    4. [solved] Updates js-controller fails "node_modules\tr-O64"
      maniac_on_moon last edited by maniac_on_moon
      $ iobroker upgrade self
      Update js-controller from @3.3.20 to @3.3.22
      NPM version: 6.14.15
      npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      npm ERR! code EINVALIDTAGNAME
      npm ERR! Invalid tag name "node_modules\tr-O64": Tags may not have any characters that encodeURIComponent encodes.
      npm ERR!     /path/to/logs/2022-01-18T08_26_51_107Z-debug.log
      which says:
      1009 verbose stack Error: Invalid tag name "node_modules\tr-O64": Tags may not have any characters that encodeURIComponent encodes.
      1009 verbose stack     at invalidTagName (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:91:15)
      1009 verbose stack     at fromRegistry (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:296:13)
      1009 verbose stack     at resolve (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:81:12)
      1009 verbose stack     at npa (/usr/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:52:10)
      1009 verbose stack     at doesChildVersionMatch (/usr/lib/node_modules/npm/lib/install/deps.js:91:21)
      1009 verbose stack     at isDep (/usr/lib/node_modules/npm/lib/install/deps.js:163:27)
      1009 verbose stack     at addRequiredDep (/usr/lib/node_modules/npm/lib/install/deps.js:175:13)
      1009 verbose stack     at resolveWithExistingModule (/usr/lib/node_modules/npm/lib/install/deps.js:630:3)
      1009 verbose stack     at /usr/lib/node_modules/npm/lib/install/deps.js:566:5
      1009 verbose stack     at /usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:35
      1009 verbose stack     at Array.forEach (<anonymous>)
      1009 verbose stack     at /usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:11
      1009 verbose stack     at asyncMap (/usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:51:8)
      1009 verbose stack     at exports.loadExtraneous.andResolveDeps (/usr/lib/node_modules/npm/lib/install/deps.js:565:3)
      1009 verbose stack     at Array.<anonymous> (/usr/lib/node_modules/npm/node_modules/slide/lib/bind-actor.js:15:8)
      tr-064 version 4.2.14
      Ist das Problem bekannt?
      Wo bin ich falsch abgebogen?
      THX und beste Grüße
      maniac_
      Systemdata Bitte Ausfüllen
      Hardwaresystem: pi4
      Arbeitsspeicher: 8GB
      Festplattenart: SD-Karte, 56/64 GB free
      Betriebssystem: raspian buster 10.11 32bit
      Node-Version: 12.22.9
      Nodejs-Version: 12.22.9
      NPM-Version: 6.14.15
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: n.a.
        Thomas Braun Most Active @maniac_on_moon last edited by
        @maniac_on_moon sagte in Update js-controller to @3.3.22 fails "node_modules\tr-O64":
        Ja. Such mal nach
        Das hatten wir schon.
          maniac_on_moon @Thomas Braun last edited by maniac_on_moon
          @thomas-braun said in Update js-controller to @3.3.22 fails "node_modules\tr-O64":
          node_modules\tr-O64
          Aus https://forum.iobroker.net/post/651167
          "Ich werd mal das AVM Plugin deinstallieren / neu installieren"
          Nach der deinstallation lies sich der iobrker nicht mehr starten --> Neuinstallation und recover aus dem Backup.
          Irgendwo ist aber noch der Wurm drin. Die Zigbee DB aus dem deconz Adapter scheint nicht mehr "richtig" gefütert zu werden und unter "system.adapter.javascript.0" sind die Scripte nicht mehr sichtbar, laufen aber noch, denn sie sind in den "Objekten" vorhanden. --> Browserproblem: Cache und Cookies gelöscht.
          Endlich wieder "SOP".
