    4. Test Adapter Alarm 3.6.x
      avhoboken last edited by
      Hi all,
      For me the first use of the Alarm adapter and there are a few things that don't understand yet, might be caused by the fact that German reading is not that good.
      If I understand "Scharf inside" should be used for the condition you want to enable the alarmsystem while there are still people in the house. So I would assume that only sensors outside or for doors/windows are added to this alarmtype and not the internal moving sensors or internal doorsensors. Correct?
      "My two qustions are:
      1. In below example I've got two internal sensors not checked for the "sharp inside" but they still create an alarm as you can see in the logfile (binnen alarm = sharp inside).
      2. Why does the default text/voice only mentions a warning of a change? I would assume that if an outside sensor is triggered it would warn for a burglary.
      I guess there i a simple explanation but I can't figure it out yet 🙂
      Thanks for any help
      blauholsten 1 Reply Last reply Reply Quote 0
      • blauholsten
        blauholsten Developer @avhoboken last edited by
        @avhoboken sagte in Test Adapter Alarm 2.1.x:
        Hi all,
        YES
        When I understood your example correct, this is not a alarm, it is a notification. This comes from your checked checkbox at "notifications".
        1. Why does the default text/voice only mentions a warning of a change? I would assume that if an outside sensor is triggered it would warn for a burglary.
        I don´t understand your question. Please explain a little bit more.
          avhoboken @blauholsten last edited by
          hi @blauholsten,
          Thanks again for the module, seems like a lot of work to develop.
          I've installed a second instance of the alarm to get the default values again so I can show what I mean. I kept all defaults and only added two sensors, 1 inside, other outside. When I active te alarm and trigger the outside or inside sensor, the alarm goes off as it should.
          When I set "Scharf innen" and trigger the inside sensor than I get the warning message that something hs changed, as I have the notifications checked.
          When I set "Scherf innen" and trigger the outside sensor I get the same warnung message as with the inside sensor, while I would expect that the burglar alarm would be triggered. Also no alarm flags in the <instance>.status. objects.
          What am I missing here?
          Thanks for any help/explanation
          Alex
          • blauholsten
            @avhoboken
            The notification checkbox is for both states of the alarm system, sharp and sharp inside and also for the night rest. Notifications are in priority the lowest, when your system ist activate and you trigger a burglar, the higher priority has the burglary.
            In your example below, you need to trigger the out sensor. After that, the system post the burglar message.
            For me, I use the notification for very low security states like outdoor motion sensor or the windows in the higher stock's.
            I hope you can understand that, I am not a native English speaker.
              Hi @blauholsten,
              You English is much better than my German :).
              The last test in my previous example was triggering the outside sensor for which I would expect that the burglar alarm is triggered. However it doesn't....
              As next try I removed the Notification checkbox for both sensors. When "Scharf innen" is set, it won't give a log entry anymore when the inside sensor is triggered (as expected) but still the same warnung message "Alarmanlage meldet eine Warnung, Veränderung bei: Outside sensor test" when the outside sensor is triggered instead of a burglar alarm.
              The Burglar alarm object is also not set.
              So it doesn't work as you describe in your feedback, what should I change in my configuration?
              cc3301a0-1e96-4385-8c02-1d02f4d94609-image.png 3ebd167f-6b1b-4ed8-a7bd-7ebcd37e1d23-image.png
              • blauholsten
                @avhoboken
                Hey,
                It works all correctly, I think 🤔. At your new example you received a message because the outside sensor is still in the "sharp inside" circuit. Your system was set in the sharp inside mode!
                Please try the same situation, but set the system in sharp mode before you trigger your outside Sensor. See what happens 😜
                  @blauholsten ,
                  Well, in that case (setting sharp mode) I get off course a nice burglar alarm when either of the sensors is triggered.
                  Probably I misunderstand the function of "sharp inside". but let's turnaround the question, with setting the system in "sharp inside" mode, can a burglar alarm be triggered and if so, how should the sensor than be configured. Because the way I've configured it now I only get the "changes warning" with no alarm triggers.
                  • blauholsten
                    @avhoboken
                    Okay, now I understand that situation.
                    During sharp inside, the system goes not to the burglary, you have under info. a few states that's signal the trigger.
                    All other things you can also handle with shortcuts.
                      @blauholsten
                      Perfect, thanks again for all your help and patience!
                        KabaKoenig last edited by
                        Hallo, Erstmal danke für das überragende Projekt.
                        Ich Teste jetzt schon 2 Tage verschiede Szenarien. Ich möchte gerne erreichen, wenn z.b. meine Frau die Alarmanlage SCHARF-INTERN schaltet, die Eingangstüre Alarmverzögert ist. So das ich wenn ich später nach hause komme durch die Tür eintreten kann und dann die Anlage unscharf schalten kann. z.b.20sec bis zur Alarm Auslösung. Ist das Möglich? Bei Extern-Scharf funktioniert das. Aber bei intern-scharf bekomme ich das nicht hin. Mach ich ein Fehler?
                        Liebe Grüße
                        Timo
                        • blauholsten
                          blauholsten Developer @KabaKoenig last edited by
                          @kabakoenig
                          die Funktionsweise setzte ich gerade um, bitte ein paar Tage Geduld. Danke
                            KabaKoenig @blauholsten last edited by
                            @blauholsten
                            Vielen Dank. Ich finde das richtig prima wie hier einem geholfen wird. Auch ein riesiges Lob von mir, so ein Projekt zu stemmen. Und ich glaube man hat es auch nicht immer einfach. Aber auch die ganze Community richtig stark.
                            • blauholsten
                              blauholsten Developer last edited by blauholsten
                              ich habe in letzter Zeit einige Stunden in die Weiterentwicklung gesteckt. Für die Version 3.x.x. die auf GitHub liegt, brauche ich dringend Tester! Ich habe eine relativ große Sache umgestellt, und bevor ich das für alle veröffentliche, muss dies getestet werden. Vielleicht werden einige die Änderung nicht so gut finden, aber ich denke es macht sinn:
                              Ab Version 3.x.x, habe ich mich dazu entschieden den Alarm auch bei scharf innen auszulösen! Das verändert die Funktion des Adapters ein wenig. Es wird jetzt zwischen Sirene intern und extern unterschieden, hierzu ist zu beachten, dass es den Datenpunkt info.sharp_inside_siren nicht mehr gibt. Diesen bitte ggf. manuell löschen! Der Datenpunkt wurde durch status.siren_inside ersetzt, und entspricht der Innensirene. Es ist zu beachten, dass das auch ggf. bei den Verknüpfungen neu einzustellen ist. Möchte man dies Aussensirene auch bei innen Alarm auslösen, kann man das in den allgemeinen Einstellungen tun. DANKE FÜR DAS VERSTÄNDNIS, ABER ICH DENKE SO IST ES LOGISCHER!
                              Danke für´s Feedback im Voraus!
                              K 1 Reply Last reply Reply Quote 2
                                @blauholsten
                                Vielen Dank für die Weiterentwicklung.
                                Habe heute morgen mal zeit gehabt zu testen.
                                was mir aufgefallen ist:
                                • Wenn ich intern scharf schalte, und es ist noch nicht alles geschlossen kommt zwar eine Meldung das noch was offen ist, aber die Anlage geht trotzdem scharf.... ist das so gewollt?
                                • Wenn ein intern Alarm ausgelöst wird geht sirne_inside und sirene auf true. wenn ich nun deaktiviere geht nur sirne_inside auf false und sirene bleibt auf true und lässt sich nicht deaktivieren.
                                • Bei der Alarmgreis ausgelöst wird gehen auch beide Sirenen state auf true und es läst sich intern_sirene bei Deaktivierung nicht zurücksetzen. also genau umgekehrt als oben.
                                Von der ganzen sache finde ich es so logischer wie es nun angedacht ist..... In normalen Alarmanlagen für Privathäuser gibt es in der Regel immer ein Gesammtscharf und ein Internscharf die wie du es nun umgesetzt hast programiert werden können.
                                Wenn mir noch was auffällt schreibe ich es.
                                Und herzlichen Dank für die mühe
                                blauholsten 2 Replies Last reply Reply Quote 0
                                • blauholsten
                                  blauholsten Developer @KabaKoenig last edited by blauholsten
                                  @kabakoenig sagte in Test Adapter Alarm 3.x.x:
                                  Eigentlich ja. Wenn du intern aktivierst bist du ja Zuhause und kannst darauf reagieren. Sollte es dennoch bedarf geben, kann ich es eventuell in den nächsten Versionen einbauen.
                                  Fehler gefunden, Versuche ich heute Abend zu beheben.
                                  Super, vielen Dank
                                    DarkDevil last edited by
                                    ich habe gerade auf die letzte stable Version 2.2.1 aktualisiert.
                                    Was sind denn die "telegram special parameters"? Könnte ich damit für den telegramm Adapter einen Empfänger angeben?
                                    Aktuell läuft der Alamadapter mit einer eigenen Telegram Instanz.
                                    • blauholsten
                                      blauholsten Developer @DarkDevil last edited by
                                      @darkdevil
                                      Ja, oder Gruppe etc...
                                      • blauholsten
                                        @kabakoenig
                                        Bitte GitHub Version 3.0.1 testen.
                                          @blauholsten
                                          Danke für deine Arbeit!!!
                                          Kam gerade dazu es zu testen...
                                          • Es werden immer noch bei Alarmauslösung beide Sirenen auf true gesetzt egal ob intern oder Extern. Was sich aber geändert hat ist die Deaktivierung beide Sirenen werden auf false gesetzt.
                                          Du möchtest bestimmt erreichen das wenn intern scharf ist und ausgelöst wird, nur Sirene Intern auf true geht?
                                          Und bei Extern scharf nur die extern Sirene auf true geht?
                                          • Der Schalter bei den Haupteinstellungen "Außen Sirene bei Einbruch scharf innen aktivieren" hat keine Änderung gezeigt.
                                          • blauholsten
                                            @kabakoenig
                                            Danke für deine Tests! Kannst du bitte nochmal testen? Bitte NEU von Github installieren. Ich hoffe jetzt geht es, man verliert manchmal voller Code die Übersicht!
                                            1.4k
                                            alarm alarmanlage alarmsystem
                                            111
                                            1376
                                            561939
