    4. Tr-064 Adapter Fehler
    • V
      vore last edited by
      > Es bringt nichts, mit uralter Version ein issue zu machen. Es gibt nämlich schon 0.1.27.
      Sorry.. das war zu diesem Zeitpunkt die Version die ich installieren konnte. Es gab nichts neueres..
      Vore
        stephan61 last edited by
        habe den adapter mit version 0.1.29 installiert und bekomme folgende Fehler im log
        wenn ich auf geräte suche gehe
        host.	2017-01-23 17:05:19.824	error	at JavascriptRedisParser.Parser.returnReply (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:192:18)
        host.	2017-01-23 17:05:19.824	error	at RedisClient.return_reply (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:828:9)
        host.	2017-01-23 17:05:19.824	error	at return_pub_sub (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:789:18)
        host.	2017-01-23 17:05:19.824	error	at RedisClient.emit (events.js:175:7)
        host.	2017-01-23 17:05:19.824	error	at emitThree (events.js:97:13)
        host.	2017-01-23 17:05:19.824	error	at RedisClient. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:94:25)
        host.	2017-01-23 17:05:19.824	error	at that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2839:41)
        host.	2017-01-23 17:05:19.824	error	at Object.options.message (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1091:26)
        host.	2017-01-23 17:05:19.824	error	at Object.onMessage (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:76:25)
        host.	2017-01-23 17:05:19.824	error	at TR064.forEachHostEntry (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:261:15)
        host.	2017-01-23 17:05:19.824	error	TypeError: Cannot read property 'actions' of undefined
        host.	2017-01-23 17:05:19.820	error	pmessage messagebox.system.adapter.tr-064.0 {"command":"discovery","message":5000,"from":"system.adapter.admin.0","callback":{"message":5000,"id":12,"ack":false,"time":1485187519815},"_id":1225833} C
        Gruß Stephan
        geändert: Code in Code-Tags Homoran (Admin)
          DrFirebird last edited by
          Bekomme genau den gleichen Fehler.
          Liegt es wohl an der 7490 ?
            Strizz last edited by
            @DrFirebird:
            Liegt es wohl an der 7490 ? `
            ich hatte auch große Probleme, den Adapter ans Laufen zu bekommen. Hat bei mir erst dann funktioniert, nachdem ich in den Settings alle Häkchen - bis auf Watch devices - entfernt habe. Jetzt läuft er immerhin seit zwei Tagen problemlos.
            Strizz
            Gesendet von iPad mit Tapatalk Pro
              😄 mit der Einstellung scheint es zu funktionieren.
              Jetzt kann ich zumindest das Gäste WLAN ein-/ausschalten.
                jawr last edited by
                ich habe Probleme den Adapter überhaupt zu starten, das Log sagt folgendes
                host.odroid-jessie64	2017-03-27 09:47:10.040	info	Restart adapter system.adapter.tr-064.0 because enabled
                host.odroid-jessie64	2017-03-27 09:47:10.040	error	instance system.adapter.tr-064.0 terminated with code 1 ()
                host.odroid-jessie64	2017-03-27 09:47:08.352	info	instance system.adapter.tr-064.0 started with pid 16334
                host.odroid-jessie64	2017-03-27 09:46:38.334	info	Restart adapter system.adapter.tr-064.0 because enabled
                host.odroid-jessie64	2017-03-27 09:46:38.331	error	instance system.adapter.tr-064.0 terminated with code 1 ()
                In den Optionen habe ich nur "Prüfen angemeldete Geräte" aktiviert. Mir ist ehrlich gesagt nicht ganz klar ob man einen Benutzer in den Einstellungen eintragen muss. Beim Login in die Fritzbox ist ja nur eine Passwrtabfrage. Ist hier ein Benutzer einzutragen, wenn ja, welcher?
                Gruß,
                jawr
                • Bluefox
                  Bluefox last edited by
                  @jawr:
                  Gruß,
                  jawr `
                  Ich denke "admin"
                    jawr last edited by
                    admin habe ich versucht, funktioniert nicht. Ich gehe ja auch mal davon aus der Adapter bei erfolglosem Login eine entsprechende Rückmeldung in das Logfile schreibt. Ich gehe aber eher davoin aus das der Loginversuch erst gar nicht ausgeführt wird wenn ich mir die Logeinträge so ansehe.
                    Gruß,
                    jawr
                    • eric2905
                      eric2905 last edited by
                      Ich schaue heute Abend mal nach, was ich eingetragen habe - bei mir läuft der Adapter.
                      Gruß,
                      Eric
                      Von unterwegs getippert
                      • andre
                        andre Developer last edited by
                        @jawr:
                        Gruß,
                        jawr `
                        Eventuell musst du die Anmeldung an der Fritzbox auf "Benutzername und Kennwort" ändern (Unter System > Fritzbox-Benutzer > Anmeldung im Heimnetz). Ich habe bei mir einen separaten Benutzer angelegt. Diesen nutzt auch nur der Adapter. Mein Adapter läuft einwandfrei mit allen Features "enabled".
                        MfG,
                        André
                          jawr last edited by
                          ich habe das mal probiert und einen Benutzer erstellt und die Anmeldung in der Fritzbox an genannter Stelle geändert. Leider ohne Erfolg. Ich gehe noch immer davon aus das es ein Problem an anderer Stelle liegt und die Anmeldung gar nicht erst erfolgt. Kann man den Adapter von der Konsole starten und erhält so evtl. mal mehr Infos?
                          Edit: So wie ich das interpretiere sind die Log Einträge doch vom iobroker controller und nicht vom adapter tr-046, würde ja bedeuten Dax der Adapter gar nichts in das log schreibt, also gar nicht erst startet.
                          Gruß,
                          jawr
                          • eric2905
                            Ich habe keinen dedizierten Benutzer angelegt und gebe beim User (bei mir) "eric" an und als Passwort das auf der Fritte definierte Passwort.
                            Hast Du unter Wählhilfe die entspr. Einstellungen gemacht?
                            Es gibt einen Thread bzgl. bestimmte Telefone klingeln zu lassen und dort kommt der Hinweis, das es nur funktioniert, wenn diese Konfig auf der Fritte sauber ist.
                            Gruß,
                            Eric
                              jawr last edited by
                              Das bezieht sich so wie ich das sehe nur auf das Klingeln der Telefone. Der Adapter sollte auch so laufen. Nochmal die Frage: Gibt es über die Konsole die Möglichkeit mal mehr über den Fehler zu erfahren?
                              Gruß,
                              jawr
                                SirKimba last edited by
                                Hallo Ihr,
                                erstmal vielen Dank für den klasse Adapter.
                                Eine Instanz alleine funktioniert bei mir prima.
                                Jede Weitere Instanz, natürlich auf eine andere Fritzbox (ich habe im Moment 3 davon) schlägt fehlt, also geht auf grün, dann rot und das ganze noch 2 mal.
                                Als Meldung bekomme ich:
                                tr-064.2 2017-04-07 18:49:20.933 info terminating
                                tr-064.2 2017-04-07 18:49:20.933 error at Timer.listOnTimeout (timers.js:92:15)
                                tr-064.2 2017-04-07 18:49:20.933 error at updateAll [as _onTimeout] (D:\ioBroker\node_modules\iobroker.tr-064\tr-064.js:841:17)
                                tr-064.2 2017-04-07 18:49:20.933 error at TR064.setABIndex (D:\ioBroker\node_modules\iobroker.tr-064\tr-064.js:273:10)
                                tr-064.2 2017-04-07 18:49:20.933 error TypeError: this.getABInfo is not a function
                                tr-064.2 2017-04-07 18:49:20.933 error uncaught exception: this.getABInfo is not a function
                                tr-064.2 2017-04-07 18:49:18.925 warn Phonebook not supported
                                tr-064.2 2017-04-07 18:49:18.816 info starting. Version 0.3.12 in D:/ioBroker/node_modules/iobroker.tr-064, node: v4.3.1
                                Ich habe die Vermutung das es irgendwie an meiner Fritzbox liegt.
                                Szenario:
                                Adapter .0 geht auf Fritzbox0 (7390 v 06.83) - Dieser funktioniert
                                Adapter .2 geht auf Fritzbox2 (7390 v 06.83)- Dieser schlägt fehlt
                                Schalte ich nun .0 ab und wechsele in .2 auf die IP von Fritzbox0, so funktioniert dieser wieder einwandfrei nach dem aktivieren.
                                • In beiden Adaptern sind bei den Checkboxes defaults
                                • Benutzer sind identisch.
                                • Wahlhilfe ist eingestellt
                                • Sicherheitsabfrage ist abgestellt
                                …. oder es liegt irgendwie daran das keine 2 oder n Instanzen parallel laufen können?
                                Hat einer von Euch eine Idee was es sein könnte ?
                                Ich bin für Hilfe echt dankbar 🙂
                                LG Kai
                                • eric2905
                                  Was passiert denn, wenn Du beide Adapter auf die Fritzbox0 jagst?
                                  Gruß,
                                  Eric
                                    @eric2905:
                                    Gruß,
                                    Eric
                                    Von unterwegs getippert `
                                    Krass …. Gut, meine Theorie das 2 Adapter nicht nebeneinander laufen können stimmt nicht.
                                    Also wenn ich beide Adapter auf fritzbox0 zeigen lasse, funktionieren beide einwandfrei.
                                    Okay, dann verhärtet sich der Verdacht das etwas mit fritzbox2 nicht stimmt.
                                    Ich habe beide Setups soweit verglichen und abgesehen von MSN, Telefonbuch, MAC und WLAN sind sie identisch. Ich mag nicht ausschließen das ich etwas übersehen habe.
                                    Mal so grundsätzlich gefragt: Gibt es Settings auf der FB die ein "must have" sind damit der Adapter läuft ?
                                    @Eric: Thx für diesen Denkanstoß
                                    LG Kai
                                      Ein kurzes Update:
                                      ich konnte mein Problem lösen. Der Fehler saß, wie so oft, vor der Tastatur.
                                      In der Fritzbox, mit der sich keine Adapter verbinden wollte, hatte ich eine Einstellung übersehen.
                                      Unter "Heimnetzwerk/Heimnetzwerkübersicht/Netzwerkeinstellungen" war der Haken bei "Zugriff für Anwendungen zulassen" nicht gesetzt.
                                      Das hatte dann zur Folge das diese komische Meldung ausgegeben wurde.
                                      LG und danke
                                      Kai
                                      • 0
                                        0018 last edited by
                                        auch bei mir startet der Adapter nun nicht mehr, ich vermute es hängt mit dem Update des Adapters oder meiner FB7490 (6.83) zusammen?
                                        Folgender Log:
                                        tr-064.0	2017-04-11 13:58:54.888	error	code=unknown error code Device responded with fault Error: Credentials incorrect
                                        tr-064.0	2017-04-11 13:53:51.162	error	code=500 sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 500
                                        tr-064.0	2017-04-11 13:53:43.681	info	starting. Version 0.3.12 in /opt/iobroker/node_modules/iobroker.tr-064, node: v4.7.3
                                        hat jemand hierzu eine Idee?
                                        Mfg
                                        • 0
                                          0018 last edited by
                                          Neuinstallation brachte auch keinen Erfolg. Fehler bleibt bestehen.
                                          jemand eine Idee was das bedeutet und wie ich das beheben kann?
                                          Mfg
                                          • eric2905
                                            @0018:
                                            jemand eine Idee was das bedeutet und wie ich das beheben kann? `
                                            hast Du Dir den Thread mal durchgelesen und die Tipps, die zu finden sind, mal ausprobiert?
                                            Gruß,
                                            Eric
                                            81.1k
                                            90
                                            22294
