    4. Proxmox Passthrough Zigbee nach neuinstallation
      thomson last edited by thomson
      Moin zusammen,
      finde meinen Fehler einfach nicht und langsam gehen mir die Ideen aus.
      Musste meinen NUC neu aufsetzen
      • nun mit Proxmox 7.1-7 statt 6.4
      • Den Container habe ich via Proxmox Backup wiederhergestellt. Soweit so gut.
        Nur der Zigbee Adapter wird nicht grün....
        Log:
        zigbee.0
        2022-01-25 15:21:10.126 error Error herdsman start
        zigbee.0
        2022-01-25 15:21:10.125 error Failed to start Zigbee
        zigbee.0
        2022-01-25 15:21:10.124 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0'"
        zigbee.0
        2022-01-25 15:21:09.929 info Installed Version: ioBroker/ioBroker.zigbee#9a112084b13a00e8d731097090a2cc1e597b1c1c
        zigbee.0
        2022-01-25 15:21:09.904 info Starting Zigbee npm ...
        zigbee.0
        2022-01-25 15:21:09.903 info Try to reconnect. 1 attempts left
        zigbee.0
        2022-01-25 15:20:59.903 info Installed Version: ioBroker/ioBroker.zigbee#9a112084b13a00e8d731097090a2cc1e597b1c1c
        zigbee.0
        2022-01-25 15:20:59.899 error Error herdsman start
        zigbee.0
        2022-01-25 15:20:59.898 error Failed to start Zigbee
        zigbee.0
        2022-01-25 15:20:59.897 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0'"
        zigbee.0
        2022-01-25 15:20:59.320 info Starting Zigbee npm ...
        zigbee.0
        2022-01-25 15:20:59.214 info starting. Version 1.6.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.22
        host.ioBroker
        2022-01-25 14:20:55.564 info instance system.adapter.zigbee.0 started with pid 1035
        host.ioBroker
        2022-01-25 14:20:53.693 info instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.ioBroker
        2022-01-25 14:20:53.509 info stopInstance system.adapter.zigbee.0 killing pid 468
        zigbee.0
        2022-01-25 14:20:52.595 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        2022-01-25 14:20:52.593 info terminating
        zigbee.0
        2022-01-25 14:20:52.592 warn Failed to stop zigbee during startup
        zigbee.0
        2022-01-25 14:20:52.506 info Zigbee: disabling joining new devices.
        zigbee.0
        2022-01-25 14:20:52.405 info cleaned everything up...
        host.ioBroker
        2022-01-25 14:20:52.480 info stopInstance system.adapter.zigbee.0 send kill signal
        zigbee.0
        2022-01-25 14:20:52.404 info Got terminate signal TERMINATE_YOURSELF
      Habe dieses als Anleitung genommen. Meinte mich daran zu erinnern das es damit ging.
      https://coldcorner.de/2018/07/12/proxmox-usb-passthrough-fuer-lxc-container-z-wave-uzb1/
      Habt ihr da eine Idee?
      Danke!
        Einstein67 @thomson last edited by Einstein67
        @thomson Du musst nur den Befehl "cgroup" auf "cgroup2" ändern (2. unleserlicher Screenshot).
          thomson @Einstein67 last edited by thomson
          @einstein67
          Danke für die schnelle Antwort.
          Leider klappt das noch nicht
          Danach Reboot
          • david83
            david83 last edited by
            @thomson
            Hi, ich habe vor einigen Wochen einen USB Passthrough nach dem folgendem Howto durchgeführt. Das Howto von Coldcorner hat bei mir auch nicht gefunzt.
            https://www.cooltux.net/doku.php?id=it-wiki:proxmox:usb_passthrough
            Mfg
            David
              @david83 mit cgroup oder cgroup2 ?
              Es ging nun ein paar Stunden . Adapter wurde Grün.
              Nach einem Neustart wieder das selbe Problem..
              E M 2 Replies Last reply Reply Quote 0
                @thomson "cgroup" gibt es bei PVE7 nicht mehr.
                Ist das einzige dass sich beim Update von PVE6 auf 7 geändert hat.
                Du hast da zuviele Zeilen in deiner xxxx.conf drinnen. Das dürfen nur 4 sein!
                  mrjeschke @thomson last edited by
                  @thomson
                  Moin,
                  Ich habe meinen Zigbee-Stick mit dieser Anleitung durchgereicht.
                  Funktioniert super und übersteht auch einen Neustart.
                  Link Text
                  T 2 Replies Last reply Reply Quote 1
                    @einstein67 said in Proxmox Passthrough Zigbee nach neuinstallation:
                    Welche müssten den raus?
                      thomson @mrjeschke last edited by
                      @maik-0 said in Proxmox Passthrough Zigbee nach neuinstallation:
                      @thomson
                      Moin,
                      Link Text
                      Probiere ich das mal. Denke mal vorher die Config wieder bereinigen.
                        @thomson
                        Moin,
                        Link Text
                        Das hat geklappt! Danke!!!!
                        Hoffe mal das bleibt 😄
                        Frage am Rande.... Wenn ich nun von dem cc2531 auf den Sonoff wechseln möchte. Dann müssen die Geräte ja neu angelernt werden.
                        Bleiben die Verknüpfungen in den Skripten den bestehen oder müssen die alle geändert werden?
                        Asgothian arteck 2 Replies Last reply Reply Quote 0
                        • Asgothian
                          Asgothian Developer @thomson last edited by
                          @thomson sagte in Proxmox Passthrough Zigbee nach neuinstallation:
                          Die bleiben bestehen - die ID's der Datenpunkte sind Hardwareabhängig. Das gleiche Gerät bekommt dabei immer die gleiche ID.
                          A.
                            arteck Developer Most Active @thomson last edited by
                            nicht zwingend... musst du schauen.. ob der Stick die alten Daten übernimmt. einfach probieren
                            693
