    3. Einsteigerfragen
    4. Installation
    5. nach Umzug Raps -> NUCi3 Debian ECONNREFUSED bei influxDB
      Thomas Braun Most Active @fraso last edited by Thomas Braun
      @fraso
      wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg
        fraso @Thomas Braun last edited by
        @thomas-braun sagte in nach Umzug Raps -> NUCi3 Debian ECONNREFUSED bei influxDB:
        Ach herrje.... was das ?
        e6iob@NUCiowget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpgfluxdb.gpg
        V	??ù?o?s??摌??GSS?`?)i?$0?<ڷ??<fǭ%B9??L??h?<?ҕ?V?n???z??%c;?\??O
        ?	|?>U?f?9?|??&:??A??t????	y#C+BP5@3?P???#}????כ???:%7z?VY?I^???p]MCq???`WvH????fuF?3?
                6??D?2sFW??7D6c!F"???$?J???>3Q???~ʡ???w0?T?,t?A?P?ΰ?????%/n?^??ŷ??m?6?T?J+?ʷ?a.????7E??!??$q?jZ9??+1????????
        ?G?~N0y??"????|??˚??H??0?B?.n5?? ?O?#O7
                                               ??|?A-~*??xc09??_?n???F???.?:?(?B`f
        9Ry??B???????g?O?cr??*;??ykx?!9?v?_5<?%D????C٩p[?v?+?Z?Cu????b????B?v
        ??C?3?u?T?֨?_p.*h??l??h?y??1InfluxDB Packaging Service <support@influxdb.com>?7
        !V	?
        	hJ?%????q?kDIٷ?????}?d?~[?}?????I??(ElV=?H?P?B??h???>a?c?8??]???i?%X???ޡj}?:6J5???'??t????2??G?{F?ʿgv????e???\6?i
        ^?1?f?j>?*?]?d??hgw-?p???H?A?޵?{?4;????l?????m????23?)??m?????'#\p‹?X?6?X?w???????{$Ԓ??@f5?y?}?oI#z??3???!.?
        0(?l??a=?g'??}??U-?z???7?(̫??W?mƂ6??C?6?r??q?a??C????0?A??5p?<?bk?.?F?++?????????@?a?b??d}?/0??\zF?W'??nd5?M=UR
        ???'?@|9?.,?9??9W?֘???tHhD?ߛEPYB????&?T85?b?[O+????"W??^_???j?Է
        ??ew???Nt??)U??;j?oO?qYP^y\?.?eRZ??FD??'?@??ݎ??.aL8E?BD??<o?{=?????%:D? V????˻??o>؃G#<?O??G9????}?g$??J???9dοl
        e?5?Ȑ?l?2???V)?r?꿓m?O?uݮ???h\cW?ԪP?ht%?l6l????M?&?Zg~x??%f???E?p' ??Qm?7??Ҕ+?F?b?2?-{M,?w???J?S,?9q鸛эR????@?????w????æ??Vm?V???_??b?%[?;?p?^?
        ??????e?q?8M??Ge`^?|?h	gS?????ˢ0?䖶????߾???lD?Kl??~???p???U?t??J?Q??F)3?-B???:?	9V??"??*???Z??#?%???L???~???v?V???
        	V	?
        	hJ?%?????Z?I??????Wg??n?W?	̚??i?-bg?U?d?T????߲?ֻ??z?=)?ƈ??#?F?2_t??Y}.?b?7?G?L???a?׊6?M??M?k?ѱ?S??2??dj???r?rnIw?,CvT?Lw?S?
        ?^?9?E??t?~???W@???%?c?0C????R
                     ?}_???Zɘ?mh?ml?ٓt8F?0*?)צ}[?
        ???䒁B??7th"ԙ??[?3???H9Nq?/%O????й0???k?^?<?@? q^_?s????)?s?ky??4V?J|]?5i???F?u???z?y?z\Z?H?
                         ?O?[????h-F5??]p3a?"?i?J?,X??T?DI6?Y???&????X?4?Z?v?7[+6?B2!????SR??`???-?[?k ۼ4?l?tV?@+n?[??`?=%C???{nCL?n??.?X?9?o???I-Ku?
        ?k?7L?7???J?㎧??$??e6iob@NUCioBroker:~$
          @fraso
          Das ist der key.
          sudo apt update
            dann sollte ich den hier nicht öffentlich reinstellen?
              @fraso
              Nein, das ist der ohnehin öffentliche influxdb.key
              Alles okay.
                e6iob@NUCioBroker:~$ sudo apt update
                OK:1 http://deb.debian.org/debian bullseye InRelease
                OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                Holen:4 https://repos.influxdata.com/debian bullseye InRelease [4.739 B]
                OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                Holen:6 https://repos.influxdata.com/debian bullseye/stable amd64 Packages [1.265 B]
                Es wurden 6.004 B in 0 s geholt (14,8 kB/s).
                Paketlisten werden gelesen… Fertig
                Abhängigkeitsbaum wird aufgebaut… Fertig
                Statusinformationen werden eingelesen… Fertig
                Alle Pakete sind aktuell.
                  @fraso
                  apt policy influxdb
                  Und nochmal
                  which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    e6iob@NUCioBroker:~$ sudo apt policy influxdb
                    influxdb:
                      Installiert:           (keine)
                      Installationskandidat: 1.8.10-1
                      Versionstabelle:
                         1.8.10-1 500
                            500 https://repos.influxdata.com/debian bullseye/stable amd64 Packages
                         1.6.7~rc0-1+b5 500
                            500 http://deb.debian.org/debian bullseye/main amd64 Packages
                    e6iob@NUCioBroker:~$ sudo which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v14.18.3
                    v14.18.3
                    6.14.15
                    e6iob
                    /home/e6iob
                    OK:2 http://security.debian.org/debian-security bullseye-security InRelease
                    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                    OK:4 https://repos.influxdata.com/debian bullseye InRelease
                    nodejs:
                      Installiert:           14.18.3-deb-1nodesource1
                      Installationskandidat: 14.18.3-deb-1nodesource1
                      Versionstabelle:
                     *** 14.18.3-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                            100 /var/lib/dpkg/status
                         12.22.5~dfsg-2~11u1 500
                            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                      @fraso sagte in nach Umzug Raps -> NUCi3 Debian ECONNREFUSED bei influxDB:
                      Ja, passt soweit. Jetzt halt noch influxdb drauf:
                      sudo apt install influxdb
                      Grafana wird nicht gebraucht?
                        fraso @Thomas Braun last edited by fraso
                        das sieht besser aus 🙂
                        Aber Adapter noch gelb. Verbindungstest Button ergibt noch immer: Error: connect ECONNREFUSED 127.0.0.1:8086
                        KORREKTUR: nach "iobroker restart" Connection OK.
                        e6iob@NUCioBroker:~$ sudo apt install influxdb
                        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                          gyp javascript-common libc-ares2 libjs-highlight.js libjs-inherits
                          libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer libssl-dev
                          libuv1-dev
                        Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                        Die folgenden NEUEN Pakete werden installiert:
                          influxdb
                        0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        Es müssen 54,4 MB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 153 MB Plattenplatz zusätzlich benutzt.
                        Holen:1 https://repos.influxdata.com/debian bullseye/stable amd64 influxdb amd64 1.8.10-1 [54,4 MB]
                        Es wurden 54,4 MB in 1 s geholt (51,2 MB/s).
                        Vormals nicht ausgewähltes Paket influxdb wird gewählt.
                        (Lese Datenbank ... 62759 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../influxdb_1.8.10-1_amd64.deb ...
                        Entpacken von influxdb (1.8.10-1) ...
                        influxdb (1.8.10-1) wird eingerichtet ...
                        Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
                        Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
                        Trigger für man-db (2.9.4-2) werden verarbeitet ...
                          Bei der Konfiguaration von influxdb kann ich dir nicht helfen.
                          Aber schmeiß den Kram noch raus:
                          sudo apt autoremove
                          Nach dem ganzen Hin und Her vielleicht den Rechner auch mal komplett durchstarten:
                          iobroker stop
                          sudo reboot
                            KORREKTUR:
                              @fraso
                              Okay, ich würde aber den autoremove noch durchführen. Das sind auch noch Überbleibsel der dfsg-nodejs-Version.
                                erledigt. Danke. Jetzt kümmere ich mich mal um meinen grünen Alexa Adapter - aber die Geräte werden nicht aktualsiert (false)
                                ist es Korrekt das ich nur als PRO Nutzer IoT brauche und die Instanz cloud nicht mehr benötigt wird?
                                  @fraso
                                  iot = Alexa
                                  cloud = Steuerung des iobrokers von Extern.
                                  F Homoran 2 Replies Last reply Reply Quote 0
                                    ok. danke. Cloud und IoT grün, Cookie Alexa wird als "aktuell" bezeichnet (habe keinen neuen gemacht nach Umzug auf NUC). Bei iot habe ich den "nach Umzug den Button klicken" angeklickt. Hab ich was vergessen?
                                      @fraso
                                      Keine Ahnung.
                                        dto. kann ich mich für Deine super ausdauernde Hilfe irgendwie erkenntlich zeigen? Paypal?
                                          @fraso
                                          Nein, nicht notwendig. Viel Spaß mit dem ioBroker.
                                            DANKE! 🙌
                                            1.5k
                                            3739
