    4. SONOFF ZigBee 3.0 USB DONGLE PLUS
      altmann @Thomas Braun last edited by altmann
      Danke schonmal für deine Antwort. Ich glaube es gab wirklich ein Problem mit den Groups. Habe den User 'iobroker' manuell zur Gruppe 'dialout' hinzugefügt und:
      2022-01-07 17:00:20.786 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
      2022-01-07 17:00:20.905 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 10544
      2022-01-07 17:00:24.284 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2022-01-07 17:00:24.286 - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because desired by instance
      2022-01-07 17:00:26.537 - info: zigbee.0 (10544) starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.8, js-controller: 3.3.22
      2022-01-07 17:00:26.698 - info: zigbee.0 (10544) Starting Zigbee npm ...
      2022-01-07 17:00:27.589 - info: zigbee.0 (10544) Installed Version: iobroker.zigbee@1.6.6
      2022-01-07 17:00:47.681 - info: zigbee.0 (10544) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20211217}}
      2022-01-07 17:00:47.692 - info: zigbee.0 (10544) Disable LED
      2022-01-07 17:00:47.694 - info: zigbee.0 (10544) --> transmitPower : normal
      2022-01-07 17:00:47.712 - info: zigbee.0 (10544) Currently no devices.
      2022-01-07 17:00:47.714 - info: zigbee.0 (10544) Zigbee started
      sowie
      pi@raspberrypi:~ $ ls -l /dev/serial/by-id
      total 0
      lrwxrwxrwx 1 root root 13 Jan  7 16:51 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ccd1fcf428c8eb11a272c5c3de5b81b4-if00-port0 -> ../../ttyUSB0
      Musste dann noch /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json löschen, dort stand wohl Schrott von meinen vorherigen Versuchen drin.
      Gerät lässt sich jetzt unter /dev/ttyUSB0 in der Instanz eintragen und startet aus meiner Sicht normal. Konnte gerade auch ohne Probleme ein Thermostat mit pairen.
      Danke für die Hilfe. Da wäre ich selber wohl nie drauf gekommen.
      Jetzt muss ich nurnoch schauen, dass ich das ganze nicht per devUSB sondern per statischer ID verbinde, dann dürfte es erstmal rund laufen.
        lustig29 last edited by
        ich bekomme meinen Sonoff 3.0 Usb Zigbee Stick nicht zum laufen.
        Error herdsman start
        zigbee.0
        2022-01-15 18:26:50.602	error	Failed to start Zigbee
        zigbee.0
        2022-01-15 18:26:50.601	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl us_3ca1ced350c9eb11b9d48b4f1d69213e-if00-port0'"
          Thomas Braun Most Active @lustig29 last edited by Thomas Braun
          @lustig29 sagte in SONOFF ZigBee 3.0 USB DONGLE PLUS:
          Lügt das System etwa?
          ls -la /dev/serial/by-id
          sagt?
          Da scheint ein Leerzeichen drin zu sein:
          Dongle_Pl us_3ca
          In Pfaden darf es keine Leerzeichen geben.
            lustig29 @Thomas Braun last edited by
            @thomas-braun said in SONOFF ZigBee 3.0 USB DONGLE PLUS:
             usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3ca1ced350c9eb11b9d48b4f1d69213e-if00-port0 -> ../../ttyUSB0
              @thomas-braun Hab alles per Hand nochmal eingetragen, geht leider immer noch nicht
                lustig29 @lustig29 last edited by
                @thomas-braun Hatte vorher einen Conbee2 an dem Anschluss laufen. Kann das vielleicht das Problem sein?
                  @lustig29
                  Kopier es.
                  sudo -u iobroker groups
                  bringt?
                    @thomas-braun ```
                    iobroker tty dialout audio video bluetooth gpio i2c
                      @lustig29
                      Bitte vollständige Ein- und Ausgabezeilen posten.
                          @lustig29
                          Komplett bedeutet in der Form (inkl. login prompt):
                          echad@chet:~ $ sudo -u iobroker groups
                          iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
                          Ein Neustart mit korrigierten Links sieht jetzt wie in der Konsole aus? Leerzeichen entfernt?
                            Ja, richtig. Genauso sieht es aus
                              Ich seh nix.
                                pi@raspberrypi:~ $ sudo -u iobroker groups
                                  @lustig29
                                  Ja, ich meinte aber auch eher
                                    zigbee.0
                                    2022-01-15 19:07:34.572	info	Installed Version: iobroker.zigbee@1.6.6
                                    zigbee.0
                                    2022-01-15 19:07:34.564	error	Error herdsman start
                                    zigbee.0
                                    2022-01-15 19:07:34.564	error	Failed to start Zigbee
                                    zigbee.0
                                    2022-01-15 19:07:34.563	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3ca1ced350c9eb11b9d48b4f1d69213e-if00-port0 us_3ca1ced350c9eb11b9d48b4f1d69213e-if00-port0'"
                                    zigbee.0
                                    2022-01-15 19:07:34.552	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2022-01-15 19:07:34.551	info	Try to reconnect. 1 attempts left
                                      Da ist immer noch Quatsch in dem Eintrag. Der letzte Teil ist doppelt/nicht gelöscht worden vor dem reinkopieren.
                                        @thomas-braun Das war es. Weiß der Geier wie das da rein gekommen ist. Vielen Dank für deine Hilfe
                                          Jan1 @lustig29 last edited by
                                          @lustig29
                                          Wir lernen, das Log File lügt nicht 😉
                                          L Thomas Braun 2 Replies Last reply Reply Quote 0
                                            lustig29 @Jan1 last edited by
                                            @jan1 Stimmt. 😊
                                            sonoff zigbee
                                            50
                                            435
                                            127144
