe.
                                      • ChrisPrefect
                                        ChrisPrefect @Homoran last edited by ChrisPrefect
                                        update done
                                          und vorher noch nie???
                                            @chrisprefect
                                            immer noch cached sources - die müssten weg sein!!
                                            dann stell mal das Repo auf stable und mach den Befehl nochmal
                                            3745
