    5. Zeitdifferenz berechnen
      paul53 @erazor86 last edited by
      @erazor86 sagte: wo das Problem liegt:
      Poste bitte den Javascript-Code ohne die letzte Zeile in Code tags.
        erazor86 @paul53 last edited by
          <variables>
            <variable id="H_b:)/lk~U=V#?2Fm-_6">Einschaltdauer</variable>
            <variable id="9zZ/z:qt+2ur[Mg(U{^@">Liste</variable>
          </variables>
          <block type="on_ext" id="g10!%+,PQcoL^1CtCc1M" x="-187" y="-487">
            <value name="OID0">
              <shadow type="field_oid" id="1^6dn_Y//1Ld.:S1*pg/">
                <field name="oid">0_userdata.0.Datenpunkte.Rechengrößen.Dauer</field>
              <block type="variables_set" id="jmdG%dMd*=ZRFyjN};FO">
                <field name="VAR" id="H_b:)/lk~U=V#?2Fm-_6">Einschaltdauer</field>
                  <block type="lists_split" id="UrkwL9|$/`pGV6dtQ4=#">
                    <mutation mode="SPLIT"></mutation>
                    <field name="MODE">SPLIT</field>
                    <value name="INPUT">
                      <block type="on_source" id="/tG2*O8M2}DxPJBVce+(">
                    <value name="DELIM">
                      <shadow type="text" id="jddb#N[0ZokH]@uv|$^L">
                        <field name="TEXT">:</field>
                  <block type="variables_set" id="yo,~CC4vFjRQ+!BI[Dj3">
                      <block type="math_arithmetic" id=";{JdB#Q(L~2pI)@VEq]X" inline="false">
                        <field name="OP">ADD</field>
                          <shadow type="math_number" id="3c9}N}KuPq4SPU`Vi.}0">
                            <field name="NUM">1</field>
                          <block type="convert_tonumber" id="6tSv_rtVlamrBt%%sdNk">
                              <block type="lists_getIndex" id="j;YZ-#|;ymc?7Z!/}m`$">
                                  <block type="variables_get" id="*zdTBCpC?k.-sQA7_Jd6">
                                    <field name="VAR" id="9zZ/z:qt+2ur[Mg(U{^@">Liste</field>
                                <value name="AT">
                                  <block type="math_number" id="8e{^1DPK0hDM:M;#X-S2">
                          <shadow type="math_number" id="pL0;D`,uYz`_FzqS0iED">
                          <block type="math_rndfixed" id="dngO+Sv-~SYJ@nbcCD?}">
                            <field name="n">1</field>
                            <value name="x">
                              <shadow type="math_number" id="IkY$?m}d-0oo0[1S/kHE">
                                <field name="NUM">3.1234</field>
                              <block type="math_arithmetic" id="W{h5)61$s9~M5v9,Fi-O">
                                <field name="OP">DIVIDE</field>
                                  <shadow type="math_number" id="]yL|:!R]:vuM,{XmCAR+">
                                  <block type="lists_getIndex" id="}XJb*fL,oH]:}i%XL1@/">
                                      <block type="variables_get" id="}~3#`VQg2s=7HTPvh~,0">
                                    <value name="AT">
                                      <block type="math_number" id="ge_58=bFeMNGFo7bk8`9">
                                        <field name="NUM">2</field>
                                  <shadow type="math_number" id="1mGyZqUY*qCf4zf!K^TZ">
                                    <field name="NUM">60</field>
                      <block type="update" id="Qg5uQ5,C~h#CP}OXp,n|">
                        <field name="OID">0_userdata.0.Datenpunkte.Rechengrößen.Dauer_dezimal</field>
                          <block type="variables_get" id=";*9U=xcn:`{pl^f5-rs,">
          @erazor86
          Tausche an 2 Stellen die Variable Liste gegen Einschaltdauer.
          E B 2 Replies Last reply Reply Quote 0
            🤦 manchmal könnte es so einfach sein.... Vielen Dank.. 🙂
              brofelscher @paul53 last edited by
              ich komme mit meiner Differenzzeit in Minuten ebenfalls nicht weiter. Ich versuche die Zeitdifferenz zwischen "Jetzt" und der letzten Aktualisierung eines Datenpunktes in Minuten zu errechnen und diese in den Datenpunkt "AbwesendSeitMinuten" zu schreiben.
              Das folgende Blockly funktioniert bis 59 Minuten prima, alles darüber hinaus funktioniert jedoch nicht. Es werden also zum Beispiel nicht 67 Minuten Differenz dargestellt, sondern nur "7". Die restlichen 60 Minuten verschwinden.
                <block type="comment" id="vdO3Z/b-^J_@l)?Eq_R+" x="13" y="38">
                  <field name="COMMENT">Abwesenheitszeit berechnen</field>
                    <block type="on" id="-Se3D{`):B`]p/=p_aOI">
                      <field name="OID">fb-checkpresence.0.presentCount</field>
                        <block type="controls_if" id="g$$Mh+_gT[pE?%~wmOw7">
                            <block type="logic_compare" id="B~cGcXi@sZ~Vuxeg9NrH">
                              <field name="OP">EQ</field>
                                <block type="get_value" id="Ra3xND;{0=Gx-[pw@??P">
                                <block type="text" id="|2l5jEGj$arki%U@aI1*">
                                  <field name="TEXT">0</field>
                            <block type="update" id="fO*d3{jQ-Q,Muo5?^aHF">
                              <field name="OID">0_userdata.0.AbwesendSeitMinuten</field>
                                <block type="convert_from_date" id="xF2Wqp~s/~y5PUaC_;7^">
                                  <field name="OPTION">m</field>
                                    <block type="math_arithmetic" id="{)*krPx!rRWcV.lMNvs9">
                                        <shadow type="math_number" id="rD[[`+/pH}Z,=`RaZDKb">
                                        <block type="time_get" id="{YtxVX%(xd!aZrGPIR%/">
                                          <field name="OPTION">object</field>
                                        <shadow type="math_number" id="U}:)~D1u/;(DT4d+kNZM">
                                        <block type="get_value" id="}D,-3Ku3mkH){l1UJ|o?">
                                          <field name="ATTR">lc</field>
                paul53 @brofelscher last edited by
                @brofelscher sagte: Blockly funktioniert bis 59 Minuten prima
                Das sind die Minuten der Uhrzeit.
                Vorschlag:
                                 <block type="math_round" id="jh5X6wfE6}koDRuR}h,7">
                                   <field name="OP">ROUND</field>
                                   <value name="NUM">
                                     <shadow type="math_number" id="dsl{1yg*UVLul@F2*}_x">
                                       <field name="NUM">3.1</field>
                                     <block type="math_arithmetic" id="CG|Sg`nEt;fkO/q}:-Eg">
                                         <shadow type="math_number" id="r16alN.iyJ)%|~KKF{p5">
                                             <block type="on_source" id="75tkb;IKslfqIl;1JyN#">
                                               <field name="ATTR">oldState.lc</field>
                                         <shadow type="math_number" id="7o1So,{6-3V~;lGxE-;P">
                                           <field name="NUM">60000</field>
                  @paul53 said in Zeitdifferenz berechnen:
                  Vorschlag:
                  Hi, dein Vorschlag passt perfekt 🙂 Danke dir.
                  Ich habe wohl die Funktion "Minuten" missverstanden, da ich für die Minuten auch die Formatierung "mm" hätte nutzen können.
                  Und wieder ist man ein wenig schlauer 🙂
                    Ich habe wieder eine neue Aufgabenstellung bzgl. Zeitverrechnung. Diesmal möchte ich die mittlere Außentemperatur der letzten 3h berechnen. Ich habe hierzu mal ein Blockly erstellt. Jedoch ist es nicht ganz korrekt, da die durchschnittliche Temp nur alle 3h neu berechnet wird. Habe es leider nicht hinbekommen wie ich es gerne hätte. Vielleicht hat jemand einen Tip?
                      paul53 @erazor86 last edited by paul53
                      @erazor86 sagte: Vielleicht hat jemand einen Tip?
                      Suche mal im Forum nach "gleitender Mittelwert".
                        Strobi @paul53 last edited by
                        Guten Abend,
                        leider funktioniert die Zeitberechnung so leider nicht.
                        Ich würde gerne immer die Zeitdifferenz bis zum nächsten Sonnenaufgang berechnen.
                        Also 1h vor dem Sonnenaufgang müsste 1h rauskommen, eine Stunde nach dem Sonnenaufgang müsste 23h rauskommen.
                        Mit folgendem Blockly kommt aber leider gar nichts raus:
                        Hat vielleicht jemand eine Idee, wie ich das hinbekommen könnte?
                        Besten Dank!
                          paul53 @Strobi last edited by paul53
                          @strobi sagte eine Stunde nach dem Sonnenaufgang müsste 23h rauskommen.
                          Nein, dann kommt am gleichen Tag ein negativer Wert raus. Teste die Berechnung erst mal mit dem Debug-Block.
                          Der Datenpunkt scheint keinen Zustand zu haben. Ist es der richtige DP? Das Skript ist aktiv, nicht unter der Gruppe "global" erstellt und der Debug-Modus (rechts oben) ist deaktiviert?
                          Für positive Werte:
                            So geht es - falls es noch jemanden interessiert - Zeitspanne bis zum nächsten Sonnenaufgang 🙂
                            • JB_Sullivan
                              JB_Sullivan last edited by
                              Auch wenn dieser Thread schon "100 Jahre" alt ist, würde ich mich gerne mit meiner Frage hier anschließen, da es sich ebenfalls um eine "Zeit berechnen" Frage handelt.
                              Konkrete Problemstellung:
                              Ich habe zwei Datenpunkte - einmal die Zeit als UTC und dann den Lokalen Korrekturfaktor +2 Std. (CET)
                              Wie kann ich den vorhandenen DP, welcher so aussieht 2022-10-25T13:23:32Z nun um + 2 Stunden hoch addieren?
                              Das hier funktioniert jedenfalls nicht 😞
                              • haus-automatisierung
                                haus-automatisierung Developer Most Active @JB_Sullivan last edited by haus-automatisierung
                                @jb_sullivan sagte in Zeitdifferenz berechnen:
                                Du willst nichts addieren. Du willst den Zeitstempel nur anders formatieren (für unsere Zeitzone). Der Zeitpunkt bleibt ja genau der gleiche. Wäre ja falsch, da nun Stunden drauf zu schlagen.
                                Das "Z" am Ende deiner Zeitangabe steht für "Zulu". Das heißt, das ist UTC. Wenn Du das nun also in die gängigen Datumsfunktionen gibst, dann wissen die schon damit umzugehen. Wenn man den Zeitpunkt nun also formatiert, dann wird die Zeitzone des Betriebssystems berücksichtigt:
                                Ergibt: 25.10.2022. 15:23:32
                                  <variables>
                                    <variable id=",cJDM_Be,aiY)MRh{R/}">timeStamp</variable>
                                  </variables>
                                  <block type="variables_set" id="#s#G]QUKK_14+DT$P.$@" x="-587" y="262">
                                    <field name="VAR" id=",cJDM_Be,aiY)MRh{R/}">timeStamp</field>
                                      <block type="convert_to_date" id="k=w+o:B(w6`jJMabP~b[">
                                          <block type="text" id="r6t?3L$0}/3s`fDw`eh7">
                                            <field name="TEXT">2022-10-25T13:23:32Z</field>
                                      <block type="debug" id="00=-ftF0Y@P^A7$W/(F?">
                                        <value name="TEXT">
                                          <shadow type="text" id="#=,ZXQ_{QyO-CuYT@KRn">
                                          <block type="convert_from_date" id="Ou5k{iL@;t`k5bxyQ^,S">
                                            <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                                            <field name="OPTION">custom</field>
                                            <field name="FORMAT">TT.MM.JJJJ. SS:mm:ss</field>
                                              <block type="variables_get" id="=OC%5Yj^4Ki#Oc,(S1m/">
                                EDIT: So gehts sogar noch einfacher
                                Aber: Wenn Du ein Datum/Zeitpunkt als Wert in einem Datenpunkt speichern möchtest, dann ist UTC dafür ebenfalls korrekt. In dem Fall setzt Du die Rolle auf date und der Admin stellt den Wert dann "richtig" (heißt: in Deiner Zeitzone formatiert) dar:
                                • JB_Sullivan
                                  JB_Sullivan @haus-automatisierung last edited by JB_Sullivan
                                  Naja, den Datenpunkt als UTC gibt es ja. Verstehe ich das richtig, das ich nur die Rolle ändern muss? Also in den Objektdaten von "indicator" in "date", damit nicht UTC sondern die Systemzeit ausgegeben wird?
                                    "type": "state",
                                    "common": {
                                      "name": "timeInCar",
                                      "role": "indicator",
                                      "type": "string",
                                      "write": false,
                                      "read": true
                                    "native": {},
                                    "from": "system.adapter.vw-connect.0",
                                    "user": "system.user.admin",
                                    "ts": 1665834213369,
                                    "_id": "vw-connect.0.FIN.status.air-conditioning.timers.timeInCar",
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                      "owner": "system.user.admin",
                                    Theoretisch ja, laut Dokumentation wird die Rolle date für number und string unterstützt: https://www.iobroker.net/#en/documentation/dev/stateroles.md
                                    • date (common.type = string - parsable by "new Date(ddd)" string
                                    • date (common.type = number - epoch seconds * 1000
                                    Aber ersteres funktioniert im Admin aktuell nicht. Habe einen Issue aufgemacht:
                                    https://github.com/ioBroker/ioBroker.admin/issues/1770
                                    Und: Ich würde davon abraten, die Rollen von Datenpunkten anzupassen, welche man nicht selbst erstellt hat!
                                    Ein Alias wäre hier eine gute Lösung. Type number, role date und beim Lesen einfach die Funktion einfügen: new Date(val).getTime()
                                      "common": {
                                        "name": "test",
                                        "desc": "Manuell erzeugt",
                                        "role": "date",
                                        "type": "number",
                                        "read": true,
                                        "write": true,
                                        "def": 0,
                                        "alias": {
                                          "id": "vw-connect.0.FIN.status.air-conditioning.timers.timeInCar",
                                          "read": "new Date(val).getTime()"
                                      "type": "state",
                                      "native": {},
                                      "_id": "alias.0.test",
                                      "acl": {
                                        "object": 1632,
                                        "state": 1636,
                                      "ts": 1666775968588
                                    Die Frage ist nach wie vor: Was hast Du denn vor? Es ändert sich im Admin ja nur die Anzeige, wenn man die Rolle setzt. Der gespeicherte Wert bleibt genau der gleiche...
                                    klein0r created this issue in ioBroker/ioBroker.admin
                                    closed Role "date" is ignored when common.type is string #1770
                                    • JB_Sullivan
                                      @haus-automatisierung sagte in Zeitdifferenz berechnen:
                                      Der Adapter liefert die Uhrzeit des Fahrzeugs in UTC und zusätzlich den lokalen (CET) Anpassungsfaktor +2
                                      Das Fahrzeug gibt die Geoposition aus und damit ich in der VIS sehe wie aktuell diese Geoposition ist, blende ich mir den diesen "Zeitstempel" Datenpunkt mit in die VIS ein. Klar kann ICH auch jedesmal im Kopf die 2 Stunden dazu rechnen.
                                      Damit ist aber dem WAF-Faktor leider nicht genüge getan 😉 Darum wollte ich den Datenpunkt so umwandeln das ein neuer, zeitlich korrekter DP entsteht, den ich dann in die VIS verknüpfe.
                                        Verstehe. Korrekt sind ja die UTC-Zeitpunkte ja auch 🙂
                                        Das ist meiner Meinung nach die Aufgabe des Frontends (also VIS). Es wäre in jedem Fall richtig, den Datenpunkt in UTC zu speichern (als string so wie er aktuell schon da ist oder number, siehe Alias im vorigen Beitrag) und diesen dann im Frontend von VIS auf die lokale Zeitzone umrechnen zu lassen.
                                        Eine Datenbank sollte Zeitstempel immer in UTC speichern (wie das Forum hier z.B. auch). Und dann erst bei der Darstellung den Zeitstempel für den User darstellen.
                                        Dafür gibt es doch z.B. das Widget TimesValue. Da einfach den Datenpunkt mit dem UTC-Zeitstempel wählen und das Format DD.MM.YYYY hh:mm:ss eintragen. Fertig. Keine Scripts, keine neuen Datenpunkte, keine Rechnerei.
                                        JB_Sullivan 1 Reply Last reply Reply Quote 1
                                        • JB_Sullivan
                                          @haus-automatisierung VIELEN DANK das wir drüber gesprochen haben 😉
                                          Tja wenn man immer alles wüsste was geht, bräuchte man sich nicht den Kopf zu zerbrechen, wie man dieses oder jenes von"hinten durchs Auge" gelöst bekommt.
                                          Also nochmals vielen Dank für deine Zeit und die Erklärungen 👍👍
                                          • hg6806
                                            hg6806 Most Active last edited by
                                            zu dem Thema hätte ich auch eine Frage.
                                            Und zwar habe ich eine Zeitdifferenz berechnet. Die ms stimmen soweit.
                                            16482933ms sind umgerechnet ca. 46h
                                            Mit dem folgenden Blockly bekomme ich aber nur 22:57?
                                            blockly
                                            20
                                            106
                                            19706
