    4. mercedes me 0.0.54 ständige Logouts
      Mediaman2000 @tombox last edited by Mediaman2000
      @tombox
      Heute ist es wieder aufgetreten: 2 neue Tan Mails und folgendes habe ich aus der iobroker Log Datei rausgezogen (Einträge zeitgleich wie das Eintreffen der neuen Tan Mails):
      2021-07-22 13:25:23.273  - error: mercedesme.0 (19812) 504
      2021-07-22 13:25:23.274  - error: mercedesme.0 (19812) "<!DOCTYPE html>\n<html lang=\"en\">\n<head>\n  <style>\n    body {\n      background-color: #eeeeee;\n      padding: 0;\n      margin: 0;\n      visibility: hidden; /* prevent FOUC */\n    }\n  </style>\n  <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n  <meta charset=\"UTF-8\">\n  <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n\n  <link rel=\"apple-touch-icon\" sizes=\"180x180\" href=\"/apple-touch-icon.png\">\n  <link rel=\"icon\" type=\"image/png\" sizes=\"32x32\" href=\"/favicon-32x32.png\">\n  <link rel=\"icon\" type=\"image/png\" sizes=\"16x16\" href=\"/favicon-16x16.png\">\n  <!--<link rel=\"manifest\" href=\"/favicon.webmanifest\">-->\n  <link rel=\"mask-icon\" href=\"/safari-pinned-tab.svg\" color=\"#84bd00\">\n  <meta name=\"msapplication-TileColor\" content=\"#2d89ef\">\n  <meta name=\"theme-color\" content=\"#ffffff\">\n\n  <link href=\"/.error/style.css\" rel=\"stylesheet\">\n\n  <!--[if lt IE 9]>\n\t  <script src=\"https://oss.maxcdn.com/html5shiv/3.7.3/html5shiv.min.js\"></script>\n\t  <script src=\"https://oss.maxcdn.com/respond/1.4.2/respond.min.js\"></script>\n\t<![endif]-->\n\n  <title>500 Server Error</title>\n</head>\n<body>\n  <div id=\"status\">\n    <div class=\"status\">\n      <div class=\"status-code\">\n        <h1>500</h1>\n      </div>\n      <h2>Sorry, we made a mistake.</h2>\n      <img src=\"/.error/background.svg\" />\n    </div>\n  </div>\n</body>\n</html>\n"
      2021-07-22 13:25:23.274  - error: mercedesme.0 (19812) RefreshToken: N4W4oFWfP5F8GfQY0yGC8pmExhKZf32rZ8UACnFPRx
      2021-07-22 13:25:23.275  - error: mercedesme.0 (19812) Refresh Token Failed do a relogin
      2021-07-22 13:25:38.348  - error: mercedesme.0 (19812) 504
      2021-07-22 13:25:38.348  - error: mercedesme.0 (19812) "<!DOCTYPE html>\n<html lang=\"en\">\n<head>\n  <style>\n    body {\n      background-color: #eeeeee;\n      padding: 0;\n      margin: 0;\n      visibility: hidden; /* prevent FOUC */\n    }\n  </style>\n  <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n  <meta charset=\"UTF-8\">\n  <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n\n  <link rel=\"apple-touch-icon\" sizes=\"180x180\" href=\"/apple-touch-icon.png\">\n  <link rel=\"icon\" type=\"image/png\" sizes=\"32x32\" href=\"/favicon-32x32.png\">\n  <link rel=\"icon\" type=\"image/png\" sizes=\"16x16\" href=\"/favicon-16x16.png\">\n  <!--<link rel=\"manifest\" href=\"/favicon.webmanifest\">-->\n  <link rel=\"mask-icon\" href=\"/safari-pinned-tab.svg\" color=\"#84bd00\">\n  <meta name=\"msapplication-TileColor\" content=\"#2d89ef\">\n  <meta name=\"theme-color\" content=\"#ffffff\">\n\n  <link href=\"/.error/style.css\" rel=\"stylesheet\">\n\n  <!--[if lt IE 9]>\n\t  <script src=\"https://oss.maxcdn.com/html5shiv/3.7.3/html5shiv.min.js\"></script>\n\t  <script src=\"https://oss.maxcdn.com/respond/1.4.2/respond.min.js\"></script>\n\t<![endif]-->\n\n  <title>500 Server Error</title>\n</head>\n<body>\n  <div id=\"status\">\n    <div class=\"status\">\n      <div class=\"status-code\">\n        <h1>500</h1>\n      </div>\n      <h2>Sorry, we made a mistake.</h2>\n      <img src=\"/.error/background.svg\" />\n    </div>\n  </div>\n</body>\n</html>\n"
      2021-07-22 13:25:38.348  - error: mercedesme.0 (19812) RefreshToken: N4W4oFWfP5F8GfQY0yGC8pmExhKZf32rZ8UACnFPRx
      2021-07-22 13:25:38.349  - error: mercedesme.0 (19812) No Login possible. Deleting auth tokens. Please enter new email code.
      2021-07-22 13:25:38.349  - error: mercedesme.0 (19812) Relogin failed
      2021-07-22 13:25:38.467  - error: mercedesme.0 (19812) Wrong Sicherheitscode please enter the new code you received via mail
      2021-07-22 13:25:38.468  - error: mercedesme.0 (19812) Error: Request failed with status code 400
      2021-07-22 13:25:38.510  - info: host.iobroker stopInstance system.adapter.mercedesme.0 (force=false, process=true)
      2021-07-22 13:25:38.537  - info: mercedesme.0 (19812) Got terminate signal TERMINATE_YOURSELF
      2021-07-22 13:25:38.541  - info: mercedesme.0 (19812) terminating
      2021-07-22 13:25:38.542  - info: mercedesme.0 (19812) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-07-22 13:25:38.568  - info: host.iobroker stopInstance system.adapter.mercedesme.0 send kill signal
      2021-07-22 13:25:39.209  - info: host.iobroker instance system.adapter.mercedesme.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-07-22 13:25:41.729  - info: host.iobroker instance system.adapter.mercedesme.0 started with pid 16442
      2021-07-22 13:25:44.749  - info: mercedesme.0 (16442) starting. Version 0.0.54 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v12.22.1, js-controller: 3.2.16
      2021-07-22 13:25:46.000  - info: mercedesme.0 (16442) Please enter the code you received via mail in the instance settings
      2021-07-22 13:25:46.001  - error: mercedesme.0 (16442) Login was not successful.
      Mein iobroker läuft ansonsten sehr stabil und starten augenscheinlich auch nicht warlos neu oder sowas...
        @mediaman2000 ich brauch die logs davor da muss irgendwas mit dem adapter passiert sein
        M mickym 2 Replies Last reply Reply Quote 0
          @tombox Ok, ich habe die komplette Logdatei von heute heruntergeladen - wie soll ich sie dir zuspielen?
          • mickym
            mickym Most Active @tombox last edited by
            @tombox Seit ca. 1 Tag scheint die Erneuerung der Tokens nicht mehr zu funktionieren.
            mercedesme.0
            2021-11-27 00:13:54.916	error	Error: Request failed with status code 400
            mercedesme.0
            2021-11-27 00:13:54.915	error	Wrong Sicherheitscode please enter the new code you received via mail
            mercedesme.0
            2021-11-27 00:13:54.780	error	Relogin failed
            mercedesme.0
            2021-11-27 00:13:54.779	error	No Login possible. Deleting auth tokens. Please enter new email code.
            mercedesme.0
            2021-11-27 00:13:54.779	error	RefreshToken: undefined
            mercedesme.0
            2021-11-27 00:13:54.778	error	"{\"error_description\":\"unknown, invalid, or expired refresh token\",\"error\":\"invalid_grant\"}"
            mercedesme.0
            2021-11-27 00:13:54.778	error	400
            mercedesme.0
            2021-11-27 00:13:54.663	error	Refresh Token Failed do a relogin
            mercedesme.0
            2021-11-27 00:13:54.654	error	RefreshToken: undefined
            mercedesme.0
            2021-11-27 00:13:54.654	error	"{\"error_description\":\"unknown, invalid, or expired refresh token\",\"error\":\"invalid_grant\"}"
            mercedesme.0
            2021-11-27 00:13:54.640	error	400
            Jedenfalls gibts dann nach 2 maligem Start wieder einen Code. Den gebe ich ein bis dann die gleiche Fehlermeldung wiederkommt. Die Intervalle sind so ca. 6-7 Stunden.
            • mickym
              mickym Most Active @Mediaman2000 last edited by mickym
              Anscheinend gibt es wieder ein neues Problem. Der Login funktioniert erst, dann
              mercedesme.0
              2022-01-16 19:40:02.620	error	Error getting Vehicles
              mercedesme.0
              2022-01-16 19:40:02.619	error	{"code":404,"message":"path /v1/vehicle/self/masterdata was not found"}
              mercedesme.0
              2022-01-16 19:40:02.617	error	404
              nach ca,. 1 Std. scheint das Token wieder ungültig zu werden.
              Scheint ein allgemeines Problem zu sein:
              https://forum.iobroker.net/topic/51440/mercedes-me-instance-cannot-retrieve-vehicle-data-anymore?_=1642350708417
                tombox @mickym last edited by
                @mickym auf 0.0.56 updaten
                mickym P 2 Replies Last reply Reply Quote 0
                • mickym
                  @tombox sagte in mercedes me 0.0.54 ständige Logouts:
                  OK danke - hab ich gerade gemacht. 🙂
                  Falls es noch Probleme geben sollte, melde ich mich nochmal. Ansonsten wie immer - hier nochmal ein herzliches Dankeschön für den tollen Service.
                    peterredl @tombox last edited by
                    @tombox
                    Kannst du mir bitte weiterhelfen?
                    Ich finde die Version 0.0.56 nicht. Im Beta Verzeichnis ist nur die 0.0.55 und mit der funktioniert es auch nicht mehr.
                    • mickym
                      mickym Most Active @peterredl last edited by
                      @peterredl Du gehst einfachbei Adapter auf Expertenmodus
                      und installierst aus eigener URL Button - alles rot markiert.
                      Dort markierst Du die mittlere Option von GitHib installieren und suchst in dem DropDown den mercedesme Adapter.
                        peterredl @mickym last edited by
                        @mickym
                        DANKE !!!!
                        Hat perfekt funktioniert. Jetzt sind meine Daten wieder verfügbar.
                        Danke nochmals und LG aus Österreich
                          ssond0815 @peterredl last edited by
                          @peterredl danke, bei mir hat es auch funktioniert
                          0.0.54 e-mail logout mercedes me adapter tan
                          791
