    4. Javascript Adapter rot
    • ChrisPrefect
      ChrisPrefect @Homoran last edited by
      @homoran Ich habe deinen Befehl ja schon ausgeführt.
        Homoran Global Moderator Administrators @ChrisPrefect last edited by
        @chrisprefect sagte in Javascript Adapter rot:
        welchen?
        Skripte werden über die Instanz exportiert
        ChrisPrefect 1 Reply Last reply Reply Quote 0
        • ChrisPrefect
          @homoran Den von @Glasfaser :
          iobroker del javascript
          • Glasfaser
            Glasfaser @ChrisPrefect last edited by Glasfaser
            @chrisprefect
            Error deleting adapter javascript from disk:
            Da hast aber ganz schön was .........
            Auf hard ...
            cd /opt/iobroker
            npm uninstall javascript
            npm uninstall js-controller
            Ausgabe
            iob update -i
            ChrisPrefect Homoran 2 Replies Last reply Reply Quote 0
            • ChrisPrefect
              ChrisPrefect @Glasfaser last edited by
              @glasfaser sagte in Javascript Adapter rot:
              iob update -i
              pi@ioBrokerVM:/opt/iobroker$ cd /opt/iobroker
              pi@ioBrokerVM:/opt/iobroker$ npm uninstall javascript
              [sudo] Passwort für pi:
              Das hat nicht funktioniert, bitte nochmal probieren.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
              up to date in 22.931s
              155 packages are looking for funding
                run `npm fund` for details
              pi@ioBrokerVM:/opt/iobroker$ npm uninstall js-controller
              [..................] / rollbackFailedOptional: verb npm-session 29b8658558937b5f
              up to date in 20.442s
              pi@ioBrokerVM:/opt/iobroker$ iob update -i
              Used repository: stable
              hash unchanged, use cached sources
              update done
              Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.javascript/io-package.json: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
              Adapter    "admin"         : 5.2.3    , installed 5.2.3
              Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
              Adapter    "backitup"      : 2.2.2    , installed 2.2.3
              Adapter    "cloud"         : 4.1.0    , installed 4.1.0
              Adapter    "deconz"        : 1.3.19   , installed 1.3.19
              Adapter    "discovery"     : 2.7.3    , installed 2.7.5
              Adapter    "email"         : 1.0.10   , installed 1.0.10
              Adapter    "flot"          : 1.10.7   , installed 1.10.7
              Adapter    "geofency"      : 1.0.3    , installed 1.0.3
              Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
              Adapter    "history"       : 1.9.14   , installed 1.10.5
              Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
              Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
              Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
              Adapter    "influxdb"      : 1.9.5    , installed 2.4.0
              Adapter    "info"          : 1.9.8    , installed 1.9.16
              Adapter    "iot"           : 1.8.24   , installed 1.8.25
              Adapter    "iqontrol"      : 1.8.2    , installed 1.11.0
              Adapter    "jarvis"        : 2.2.1    , installed 3.0.7
              Controller "js-controller" : 3.3.22   , installed 3.3.22
              Adapter    "lifx"          : 0.1.1    , installed 0.1.1
              Adapter    "linkeddevices" : 1.4.3    , installed 1.4.3
              Adapter    "material"      : 1.0.4    , installed 1.1.2
              Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
              Adapter    "mobile"        : 1.0.1    , installed 1.0.1
              Adapter    "modbus"        : 3.4.14   , installed 3.4.17
              Adapter    "mqtt"          : 2.4.0    , installed 2.4.1
              Adapter    "node-red"      : 2.4.1    , installed 2.4.1
              Adapter    "octoprint"     : 2.1.0    , installed 2.1.1
              Adapter    "onvif"         : 0.4.4    , installed 0.4.4
              Adapter    "ping"          : 1.5.0    , installed 1.5.0
              Adapter    "proxy"         : 1.2.2    , installed 1.2.2
              Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
              Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
              Adapter    "samsung"       : 0.2.9    , installed 0.2.9
              Adapter    "scenes"        : 2.3.8    , installed 2.3.8
              Adapter    "shelly"        : 4.0.7    , installed 5.0.0
              Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
              Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
              Adapter    "socketio"      : 3.1.4    , installed 3.1.5
              Adapter    "sonoff"        : 2.4.5    , installed 2.4.7
              Adapter    "statistics"    : 1.0.9    , installed 1.0.10
              Adapter    "swiss-weather-api": 1.0.2   , installed 1.0.2
              Adapter    "telegram"      : 1.10.0   , installed 1.10.0
              Adapter    "tesla-motors"  : 0.5.2    , installed 1.0.7
              Adapter    "tr-064"        : 4.2.14   , installed 4.2.15
              Adapter    "unifi"         : 0.5.10   , installed 0.5.10
              Adapter    "vis"           : 1.4.5    , installed 1.4.7
              Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
              Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
              Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
              Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
              Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
              Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.9
              Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
              Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
              Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
              Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
              Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
              Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
              Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
              Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
              Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
              Adapter    "web"           : 3.4.9    , installed 3.4.16
              Adapter    "windows-control": 0.1.5   , installed 0.1.5
              Adapter    "yahka"         : 0.13.1   , installed 0.13.1
              Adapter    "zigbee"        : 1.6.6    , installed 1.6.12
                Homoran Global Moderator Administrators @Glasfaser last edited by
                Auf hard ...
                shure?
                ohne -u iobroker -H ?
                • Glasfaser
                  @chrisprefect
                  Erlich ......
                  nimm ein Backup .... installiere ioBroker neu
                  und lass die Finger von root
                  Homoran ChrisPrefect 2 Replies Last reply Reply Quote 1
                  • Glasfaser
                    Glasfaser @Homoran last edited by
                    @homoran sagte in Javascript Adapter rot:
                    shure?
                    Ja ... wollte sehen was passiert
                      nimm ein Backup
                      da sind dann auch deine Skripte drin
                      • ChrisPrefect
                        @glasfaser Das Backup das ich habe ist von vorgestern. Das war wohl noch vor dem Update der Admin-Instanz. Aber wenn ich das wieder zurückspiele und wieder update bin ich gleich weit.
                        Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                          nein!
                          Nicht wenn du vorher eine vernünftige Grundinstallation ohne root und ohne Desktop installierst
                          ChrisPrefect 1 Reply Last reply Reply Quote 1
                          • Glasfaser
                            Nein...
                            und dann stimmen die Rechte wieder
                            • ChrisPrefect
                              @homoran Das schaffe ich in meinem aktuellen Zustand nicht. Um Debian in der VM mit den Virtualbox-Tools zu installieren brauche ich schon einen Tag. Und dann hoffen, dass das Backitup funktioniert ist zu riskant.
                              • ChrisPrefect
                                @glasfaser Ich hatte mich seit dem Backup der VM nicht per Root eingeloggt. Wenn dann wär das vor vielen, vielen Monaten mal gewesen.
                                  VB kenne ich nicht, bei Proxmox dauert das etwa 1/2 Stunde
                                  Das sollte funktionieren.
                                  Aber du arbeitest ja mit VMs. Warum machst du nicht erst einmal eine zweite VM parallel neu und installierst da in Ruhe alles
                                  • ChrisPrefect
                                    Ich habe jetzt das Backup der VM zurückgespielt und nochmals alles upgedatet. Diesmal hat es funktioniert. Das einzige, was diesmal anders war, ist, dass ich nun zuerst den Javascript-Adapter auf .19 upgedatet habe, dann den jscrontroller/Host auf 3.3.22 und dann noch den Admin-Adapter auf 5.2.3.
                                    Seit dem VM-Backup war ich auch nicht als Root eingeloggt... Schon komisch, dass sich ioBroker bei mir so oft irgendwie aufhängt.
                                    Solche Ausfälle sind für mich immer extrem stressig, wenn das Smarthome nicht läuft, gerade wenn man nicht fit ist.
                                    Merci für die schnelle und ausführliche Hilfe!
                                    Glasfaser 1 Reply Last reply Reply Quote 2
                                    • Glasfaser
                                      @chrisprefect
                                      .... schön das es wieder geht . 🙂
                                      Ein weiteres "rumbastel" wäre auch sinnlos gewesen ... deshalb habe ich auch geschrieben :
                                      Erlich ......
                                      3759
