    • Dominik F.
      Dominik F. @MCU last edited by
      @mcu
      keine Ahnung was das ist und was das soll 😄
      In dem was ich dir kopiert habe steht das ja öfter drin, bei mir im css aber nicht
      Dominik F. 1 Reply Last reply Reply Quote 1
      • Dominik F.
        Dominik F. @Dominik F. last edited by
        Ich bekomme in regelmäßgen Abständen folgende Fehlermeldungen:
        host.IoBroker
        2022-01-24 11:39:54.899	error	instance system.adapter.jarvis.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        jarvis.0
        2022-01-24 11:39:54.348	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        jarvis.0
        2022-01-24 11:39:54.348	info	terminating
        jarvis.0
        2022-01-24 11:39:54.348	info	Adapter stopped und unloaded.
        jarvis.0
        2022-01-24 11:39:54.345	error	Cannot read property 'ip' of undefined
        jarvis.0
        2022-01-24 11:39:54.345	error	TypeError: Cannot read property 'ip' of undefined at ioWebSocket.eventFromClient (/opt/iobroker/node_modules/iobroker.jarvis/lib/websocket.io.min.js:1:4231) at ioWebSocketClient._parentMessage (/opt/iobroker/node_modules/iobroker.jarvis/lib/websocket.io.min.js:1:6959) at ioWebSocketClient.disconnect (/opt/iobroker/node_modules/iobroker.jarvis/lib/websocket.io.min.js:1:8944) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/lib/websocket.io.min.js:1:8136) at Socket.emit (events.js:400:28) at Socket.emitReserved (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/socket.io/dist/typed-events.js:56:22) at Socket._onclose (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/socket.io/dist/socket.js:358:14) at Client.onclose (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/socket.io/dist/client.js:239:20) at Socket.emit (events.js:412:35) at Socket.onClose (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/engine.io/build/socket.js:303:18)
        jarvis.0
        2022-01-24 11:39:54.343	error	uncaught exception: Cannot read property 'ip' of undefined
        Hat jemand eine Idee dazu?
        • Zefau
          Zefau @Dominik F. last edited by Zefau
          @dominik-f bitte auf 3.0.10 gehen
          Dominik F. 1 Reply Last reply Reply Quote 0
          • Dominik F.
            Dominik F. @Zefau last edited by
            @zefau
            Mache ich, dank dir
            • RoddiEF
              RoddiEF last edited by
              Eine Frage:
              wie kommt man denn an die (wie auf dem Bild zu sehen) unteren ran ?
              Man kann das Fenster nicht verschieben oder das die untere Liste (Server) nach oben aufgeht.
              So kommt man an die unteren nicht ran um diese Auszuwählen...
              • Zefau
                Zefau @RoddiEF last edited by
                @roddief v3.0.10
                RoddiEF 1 Reply Last reply Reply Quote 0
                • RoddiEF
                  RoddiEF @Zefau last edited by
                  @zefau mir wird keine v3.0.10 angezeigt.
                  Aktuelle wird mir nur v3.0.9 gezeigt. "Repo" ist in den Einstellungen auf "latest" eingestellt.
                  • Zefau
                    @roddief dann aktualisiere mal im Adapter Tab die Update Liste
                    Dominik F. RoddiEF 2 Replies Last reply Reply Quote 0
                    • Dominik F.
                      ich möchte folgendes realisieren:
                      Ich möchte ein Drop Down erstellen,
                      Die Texte sind in folgendem Datenpunkt:
                      {heatingcontrol.0.vis.ProfileValueListText}
                      Die Werte sind in folgendem Datenpunkt:
                      {heatingcontrol.0.vis.ProfileValueListValue}
                      Getriggert wird am Ende folgender Datenpunkt:
                      heatingcontrol.0.CurrentProfile
                      Wie bekomme ich die 3 Sachen unter einen Hut? Wie kann ich in der Anzeigevariante einen Datenpunkt angeben?
                        MCU @Dominik F. last edited by MCU
                        @dominik-f https://github.com/Zefau/ioBroker.jarvis/issues/486
                        Stell mal die Werte der DPs rein. Und beschreib mal deren Abhängigkeit.
                        duczz created this issue in Zefau/ioBroker.jarvis
                        open HeatingControl Modul #486
                        Dominik F. 2 Replies Last reply Reply Quote 0
                        • Dominik F.
                          @mcu
                          Ganz oben in der Anfrage steht ja ein Link, dort sind alle Datenpunkte beschrieben. Das ganze ist dort ja schon über 1 Jahr alt und erfreut sich leider keiner großen Beliebtheit.
                          Da ich ja eh gerade alles von 0 aufbaue finde ich es nicht schlimm, mir die Sachen selber zusammenzuschustern. Dabei lerne ich ja gleichzeitig auch sehr viel von Jarvis. Ich hab es z.B. hinbekommen, dass ich einen Taster erstelle, der die Farbe ändert wenn sich ein anderer Datenpunkt ändert. Da bin ich schon ein wenig stolz auf mich 😄
                          Ich denke wenn ich das mit dem Drop Down hin bekomme, kann ich mir danach fast alles schon so bauen wie ich mir das brauche. Macht auch gerade spaß auch wenn ich viel von deiner Zeit in Anspruch nehme. Sorry und Danke gleichzeit dafür
                            @dominik-f Stell mal die Einstellung mit dem Taster rein, dann nehme ich das in die Doku.
                            • Dominik F.
                              Dominik F. @MCU last edited by Dominik F.
                              @mcu
                              Der Button schaltet den Datenpunkt immer wieder zurück auf "auto". Ist der Datenpunkt auf "auto", ist der Button grün, wenn er auf "manual" steht rot.
                              • RoddiEF
                                @zefau Thx, es kann manchmal so einfach sein... 😉
                                Wenn man Stundenlang am PC sitzt, vergisst man die einfachsten Sachen (Reload der Seite)....
                                • Dominik F.
                                  @mcu
                                  Hast du denn eine Idee wie ich die Datenpunkte in die Anzeigewerte bekomme?
                                  Dann hab ich noch eine andere Frage:
                                  Habe folgendes in eine Anzeigevariante geschrieben:
                                    "manual": "false",
                                    "val.indexOf('auto')": "true"
                                  Nur leider funktioniert das mit dem Index nicht, habe ich da was falsch geschrieben?
                                    @dominik-f Was steht im DP-Wert? -> val.indexOf('auto')?
                                    In der Anzeigevariante kannst du nur echte DP-Werte nutzen.
                                    • Dominik F.
                                      @mcu
                                      der eine Wert ist "manual", den hab ich mit false ja abgedeckt. Die anderen Werte haben immer "auto" mit im Wert stehen, deshalb wollte ich das mit indexOF lösen. Dies hat in den Bindings in Vis bisher immer funktioniert.
                                      Ich wollte dort nicht jeden Wert einzelnd aufschreiben müssen.
                                      • Dominik F.
                                        @mcu
                                        Ich hab eine Lösung gefunden. Allerdings verstehe ich das nicht so wirklich aber es funktioniert:
                                        {"manual":"false","val.indexOf('auto')==-1":"true"}
                                        M 1 Reply Last reply Reply Quote 2
                                          @dominik-f sagte in jarvis v3.0.0 - just another remarkable vis:
                                          Es ist immer dann true, wenn es kein "manual" ist.
                                          Kannst auch "test" in den DP schreiben, kommt auch true.
                                          M Dominik F. 2 Replies Last reply Reply Quote 1
                                            MCU @MCU last edited by
                                            @mcu Wenn es sowieso nur manual und auto* gibt, kannst du auch mit "default":"true", "manual":"false" arbeiten
                                            254
                                            4489
                                            2651401
