    4. Alpha Testing: OCPP Wallbox Adapter
      fL4sH 0 @foxriver76 last edited by fL4sH 0
      @foxriver76 Hallo, super Adapter den du da entwickelt hast, danke dafür. Ich konnte den Adapter heute mit meiner ABB Terra AC Wallbox verbinden und er funktioniert auch. Nur leider kann man das Chargelimit nicht setzen und Availability ist ohne Funktion. Der Wert
      der MeterValue ist bei der ABB Terra AC (lt. der App ChargeSync) die Spannung von L1 in V nicht in Wh.
      Ich hoffe die Entwicklung geht noch weiter und ich kann vllt ein bisschen dazu beitragen. Anbei noch OCPP Unterlagen von der ABB Terra AC.
      Terra.AC.OCPP.1.6.Implementation.overview._v1.5.-.external.pdf
      Wenn ich noch was testen soll und kann, würde ich das gerne machen.
      Hier ist sind noch Daten aus dem Log.
      Die Werte werden alle mitgegeben.
      2022-01-18 20:00:50.625	debug	{"connectorId":1,"transactionId":1,"meterValue":[{"timestamp":"2022-01-18T19:00:50.000Z","sampledValue":
      [{"value":"229.60","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L1-N","unit":"V"},
      {"value":"9.57","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L1","unit":"A"},
      {"value":"2170","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L1","unit":"W"},
      {"value":"229.90","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L2-N","unit":"V"},
      {"value":"9.54","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L2","unit":"A"},
      {"value":"2163","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L2","unit":"W"},
      {"value":"232.40","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L3-N","unit":"V"},
      {"value":"0.0","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L3","unit":"A"},
      {"value":"0","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L3","unit":"W"},
      {"value":"176","context":"Sample.Periodic","format":"Raw","measurand":"Energy.Active.Import.Register","unit":"Wh"},
      {"value":"10","context":"Sample.Periodic","format":"Raw","measurand":"Current.Offered","unit":"A"}]}],
      "commandOcpp":"MeterValues"}
      ocpp.0
      Dieser Daten werden abgesetzt wenn man das Chargelimit auf 6A setzt.
      Sending RemoteStartTransaction for /TACW1142021G1020: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":1,"chargingProfilePurpose":"TxProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":6}]}}}
      Gruß Tobias
      • foxriver76
        foxriver76 Developer @fL4sH 0 last edited by
        @fl4sh-0 cool die Meter values kann ich bei Gelegenheit einbauen gerne GitHub issue machen.
        Für das ändern des Limits, ich habe da bei mir nur bei inaktiven Ladevorgang getestet und da hat es funktioniert, wie hast du es getestet?
          @foxriver76 said in Alpha Testing: OCPP Wallbox Adapter:
          Das mit den MeterValues wäre mega cool wenn das klappen würde. Werde mich mal bei GitHub anmelden und ein Issue aufmachen.
          Das Limit habe ich bisher nur während eines Ladevorgangs im iobroker geändert und das hatte keine Auswirkung.
          In der App konnte ich das Limit während eines Ladevorgangs ändern und das funktioniert auch.
          Bei einem inaktiven Ladevorgang habe ich es bisher noch nicht getestet, werde ich aber bei Gelegenheit mal versuchen.
            Das Limit wird bei der ABB über Chargelimit nicht berücksichtigt. Ich habe alle Varianten durchgespielt.
            Inaktiven Ladevorgang -> Stecker nicht gesteckt
            Inaktiven Ladevorgang ->Stecker gesteckt
            Der eingestellte Wert im iobroker wird nicht übernommen.
            Anschließend habe ich noch mal den Wert in der App geändert um eine Veränderung im Log zu sehen und der letzte Wert der MeterValue ist der eingestellte ladestrom aus der App.
            v5.2.3
            0
            Log-Größe: 835.3 KB
            ocpp.0
            Zeit
            debug
            Nachricht
            ocpp.0
            2022-01-18 22:04:56.747	warn	Client "/TACW1142021G1020" timed out
            ocpp.0
            2022-01-18 22:03:26.747	info	Received Status Notification from "/TACW1142021G1020": Available
            ocpp.0
            2022-01-18 22:03:26.747	debug	{"connectorId":1,"errorCode":"NoError","info":"null","status":"Available","vendorErrorCode":"0x00","commandOcpp":"StatusNotification"}
            ocpp.0
            2022-01-18 22:03:19.606	info	Received stop transaction from "/TACW1142021G1020"
            ocpp.0
            2022-01-18 22:03:19.606	debug	{"meterStop":113,"idTag":"1","timestamp":"2022-01-18T21:03:17.000Z","transactionId":1,"reason":"Remote","commandOcpp":"StopTransaction"}
            ocpp.0
            2022-01-18 22:03:19.106	info	Received Status Notification from "/TACW1142021G1020": Finishing
            ocpp.0
            2022-01-18 22:03:19.105	debug	{"connectorId":1,"errorCode":"NoError","info":"null","status":"Finishing","vendorErrorCode":"0x00","commandOcpp":"StatusNotification"}
            ocpp.0
            2022-01-18 22:03:17.744	debug	Received heartbeat from "/TACW1142021G1020"
            ocpp.0
            2022-01-18 22:03:17.744	debug	{"commandOcpp":"Heartbeat"}
            ocpp.0
            2022-01-18 22:03:17.245	info	Received Status Notification from "/TACW1142021G1020": SuspendedEV
            ocpp.0
            2022-01-18 22:03:17.245	debug	{"connectorId":1,"errorCode":"NoError","info":"null","status":"SuspendedEV","vendorErrorCode":"0x00","commandOcpp":"StatusNotification"}
            ocpp.0
            2022-01-18 22:03:14.759	debug	Sending RemoteStopTransaction for /TACW1142021G1020
            ocpp.0
            2022-01-18 22:02:55.293	info	Received MeterValues from "/TACW1142021G1020"
            ocpp.0
            2022-01-18 22:02:55.292	debug	{"connectorId":1,"transactionId":1,"meterValue":[{"timestamp":"2022-01-18T21:02:53.000Z","sampledValue":[{"value":"229.40","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L1-N","unit":"V"},{"value":"9.61","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L1","unit":"A"},{"value":"2175","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L1","unit":"W"},{"value":"229.90","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L2-N","unit":"V"},{"value":"9.56","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L2","unit":"A"},{"value":"2169","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L2","unit":"W"},{"value":"231.90","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L3-N","unit":"V"},{"value":"0.0","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L3","unit":"A"},{"value":"0","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L3","unit":"W"},{"value":"86","context":"Sample.Periodic","format":"Raw","measurand":"Energy.Active.Import.Register","unit":"Wh"},{"value":"10","context":"Sample.Periodic","format":"Raw","measurand":"Current.Offered","unit":"A"}]}],"commandOcpp":"MeterValues"}
            ocpp.0
            2022-01-18 22:02:23.367	info	Received MeterValues from "/TACW1142021G1020"
            ocpp.0
            2022-01-18 22:02:23.367	debug	{"connectorId":1,"transactionId":1,"meterValue":[{"timestamp":"2022-01-18T21:02:21.000Z","sampledValue":[{"value":"229.20","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L1-N","unit":"V"},{"value":"9.61","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L1","unit":"A"},{"value":"2174","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L1","unit":"W"},{"value":"229.60","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L2-N","unit":"V"},{"value":"9.57","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L2","unit":"A"},{"value":"2168","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L2","unit":"W"},{"value":"231.90","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L3-N","unit":"V"},{"value":"0.0","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L3","unit":"A"},{"value":"0","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L3","unit":"W"},{"value":"47","context":"Sample.Periodic","format":"Raw","measurand":"Energy.Active.Import.Register","unit":"Wh"},{"value":"10","context":"Sample.Periodic","format":"Raw","measurand":"Current.Offered","unit":"A"}]}],"commandOcpp":"MeterValues"}
            ocpp.0
            2022-01-18 22:01:51.432	info	Received MeterValues from "/TACW1142021G1020"
            ocpp.0
            2022-01-18 22:01:51.431	debug	{"connectorId":1,"transactionId":1,"meterValue":[{"timestamp":"2022-01-18T21:01:50.000Z","sampledValue":[{"value":"228.70","context":"Transaction.Begin","format":"Raw","measurand":"Voltage","phase":"L1-N","unit":"V"},{"value":"10.62","context":"Transaction.Begin","format":"Raw","measurand":"Current.Import","phase":"L1","unit":"A"},{"value":"2403","context":"Transaction.Begin","format":"Raw","measurand":"Power.Active.Import","phase":"L1","unit":"W"},{"value":"229.00","context":"Transaction.Begin","format":"Raw","measurand":"Voltage","phase":"L2-N","unit":"V"},{"value":"10.58","context":"Transaction.Begin","format":"Raw","measurand":"Current.Import","phase":"L2","unit":"A"},{"value":"2396","context":"Transaction.Begin","format":"Raw","measurand":"Power.Active.Import","phase":"L2","unit":"W"},{"value":"231.80","context":"Transaction.Begin","format":"Raw","measurand":"Voltage","phase":"L3-N","unit":"V"},{"value":"0.0","context":"Transaction.Begin","format":"Raw","measurand":"Current.Import","phase":"L3","unit":"A"},{"value":"0","context":"Transaction.Begin","format":"Raw","measurand":"Power.Active.Import","phase":"L3","unit":"W"},{"value":"0","context":"Transaction.Begin","format":"Raw","measurand":"Energy.Active.Import.Register","unit":"Wh"},{"value":"11","context":"Transaction.Begin","format":"Raw","measurand":"Current.Offered","unit":"A"}]}],"commandOcpp":"MeterValues"}
            ocpp.0
            2022-01-18 22:01:42.405	info	Received Start transaction from "/TACW1142021G1020"
            ocpp.0
            2022-01-18 22:01:42.404	debug	{"connectorId":1,"idTag":"1","meterStart":0,"timestamp":"2022-01-18T21:01:40.000Z","commandOcpp":"StartTransaction"}
            ocpp.0
            2022-01-18 22:01:41.903	info	Received Status Notification from "/TACW1142021G1020": Charging
            ocpp.0
            2022-01-18 22:01:41.902	debug	{"connectorId":1,"errorCode":"NoError","info":"null","status":"Charging","vendorErrorCode":"0x00","commandOcpp":"StatusNotification"}
            ocpp.0
            2022-01-18 22:01:41.403	info	Received Status Notification from "/TACW1142021G1020": SuspendedEV
            ocpp.0
            2022-01-18 22:01:41.402	debug	{"connectorId":1,"errorCode":"NoError","info":"null","status":"SuspendedEV","vendorErrorCode":"0x00","commandOcpp":"StatusNotification"}
            ocpp.0
            2022-01-18 22:01:40.892	debug	Sending RemoteStartTransaction for /TACW1142021G1020: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":1,"chargingProfilePurpose":"TxProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":8}]}}}
            • foxriver76
              @fl4sh-0 habe die meterValues eingebaut mit 0.3.0 den alten meterValue State bitte manuell löschen.
              Dass die Ladeleistung bei den ABB Boxen nicht angezogen wird kann ich nicht ganz nachvollziehen, weiß aktuell leider nicht woran es liegt
                @foxriver76
                Ach mega cool! Das ging schnell und funktioniert. Vielen Dank.
                  Ich habe noch mal ein bisschen mit dem Ladelimit getestet. Das stand im Log:
                  ocpp.0
                  2022-01-19 07:28:25.519	debug	Sending RemoteStartTransaction for /TACW1142021G1020: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":1,"chargingProfilePurpose":"TxProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":8}]}}}
                  ocpp.0
                  2022-01-19 07:27:46.152	debug	Sending SetChargingProfile for /TACW1142021G1020
                  Gesendet wird das SetChargingProfile auch und wenn anschließend die Transaktion gestartet wird, sendet er auch einige Daten. Was ich mich nur frage warum startSchedule":"2013-01-01T00:00Z diesen Zeitstempel hat?
                  Hier sind noch Auszüge aus der Ocpp Dokumentation der ABB.
                  Vielleicht kannst du damit ja was anfangen und es hilft dir weiter.
                  • foxriver76
                    @fl4sh-0
                    Ist der example Zeitstempel aus der OCPP Doku um das zu bewirken.
                    Was ich noch sehe bei dir Max Stack Level 0 wir setzen 1 evtl ist es das noch. Nervig nach wie vor dass ich die Config nicht zurück bekomme sonst könnte ich sowas im Adapter dynamisch behandeln.
                      @fl4sh-0
                      Dann hätte man ja eventuell schon was gefunden wo man ansetzten kann.
                      Was meinst du denn damit, das du die Config nicht zurück bekommst, wenn ich fragen darf?
                      Könnte man solche Sachen nicht über eine Variablen aus dem OCPP Adapter aussteuern, ähnlich wie beim Port ?
                      • foxriver76
                        @fl4sh-0 Das mit dem stackLevel können wir später probieren.
                        Konfigurierbar ja wäre möglich, ist aber ja schon sehr technisch und für den Anwender jetzt nicht so spannend. Eigentlich müsste die WB auf einen GetConfiguration Request antworten. In der Antwort würden dann auch Informationen wie das maxStackLevel stehen.
                        Leider antwortet bislang keine WB darauf obwohl sie es sollte, auf meiner Seite sehe ich leider aktuell keinen Fehler.
                          Das sind die GetConfiguration Daten aus der ABB Dokumentation.
                          • foxriver76
                            @fl4sh-0 Ich habe bereits probiert einzelne Keys die sicher vorhanden sein müssten zu requesten, als auch die gesamte Config. Habe ben nochmal nachgeschaut.. keine Ahnung woran es liegt.
                            Ich habe auf GitHub das stackLevel auf 0 geändert, bitte mal testen.
                              Anbei die Logdatei mit dem stacklevel 0 leider ohne Erfolg. Er sendet zwar SetChargingProfile aber kann es anscheind nicht verarbeiten.
                              Über die APP kann man das Limit zwischen 6A -16A stufenlos einstellen auch während eines Ladevorgangs. Aber für PV-Überschussladung ist das über die App nicht realisierbar und auch nur über Bluetooth steuerbar. Gibt es vllt noch eine andere Möglichkeit woran es liegen kann das der das Limit nicht setzt?
                              ocpp.0 2022-01-19 10:39:38.888	debug	{"connectorId":1,"transactionId":1,"meterValue":[{"timestamp":"2022-01-19T09:39:38.000Z","sampledValue":[{"value":"229.10","context":"Transaction.Begin","format":"Raw","measurand":"Voltage","phase":"L1-N","unit":"V"},{"value":"5.77","context":"Transaction.Begin","format":"Raw","measurand":"Current.Import","phase":"L1","unit":"A"},{"value":"16","context":"Transaction.Begin","format":"Raw","measurand":"Power.Active.Import","phase":"L1","unit":"W"},{"value":"229.00","context":"Transaction.Begin","format":"Raw","measurand":"Voltage","phase":"L2-N","unit":"V"},{"value":"5.76","context":"Transaction.Begin","format":"Raw","measurand":"Current.Import","phase":"L2","unit":"A"},{"value":"5","context":"Transaction.Begin","format":"Raw","measurand":"Power.Active.Import","phase":"L2","unit":"W"},{"value":"230.90","context":"Transaction.Begin","format":"Raw","measurand":"Voltage","phase":"L3-N","unit":"V"},{"value":"0.0","context":"Transaction.Begin","format":"Raw","measurand":"Current.Import","phase":"L3","unit":"A"},{"value":"0","context":"Transaction.Begin","format":"Raw","measurand":"Power.Active.Import","phase":"L3","unit":"W"},{"value":"0","context":"Transaction.Begin","format":"Raw","measurand":"Energy.Active.Import.Register","unit":"Wh"},{"value":"6","context":"Transaction.Begin","format":"Raw","measurand":"Current.Offered","unit":"A"}]}],"commandOcpp":"MeterValues"}
                              ocpp.0 2022-01-19 10:39:30.629	info	Received Start transaction from "/TACW1142021G1020"
                              ocpp.0 2022-01-19 10:39:30.628	debug	{"connectorId":1,"idTag":"1","meterStart":0,"timestamp":"2022-01-19T09:39:29.000Z","commandOcpp":"StartTransaction"}
                              ocpp.0 2022-01-19 10:39:29.936	info	Received Status Notification from "/TACW1142021G1020": Charging
                              ocpp.0 2022-01-19 10:39:29.936	debug	{"connectorId":1,"errorCode":"NoError","info":"null","status":"Charging","vendorErrorCode":"0x00","commandOcpp":"StatusNotification"}
                              ocpp.0 2022-01-19 10:39:28.982	info	Received Status Notification from "/TACW1142021G1020": SuspendedEV
                              ocpp.0 2022-01-19 10:39:28.981	debug	{"connectorId":1,"errorCode":"NoError","info":"null","status":"SuspendedEV","vendorErrorCode":"0x00","commandOcpp":"StatusNotification"}
                              ocpp.0 2022-01-19 10:39:28.465	debug	Sending RemoteStartTransaction for /TACW1142021G1020: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":10}]}}}
                              ocpp.0 2022-01-19 10:39:13.348	debug	Received heartbeat from "/TACW1142021G1020"
                              ocpp.0 2022-01-19 10:39:13.347	debug	{"commandOcpp":"Heartbeat"}
                              ocpp.0 2022-01-19 10:38:58.104	debug	Sending SetChargingProfile for /TACW1142021G1020
                              ocpp.0 2022-01-19 10:38:18.006	info	Sending GetConfiguration to "/TACW1142021G1020"
                              ocpp.02022-01-19 11:57:33.366	debug	Sending RemoteStartTransaction for /TACW1142021G1020: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":9}]}}}
                              ocpp.02022-01-19 12:16:06.331	debug	Sending SetChargingProfile for /TACW1142021G1020
                                @foxriver76 Moin, könntest du einmal beschreiben wie dein Vorgehen beim einstellen des Ladelimits ist. Ich würde das dann gerne nochmal genau so nachspielen.
                                Gibt es die Möglichkeit das Ladelimit gesondert zu pushen ?
                                Könnte man den startSchedule":"2013-01-01T00:00Z im SetChargingProfil auf das aktuelle Datum setzen ? Nicht das die Wallbox damit nicht klar kommt weil der Wert soweit in der Vergangenheit liegt. Hatte schon ein paar andere SetChargingProfile gesehen wo ein aktuelles Datum hinterlegt war.
                                Gruß Tobias
                                • foxriver76
                                  foxriver76 Developer @fL4sH 0 last edited by foxriver76
                                  @fl4sh-0
                                  Wo?
                                  Ja bin das WE allerdings unterwegs. Du kannst dir Daten auch lokal bei dir ändern wenn du dir das zutraust um mal rum zu spielen, die Stellen sollten identifizierbar sein. /opt/iobroker/node_modules/iobroker.ocpp/build/main.js oder Windows analog.
                                  https://github.com/foxriver76/ioBroker.ocpp/blob/86dbc2f6f88ee6e6aead8d686356671a10b4ef4c/build/main.js#L341
                                  Und
                                  https://github.com/foxriver76/ioBroker.ocpp/blob/86dbc2f6f88ee6e6aead8d686356671a10b4ef4c/build/main.js#L393
                                    @fl4sh-0
                                    Wo?
                                    Und
                                    Hatte das mal auf anderen Seiten gesehen: Hier die Beispiele.
                                    "SetChargingProfile",{"connectorId":0,"csChargingProfiles":{"chargingProfileId":10,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Absolute","recurrencyKind":"Daily","validFrom":"2019-10-22T08:25:00.000Z","validTo":"2019-10-22T08:36:00.000Z","chargingSchedule":{"startSchedule":"2019-10-22T08:26:00.000Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":1,"numberPhases":3}]}}}]
                                    SetChargingProfile exchange:
                                    "SetChargingProfile",{"connectorId":1,"csChargingProfiles":{"chargingProfileId":100,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","validFrom":"2018-05-12T00:00:00.000Z","validTo":"2018-05-19T00:00:00.000Z","chargingSchedule":{"duration":86400,"chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":25.5,"numberPhases":1},{"startPeriod":28800,"limit":15.5,"numberPhases":1},{"startPeriod":72000,"limit":25,"numberPhases":1}]}}}]
                                    GetCompositeSchedule exchange:
                                    "GetCompositeSchedule",{"connectorId":1,"duration":86400,"chargingRateUnit":"A"}]
                                    Sending RemoteStartTransaction for /ABB-Terra-AC: {"connectorId":1,"idTag":"1","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":12}]}}}
                                    Ich habe mit der main.js mal ein bisschen rumgespielt und die Werte ein bisschen geändert aber leider ohne Erfolg.
                                    Die Wallbox will das chargelimit immer noch nicht übernehmen......
                                    Ich habe mal eine Anfrage direkt zu ABB geschickt und schaue mal ob die sich dazu äußern.
                                    • foxriver76
                                      @fl4sh-0 Nach verändern der main.js auch immer Adapter neugestartet?
                                        Einen Neustart habe ich immer gemacht weil er sonst die Daten nicht übernommen hatte 😉
                                        • foxriver76
                                          @fl4sh-0 Top, also richtig gemacht, schade dass es erfolglos war.
                                            @fl4sh-0
                                            Wo?
                                            Und
                                            Worin besteht eigentlich der unterschied zwischen diesen beiden Blöcken ?
                                            Beim oberen Block ist: limit: limitState.val und beim unteren limit: state.val
                                            Wenn ich das richtig lese, sendet der untere Block doch "SetChargingProfile" oder ?
                                            31.7k
                                            79.8k
                                            adapter ocpp wallbox
                                            48
                                            440
                                            78154
