    4. Test Adapter Chromecast v3.0.x
    • Jey Cee
      Jey Cee Developer @Dragon last edited by
      @dragon welche Sayit Version? Hast du weitere Informationen die einen Hinweis geben warum?
      D Horst Böttcher 2 Replies Last reply Reply Quote 0
        Dragon @Jey Cee last edited by
        @jey-cee Sayit Version ist 1.12.3. Nach einem Downgrade vom Chromecast Adapter funktioniert wieder alles. Also liegt das Problem wahrscheinlich hier. Einen Log gibt es nicht, da er keine Fehler ausgibt, sondern einfach sagt es sei alles in Ordnung, aber der GHome einfach nichts sagt.
        • Horst Böttcher
          Horst Böttcher @Jey Cee last edited by
          @jey-cee
          nach mehrren neutarten des pi
          wieder absturz
          chromecast.0	2022-01-20 15:38:14.907	error	(19535) Cannot read property 'contentId' of undefined
          chromecast.0	2022-01-20 15:38:14.907	error	(19535) TypeError: Cannot read property 'contentId' of undefined at PersistentPlayer._playerStatus (/opt/iobroker/node_modules/castv2-player/lib/persistentPlayer.js:719:58) at DefaultMediaRece
          chromecast.0	2022-01-20 15:38:14.905	error	(19535) uncaught exception: Cannot read property 'contentId' of undefined
          chromecast.0	2022-01-20 14:37:41.482	error	(19438) Cannot read property 'contentId' of undefined
          chromecast.0	2022-01-20 14:37:41.481	error	at Client.emit (events.js:412:35)
          chromecast.0	2022-01-20 14:37:41.481	error	at Client.onmessage (/opt/iobroker/node_modules/castv2/lib/channel.js:23:10)
          chromecast.0	2022-01-20 14:37:41.481	error	at Channel.emit (events.js:400:28)
          chromecast.0	2022-01-20 14:37:41.481	error	at Channel.onmessage (/opt/iobroker/node_modules/castv2-client/lib/controllers/controller.js:16:10)
          chromecast.0	2022-01-20 14:37:41.481	error	at fn.emit (events.js:412:35)
          chromecast.0	2022-01-20 14:37:41.481	error	at fn.onmessage (/opt/iobroker/node_modules/castv2-client/lib/controllers/media.js:21:12)
          chromecast.0	2022-01-20 14:37:41.481	error	at fn.emit (events.js:400:28)
          chromecast.0	2022-01-20 14:37:41.481	error	at fn.onstatus (/opt/iobroker/node_modules/castv2-client/lib/senders/default-media-receiver.js:16:10)
          chromecast.0	2022-01-20 14:37:41.481	error	at DefaultMediaReceiver.emit (events.js:400:28)
          chromecast.0	2022-01-20 14:37:41.481	error	at PersistentPlayer._playerStatus (/opt/iobroker/node_modules/castv2-player/lib/persistentPlayer.js:719:58)
          chromecast.0	2022-01-20 14:37:41.481	error	(19438) TypeError: Cannot read property 'contentId' of undefined
          chromecast.0	2022-01-20 14:37:41.480	error	(19438) uncaught exception: Cannot read property 'contentId' of undefined
          chromecast.0	2022-01-20 14:37:08.164	error	(19391) Cannot read property 'contentId' of undefined
          chromecast.0	2022-01-20 14:37:08.163	error	at Client.emit (events.js:412:35)
          chromecast.0	2022-01-20 14:37:08.163	error	at Client.onmessage (/opt/iobroker/node_modules/castv2/lib/channel.js:23:10)
          chromecast.0	2022-01-20 14:37:08.163	error	at Channel.emit (events.js:400:28)
          chromecast.0	2022-01-20 14:37:08.163	error	at Channel.onmessage (/opt/iobroker/node_modules/castv2-client/lib/controllers/controller.js:16:10)
          chromecast.0	2022-01-20 14:37:08.163	error	at fn.emit (events.js:412:35)
          chromecast.0	2022-01-20 14:37:08.163	error	at fn.onmessage (/opt/iobroker/node_modules/castv2-client/lib/controllers/media.js:21:12)
          chromecast.0	2022-01-20 14:37:08.163	error	at fn.emit (events.js:400:28)
          chromecast.0	2022-01-20 14:37:08.163	error	at fn.onstatus (/opt/iobroker/node_modules/castv2-client/lib/senders/default-media-receiver.js:16:10)
          chromecast.0	2022-01-20 14:37:08.163	error	at DefaultMediaReceiver.emit (events.js:400:28)
          chromecast.0	2022-01-20 14:37:08.163	error	at PersistentPlayer._playerStatus (/opt/iobroker/node_modules/castv2-player/lib/persistentPlayer.js:719:58)
          chromecast.0	2022-01-20 14:37:08.163	error	(19391) TypeError: Cannot read property 'contentId' of undefined
          chromecast.0	2022-01-20 14:37:08.160	error	(19391) uncaught exception: Cannot read property 'contentId' of undefined
            Berchemer @Dragon last edited by
            @dragon sagte in Test Adapter Chromecast v3.0.x:
            Mit der Version 3.0.x lässt sich der Sayit Adapter nicht mehr nutzen. Die Google Geräte spucken also leider keinen Ton mehr aus...
            Kann es sein, dass Du noch das alte Objekt für die Lautstärke verwendest und nicht den Wert unter "player"?
              Berchemer @Berchemer last edited by
              @berchemer sagte in Test Adapter Chromecast v3.0.x:
              Wer lesen kann ist klar im Vorteil...
              Ging um den Sayit-Adapter und nicht direkt den Chromecast 😞
              Sorry 👼
                Krys last edited by Krys
                Moin miteinander,
                kann das jemand mit sayit bestätigen, dass es NICHT mehr funktioniert.
                sayit bräuchte ich schon.
                Sehr nice, dass nun Gruppen funktionieren sollen. Bin gespannt.
                Edit: Ausprobiert, sayit funktioniert und das mit den Gruppen, was ja einige Posts vorher angefragt wurde und jetzt umgesetzt wurde läuft auch! Einfach ein Traum. Danke für die Mühe! @Jey-Cee
                  Dragon @Krys last edited by
                  @krys Was meinst du mit sayit funktioniert? 🤔
                  Ich Update meinen Adapter auf 3.0.0 und es kommt kein Ton mehr, egal welches Gerät, ob Gruppe oder einzelnes. Downgrade ich wieder funktioniert die Wiedergabe wieder. Dann kann es doch nicht funktionieren und die Fehlerdiagnose ist auch recht einfach...
                    Krys @Dragon last edited by
                    @dragon Hi, bei mir funktioniert alles. "Einzelnes ansprechen der Geräte als auch der Gruppen (Musikwiedergabe)", "Sprachausgabe über sayit". Es funktioniert also alles.
                      @krys Woran kann es dann liegen?
                        @dragon ich habe nichts besonderes gemacht. Nur den Adapter geupdatet und meine Skripte angepasst + in sayit das "neue", "richtige" Gerät ausgewählt.
                          Dragon @Krys last edited by Dragon
                          @krys was meinst du mit in sayit das neue richtige Gerät gewählt? In dem blockly welches ich nutze kann man nichts auswählen.
                          Nach einigem suchen das Problem gefunden... Die Gruppe hat ein kryptische Buchstaben/Zahlenbezeichnung. Nicht mehr den netten Namen der einfach lesbar war... 3.0.1 funktioniert also jetzt....
                            Falsch hier, ich bin ja noch auf 2.3.1, muss erst noch updaten!
                              ich hab das nun auch mal mit der neuen Version probiert, jedoch erfolgt keine Sprachausgabe mehr
                              • Instanz gestoppt und Objektbaum gelöscht
                              • neue Version von Git geladen und gestartet, Objekte wurden angelegt
                              • Net-Tools ist installiert und läuft
                              • discovery ist installiert
                              • sayit Instanz Version 1.12.6
                              ein einfaches blockly, keine Ausgabe
                              • Jey Cee
                                Jey Cee Developer @crunchip last edited by
                                @crunchip kannst du in der Sayit Konfiguration den Chromecast Auswählen auf dem was Ausgegeben werden soll?
                                crunchip 1 Reply Last reply Reply Quote 1
                                  crunchip Forum Testing Most Active @Jey Cee last edited by crunchip
                                  @jey-cee ah, danke für den Denkanstoß, da hatte ich gar nicht darauf geachtet, weil da immer nur mein mini drin stand.
                                  ich teste mal(bin zwischenzeitlich schon wieder zurück)
                                  Edit:
                                  • Bommelpage
                                    Bommelpage last edited by
                                    Servus, hab heute auch auf den neuen Adapter 3.0.1 umgestellt.
                                    Hat prima geklappt.👍
                                    Erste Tests meiner Skripts waren positiv, Sayit Ausgabe funktioniert auch,
                                    Auch mein Morgenskript funktioniert, wo ich mit Wetter, Termine usw. ansagen las,
                                    und wenn die Ansage fertig ist und im Datenpunkt player.playerState auf idle springt,
                                    streame ich über player.url2play meinen Radiosender ab.
                                    Bisher alles gut, vielen Dank für das neue Skript 👍 😊
                                    Horst Böttcher 1 Reply Last reply Reply Quote 0
                                    • Horst Böttcher
                                      Horst Böttcher @Bommelpage last edited by
                                      @bommelpage sagte in Test Adapter Chromecast v3.0.x:
                                      wo hste den denn runtergelden
                                        @jey-cee ich hol das Thema nochmal hoch, vllt fällt dir was ein.
                                        Seit geraumer Zeit erfolgt keine Sprachausgabe mehr, bzw nicht immer.
                                        Kann aber zum einen nicht feststellen warum und auch nicht mehr sagen, seit wann das so ist.
                                        der richtige chromecast ist ausgewählt und hat ja nun auch ne zeit lang bei allem funktioniert.
                                        Per google mini lass ich mir eigentlich nur Anrufer ansagen und Wettermeldungen
                                        Seltsamerweise funktioniert jedoch die Anrufansage aber keine Wettermeldung mehr, auch das test blocky gibt keine Ausgabe mehr aus.
                                        das funktioniert
                                        das funktioniert nicht
                                        beim Wetterscript https://forum.iobroker.net/topic/30616/script-dwd-uwz-nina-warnungen-als-push-sprachnachrichten/ kommt folgende Meldung im log
                                        sayit.0
                                        2022-05-12 15:41:47.086	error	Cannot get file:TypeError: text should be a string
                                        sayit.0
                                        2022-05-12 15:41:47.053	info	saying: keine besonderen Handlungen erforderlich. Insgesamt 2 aktive Warnungen.
                                        admin.0
                                        2022-05-12 15:41:09.897	info	==> Connected system.user.admin from ::ffff:10.1.1.129
                                        sayit.0
                                        2022-05-12 15:40:19.051	info	Set "chromecast.0.20dfb9c72a61.player.announcement to {"url":"http://10.1.1.10:8082/state/sayit.0.tts.mp3","volume":"50"}
                                        sayit.0
                                        2022-05-12 15:40:17.656	info	saying: Entwarnung: Landesweiter Probealarm in Bayern von Nina für ....
                                        • Jey Cee
                                          @crunchip da kann ich mir jetzt auch keinen Reim drauf machen.
                                          Du kannst mal sayit und chromecast auf debug stellen, vielleicht kommt da was bei rum.
                                            @jey-cee sagte in Test Adapter Chromecast v3.0.x:
                                            nicht wirklich,
                                            aber,
                                            sayit Eingang lag bei rund 650. Scheinbar hatte sich da wohl was "aufgestaut".
                                            Jetzt geht wieder alles
                                            chromecast
                                            27
                                            138
                                            13603
