    4. [SourceAnalytix 0.4.8-Final] Released !
      crunchip Forum Testing Most Active @Smallfeuer last edited by
      @smallfeuer wo löschen?
      • JB_Sullivan
        JB_Sullivan @crunchip last edited by JB_Sullivan
        @crunchip
        Wo sollte ich die finden? Im original Datenpunkt? oder bei SA unter cumulativReading?
        Original DP
          "type": "state",
          "common": {
            "name": "Zählerstand Abgabe Gesammt",
            "type": "number",
            "role": "value.power.delivery",
            "unit": "kWh",
            "write": false,
            "read": true,
            "custom": {
              "sourceanalytix.0": {
               "valueAtDeviceReset": 0,                  <---------------------- so?
                "valueAtDeviceInit": null,                  <----------------------- so?
                "enabled": true,
                "alias": "",
                "selectedPrice": "ElectricityDelivery",
                "selectedUnit": "kWh",
                "costs": true,
                "consumption": true,
                "meter_values": true,
                "start_day": 3289.9739438,
                "start_week": 3289.9739438,
                "start_month": 3288.6489348,
                "start_quarter": 3288.6489348,
                "start_year": 3288.6489348,
                "currentValue": 31.546147,
                "valueAtDeviceReset": 3290.0493853,
                "valueAtDeviceInit": 3290.0486133,
                "cumulativeValue": 3289.9739438
              "influxdb.0": {
                "enabled": true,
                "changesOnly": true,
                "debounce": "1000",
                "retention": "31536000",
                "changesRelogInterval": "3600",
                "changesMinDelta": 0,
                "storageType": "",
                "aliasId": ""
          "native": {},
          "from": "system.adapter.discovergy.0",
          "user": "system.user.admin",
          "ts": 1641841305171,
          "_id": "discovergy.0.TEST.energyOut",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
        SA DP
          "type": "state",
          "common": {
            "name": "Cumulative Reading",
            "type": "number",
            "role": "value",
            "read": true,
            "write": false,
            "unit": "kWh",
            "def": 0
          "native": {},
          "from": "system.adapter.sourceanalytix.0",
          "ts": 1641846295976,
          "_id": "sourceanalytix.0.discovergy__0__TEST__energyOut.cumulativeReading",
          "acl": {
            "object": 1636,
            "state": 1636,
          crunchip Forum Testing Most Active @JB_Sullivan last edited by crunchip
          @jb_sullivan sagte in [SourceAnalytix 0.4.8-Final] Released !:
          und kein screenshot bitte, so kann ich dir es nicht zeigen
          • JB_Sullivan
            @crunchip
            Habs oben geändert, da ich dir leider nicht so ganz folgen kann.
              Smallfeuer @crunchip last edited by
              @crunchip Ich hab es gefunden 😉 Ich hab über WinSCP die json Datei aus dem History Ordern von heut bearbeitet und den fehlerhaften Datensatz rausgehaun. Jetzt stimmt mein Jahreschart wieder.
              Aber trotzdem nochmal danke für deinen 24/7 Support hier 🙂 Schönen Feierabend...
                @jb_sullivan also nochmal
                • SA Stoppen
                • ExpertenModus aktivieren
                • Raw aufrufen und die beiden Zeilen löschen
                27  "valueAtDeviceReset": 3290.0493853,
                28  "valueAtDeviceInit": 3290.0486133,
                hier deinen aktuellen Zählerstand eintragen
                29 "cumulativeValue": 3289.9739438
                • speichern
                • Sa Starten
                übrigens steht das auch in der Beschreibung https://github.com/DrozmotiX/ioBroker.sourceanalytix
                unter Troubleshooting Punkt 7
                • JB_Sullivan
                  @crunchip sagte in [SourceAnalytix 0.4.8-Final] Released !:
                  also nochmal
                  Das war jetzt aber eine schwere Geburt - OK, mit dem Hinweis auf GIT ist lieb gemeint, aber da würde ich als allerletztes suchen, wenn der Adpater über Monate funktioniert hat. Zumal man ja auch weiß das Discovergy heute ein Problem hatte. Da sucht man doch in einer ganz anderen Ecke.
                  Ist das mit den beiden Eintragungen ein generelles "Problem" bei SA? Was sollen diese Zeilen in einem "optimalen Leben" bewirken? Ich meine hier ist es ein fest verbautes Smartmeter, aber so Steckdosen Energiezähler werden ja ggf. doch öfter mal raus gezogen (device Reset?) Damit torpediert man sich ja seine ganzen Aufzeichnungen.
                    @jb_sullivan es geht ja nicht unbeding das Geräte mal vom Strom genommen werden.
                    Problem ist eher,
                    wie z.b. shelly die resetten sich jede Nacht, also kein fortlaufender Zahler
                    sonoff, gibt es bei manchen das Problem, obwohl der Zähler fortlaufend ist, das nach einem Stromausfall der zähler bei 0 beginnt.
                    desweiteren gibt es noch den ein oder anderen Zähler, bei dem ebenfalls ein device reset eintritt, ist soviel ich weiss, Issue am laufen und noch auf Fehlersuche.
                    oder aber auch anderweitig ein Zählerstand erfasst wird(Script)
                    daher wurde diese Funktion mit dem device reset eingebaut, damit man das auch mitbekommt.
                    Letztendlich ist der Adapter auch noch nicht im stable, sollte man bedenken und daher
                    sollte das die erste Anlaufstelle sein
                    das ist wie eben geschrieben im Fall der Fälle, eine Funktion, die dir das ermöglicht, rechtzeitig vor Mitternacht noch die Werte zu korrigieren, so das die Werte korrekt geschrieben werden können.
                      ChrisXY last edited by
                      Gibt es keinen last day Wert mehr ? von den Kosten?
                      • Chaot
                        Chaot @crunchip last edited by
                        @chaot sagte in [SourceAnalytix 0.4.8-Final] Released !:
                        Geht die Änderung des Bezugpreises rückwirkend auf die bisherigen Berechnungen?
                        ich zitiere aus der Telegram Gruppe
                        Ab diesem Tag + die jeweilige Periode (Woche/monat/kwartal)
                        heisst, keine Änderungen rückwirkend
                        Scheint zu stimmen.
                        Da ich gestern noch mal schnell die Preise von Netto auf Bruttopreise geändert habe damit am Jahresende der Bruttopreis stimmt habe ich das mal beobachtet.
                        Allerdings scheinen die Monatskosten sofort vollständig auf den neuen Preis zu gehen. Was ja auch logisch wäre, da eine Umstellung der Preise ja normalerweise nicht zum 15. des Monats erfolgt. Vorteil dabei ist das ich nicht genau am ersten Tag des Monats die Preisänderung eingeben muss sondern es scheinbar ausreicht wenn die im Verlauf des Monats eingegeben wird.
                        Da mein Versorger seit 2019 die Preise nicht angepasst hat gehe ich fest davon aus das ich spätestens zum Sommer eine Preisänderung bekommen werde. Da werde ich das dann nochmal genauer verfolgen.
                          crunchip Forum Testing Most Active @ChrisXY last edited by
                          @chrisxy gibt es natürlich
                          • ChristianM
                            ChristianM last edited by
                            Warum gibt es die monatlichen Verbräuche eigentlich nicht mehr für das aktuelle Jahr? So muss man ja jedes Jahr die Tabelle komplett ändern oder habe ich noch irgendwo einen Fehler in meiner Konfiguration?
                              crunchip Forum Testing Most Active @ChristianM last edited by
                              @christianm sagte in [SourceAnalytix 0.4.8-Final] Released !:
                              ChristianM 1 Reply Last reply Reply Quote 0
                              • ChristianM
                                ChristianM @crunchip last edited by
                                @crunchip
                                Ich meinte, Januar,Februar,März........ Dezember für das aktuelle Jahr.
                                  @christianm dein aktuelles Jahr ist doch 2022, da stehen die Monate doch drin.
                                  Für welche Tabelle?
                                  Les mal weiter oben, https://forum.iobroker.net/post/694204
                                  • ChristianM
                                    @crunchip
                                    nein, dafuer haben wir das Archive des Jahres. Man kan immer mit. variablen arbeiten z.b. $(year) womit das jähr automatisch immer jetziges ist oder $(year - 1) usw man muss nicht immer alles in daten loesen wollen
                                    Das hier habe ich gefunden, aber wie setze ich das denn jetzt in VIS oder auch mit Blockly um?
                                    Wenn ich einfach nur eine tabelle wie diese hier haben möchte?
                                    https://forum.iobroker.net/assets/uploads/files/1635061607610-b6041954-0850-44c9-9d45-2c339fd53f82-image.png
                                      @christianm auf die schnelle habe ich da auch keine Idee, nutze das nicht.
                                      • Daniel Bohn
                                        Daniel Bohn last edited by
                                        Moin,
                                        erstmal: Super Adapter 🙂
                                        Was mir fehlt - es kann aber auch sein, dass ich einfach ein Brett vorm Kopf habe - ist, dass ich für meienn Wärmespeicher einen HT/NT Tarif habe. Konkret heißt das: Zwischen 06:00 Uhr und 22:00 zahle ich einen HT-Preis (z.B. 0,20€ / kwh), Nachts zwischen 22:00 bis 06:00 den NT-Preis (z.B. 0,15€ / kwh).
                                        Zwar kann ich mehrere Tarife in SAx anlegen, jedoch swichted das ganz dann ja für z.B. einen Shelly nicht um. Ich kann HT und NT also nicht differenzieren...
                                        Übersehe ich hier etwas?
                                        schöne Grüße
                                        Daniel
                                          crunchip Forum Testing Most Active @Daniel Bohn last edited by
                                          @daniel-bohn richtig, wenn du keine zwei separate Zähler hast, geht das so nicht.
                                          Du könntest es dann mit nem script lösen und zwei eigenen Datenpunkte erstellst.
                                          Daniel Bohn 1 Reply Last reply Reply Quote 0
                                          • Daniel Bohn
                                            Daniel Bohn @crunchip last edited by
                                            @crunchip Hey, danke für die schnelle Antwort. Ja, das habe ich befürchtet - macht aber nix. Dann mach ich mir ein passendes Blockly 😉
                                            2302
                                            1135318
