    4. Test Adapter OctoPrint
    • Negalein
      Negalein Global Moderator @Latzi last edited by
      @latzi sagte in Test Adapter OctoPrint:
      bitte sehr
      funktioniert nicht ganz
      0_userdata.0.3DDrucker.thumbnail
      octoprint.0.files.local_Kinder_Gekko_einzeln.thumbnail_url
      on({id: 'octoprint.0.printjob.file.name', change: "any"}, async function (obj) {
         var octo_thumb='';
         var thumb_file='';
         if ((obj.state.val)!== null) {
             thumb_file=getState("octoprint.0.printjob.file.origin").val +"_" + obj.state.val.replace(".gcode","");
             octo_thumb= getState("octoprint.0.files." + thumb_file + ".thumbnail_url").val;
         setState("0_userdata.0.3DDrucker.dir_thumb", thumb_file, true);
         setState("0_userdata.0.3DDrucker.thumbnail", octo_thumb, true);
      08:19:01.641	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:6:20)
      08:19:01.642	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:9:4)
      08:19:06.649	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:6:20)
      08:19:06.650	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:9:4)
      08:19:11.626	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:6:20)
      08:19:11.627	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:9:4)
      08:19:16.955	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:6:20)
      08:19:16.956	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:9:4)
      08:19:21.639	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:6:20)
      08:19:21.639	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:9:4)
      08:19:26.655	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:6:20)
      08:19:26.656	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:9:4)
      08:19:31.653	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:6:20)
      08:19:31.654	warn	javascript.0 (526697) at Object.<anonymous> (script.js.3D-Drucker.Slicerthumbnail:9:4)
      • da_Woody
        da_Woody @Negalein last edited by
        @negalein du hast da noch eine alte version! inzwischen sinds 13 zeilen...
        https://forum.iobroker.net/topic/36210/test-adapter-octoprint/229
        Latzi 1 Reply Last reply Reply Quote 0
        • Latzi
          Latzi @da_Woody last edited by
          @da_woody @Negalein
          auch das neue script wird nicht funktionieren, da wird ein Verzeichnis "Kinder" verwendet, ist im script so nicht vorgesehen 😞
          Da muss ich wohl umbauen und den DP path verwenden, wird etwas dauern - ich meld mich
          Negalein da_Woody 2 Replies Last reply Reply Quote 0
          • Negalein
            stimmt
            0_userdata.0.3DDrucker.dir_thumb wird befüllt
            0_userdata.0.3DDrucker.thumbnail bleibt leer
            • da_Woody
              da_Woody @Latzi last edited by
              @latzi das ist kein verzeichniss, das ist der filename des druckteils... 😉
              • Latzi
                Latzi @Negalein last edited by
                @negalein
                kannst du bitte die DP unter octoprint.0.printjob.file zeigen?
                • Negalein
                  Negalein Global Moderator @da_Woody last edited by
                  @da_woody sagte in Test Adapter OctoPrint:
                  Verzeichnis und Filename
                  File: http://10.0.1.182:80/plugin/prusaslicerthumbnails/thumbnail/Kinder/Gekko_einzeln.png?20220120081343
                  Verzeichnis: octoprint.0.files.local_Kinder_Gekko_einzeln
                  • Negalein
                    Latzi da_Woody 2 Replies Last reply Reply Quote 0
                    • Latzi
                      @negalein
                      jetzt gibt es ein Problem, hier tauch nirgends das "Kinder" auf, ich hab keine Ahnung woher das kommt!
                      da_Woody Negalein 2 Replies Last reply Reply Quote 0
                      • da_Woody
                        @negalein 0_userdata.0.3DDrucker.thumbnail ist bei mir auch leer, 0_userdata.0.3DDrucker.thumbnail_url wird befüllt.
                        octoprint.0.printjob.file sollte das nicht octoprint.0.printjob.files sein?
                        • da_Woody
                          @latzi so heisst das druckteil! so wie bei mir z.b. local_assortment_box_2x3_v3
                          • Negalein
                            dh., weil ich es in Octoprint bin Ordner ablege?
                            Kinderist der Ordner.
                            da_Woody Latzi 2 Replies Last reply Reply Quote 0
                            • da_Woody
                              @negalein ahh, dann erkennt das script nicht den ordner, sondern nimmt das als teil des namens...
                              • Negalein
                                das hab ich nicht
                                Nö
                                • Latzi
                                  @negalein
                                  ja, vermutlich ist das das "Problem".
                                  Würde das Verzeichnis beim printjob enthalten sein, hätte ich kein Problem damit. So kann ich nicht herausfinden, wo ich suchen soll 😞
                                  • Negalein
                                    Schei.....benkleister 😞
                                    • Latzi
                                      Latzi last edited by Latzi
                                      @haus-automatisierung
                                      Hallo Matthias,
                                      besteht die Möglichkeit, den DP path aus octorint.x.files.yyy in octoprint.x.printjob.file zu übertragen, damit ich "Verzeichnisse" mitbekomme, die weder in name noch origin zum printjob enthalten sind?
                                      da_Woody 1 Reply Last reply Reply Quote 1
                                      • da_Woody
                                        @latzi wollte ich gerade schreiben, gerade getestet, im path wirds richtig angezeigt...
                                        kannst du nicht mit dem path arbeiten? da steht der komplette pfad, mit .gcode drinnen...
                                        path: local/Sortimo/assortment_box_2x3_v3.gcode
                                        • Latzi
                                          Latzi @da_Woody last edited by Latzi
                                          @da_woody
                                          nein, da ich ja nicht weiß, wo in octoprint.x.file gerade gedruckt wird. Nur octoprint.x.printjob ist immer gleich und dort gibt es leider keinen path 😉
                                          • da_Woody
                                            adapter entwicklung adatper updates developer testen
                                            49
                                            461
                                            95683
