    4. Test : Wasserenthärtung judo i-soft plus Adapter
      mpenno @arteck last edited by
      @arteck Hattest Du schon einmal schauen können? Sag Bescheid, wenn ich was testen kann.
      Viele Grüße
      Michael
        arteck Developer Most Active @mpenno last edited by
        @mpenno installier mal von GIT
          @arteck Gerade frisch vom GIT geladen und installiert:
          Alte Version 1.0.10 deinstalliert:
          $ iobroker del judoisoft.0
          Neue Version installiert:
          $ iobroker url https://github.com/arteck/ioBroker.judoisoft --host iobroker
          $ iobroker add judoisoft auto --host iobroker
          Dann sind die Meldungen gleich nach dem Start:
          2021-11-20 19:16:00.107 - debug: judoisoft.0 (26729) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2021-11-20 19:16:00.157 - debug: judoisoft.0 (26729) Objects client ready ... initialize now
          2021-11-20 19:16:00.160 - debug: judoisoft.0 (26729) Objects create System PubSub Client
          2021-11-20 19:16:00.162 - debug: judoisoft.0 (26729) Objects create User PubSub Client
          2021-11-20 19:16:00.168 - debug: judoisoft.0 (26729) Objects client initialize lua scripts
          2021-11-20 19:16:00.185 - debug: judoisoft.0 (26729) Objects connected to redis: 127.0.0.1:9001
          2021-11-20 19:16:00.195 - debug: judoisoft.0 (26729) objectDB connected
          2021-11-20 19:16:00.197 - debug: judoisoft.0 (26729) Redis States: Use Redis connection: 127.0.0.1:9000
          2021-11-20 19:16:00.209 - debug: judoisoft.0 (26729) States create System PubSub Client
          2021-11-20 19:16:00.210 - debug: judoisoft.0 (26729) States create User PubSub Client
          2021-11-20 19:16:00.260 - debug: judoisoft.0 (26729) States connected to redis: 127.0.0.1:9000
          2021-11-20 19:16:00.261 - debug: judoisoft.0 (26729) statesDB connected
          2021-11-20 19:16:00.518 - info: judoisoft.0 (26729) starting. Version 1.0.11 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v12.22.6, js-controller: 3.3.18
          2021-11-20 19:16:00.544 - debug: judoisoft.0 (26729) base url https://10.0.0.16:8124/?group=
          2021-11-20 19:16:00.546 - debug: judoisoft.0 (26729) create state
          2021-11-20 19:16:01.295 - debug: judoisoft.0 (26729) get statusURL for local
          2021-11-20 19:16:04.076 - debug: judoisoft.0 (26729) getSerialnumber : {"group":"register","command":"show","msgnumber":"2","token":"7b98408537f94dacb94f282e52b20d534af8c9b564c6eea443c2bd208371d836","status":"ok","data":[{"wtuType":"i-soft plus","serial number":"120236"}]}
          2021-11-20 19:16:04.081 - debug: judoisoft.0 (26729) getwtuType i-soft plus
          2021-11-20 19:16:04.087 - debug: judoisoft.0 (26729) getserialN 120236
          2021-11-20 19:16:04.458 - debug: judoisoft.0 (26729) connect Result: {"group":"register","command":"connect","msgnumber":"1","token":"7b98408537f94dacb94f282e52b20d534af8c9b564c6eea443c2bd208371d836","parameter":"i-soft plus","serial number":"120236","status":"ok"}
          2021-11-20 19:16:04.461 - debug: judoisoft.0 (26729) get Information Static Local
          2021-11-20 19:17:04.468 - error: judoisoft.0 (26729) SoftwareVersion ERROR
            @mpenno und weiter..warum schnibbelst du das LOG ab
              @arteck Da gab es nichts, weiter. Hatte dann nur den Log-Modus vom Adapter von "Info" auf "debug" gestellt.
              2021-11-20 19:00:03.612 - info: smartmeter.0 (537) Received 7 values, 3 updated
              2021-11-20 19:04:37.171 - info: host.iobroker iobroker del judoisoft.0
              2021-11-20 19:04:41.099 - info: host.iobroker iobroker Delete adapter "judoisoft.0"
              2021-11-20 19:04:41.108 - info: host.iobroker iobroker host.iobroker Counted 1 instances of judoisoft.0
              2021-11-20 19:04:41.124 - info: host.iobroker iobroker host.iobroker Counted 2 channels of judoisoft.0
              2021-11-20 19:04:41.137 - info: host.iobroker iobroker host.iobroker Counted 39 states of judoisoft.0
              2021-11-20 19:04:41.147 - info: host.iobroker iobroker host.iobroker Counted 14 states of system.adapter.judoisoft.0
              2021-11-20 19:04:41.156 - info: host.iobroker iobroker host.iobroker Counted 33 states (io.judoisoft.0.*) from states
              2021-11-20 19:04:41.177 - info: host.iobroker iobroker host.iobroker Counted 14 states (system.adapter.judoisoft.0.*) from states
              2021-11-20 19:04:42.097 - info: host.iobroker iobroker host.iobroker Deleting 56 object(s).
              2021-11-20 19:04:43.526 - info: host.iobroker object deleted system.adapter.judoisoft.0
              2021-11-20 19:04:43.552 - info: host.iobroker iobroker host.iobroker Deleting 47 state(s).
              2021-11-20 19:04:44.798 - info: host.iobroker iobroker exit 0
              2021-11-20 19:05:04.905 - info: smartmeter.0 (537) Received 7 values, 3 updated
              2021-11-20 19:05:50.450 - info: host.iobroker iobroker del judoisoft
              2021-11-20 19:05:52.394 - info: host.iobroker iobroker Delete adapter "judoisoft"
              2021-11-20 19:05:52.406 - info: host.iobroker iobroker host.iobroker Counted 1 meta of judoisoft
              2021-11-20 19:05:52.410 - info: host.iobroker iobroker host.iobroker Counted 1 adapter for judoisoft
              2021-11-20 19:05:53.466 - info: host.iobroker iobroker host.iobroker file judoisoft.admin deleted
              2021-11-20 19:05:53.475 - info: host.iobroker iobroker host.iobroker object judoisoft deleted
              2021-11-20 19:05:53.484 - info: host.iobroker iobroker host.iobroker object judoisoft.admin deleted
              2021-11-20 19:05:53.486 - info: host.iobroker iobroker host.iobroker Deleting 2 object(s).
              2021-11-20 19:05:53.544 - info: host.iobroker iobroker npm uninstall iobroker.judoisoft --loglevel error --prefix "/opt/iobroker" (System call)
              2021-11-20 19:07:38.815 - info: host.iobroker iobroker exit 0
              2021-11-20 19:08:04.341 - info: host.iobroker iobroker url https://github.com/arteck/ioBroker.judoisoft --host iobroker
              2021-11-20 19:08:06.753 - info: host.iobroker iobroker install arteck/ioBroker.judoisoft#7e27026ac35087578cc503718032f41ebaf0dd3a
              2021-11-20 19:08:07.321 - info: host.iobroker iobroker NPM version: 6.14.15
              2021-11-20 19:08:07.322 - info: host.iobroker iobroker npm install arteck/ioBroker.judoisoft#7e27026ac35087578cc503718032f41ebaf0dd3a --loglevel error --prefix "/opt/iobroker" (System call)
              2021-11-20 19:09:44.780 - info: host.iobroker iobroker upload [4] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/words.js words.js application/javascript
              2021-11-20 19:09:44.872 - info: host.iobroker iobroker upload [3] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/style.css style.css text/css
              2021-11-20 19:09:44.933 - info: host.iobroker iobroker upload [2] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/judo.png judo.png image/png
              2021-11-20 19:09:44.992 - info: host.iobroker iobroker upload [1] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/index_m.html index_m.html text/html
              2021-11-20 19:09:45.051 - info: host.iobroker iobroker upload [0] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/adapter-settings.js adapter-settings.js application/javascript
              2021-11-20 19:09:46.161 - info: host.iobroker iobroker exit 0
              2021-11-20 19:10:05.824 - info: smartmeter.0 (537) Received 7 values, 3 updated
              2021-11-20 19:10:17.949 - info: host.iobroker iobroker add judoisoft auto --host iobroker
              2021-11-20 19:10:19.842 - info: host.iobroker iobroker host.iobroker create instance judoisoft
              2021-11-20 19:10:19.865 - info: host.iobroker iobroker host.iobroker object judoisoft.0.info.connection created
              2021-11-20 19:10:19.892 - info: host.iobroker iobroker host.iobroker object judoisoft.0.info created
              2021-11-20 19:10:19.926 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.logLevel created
              2021-11-20 19:10:19.960 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.sigKill created
              2021-11-20 19:10:20.000 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.eventLoopLag created
              2021-11-20 19:10:20.034 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.outputCount created
              2021-11-20 19:10:20.067 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.inputCount created
              2021-11-20 19:10:20.099 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.uptime created
              2021-11-20 19:10:20.131 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.memRss created
              2021-11-20 19:10:20.167 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.memHeapTotal created
              2021-11-20 19:10:20.252 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.memHeapUsed created
              2021-11-20 19:10:20.286 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.cputime created
              2021-11-20 19:10:20.324 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.cpu created
              2021-11-20 19:10:20.358 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.compactMode created
              2021-11-20 19:10:20.390 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.connected created
              2021-11-20 19:10:20.424 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.alive created
              2021-11-20 19:10:20.455 - info: host.iobroker iobroker host.iobroker Set default value of judoisoft.0.info.connection: false
              2021-11-20 19:10:20.496 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0 created
              2021-11-20 19:10:21.536 - info: host.iobroker iobroker exit 0
              2021-11-20 19:13:58.814 - info: host.iobroker "system.adapter.judoisoft.0" enabled
              2021-11-20 19:13:58.939 - info: host.iobroker instance system.adapter.judoisoft.0 started with pid 26613
              2021-11-20 19:14:01.266 - info: judoisoft.0 (26613) starting. Version 1.0.11 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v12.22.6, js-controller: 3.3.18
              2021-11-20 19:15:04.132 - error: judoisoft.0 (26613) SoftwareVersion ERROR
              2021-11-20 19:15:07.261 - info: smartmeter.0 (537) Received 7 values, 3 updated
              2021-11-20 19:15:55.827 - info: host.iobroker stopInstance system.adapter.judoisoft.0 (force=false, process=true)
              2021-11-20 19:15:55.849 - info: judoisoft.0 (26613) Got terminate signal TERMINATE_YOURSELF
              2021-11-20 19:15:55.850 - info: judoisoft.0 (26613) cleaned everything up...
              2021-11-20 19:15:55.852 - info: judoisoft.0 (26613) terminating
              2021-11-20 19:15:55.853 - info: judoisoft.0 (26613) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2021-11-20 19:15:55.898 - info: host.iobroker stopInstance system.adapter.judoisoft.0 send kill signal
              2021-11-20 19:15:56.437 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2021-11-20 19:15:58.991 - info: host.iobroker instance system.adapter.judoisoft.0 started with pid 26729
              Danke Dir
                @mpenno sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
                danach muss noch was kommen.... wenn nich dann hast du eine falsche Version..installieren JETZT nochmal vom GIT
                  @arteck Ich habe gerade die neue Version installiert (also von 1.0.11 auf 1.0.12):
                  Das Log sieht nun so aus, die Error-Meldungen am Ende kamen so im Abstand von einer Minute (solange hatte ich gestern nicht gewartet):
                  2021-11-22 15:55:57.787 - info: smartmeter.0 (537) Received 7 values, 3 updated
                  2021-11-22 15:57:46.799 - info: host.iobroker iobroker del judoisoft.0
                  2021-11-22 15:57:51.827 - info: host.iobroker iobroker Delete adapter "judoisoft.0"
                  2021-11-22 15:57:51.844 - info: host.iobroker iobroker host.iobroker Counted 1 instances of judoisoft.0
                  2021-11-22 15:57:51.879 - info: host.iobroker iobroker host.iobroker Counted 2 channels of judoisoft.0
                  2021-11-22 15:57:51.899 - info: host.iobroker iobroker host.iobroker Counted 39 states of judoisoft.0
                  2021-11-22 15:57:51.916 - info: host.iobroker iobroker host.iobroker Counted 14 states of system.adapter.judoisoft.0
                  2021-11-22 15:57:51.932 - info: host.iobroker iobroker host.iobroker Counted 33 states (io.judoisoft.0.*) from states
                  2021-11-22 15:57:51.980 - info: host.iobroker iobroker host.iobroker Counted 15 states (system.adapter.judoisoft.0.*) from states
                  2021-11-22 15:57:52.938 - info: host.iobroker iobroker host.iobroker Deleting 56 object(s).
                  2021-11-22 15:57:55.451 - info: host.iobroker object deleted system.adapter.judoisoft.0
                  2021-11-22 15:57:55.453 - info: host.iobroker stopInstance system.adapter.judoisoft.0 (force=false, process=true)
                  2021-11-22 15:57:55.514 - info: host.iobroker stopInstance system.adapter.judoisoft.0 send kill signal
                  2021-11-22 15:57:55.519 - info: host.iobroker iobroker host.iobroker Deleting 48 state(s).
                  2021-11-22 15:57:55.482 - info: judoisoft.0 (26729) Got terminate signal TERMINATE_YOURSELF
                  2021-11-22 15:57:55.560 - info: judoisoft.0 (26729) cleaned everything up...
                  2021-11-22 15:57:55.561 - info: judoisoft.0 (26729) terminating
                  2021-11-22 15:57:55.562 - info: judoisoft.0 (26729) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2021-11-22 15:57:55.566 - debug: judoisoft.0 (26729) system.adapter.judoisoft.0: logging false
                  2021-11-22 15:57:55.572 - warn: judoisoft.0 (26729) State "judoisoft.0.info.connection" has no existing object, this might lead to an error in future versions
                  2021-11-22 15:57:56.156 - error: host.iobroker instance system.adapter.judoisoft.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                  2021-11-22 15:57:56.157 - info: host.iobroker Do not restart adapter system.adapter.judoisoft.0 because desired by instance
                  2021-11-22 15:57:56.782 - info: host.iobroker iobroker exit 0
                  2021-11-22 15:58:16.324 - info: host.iobroker iobroker del judoisoft
                  2021-11-22 15:58:18.164 - info: host.iobroker iobroker Delete adapter "judoisoft"
                  2021-11-22 15:58:18.232 - info: host.iobroker iobroker host.iobroker Counted 1 meta of judoisoft
                  2021-11-22 15:58:18.239 - info: host.iobroker iobroker host.iobroker Counted 1 adapter for judoisoft
                  2021-11-22 15:58:18.359 - info: host.iobroker iobroker host.iobroker Counted 2 states (system.adapter.judoisoft.*) from states
                  2021-11-22 15:58:19.525 - info: host.iobroker iobroker host.iobroker file judoisoft.admin deleted
                  2021-11-22 15:58:19.533 - info: host.iobroker iobroker host.iobroker object judoisoft deleted
                  2021-11-22 15:58:19.541 - info: host.iobroker iobroker host.iobroker object judoisoft.admin deleted
                  2021-11-22 15:58:19.543 - info: host.iobroker iobroker host.iobroker Deleting 2 object(s).
                  2021-11-22 15:58:19.629 - info: host.iobroker iobroker host.iobroker Deleting 2 state(s).
                  2021-11-22 15:58:19.645 - info: host.iobroker iobroker npm uninstall iobroker.judoisoft --loglevel error --prefix "/opt/iobroker" (System call)
                  2021-11-22 16:00:08.500 - info: host.iobroker iobroker exit 0
                  2021-11-22 16:00:58.663 - info: smartmeter.0 (537) Received 7 values, 3 updated
                  2021-11-22 16:01:25.391 - info: host.iobroker iobroker url https://github.com/arteck/ioBroker.judoisoft --host iobroker
                  2021-11-22 16:01:27.887 - info: host.iobroker iobroker install arteck/ioBroker.judoisoft#12ca8fedb29ecb6955422c836ba1de528ca6f4cc
                  2021-11-22 16:01:28.446 - info: host.iobroker iobroker NPM version: 6.14.15
                  2021-11-22 16:01:28.448 - info: host.iobroker iobroker npm install arteck/ioBroker.judoisoft#12ca8fedb29ecb6955422c836ba1de528ca6f4cc --loglevel error --prefix "/opt/iobroker" (System call)
                  2021-11-22 16:03:05.132 - info: host.iobroker iobroker upload [4] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/words.js words.js application/javascript
                  2021-11-22 16:03:05.223 - info: host.iobroker iobroker upload [3] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/style.css style.css text/css
                  2021-11-22 16:03:05.279 - info: host.iobroker iobroker upload [2] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/judo.png judo.png image/png
                  2021-11-22 16:03:05.339 - info: host.iobroker iobroker upload [1] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/index_m.html index_m.html text/html
                  2021-11-22 16:03:05.398 - info: host.iobroker iobroker upload [0] judoisoft.admin /opt/iobroker/node_modules/iobroker.judoisoft/admin/adapter-settings.js adapter-settings.js application/javascript
                  2021-11-22 16:03:06.515 - info: host.iobroker iobroker exit 0
                  2021-11-22 16:04:06.545 - info: host.iobroker iobroker add judoisoft auto --host iobroker
                  2021-11-22 16:04:08.474 - info: host.iobroker iobroker host.iobroker create instance judoisoft
                  2021-11-22 16:04:08.486 - info: host.iobroker iobroker host.iobroker object judoisoft.0.info.connection created
                  2021-11-22 16:04:08.516 - info: host.iobroker iobroker host.iobroker object judoisoft.0.info created
                  2021-11-22 16:04:08.552 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.logLevel created
                  2021-11-22 16:04:08.586 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.sigKill created
                  2021-11-22 16:04:08.619 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.eventLoopLag created
                  2021-11-22 16:04:08.653 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.outputCount created
                  2021-11-22 16:04:08.704 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.inputCount created
                  2021-11-22 16:04:08.737 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.uptime created
                  2021-11-22 16:04:08.803 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.memRss created
                  2021-11-22 16:04:08.837 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.memHeapTotal created
                  2021-11-22 16:04:08.879 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.memHeapUsed created
                  2021-11-22 16:04:08.918 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.cputime created
                  2021-11-22 16:04:08.956 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.cpu created
                  2021-11-22 16:04:08.992 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.compactMode created
                  2021-11-22 16:04:09.029 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.connected created
                  2021-11-22 16:04:09.066 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0.alive created
                  2021-11-22 16:04:09.098 - info: host.iobroker iobroker host.iobroker Set default value of judoisoft.0.info.connection: false
                  2021-11-22 16:04:09.175 - info: host.iobroker iobroker host.iobroker object system.adapter.judoisoft.0 created
                  2021-11-22 16:04:10.210 - info: host.iobroker iobroker exit 0
                  2021-11-22 16:05:38.528 - info: host.iobroker "system.adapter.judoisoft.0" enabled
                  2021-11-22 16:05:38.670 - info: host.iobroker instance system.adapter.judoisoft.0 started with pid 31376
                  2021-11-22 16:05:40.638 - debug: judoisoft.0 (31376) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2021-11-22 16:05:40.686 - debug: judoisoft.0 (31376) Objects client ready ... initialize now
                  2021-11-22 16:05:40.688 - debug: judoisoft.0 (31376) Objects create System PubSub Client
                  2021-11-22 16:05:40.690 - debug: judoisoft.0 (31376) Objects create User PubSub Client
                  2021-11-22 16:05:40.692 - debug: judoisoft.0 (31376) Objects client initialize lua scripts
                  2021-11-22 16:05:40.713 - debug: judoisoft.0 (31376) Objects connected to redis: 127.0.0.1:9001
                  2021-11-22 16:05:40.723 - debug: judoisoft.0 (31376) objectDB connected
                  2021-11-22 16:05:40.726 - debug: judoisoft.0 (31376) Redis States: Use Redis connection: 127.0.0.1:9000
                  2021-11-22 16:05:40.736 - debug: judoisoft.0 (31376) States create System PubSub Client
                  2021-11-22 16:05:40.737 - debug: judoisoft.0 (31376) States create User PubSub Client
                  2021-11-22 16:05:40.785 - debug: judoisoft.0 (31376) States connected to redis: 127.0.0.1:9000
                  2021-11-22 16:05:40.786 - debug: judoisoft.0 (31376) statesDB connected
                  2021-11-22 16:05:41.203 - info: judoisoft.0 (31376) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v12.22.6, js-controller: 3.3.18
                  2021-11-22 16:05:41.229 - debug: judoisoft.0 (31376) base url https://10.0.0.16:8124/?group=
                  2021-11-22 16:05:41.231 - debug: judoisoft.0 (31376) create state
                  2021-11-22 16:05:41.862 - debug: judoisoft.0 (31376) get statusURL for local
                  2021-11-22 16:05:43.082 - debug: judoisoft.0 (31376) getSerialnumber : {"group":"register","command":"show","msgnumber":"2","token":"aae200925d3ac7d9e37191d98b943c2a5002325267bd8d5d5e30e51cedffce98","status":"ok","data":[{"wtuType":"i-soft plus","serial number":"120236"}]}
                  2021-11-22 16:05:43.086 - debug: judoisoft.0 (31376) getwtuType i-soft plus
                  2021-11-22 16:05:43.092 - debug: judoisoft.0 (31376) getserialN 120236
                  2021-11-22 16:05:43.420 - debug: judoisoft.0 (31376) connect Result: {"group":"register","command":"connect","msgnumber":"1","token":"aae200925d3ac7d9e37191d98b943c2a5002325267bd8d5d5e30e51cedffce98","parameter":"i-soft plus","serial number":"120236","status":"ok"}
                  2021-11-22 16:05:43.424 - debug: judoisoft.0 (31376) get Information Static Local
                  2021-11-22 16:05:59.417 - info: smartmeter.0 (537) Received 7 values, 3 updated
                  2021-11-22 16:06:43.430 - error: judoisoft.0 (31376) SoftwareVersion ERROR
                  2021-11-22 16:07:43.436 - error: judoisoft.0 (31376) HardwareVersion ERROR
                  2021-11-22 16:08:43.441 - error: judoisoft.0 (31376) InstallationDate ERROR
                  2021-11-22 16:09:43.447 - error: judoisoft.0 (31376) ServiceDate ERROR
                  2021-11-22 16:09:43.449 - debug: judoisoft.0 (31376) get Consumption data Local
                  2021-11-22 16:10:44.549 - error: judoisoft.0 (31376) getInfos ERROR
                  2021-11-22 16:10:59.851 - info: smartmeter.0 (537) Received 7 values, 3 updated
                  2021-11-22 16:16:01.197 - info: smartmeter.0 (537) Received 7 values, 3 updated
                    @mpenno das hatten wir gerade gehabt.. schau in der APP ob du da an die Daten kommst .. wenn nicht musst du ein Update der Anlage per USB machen.. oder einen Techniker kommen lassen.
                    • O
                      oranggila last edited by
                      Ich war hier lange nicht mehr aktiv. Die App konnte sich nicht mehr mit meiner Anlage verbinden. Nach Anruf beim Judo Support diese Woche bekam ich die Firmware zugeschickt, die ich neu installieren sollte über USB-Stick. Das hat auch geklappt. TFT-IO / Firmewareversion 1.0.64 ist jetzt drauf und die Verbindung über die JU-Control App funktioniert wieder.
                      Ich bekomme aber den iobroker Adapter nicht mehr zum laufen. Login über http Request schlägt schon fehl:
                      https://192.168.0.29:8124/?group=register&command=login&msgnumber=2&name=login&user=<user>&password=<password>&role=customer
                      Response:
                      {"group":"register","command":"login","msgnumber":"2","name":"login","user":"<user>","password":"*","role":"customer","status":"error","data":"login failed"}
                      Den Adapter habe ich lokal und über Cloud probiert. Er wird zwar grün, aber die Datenpunkte bleiben leer. Nur Connection Status=online, SerialNumber und lastInfoUpdate wird gefüllt.
                      Hier das Log vom Adapter mit "silly" (lokal):
                      2022-01-16 18:39:54.961  - host.NUCiobroker "system.adapter.judoisoft.0" enabled
                      2022-01-16 18:39:55.125  - host.NUCiobroker instance system.adapter.judoisoft.0 started with pid 13114
                      2022-01-16 18:39:55.599  - judoisoft.0 (13114) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      2022-01-16 18:39:55.618  - judoisoft.0 (13114) Objects client ready ... initialize now
                      2022-01-16 18:39:55.620  - judoisoft.0 (13114) Objects create System PubSub Client
                      2022-01-16 18:39:55.620  - judoisoft.0 (13114) Objects create User PubSub Client
                      2022-01-16 18:39:55.621  - judoisoft.0 (13114) Objects client initialize lua scripts
                      2022-01-16 18:39:55.636  - judoisoft.0 (13114) Objects connected to redis: 0.0.0.0:9001
                      2022-01-16 18:39:55.637  - judoisoft.0 (13114) redis psubscribe cfg.o.system.user.*
                      2022-01-16 18:39:55.640  - judoisoft.0 (13114) objectDB connected
                      2022-01-16 18:39:55.641  - judoisoft.0 (13114) Redis States: Use Redis connection: 0.0.0.0:9000
                      2022-01-16 18:39:55.646  - judoisoft.0 (13114) States create System PubSub Client
                      2022-01-16 18:39:55.647  - judoisoft.0 (13114) States create User PubSub Client
                      2022-01-16 18:39:55.698  - judoisoft.0 (13114) States connected to redis: 0.0.0.0:9000
                      2022-01-16 18:39:55.699  - judoisoft.0 (13114) statesDB connected
                      2022-01-16 18:39:55.923  - judoisoft.0 (13114) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v12.20.1, js-controller: 3.3.18
                      2022-01-16 18:39:55.935  - judoisoft.0 (13114) base url https://192.168.0.29:8124/?group=
                      2022-01-16 18:39:55.936  - judoisoft.0 (13114) create state
                      2022-01-16 18:39:55.945  - judoisoft.0 (13114) States system redis pmessage 2022-01-16 18:39:56.217  - judoisoft.0 (13114) get statusURL for local
                      2022-01-16 18:40:07.556  - judoisoft.0 (13114) get Information Static Local
                      2022-01-16 18:40:08.792  - judoisoft.0 (13114) State value to set for "judoisoft.0.InstallationDate" has to be type "number" but received type "object"
                      2022-01-16 18:40:08.842  - judoisoft.0 (13114) get Consumption data Local
                      2022-01-16 18:40:08.847  - judoisoft.0 (13114) State value to set for "judoisoft.0.ServiceDate" has to be type "number" but received type "object"
                      2022-01-16 18:40:08.880  - judoisoft.0 (13114) reconnect 1642354808880
                      2022-01-16 18:40:08.880  - judoisoft.0 (13114) get statusURL for local
                      Und hier mit Cloud Login:
                      2022-01-16 18:49:55.652 - info: host.NUCiobroker instance system.adapter.judoisoft.0 started with pid 28347
                      2022-01-16 18:49:56.114 - debug: judoisoft.0 (28347) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      2022-01-16 18:49:56.133 - debug: judoisoft.0 (28347) Objects client ready ... initialize now
                      2022-01-16 18:49:56.134 - debug: judoisoft.0 (28347) Objects create System PubSub Client
                      2022-01-16 18:49:56.135 - debug: judoisoft.0 (28347) Objects create User PubSub Client
                      2022-01-16 18:49:56.135 - debug: judoisoft.0 (28347) Objects client initialize lua scripts
                      2022-01-16 18:49:56.149 - debug: judoisoft.0 (28347) Objects connected to redis: 0.0.0.0:9001
                      2022-01-16 18:49:56.150 - silly: judoisoft.0 (28347) redis psubscribe cfg.o.system.user.*
                      2022-01-16 18:49:56.153 - debug: judoisoft.0 (28347) objectDB connected
                      2022-01-16 18:49:56.154 - debug: judoisoft.0 (28347) Redis States: Use Redis connection: 0.0.0.0:9000
                      2022-01-16 18:49:56.159 - debug: judoisoft.0 (28347) States create System PubSub Client
                      2022-01-16 18:49:56.159 - debug: judoisoft.0 (28347) States create User PubSub Client
                      2022-01-16 18:49:56.206 - debug: judoisoft.0 (28347) States connected to redis: 0.0.0.0:9000
                      2022-01-16 18:49:56.207 - debug: judoisoft.0 (28347) statesDB connected
                      2022-01-16 18:49:56.389 - info: judoisoft.0 (28347) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v12.20.1, js-controller: 3.3.18
                      2022-01-16 18:49:56.403 - debug: judoisoft.0 (28347) base url https://www.myjudo.eu/interface/
                      2022-01-16 18:49:56.404 - debug: judoisoft.0 (28347) create state
                      2022-01-16 18:49:56.446 - silly: judoisoft.0 (28347) States system redis pmessage system.adapter.judoisoft.0.logLevel/system.adapter.judoisoft.0.logLevel:{"val":"silly","ack":true,"ts":1642355396405,"q":0,"from":"system.adapter.judoisoft.0","lc":1642351519286}
                      2022-01-16 18:49:56.586 - debug: judoisoft.0 (28347) get statusURL for Cloud
                      2022-01-16 18:50:01.832 - debug: judoisoft.0 (28347) get Consumption data Cloud
                      2022-01-16 18:50:07.853 - debug: judoisoft.0 (28347) all fine [object Object]
                      2022-01-16 18:50:07.856 - debug: judoisoft.0 (28347) -> SerialNumber
                      2022-01-16 18:50:07.860 - debug: judoisoft.0 (28347) -> SoftwareVersion
                      2022-01-16 18:50:07.862 - debug: judoisoft.0 (28347) -> HardwareVersion
                      2022-01-16 18:50:07.862 - debug: judoisoft.0 (28347) -> _da null
                      2022-01-16 18:50:07.863 - debug: judoisoft.0 (28347) -> _dt null
                      2022-01-16 18:50:07.863 - debug: judoisoft.0 (28347) -> InstallationDate
                      2022-01-16 18:50:07.868 - info: judoisoft.0 (28347) State value to set for "judoisoft.0.InstallationDate" has to be type "number" but received type "string"
                      2022-01-16 18:50:07.871 - debug: judoisoft.0 (28347) -> ServiceDays
                      2022-01-16 18:50:07.875 - debug: judoisoft.0 (28347) -> Maintenance
                      2022-01-16 18:50:07.879 - debug: judoisoft.0 (28347) -> WaterTotal
                      2022-01-16 18:50:07.879 - debug: judoisoft.0 (28347) -> SaltRange
                      2022-01-16 18:50:07.884 - debug: judoisoft.0 (28347) -> NaturalHardness
                      2022-01-16 18:50:07.887 - debug: judoisoft.0 (28347) -> ResidualHardness
                      2022-01-16 18:50:07.891 - silly: judoisoft.0 (28347) States user redis pmessage judoisoft.0.ResidualHardness/judoisoft.0.ResidualHardness:{"val":0,"ack":true,"ts":1642355407888,"q":0,"from":"system.adapter.judoisoft.0","user":"system.user.admin","lc":1642351757580}
                      2022-01-16 18:50:07.892 - debug: judoisoft.0 (28347) --> stateID judoisoft.0.ResidualHardness changed: 0 (ack = true)
                      2022-01-16 18:50:07.892 - debug: judoisoft.0 (28347) -> SaltQuantity
                      2022-01-16 18:50:07.895 - debug: judoisoft.0 (28347) -> WaterCurrent
                      2022-01-16 18:50:07.897 - debug: judoisoft.0 (28347) -> StandByValue
                      Liegt es an einer neuen Firmware Version, was kann ich tun?
                        arteck Developer Most Active @oranggila last edited by
                        @oranggila sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
                        Cloud Login:
                        mit dem Cloud Login gehts .. so wie ich es sehe laut LOG
                        • O
                          oranggila @arteck last edited by
                          @arteck Ja, aber die Datenpunkte bleiben leer:
                          • O
                            oranggila @oranggila last edited by
                            @oranggila geändert werden nur diese:
                              was passiert hier wenn du das richtig im Browser eingibst
                              also user und psw richtig mit deinne daten
                              • O
                                oranggila @arteck last edited by oranggila
                                @arteck {"group":"register","command":"login","msgnumber":"2","name":"login","user":"<user>","password":"*","role":"customer","status":"error","data":"login failed"}
                                Aber über myjudo.eu kann ich mich anmelden und sehe alle Gerätedaten.
                                arteck O 2 Replies Last reply Reply Quote 0
                                  @oranggila welche Anlage ist es ??
                                  • O
                                    oranggila @oranggila last edited by oranggila
                                    @arteck i-soft plus
                                      @oranggila hast du sonderzeichen im password ??
                                      denn ohne Login können keine Daten abgeholt werden
                                      • O
                                        @arteck Nein, nur Groß- und Kleinbuchstaben + Zahlen. Am PW kann's nicht liegen, denn mit dem gleichen ging es früher.
                                          arteck Developer Most Active @oranggila last edited by arteck
                                          @oranggila ich du musst sicher stellen dass du dich an der Anlage anmelden musst logisch oder.. ohne Login keine Daten
                                          du du einen json zurück bekommst mit login failed machst du was falsch
                                          also mein user ist hier arteck und das psw ist 12345
                                          so muss das aussehen
                                          https://192.168.0.29:8124/?group=register&command=login&msgnumber=2&name=login&user=arteck&password=12345&role=customer
                                          jetzt bitte die Daten auf deine umschreiben also deinen user und psw
                                          • O
                                            @arteck Ja das ist logisch. Ich bin jetzt einen Schritt weiter: Nach dem Firmwareupdate konnte ich am Gerät User/PW nicht erneut eingeben/registrieren. Es kam Fehler: "User ist bereits registriert". Ich habe es jetzt nochmal gemacht, aber anschließend die Datenschutzererklärung abgelehnt. Damit werden die Userdaten am Gerät eingetragen, aber nicht mehr an den Judo Server geschickt und dort aktualisiert. Das hat geklappt und nun kann ich mich wieder lokal einloggen.
                                            Jetzt kommen die Daten wieder. 👍
                                            i-soft judo wasserenthärtung
                                            22
                                            216
                                            23094
